- add the SATA framework
- add the SATA command line
Signed-off-by: Dave Liu <daveliu@freescale.com>
move the cmd_sata.c from common/ to drivers/ata_piix.c,
the cmd_sata.c have some part of ata_piix controller drivers.
consolidate the driver to have better framework.
common/cmd_bootm.c
cpu/mpc8xx/cpu.c
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
This patch changes the "usb storage" command to return success if it
finds a USB storage device, otherwise it returns error.
Signed-off-by: Markus Klotzbuecher <mk@denx.de>
Linux understands "host" (default), "peripheral" and "otg" (broken).
Though, U-Boot doesn't restrict dr_mode variable to these values (think
of renames in future).
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
These defines embedded the u-boot env variables and/or the bd_t structure
in the fdt blob. The conclusion of discussion on the u-boot email list
was that embedding these in the fdt blob is not useful: there are better
ways of passing the data (in fact, the fdt blob itself replaces the
bd_t struct).
The only board that enables these is the stxxtc and they don't appear
to be used by linux.
Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Add a simple expr style command that will set an env variable as the result
of the command. This allows us to do simple math in shell. The following
operations are supported: &, |, ^, +, -, *, /.
Fix imxtract command not being compiled-in despite CONFIG_CMD_XIMG being in
include/config_cmd_default.h. Fix few warnings and handling of new format
images.
The introduciton of the 'fdt bootcpu' broke parsing for 'fdt boardsetup'.
fdt header - Display header info
fdt bootcpu <id> - Set boot cpuid
fdt memory <addr> <size> - Add/Update memory node
fdt rsvmem print - Show current mem reserves
fdt rsvmem add <addr> <size> - Add a mem reserve
fdt rsvmem delete <index> - Delete a mem reserves
lwmon5 board: the storage for the log-buffer itself is OCM(on-chip memory), the log-buffer header is moved to six GPT registers (PPC440EPX_GPT0_COMP1, ..., PPC440EPX_GPT0_COMP5).
To enable this, alternative, configuration the U-Boot board configuration
file for lwmon5 includes the definitions of alternative addresses for header
(CONFIG_ALT_LH_ADDR) and buffer (CONFIG_ALT_LB_ADDR).
The Linux shall be configured with the CONFIG_ALT_LB_LOCATION option set,
and has the BOARD_ALT_LH_ADDR and BOARD_ALT_LB_ADDR constants defined in the
lwmon5 board-specific header (arch/ppc/platforms/4xx/lwmon5.h).
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
as POST_CRITICAL fails then the alternative, post_critical, boot-command is used. If this command is not defined then U-Boot enters into interactive mode.
Signed-off-by: Dmitry Rakhchev <rda@emcraft.com>
This moves the Blackfin-common bootldr command out of the BF537-STAMP
specific board directory and into the common directory so that all Blackfin
boards may utilize it.
ARM platforms don't have a bd->bi_memsize so use bd->bi_dram[0].size instead.
Save FIT configuration provied in the first bootm argument and use it
when to get ramdisk/FDT subimages when second and third (ramdisk/FDT)
arguments are not specified.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
This patch allocates a set of show_boot_progress() IDs for new uImage format
and adds show_boot_progress() calls in new uImage format handling code.
Updated commands:
docboot - cmd_doc.c
fdcboot - cmd_fdc.c
diskboot - cmd_ide.c
nboot - cmd_nand.c
scsiboot - cmd_scsi.c
usbboot - cmd_usb.c
autoscript() routine is updated to accept second argument, which
is only used for FIT images and provides a FIT subimage unit name.
autoscript() routine callers must now pass two arguments. For
non-interactive use (like in cmd_load.c, cmd_net.c), new environment
variable 'autoscript_uname' is introduced and used as a FIT
subimage unit name source.
autoscript command accepts extended syntax of the addr argument:
addr:<subimg_uname>
This patch adds new node offset fields to struct bootm_headers
and updates bootm_headers processing code to make use of them.
Saved node offsets allow to avoid repeating fit_image_get_node() calls.
