Avoid calling directly into the MMC code - use the new API call instead.
Add a function that automatically builds the device name given the parent
and a supplied string. Most callers will want to do this, so putting this
functionality in one place makes more sense.
Add driver-model block-device support to the SATA implementation. This is
just a dummy implementation for now, since the SATA low-level API uses
numbered devices and that doesn't fit with driver model.
Add driver-model block-device support to the SCSI implementation.
Add driver-model block-device support to the IDE implementation.
This function is implemented by the legacy block functions now. Drop it.
At present the SATA command code includes both the command-processing code
and the core SATA functions and data structures.
Separate the latter into its own file, adding functions as needed to avoid
the command code accessing data structures directly.
With this commit:
- All CONFIG option are referenced from the non-command code
- The concept of a 'current SATA device' is confined to the command code
This will make it easier to convert this code to driver model.
At present the IDE command code includes both the command-processing code
and the core IDE functions and data structures.
With this commit:
- Most CONFIG option are referenced from the non-command code
- The concept of a 'current IDE device' is confined to the command code
At present the SCSI command code includes both the command-processing code
and the core SCSI functions and data structures.
the command code accessing data structures directly. This functions use the
new legacy block functions.
With this commit:
- There is no CONFIG option referenced from the command code
- The concept of a 'current SCSI device' is confined to the command code
Add a legacy block interface for USB storage.
This option currently enables both the command and the SCSI functionality.
Rename the existing option to CONFIG_SCSI since most of the code relates
to the feature.
When defined, SPL will proceed to another boot method
if the image it has loaded does not have a signature.
This is useful if the subsequent boot methods are much
more complex.
Cc: Peng Fan <van.freenix@gmail.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Allow the spl_parse_image_header() to return value. This is convenient
for controlling the SPL boot flow if the loaded image is corrupted.
The code shouldn't continue probing the port if get_port_status() failed.
Cc: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Stephen Warren <swarren@nvidia.com>
The Kingston DT Ultimate USB 3.0 stick is sensitive to this first
Get Descriptor request and if the request is not in a separate
microframe, the stick refuses to operate. Add slight delay, which
is enough for one microframe to pass on any USB spec revision.
Some devices, like the SanDisk Cruzer Pop need some time to process
the Set Configuration request, so wait a little until they are ready.
The pointer should always be inited to NULL, not zero (0). These are
two different things and not necessarily equal.
For multiple ethernet interfaces the FDT offset of '/aliases' will change as we
are adding MAC addresses to the FDT.
Therefore only the first interface ('ethernet0') will get properly updated in
the FDT, with the rest getting FDT errors when we try to set their MAC address.
Signed-off-by: Lev Iserovich <iserovil@deshawresearch.com>
Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
Remove several hundred lines of content surrounded by:
#if 0 /* Moved to malloc.h */
... moved stuff ...
#endif /* 0 */ /* Moved to malloc.h */
The error message "spl: mmc block read error" may come from two
different functions, so we should better annotate the function name
where the error comes from to help debugging.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Introduce env support for sata device.
1. Implement write_env/read_env/env_relocate_spec/saveenv/sata_get_env_dev
2. If want to enable this feature, define CONFIG_ENV_IS_IN_SATA, and
define CONFIG_SYS_SATA_ENV_DEV or implement your own sata_get_ev_dev.
Signed-off-by: Peng Fan <van.freenix@gmail.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Stuart Longland <stuartl@vrt.com.au>
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
remove logging of the 'skipped' blocks
Signed-off-by: Steve Rae <srae@broadcom.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
When 7bfc3b1 (sparse: Refactor chunk parsing function) was implemented,
it dropped 9981945 (aboot: fix block addressing for don't care chunk type).
This re-implements the required fix for the "don't care chunk type"...
If CONFIG_SPL_OS_BOOT is enabled and Linux image is not flashed at
RAW_MODE_KERNEL_SECTOR in MMC, spl still assumes that Linux is
available and tries to boot it and hangs. In order to avoid this,
adding a check to verify if parsed image header is of type IH_OS_LINUX.
If it fails then fall back to load u-boot image.
Patch to fix boot hang when using env on i2c eeprom caused by invalid gd->env_addr
Signed-off-by: Guy Thouret <guy.thouret@wems.co.uk>
It may overflow in sparse_block_size_to_storage, use uint64_t instead in
the calculation.
Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com>
The dm usb_kbd_remove function() will deregister the usb keyboard for
us on a "usb reset" / "usb stop" so there is no need to manually call
usb_kbd_deregister() in the dm case.
This commit removes usb_kbd_deregister() in the dm case fixing the
following "usb reset" errors:
usb_kbd_remove: warning, ret=-6
device_remove: Device 'usb_kbd' failed to remove, but children are gone
Patch f8bb6964 (Drop command-processing code when CONFIG_CMDLINE is
disabled) introduced a small typo. This patch fixes it and unbreaks
all boards again that don't have the Hush parser enabled.
Add exclamation mark to the errmsg, when error and set_default_env.
