This bug appears in b6396403 which makes u-boot unable to pass
arguments via bootm to a standalone application without this patch.
Steps to reproduce.
Compile a u-boot. Use mkimage to package the standalone hello_world.bin
file.
e.g. For the MIPS Boston platform
mkimage -n "hello" -A mips -O u-boot -C none -T standalone \
-a 0xffffffff80200000 -d hello_world.bin \
-ep 0xffffffff80200000 hello_out
Then tftp hello_out and run it using
boston # dhcp 192.168.154.45:hello_out
boston # bootm $loadaddr 123 321
Without the patch the following output is observed.
Image Name: hello
Image Type: MIPS U-Boot Standalone Program (uncompressed)
Data Size: 1240 Bytes = 1.2 KiB
Load Address: 80200000
Entry Point: 80200000
Verifying Checksum ... OK
Loading Standalone Program ... OK
Example expects ABI version 8
Actual U-Boot ABI version 8
Hello World
argc = 0
argv[0] = "0xffffffff88000000"
With the patch, you see the following.
Image Name: hello
Hello World
argc = 3
argv[1] = "123"
argv[2] = "321"
argv[3] = "<NULL>"
Without the patch, the go command at the entry point seems to work.
boston # go 0xffffffff80200000 123 321
Hello World
argc = 3
argv[0] = "0xffffffff80200000"
argv[1] = "123"
argv[2] = "321"
argv[3] = "<NULL>"
Hit any key to exit ...
Signed-off-by: Zubair Lutfullah Kakakhel <Zubair.Kakakhel@imgtec.com>
Without this, if g_dnl_register() fails, DFU code continues on
blindly and crashes. This fix makes it simply print an error
message instead.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
[l.majewski@samsung.com - some manual tweaks needed]
This patch enables the DFU boot mode support
for dra7x platform.
Signed-off-by: Ravi Babu <ravibabu@ti.com>
Adding support functions to run dfu spl commands.
The cmd_dfu functionality is been used by both SPL and
u-boot, saperating the core dfu functionality moving
it to common/dfu.c.
Traditionally the DFU support is available only
as part 2nd stage boot loader(u-boot) and DFU
is not supported in SPL.
The SPL-DFU feature is useful for boards which
does not have MMC/SD, ethernet boot mechanism
to boot the board and only has USB inteface.
This patch add DFU support in SPL with RAM
memory device support to load and execute u-boot.
And then leverage full functionality DFU in
u-boot to flash boot inital binary images to
factory or bare-metal boards to memory devices
like SPI, eMMC, MMC/SD card using USB interface.
This SPL-DFU support can be enabled through
Menuconfig->Boot Images->Enable SPL-DFU support
Now, arch/${ARCH}/include/asm/errno.h and include/linux/errno.h have
the same content. (both just wrap <asm-generic/errno.h>)
Replace all include directives for <asm/errno.h> with <linux/errno.h>.
[trini: Fixup include/clk.]
This makes functions much simpler.
Commit bac17b78dace ("image-fit: switch ENOLINK to ENOENT") changed
fit_get_node_from_config to return -ENOENT when a property doesn't
exist, but didn't change any of its callers which check return values.
Notably it didn't change boot_get_ramdisk, which leads to U-Boot failing
to boot FIT images which don't include ramdisks with the following
message:
Ramdisk image is corrupt or invalid
It also didn't take into account that by returning -ENOENT to denote the
lack of a property we lost the ability to determine from the return
value of fit_get_node_from_config whether it was the property or the
configuration node that was missing, which may potentially lead callers
to accept invalid FIT images.
Fix this by having fit_get_node_from_config return -EINVAL when the
configuration node isn't found and -ENOENT when the property isn't
found, which seems to make semantic sense. Callers that previously
checked for -ENOLINK are adjusted to check for -ENOENT, which fixes the
breakage introduced by commit bac17b78dace ("image-fit: switch ENOLINK
to ENOENT").
The only other user of the return fit_get_node_from_config return value,
indirectly, is bootm_find_os which already checked for -ENOENT. From a
read-through of the code I suspect it ought to have been checking for
-ENOLINK prior to bac17b78dace ("image-fit: switch ENOLINK to ENOENT")
anyway, which would make it right after this patch, but this would be
good to get verified by someone who knows this x86 code or is able to
test it.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Cc: Jonathan Gray <jsg@jsg.id.au>
Acked-by: George McCollister <george.mccollister@gmail.com>
Tested-by: George McCollister <george.mccollister@gmail.com>
Currently we have a mismash of architectures which use arch_cpu_init
from architecture-wide code (arc, avr32, blackfin, mips, nios2, xtensa)
and architectures which use arch_cpu_init from machine/SoC level code
(arm, x86).
In order to clean this mess up & allow for both use cases, introduce a
new mach_cpu_init callback which is run immediately after arch_cpu_init.
