Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
These files do not need to be compiled when CONFIG_CMDLINE is disabled.
Update the Makefile to reflect this.
Normally board_run_command() will handle command processed. But if for some
reason it returns then we should panic to avoid further processing.
This patch changes the USB port scanning procedure and timeout
handling in the following ways:
a)
The power-on delay in usb_hub_power_on() is now reduced to a value of
max(100ms, "hub->desc.bPwrOn2PwrGood * 2"). The code does not wait
using mdelay, instead usb_hub_power_on() will wait before querying
the device in the scanning loop later. The total timeout for this
hub, which is 1 second + "hub->desc.bPwrOn2PwrGood * 2" is calculated
and will be used in the following per-port scanning loop as the timeout
to detect active USB devices on this hub.
b)
Don't delay the minimum delay (for power to stabilize) in
usb_hub_power_on(). Instead skip querying these devices in the scannig
loop until the delay time is reached.
c)
The ports are now scanned in a quasi parallel way. The current code did
wait for each (unconnected) port to reach its timeout and only then
continue with the next port. This patch now changes this to scan all
ports of all USB hubs quasi simultaneously. For this, all ports are added
to a scanning list. This list is scanned until all ports are ready
by either a) reaching the connection timeout (calculated earlier), or
by b) detecting a USB device. This results in a faster USB scan time as
the recursive scanning of USB hubs connected to the hub that's currently
being scanned will start earlier.
One small functional change to the original code is, that ports with
overcurrent detection will now get rescanned multiple times
(PORT_OVERCURRENT_MAX_SCAN_COUNT).
Without this patch:
starting USB...
USB0: USB EHCI 1.00
scanning bus 0 for devices... 9 USB Device(s) found
time: 20.163 seconds
With this patch:
starting USB...
USB0: USB EHCI 1.00
time: 1.822 seconds
So ~18.3 seconds of USB scanning time reduction.
Acked-by: Hans de Goede <hdegoede@redhat.com>
Debugging has shown, that all USB hubs are being reset twice while
USB scanning. This introduces additional delays and makes USB scanning
even more slow. Testing has shown that this 2nd USB hub reset doesn't
seem to be necessary.
This patch now removes this 2nd USB hub reset. Resulting in faster USB
scan time. Here the current numbers:
Without this patch:
=> time usb start
starting USB...
USB0: USB EHCI 1.00
time: 24.003 seconds
With this patch:
=> time usb start
starting USB...
USB0: USB EHCI 1.00
time: 20.392 seconds
So ~3.6 seconds of USB scanning time reduction.
This patch removes 2 mdelay(200) calls from usb_hub_port_connect_change().
These delays don't seem to be necessary. At least not in my tests. Here
the number for a custom x86 Bay Trail board (not in mainline yet) with
a quite large and complex USB hub infrastructure.
Without this patch:
starting USB...
USB0: USB EHCI 1.00
time: 28.415 seconds
With this patch:
starting USB...
USB0: USB EHCI 1.00
So ~4.5 seconds of USB scanning time reduction.
Start with a short USB hub reset delay of 20ms. This can be enough for
some configurations.
The 2nd delay at the end of the loop is completely removed. Since the
delay hasn't been long enough, a longer delay time of 200ms is assigned
and will be used in the next loop round.
This hub reset handling is also used in the v4.4 Linux USB driver,
hub_port_reset().
This reverts commit 71105f50fedddfa5b0535d102c3d5078671721ad.
The reverted commit was applied for a temporary to unbreak
few Exynos boards on the release.
After the discussion about the change, this commit should be avoided.
Fixed device-tree for Exynos, allows reverting it without any issues.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
At present on x86 machines with use cache-as-RAM, the memory goes away just
before board_init_r() is called. This means that serial drivers are
no-longer unavailable, until initr_dm() it called, etc.
Any attempt to use printf() within this period will cause a hang.
To fix this, mark the serial devices as 'unavailable' when it is no-longer
available. Bring it back when serial_initialize() is called. This means that
the debug UART will be used instead for this period.
Commit 1057e6c broke use of the timer with driver model. If the timer is used
before relocation, then it becomes broken after relocation. This prevents
some x86 boards from booting. Fix it.