Re-enable interrupts if we return from do_bootm_<os> and 'autostart'
environment variable is not set to 'yes'.
boot_get_ramdisk() and image_get_ramdisk() do not need all
cmdtp, flag, argc and argv arguments. Simplify routines definition.
This patch updates boot_get_ramdisk() routine adding format
verification and handling for new (FIT) uImages.
New format uImages are recognized by the bootm command,
validity of specified kernel component image is checked and
its data section located and used for further processing
(uncompress, load, etc.)
imls and iminfo can now recognize nad print out contents of the new (FIT)
format uImages.
Add FDT-based functions for handling new format component images,
configurations, node operations, property get/set, etc.
fit_ - routines handling global new format uImage operations
like get/set top level property, process all nodes, etc.
fit_image_ - routines handling component images subnodes
fit_conf_ - routines handling configurations node
and get rid of a couple of unneeded casts.
If I try to "cp.b <ram> <dataflash>", u-boot selects normal flash
routines instead of dataflash. This is because it checks "if source
address is not dataflash" instead of target address.
Signed-off-by: Kim B. Heino <Kim.Heino@bluegiga.com>
Use uint32_t when accessing size table in image_multi_count() and
image_multi_getimg() for multi component images.
Add missing uimage_to_cpu() endianness conversion.
This patch adds the following common routines:
1) Dedicated mkimage print_header() is replaced with common
image_print_contents()
image_print_contents_noindent()
2) Common os/arch/type/comp fields name <--> id translation routines
genimg_get_os_name()
genimg_get_arch_name()
genimg_get_type_name()
genimg_get_comp_name()
genimg_get_os_id()
genimg_get_arch_id()
genimg_get_type_id()
genimg_get_comp_id()
This patch introduces the following prefix convention for the
image format handling and bootm related code:
genimg_ - dual format shared code
image_ - legacy uImage format specific code
fit_ - new uImage format specific code
boot_ - booting process related code
Related routines are renamed and a few pieces of code are moved around and
re-grouped.
Allow the user to set 'bootm_low' and 'bootm_size' env vars as a way
to restrict what memory range is used for bootm.
Acked-by: Marian Balakowicz <m8@semihalf.com>
Convert generic ramdisk_high(), get_boot_cmdline(), get_boot_kbd()
functions over to using lmb for allocation of the ramdisk, command line
and kernel bd info.
Convert PPC specific fdt_relocate() to use lmb for allocation of the device
tree.
Provided a weak function that board code can call to do additional
lmb reserves if needed.
Also introduce the concept of bootmap_base to specify the offset in
physical memory that the bootmap is located at. This is used for
allocations of the cmdline, kernel bd, and device tree as they should
be contained within bootmap_base and bootmap_base + CFG_BOOTMAPSZ.
The autostart env variable was dropped as part of the initial new uImage
cleanup. Add it back here so the arch specific code can decide if it
wants to really boot or not.
Introduce the LMB lib used on PPC in the kernel as a clean way to manage
the memory spaces used by various boot images and structures. This code
will allow us to simplify the code in bootm and its support functions.
Changed image_get_ramdisk() to just return NULL on error and have
get_ramdisk() propogate that error to the caller. It's left to the
caller to call do_reset() if it wants to.
Also moved calling do_reset() in get_fdt() and fdt_relocate() on ppc
to a common location. In the future we will change get_fdt() and
fdt_relocate() to return success/failure and not call do_reset() at all.
We don't actually need the kdb param as we are just using it to get
bd->bi_memsize which we can get from gd->bd->bi_memsize. Also, if we
boot via OF we might not actually fill out a kdb.
Dual format image code must properly handle all three FDT passing methods:
- raw FDT blob passed
- FDT blob embedded in the legacy uImage
- FDT blob embedded in the new uImage
This patch enables proper raw FDT handling when no FIT imaeg support
is compiled in. This is a bit tricky as we must dected FIT format even
when FIT uImage handling is not enabled as both FIT uImages and raw FDT
blobs use tha same low level format (libfdt).
Legacy image specific verification is factored out to a separate helper
routine to keep get_kernel() generic and simple.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Do not pass image verification flag directly to related routines.
Simplify argument passing and move it to the bootm_header structure which
contains curently processed image specific data and is already being passed
on the argument list.