This will allow for architectures to have arch-wide code without needing
individual machines to all implement their own arch_cpu_init with a call
to some common function.
Move the config IDENT_STRING to Kconfig and migrate all boards
[sivadur: Migrate zynq boards]
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
[trini: Update configs, add some default to sunxi Kconfig]
Some of the SPL options have TPL equivalents. Add these to Kconfig so that
we can convert these options over to work from Kconfig.
There are a lot of SPL options in U-Boot to enable various features and
drivers. Currently these do not use Kconfig. Add them to Kconfig along
with suitable help, and drop them from the README.
At present TPL uses the same options as SPL support. In a few cases the board
config enables or disables the SPL options depending on whether
CONFIG_TPL_BUILD is defined.
With the move to Kconfig, options are determined for the whole build and
(without a hack like an #undef in a header file) cannot be controlled in this
way.
Create new TPL options for these and update users. This will allow Kconfig
conversion to proceed for these boards.
Move the SPL settings into common/spl where most of the SPL code is kept.
move VERSION_VARIABLE from board config file into a
Kconfig option.
ENOLINK is not required by POSIX and does not exist on OpenBSD
and likely other systems.
Signed-off-by: Jonathan Gray <jsg@jsg.id.au>
Correct a small number of spelling mistakes.
This reworks spl_set_header_raw_uboot to allow having both os boot
(which comes with a valid header) and aborting when no valid header is
found (thus excluding raw u-boot.bin images).
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
Commit 62afc601883e788f3f22291202d5b2a23c1a8b06 introduced fpga image load via
bootm but broke the OS check in fit_image_load().
This commit removes following compiler warning:
---8<---
In file included from tools/common/image-fit.c:1:
/Volumes/devel/u-boot/tools/../common/image-fit.c:1715:39: warning: use of logical '||' with constant operand [-Wconstant-logical-operand]
os_ok = image_type == IH_TYPE_FLATDT || IH_TYPE_FPGA ||
/Volumes/devel/u-boot/tools/../common/image-fit.c:1715:39: note: use '|' for a bitwise operation
1 warning generated.
--->8---
Signed-off-by: Andreas Bießmann <andreas@biessmann.org>
Cc: Michal Simek <michal.simek@xilinx.com>
Acked-by: Michal Simek <michal.simek@xilinx.com>
When phy autoneg on, the link speed and duplex should be
determined by phy advertising register and
phy link partner ability register.
Check phy advertising register when geting phy link speed and
duplex if autoneg on.
Signed-off-by: Dongpo Li <lidongpo@hisilicon.com>
This improves the cread_line() function so that it will correctly
process the 'Home', 'End', 'Delete' and arrow key escape sequences
produced by various terminal emulators. This makes command line editing
a more pleasant experience.
The previous code only supported the cursor keys and the 'Home' key, and
only for certain terminal emulator configurations. This adds support for
the 'End and 'Delete' keys, and recognises a wider range of escape
sequences. For example, the left arrow key can be 'ESC O D' instead of
'ESC [ D', and the 'Home' key can be 'ESC [ H', 'ESC O H', 'ESC 1 ~' or
'ESC 7 ~', depending on what terminal emulator you use and how it is
configured.
Signed-off-by: James Byrne <james.byrne@origamienergy.com>
Changes for v2
- Explicitly initialize variable to avoid spurious compiler warning.
Changes for v3
- Remove unnecessary setting of 'act' to ESC_REJECT (now its default
value).
The bootz and booti commands rely on common functionality that is found
in common/bootm.c and common/bootm_os.c. They do not however rely on
the rest of cmd/bootm.c to be implemented so split them into their own
files. Have various Makefiles include the required infrastructure for
CONFIG_CMD_BOOT[IZ] as well as CONFIG_CMD_BOOTM. Move the declaration
of 'images' over to common/bootm.c.
Now that nand_info[] is an array of pointers we need to ensure that it's
been populated prior to use. We may for example have ENV in NAND set in
configurations that run on boards with and without NAND (where default
env is fine enough, such as omap3_beagle and beagleboard (NAND) vs
beagle xM (no NAND)).
Fixes: b616d9b0a708 ("nand: Embed mtd_info in struct nand_chip")
Cc: Scott Wood <oss@buserror.net>
Acked-by: Scott Wood <oss@buserror.net>
The Xtensa processor architecture is a configurable, extensible,
and synthesizable 32-bit RISC processor core provided by Cadence.
This is the first part of the basic architecture port with changes to
common files. The 'arch/xtensa' directory, and boards and additional
drivers will be in separate commits.
Signed-off-by: Chris Zankel <chris@zankel.net>
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
The cleanup of the legacy mii registration API that's no longer used now
that the drivers have been converted to use the (more) modern API.
The next patch will call fdt_translate_address() from somewhere with a
"const void *blob" rather than a "void *blob", so fdt_translate_address()
must accept a const pointer too. Constify the minimum number of function
parameters to achieve this.