Fixes: 1057e6c (timer: Set up the real timer after driver model is available)
Output the pointer returned by each call to malloc(). This can be useful
when debugging memory problems.
Fix "warning: cast to pointer from integer of different size".
We have a nice framework around image fils to prepare a device tree
for OS execution. That one patches in missing device tree nodes and
fixes up the memory range bits.
We need to call that one from the EFI boot path too to get all those
nice fixups. This patch adds the call.
The EFI loader needs to maintain views of memory - general system memory
windows as well as used locations inside those and potential runtime service
MMIO windows.
To manage all of these, add a few helpers that maintain an internal
representation of the map the similar to how the EFI API later on reports
it to the application.
For allocations, the scheme is very simple. We basically allow allocations
to replace chunks of previously done maps, so that a new LOADER_DATA
allocation for example can remove a piece of the RAM map. When no specific
address is given, we just take the highest possible address in the lowest
RAM map that fits the allocation size.
After booting has finished, EFI allows firmware to still interact with the OS
using the "runtime services". These callbacks live in a separate address space,
since they are available long after U-Boot has been overwritten by the OS.
This patch adds enough framework for arbitrary code inside of U-Boot to become
a runtime service with the right section attributes set. For now, we don't make
use of it yet though.
We could maybe in the future map U-boot environment variables to EFI variables
here.
The original name of this function is unclear. This patch renames this
CRC16 function to crc16_ccitt() matching its name with its
implementation.
To make the usage of this function more flexible, lets add the CRC start
value as parameter to this function. This way it can be used by other
functions requiring different start values than 0 as well.
FIT image supports more than 32 bits in addresses by using #address-cell
field. Fixing 64-bit support by using this field.
Signed-off-by: York Sun <york.sun@nxp.com>
FIT image supports load address and entry address. Getting these
addresses can use a common function.
Detect a FIT when loading from MMC and handle it using the new FIT SPL
support.
This provides a way to load a FIT containing U-Boot and a selection of device
tree files. The board can select the correct device tree by probing the
hardware. Then U-Boot is started with the selected device tree.
Sometimes it is useful to obtain the short name for an Operating System,
architecture or compression mechanism. Provide functions for this.
Add an option to enable libfdt in SPL. This can be useful when decoding
FIT files in SPL.
We need to make sure this option is not enabled in SPL by this change.
Also this option needs to be enabled in host builds. Si add a new
IMAGE_USE_LIBFDT #define which can be used in files that are built on the
host but must also build for U-Boot and SPL.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
Update this code to support CONFIG_BLK. Each USB storage device can have
one or more block devices as children, each one representing a LUN
(logical unit) of the USB device.
Adjust a few things so that the addition of driver-models support involved
adding code rather than also changing it. This makes the patches easier to
review.
The limit on storage devices is USB_MAX_STOR_DEV but we use one extra
element while probing to see if a device is a storage device. Avoid this,
since it causes memory corruption.
To ease conversion to driver model, add helper functions which deal with
calling each block device method. With driver model we can reimplement these
functions with the same arguments.
Use inline functions to avoid increasing code size on some boards.
This is a device number, and we want to use 'dev' to mean a driver model
device. Rename the member.
Rename three partition functions so that they start with part_. This makes
it clear what they relate to.
Rename this function to blk_get_device_part_str(). This is a better name
because it makes it clear that the function returns a block device and
parses a string.
The current name is too generic. Add a 'blk_' prefix to aid searching and
make its purpose clearer.
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long
and causes 80-column violations, rename it to struct blk_desc.
This is an enhancement that permits storing the environment file on an
EXT4 partition such as the root filesystem. It is based on the existing
FAT environment file code.
Following the previous patch, malloc() is never called before gd is set,
so we can remove the special-case check for this condition.
This reverts commit 854d2b9753e4 "dlmalloc: ensure gd is set for early
alloc".
Cc: Rabin Vincent <rabin@rab.in>
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
When using the early timer, we need to manually trigger setting up the
real timer. This will not happen automatically. Do this immediately after
starting driver model.
This reverts commit 84ca65aa4bd0d03867e9e49805201d0564d3ffb0.
