path: root/common
2015-05-13mtd/nand/ubi: assortment of alignment fixesMarcel Ziswiler
Various U-Boot adoptions/extensions to MTD/NAND/UBI did not take buffer alignment into account which led to failures of the following form: ERROR: v7_dcache_inval_range - start address is not aligned - 0x1f7f0108 ERROR: v7_dcache_inval_range - stop address is not aligned - 0x1f7f1108
2015-05-11image-fdt.c: store returned error valueMax Krummenacher
This fixes the following warning (and the runtime error reporting): ../common/image-fdt.c:491:4: warning: 'fdt_ret' may be used uninitialized in this function [-Wmaybe-uninitialized]
2015-05-05common: hash: fix crc32 verifyMarcel Ziswiler
did not work: Colibri T30 # crc32 0x80000000 0x100 crc32 for 80000000 ... 800000ff ==> 9eb4f5ca Colibri T30 # crc32 -v 0x80000000 0x100 c9a057b3 crc32 for 80000000 ... 800000ff ==> 9eb4f5ca != ffffffff ** ERROR ** Colibri T30 # crc32 -v 0x80000000 0x100 9eb4f5ca crc32 for 80000000 ... 800000ff ==> 9eb4f5ca != 301eeead ** ERROR ** now works again: Colibri T30 # crc32 0x80000000 0x100 crc32 for 80000000 ... 800000ff ==> 9eb4f5ca Colibri T30 # crc32 -v 0x80000000 0x100 c9a057b3 crc32 for 80000000 ... 800000ff ==> 9eb4f5ca != c9a057b3 ** ERROR ** Colibri T30 # crc32 -v 0x80000000 0x100 9eb4f5ca Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-04-18generic-board: allow showing custom board infoMarcel Ziswiler
Allow showing custom board info from a checkboard() function being implemented if CONFIG_CUSTOM_BOARDINFO is specified.
2015-04-10common/armflash: Support for ARM flash imagesLinus Walleij
The ARM reference designs all use a special flash image format that stores a footer (two versions exist) at the end of the last erase block of the image in flash memory. Version one of the footer is indicated by the magic number 0xA0FFFF9F at 12 bytes before the end of the flash block and version two is indicated by the magic number 0x464F4F54 0x464C5348 (ASCII for "FLSHFOOT") in the very last 8 bytes of the erase block. This command driver implements support for both versions of the AFS images (the name comes from the Linux driver in drivers/mtd/afs.c) and makes it possible to list images and load an image by name into the memory with these commands: afs - lists flash contents afs load <image> - loads image to address indicated in the image afs load <image> <addres> - loads image to a specified address This image scheme is used on the ARM Integrator family, ARM Versatile family, ARM RealView family (not yet supported in U-Boot) and ARM Versatile Express family up to and including the new Juno board for 64 bit development. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-04-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2015-04-10common, ubi: use positive return values for ubi checkStefan Agner
The ubi check command is expected to not fail and just check whether a volume exist or not. Currently, when a volume does not exist, the command fails which leads to an error: "exit not allowed from main input shell." Use 1 to indicate that a volume does not exist. This allows to use ubi check in an if statement, e.g. if ubi check rootfs; then; echo "exists"; else; echo "not there"; fi
2015-04-10Introduce CONFIG_SPL_PANIC_ON_RAW_IMAGEAlbert ARIBAUD \(3ADEV\)
introduce CONFIG_SPL_PANIC_ON_RAW_IMAGE. An SPL which define this will panic() if the image it has loaded does not have a mkimage signature. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-04-10lpc32xx: add lpc32xx-spl.bin boot image targetAlbert ARIBAUD \(3ADEV\)
2015-04-07cmd_mem.c: Update 'iteration_limit' to unsigned longTom Rini
With e37f1eb we now use strict_strtoul() in do_mem_mtest() and this gives us a warning: ../include/vsprintf.h:38:5: note: expected 'long unsigned int *' but argument is of type 'int *' Signed-off-by: Tom Rini <trini@konsulko.com>
2015-04-07cmd_mem: cleanups, catch bad usagePavel Machek
Currently, memtest will silently accept bad data. Perform error checking on user intput. Signed-off-by: Pavel Machek <pavel@denx.de>
2015-04-07env_sf: Fix recovery defaultMario Schuknecht
The u-boot environment is redundantly stored in a NOR flash on our boards. Redundant means that there are two places to store the environment. But only one of the two is active. I discovered that on one board the u-boot (env_sf) uses the environment from the second place and the Kernel (fw_printenv) uses the environment from the first place. To decide which is the active environment there is a byte inside the environment. 1 means active and 0 means obsolete. But on that board both environments had have a 1. This can happen if a power loss or reset occurs during writing the environment. In this situation the u-boot (env_sf) implementation uses the second environment as default. But the Kernel (fw_printenv) implementation uses the first environment as default. This commit corrects the default in the u-boot env_sf implementation when a problem was detected. Now the recovery default is the same like in all other environment implementations. E.g. fw_printenv and env_flash. This ensures that u-boot and Kernel use the same environment. Signed-off-by: Mario Schuknecht <mario.schuknecht@dresearch-fe.de>