Cc: Mario Schuknecht <mario.schuknecht@dresearch-fe.de>
Cc: Vignesh R <vigneshr@ti.com>
Cc: Jagan Teki <jteki@openedev.com>
Cc: Ravi Babu <ravibabu@ti.com>
Cc: York Sun <york.sun@nxp.com>
In case of #define DEBUG 1 (fordebugging SPL). A bug in
spl_nand_load_image() will be triggered, because it prints
using hw ecc regardless of soft ecc configurations and
initializations.
Signed-off-by: Ahmed Samir <engkhalil86@gmail.com>
Command parsing and processing code is not needed when the command line is
disabled. Remove this code in that case.
Since commit b391d74 "debug_uart: output CR along with LF", the
handling in puts() is duplicated, not to mention that it should
output carriage return before line feed.
Minor change: chosen is written with one "o".
No code change here, only comment & printf.
Signed-off-by: Alexander Merkle <alexander.merkle@lauterbach.com>
When compiling the code for 64bit, the lcd code emits warnings because it
tries to cast pointers to 32bit values. Fix it by casting them to longs
instead, actually properly aligning with the function prototype.
On some sunxi boards (and presumably also non sunxi boards) u-boot can
be either loaded from a sdcard in a micro-sd slot, or from eMMC.
Print which MMC spl tries to boot from, to help debugging.
The function spl_parse_image_header() falls back to a raw image
if the U-Boot header is missing and CONFIG_SPL_PANIC_ON_RAW_IMAGE
is undefined. While, mmc_load_image_raw_sector() only accepts a
U-Boot legacy image or an FIT image, preventing us from loading a
raw image.
This should return 0 on success, not 1. Fix it.
These files do not need to be compiled when CONFIG_CMDLINE is disabled.
Update the Makefile to reflect this.
Normally board_run_command() will handle command processed. But if for some
reason it returns then we should panic to avoid further processing.
This patch changes the USB port scanning procedure and timeout
handling in the following ways:
a)
The power-on delay in usb_hub_power_on() is now reduced to a value of
max(100ms, "hub->desc.bPwrOn2PwrGood * 2"). The code does not wait
using mdelay, instead usb_hub_power_on() will wait before querying
the device in the scanning loop later. The total timeout for this
hub, which is 1 second + "hub->desc.bPwrOn2PwrGood * 2" is calculated
and will be used in the following per-port scanning loop as the timeout
to detect active USB devices on this hub.
b)
Don't delay the minimum delay (for power to stabilize) in
usb_hub_power_on(). Instead skip querying these devices in the scannig
loop until the delay time is reached.
c)
The ports are now scanned in a quasi parallel way. The current code did
wait for each (unconnected) port to reach its timeout and only then
continue with the next port. This patch now changes this to scan all
ports of all USB hubs quasi simultaneously. For this, all ports are added
to a scanning list. This list is scanned until all ports are ready
by either a) reaching the connection timeout (calculated earlier), or
by b) detecting a USB device. This results in a faster USB scan time as
the recursive scanning of USB hubs connected to the hub that's currently
being scanned will start earlier.
One small functional change to the original code is, that ports with
overcurrent detection will now get rescanned multiple times
(PORT_OVERCURRENT_MAX_SCAN_COUNT).
Without this patch:
starting USB...
USB0: USB EHCI 1.00
scanning bus 0 for devices... 9 USB Device(s) found
time: 20.163 seconds
With this patch:
starting USB...
USB0: USB EHCI 1.00
time: 1.822 seconds
So ~18.3 seconds of USB scanning time reduction.
Acked-by: Hans de Goede <hdegoede@redhat.com>
Debugging has shown, that all USB hubs are being reset twice while
USB scanning. This introduces additional delays and makes USB scanning
even more slow. Testing has shown that this 2nd USB hub reset doesn't
seem to be necessary.
This patch now removes this 2nd USB hub reset. Resulting in faster USB
scan time. Here the current numbers:
Without this patch:
=> time usb start
starting USB...
USB0: USB EHCI 1.00
time: 24.003 seconds
With this patch:
=> time usb start
starting USB...
USB0: USB EHCI 1.00
time: 20.392 seconds
So ~3.6 seconds of USB scanning time reduction.
This patch removes 2 mdelay(200) calls from usb_hub_port_connect_change().
These delays don't seem to be necessary. At least not in my tests. Here
the number for a custom x86 Bay Trail board (not in mainline yet) with
a quite large and complex USB hub infrastructure.
Without this patch:
starting USB...
USB0: USB EHCI 1.00
time: 28.415 seconds
With this patch:
starting USB...
USB0: USB EHCI 1.00
So ~4.5 seconds of USB scanning time reduction.
Start with a short USB hub reset delay of 20ms. This can be enough for
some configurations.
The 2nd delay at the end of the loop is completely removed. Since the
delay hasn't been long enough, a longer delay time of 200ms is assigned
and will be used in the next loop round.
This hub reset handling is also used in the v4.4 Linux USB driver,
hub_port_reset().
This reverts commit 71105f50fedddfa5b0535d102c3d5078671721ad.
The reverted commit was applied for a temporary to unbreak
few Exynos boards on the release.
After the discussion about the change, this commit should be avoided.
Fixed device-tree for Exynos, allows reverting it without any issues.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