On signature verification failures fit_image_verify() should NOT exit with
error. Only keys marked 'required' can cause image verification failure.
This logic is already there and works correctly.
Add a comment to make this clear.
Fixes: 84ca65aa (image-fit: Fix signature checking)
A recent change broke the 'bootm' command on sandbox. The root cause is
using a pointer as an address. Conversion from pointer to address needs to
use map_to_sysmem() so that sandbox can do the right thing. The problem was
pre-existing but uncovered by a recent commit.
Fix this. Also move fit_get_end() to the C file to avoid needing to include
mapmem.h (and thus asm/io.h) everywhere.
Fixes: 1fec3c5d (common/image.c: Make boot_get_ramdisk() perform a check for Android images)
Since commit fd61d39970b9901217efc7536d9f3a61b4e1752a:
spl: mmc: add break statements in spl_mmc_load_image()
RAW and FS boot modes are now exclusive again. So, if MMCSD_MODE_RAW fails, the
board hangs. This patch allows to try MMCSD_MODE_FS then.
It has been tested on a beaglebone black to boot on an EXT partition.
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Paul Kocialkowski <contact@paulk.fr>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
Cc: Matwey V. Kornilov <matwey.kornilov@gmail.com>
Acked-by: Nikita Kiryanov <nikita@compulab.co.il>
$ make tools-all
In file included from tools/env/env_flags.c:1:0:
tools/env/../../common/env_flags.c: In function
‘env_flags_parse_varaccess_from_binflags’:
tools/env/../../common/env_flags.c:156:18: warning: implicit declaration
of function ‘ARRAY_SIZE’ [-Wimplicit-function-declaration]
for (i = 0; i < ARRAY_SIZE(env_flags_varaccess_mask); i++)
Seems like the other utilities just add a copy of ARRAY_SIZE since
there's nowhere to include it from (tools/imagetool.h,
tools/mxsimage.h). Let's do the same here.
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
Boards with a saved environment may use 'lcd' in their stdout environment
variable, expecting that this will enable output to the LCD. When the board
moves to use driver model for video, this will no-longer work. Add a
work-around to fix this. A warning messages is printed, and we will remove
the work-around at the end of 2016.
Acked-by: Anatolij Gustschin <agust@denx.de>
This commit breaks bootup on sunxi boards, the get stuck
when running the main u-boot binary at:
CPU: Allwinner H3 (SUN8I)
I2C: ready
DRAM:
This reverts commit 8e7cba048baae68ee0916a8f52b4304277328d5e.
Signed-off-by: David Müller <d.mueller@elsoft.ch>
Commit 9c11135ce053 ("image: fix getenv_bootm_size() function") fixed
the case where "bootm_low" is defined, but "bootm_size" is not.
Instead, it broke the case where neither "bootm_low" nor "bootm_size"
is defined. Fix this function again.
Fixes: 9c11135ce053 ("image: fix getenv_bootm_size() function")
Tested-by: Matthias Weisser <m.weisser.m@gmail.com>
Tested-by: Hannes Schmelzer <oe5hpm@oevsv.at>
The recent change to memalign() caused the allocation failure detection
code to be dead code; the "retry" logic is always activated under the same
condition that the original failure detection code is, and also fully
handles any possible failures. This patch solves the presence of dead
code.
Two alternatives are possible:
a) Delete the now-dead test, and rely on the "retry" path to handle any
allocation problems, as it does.
b) Make the "retry" path fall through to the existing (currently dead)
failure detection code, thus making it not-dead.
(b) was chosen since it reduces the diff between U-Boot's and the upstream
dlmalloc. This should make it marginally easier to import a new version of
dlmalloc in the future.
Reported by: Coverity Scan
Fixes: 4f144a416469 ("malloc: work around some memalign fragmentation issues")
The case of memory of size 0 is not that different from a memory of any other
size, so we remove the duplicate code and treat the small differences when it
is the case.
Signed-off-by: Eddy Petrișor <eddy.petrisor@gmail.com>
Add trivial support for changing the U-Boot command prompt string
by setting PS1 and PS2 environment variables. Only static variables
are supported.
Pull the code which displays U-Boot prompt and reads the command line
into a separate function. No functional change.