Squashed in build fix from Stephen:
This commit allows injecting a board/platform/device-specific post-
processing function into the FIT image data loading process, which can
include modifying the size and altering the starting source address of
an image data artifact. This might be desired to do things like strip
headers or footers attached to the images before they were packaged into
the FIT, or to perform operations such as decryption or authentication.
Introduce new configuration option CONFIG_FIT_IMAGE_POST_PROCESS to
allow controlling this feature. If enabled, a platform-specific post-
process function must be provided.
Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
The devicetrees for various platforms already exceed 16k. Add a define
CONFIG_SYS_FDT_SIZE to specify the FDT size, and set to 16k for the
two boards that define this CONFIG_SYS_FDT_BASE parameter. This
allows platforms with larger devicetree blobs to boot from NOR.
Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl>
Add new Kconfig option to disable arch_fixup_fdt() calls for cases where
U-Boot shouldn't update memory setup in DTB file.
One example of usage of this option is to boot OS with different memory
setup than U-Boot use.
Fix up the call in mmc_load_image_raw_partition() to use the correct
function to obtain the MMC device, so that this code can support driver
model.
Quite a few places have a bind() method which just calls dm_scan_fdt_dev().
We may as well call dm_scan_fdt_dev() directly. Update the code to do this.
This new function is more convenient for callers, and handles pre-relocation
situations automatically.
This change introduces default_splash_locations which
simplifies splash recovery from the first partition of
USB/MMC/SATA drive.
Given usual mapping of the first partition of external media for
basic boot stuff like uImage/zImage, .dtb etc it looks quite
obvious option to put there splash.bmp as well.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Jeroen Hofstee <jeroen@myspectrum.nl>
Current implementation of splash_init_usb() requires usb_stor_scan()
which doesn't exist in case of DM_USB simply because real probing
happens right in usb_init().
So disable usage of usb_stor_scan() in case of DM_USB.
Cc: Robert Winkler <robert.winkler@boundarydevices.com>
In certain circumstances it comes in handy to be able to boot into a second
U-Boot. But as of now it is not possible to boot a U-Boot binary that is inside
a FIT image, which is problematic for projects that e.g. need to guarantee a
unbroken chain of trust from SOC all the way into the OS, since the FIT signing
mechanism cannot be used.
This patch adds the capability to load such FIT images.
An example .its snippet (utilizing signature verification) might look
like the following:
images {
firmware@1 {
description = "2nd stage U-Boot image";
data = /incbin/("u-boot-dtb.img.gz");
type = "firmware";
arch = "arm";
os = "u-boot";
compression = "gzip";
load = <0x8FFFC0>;
entry = <0x900000>;
signature@1 {
algo = "sha256,rsa4096";
key-name-hint = "key";
Signed-off-by: Mario Six <mario.six@gdsys.cc>
In raw mode a full sector is to be read even if image covers part of
a sector. Number of sectors are calculated as ROUND_UP(size)/sec_size by FIT
framework. This calculation assumes that image is at the 0th offset of a sector,
which is not true always in FIT case. So, include the image offset while
calculating number of sectors.
Other payload than uImage is currently considered to be raw U-Boot
image. Check also for zImage in Falcon mode.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Add support for loading from UBI volumes on the top of NAND
and OneNAND.
Move config option CONFIG_SYS_NO_FLASH as Kconfig
option. All the boards which needs to enable this
option can be done through defconfigs
Make code 64bit aware.
Warnings:
+../arch/arm/lib/spl.c: In function ‘jump_to_image_linux’:
+../arch/arm/lib/spl.c:63:3: warning: cast to pointer from integer of
different size [-Wint-to-pointer-cast]
+../common/spl/spl_fat.c: In function ‘spl_load_image_fat’:
+../common/spl/spl_fat.c:91:33: warning: cast to pointer from integer
of different size [-Wint-to-pointer-cast]
arch/arm/cpu/armv8/Makefile
arch/arm/lib/bootm-fdt.c
Fix a number of typos, including:
* "compatble" -> "compatible"
* "eanbeld" -> "enabled"
* "envrionment" -> "environment"
* "FTD" -> "FDT" (for "flattened device tree")
* "ommitted" -> "omitted"
* "overriden" -> "overridden"
* "partiton" -> "partition"
* "propogate" -> "propagate"
* "resourse" -> "resource"
* "rest in piece" -> "rest in peace"
* "suport" -> "support"
* "varible" -> "variable"
When secure ram is used, MMU tables have to be put into secure ram.
To use common MMU code, gd->arch.tlb_addr will be used to host TLB
entry pointer. To save allocated memory for later use, tlb_allocated
variable is added to global data structure.
Signed-off-by: York Sun <york.sun@nxp.com>
Secure_ram variable was put in generic global data. But only ARMv8
uses this variable. Move it to ARM specific data structure.