2015-04-03arc: clean-up init procedureAlexey Brodkin
Intention behind this work was elimination of as much assembly-written code as it is possible. In case of ARC we already have relocation fix-up implemented in C so why don't we use C for U-Boot copying, .bss zeroing etc. It turned out x86 uses pretty similar approach so we re-used parts of code in "board_f.c" initially implemented for x86. Now assembly usage during init is limited to stack- and frame-pointer setup before and after relocation. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Simon Glass <sjg@chromium.org>
2015-03-30nand: yaffs: Remove the "nand write.yaffs" commandPeter Tyser
This command is only enabled by one board, complicates the NAND code, and doesn't appear to have been functioning properly for several years. If there are no bad blocks in the NAND region being written nand_write_skip_bad() will take the shortcut of calling nand_write() which bypasses the special yaffs handling. This causes invalid YAFFS data to be written. See http://lists.denx.de/pipermail/u-boot/2011-September/102830.html for an example and a potential workaround. U-Boot still retains the ability to mount and access YAFFS partitions via CONFIG_YAFFS2. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2015-03-30cmd_nand: Verify writes to NANDPeter Tyser
Previously NAND writes were only verified when CONFIG_MTD_NAND_VERIFY_WRITE was defined. On boards without this define writes could fail silently. Boards with CONFIG_MTD_NAND_VERIFY_WRITE could prematurely report failures which ECC could correct. Add a verification step after all "nand write[.x]" commands to ensure the writes were successful. The verification uses ECC for for "normal" writes, but does not for raw and yaffs writes. Some test cases which inject fake bad bits on a 2K page flash are below. Test cases with CONFIG_MTD_NAND_VERIFY_WRITE defined: Example of an ECC write which previously failed when CONFIG_MTD_NAND_VERIFY_WRITE was defined, but now succeeds because ECC is used during verification: nand erase 0 0x10000 dhcp /somefile mw.b 0x10000 0xff 0x2000 mw.b 0x10020 0xfe 1 nand write.raw 0x10000 0x800 1 mw.b 0x1000020 0x01 1 nand write 0x1000000 0x800 0x1800 Test cases without CONFIG_MTD_NAND_VERIFY_WRITE defined: Example of an ECC write which previously silently failed: nand erase 0 0x10000 dhcp /somefile mw.b 0x10000 0xff 0x2000 mw.b 0x10020 0x00 1 nand write.raw 0x10000 0x800 1 mw.b 0x1000020 0xff 1 nand write 0x1000000 0x800 0x1800 Example of a raw write which previously failed silently due to stuck data bit, but now errors out: nand erase 0 0x10000 dhcp /somefile mw.b 0x10000 0xff 0x2000 mw.b 0x10020 0xfe 1 nand write.raw 0x10000 0x800 1 mw.b 0x1000020 0x01 1 nand write.raw 0x1000000 0x800 3 Example of a raw write which previously failed silently due to stuck OOB bit, but now errors out: nand erase 0 0x10000 dhcp /somefile mw.b 0x10000 0xff 0x2000 mw.b 0x10810 0xfe 1 nand write.raw 0x10000 0x800 1 mw.b 0x1000810 0x01 1 nand write.raw 0x1000000 0x800 3 Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2015-03-28m68k: fix 3 broken boardsangelo@sysam.it
Fix eb_cpu5282 and eb_cpu5282_internal unresolved external error. These boards have video but don't need any ppc related video_setmem(). Fix M53017EVB moving away embedded env to a different offset, as in M52277EVB. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2015-03-28common/board_f: move board_init_f_mem() from #else CONFIG_X86Alexey Brodkin
Purpose of this change is to make it possible to re-use code currently used on X86 solely for other architectures. For example: * init_sequence_f_r * board_init_f_r Even though board_init_f_mem() has nothing to do with any particular architecture it won't work (at least in current implementation) for X86. This is because on X86 "gd" is an alias to function get_fs_gd_ptr(), thus we cannot assign anything to it. So this change separates selection of board_init_f_mem() from X86 while keeping it disabled for X86 still. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com>
2015-03-25part: Add support for list filtering on bootable partitionsSjoerd Simons
Add an optional -bootable parameter to the part list commands to only put the list of bootable partitions in the environment variable Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2015-03-24remove unnecessary version.h includesRob Herring
Various files are needlessly rebuilt every time due to the version and build time changing. As version.h is not actually needed, remove the include. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Tom Warren <twarren@nvidia.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Wolfgang Denk <wd@denx.de> Cc: York Sun <yorksun@freescale.com> Cc: Stefan Roese <sr@denx.de> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Simon Glass <sjg@chromium.org> Cc: Philippe Reynes <tremyfr@yahoo.fr> Cc: Eric Jarrige <eric.jarrige@armadeus.org> Cc: "David Müller" <d.mueller@elsoft.ch> Cc: Phil Edworthy <phil.edworthy@renesas.com> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Torsten Koschorrek <koschorrek@synertronixx.de> Cc: Anatolij Gustschin <agust@denx.de> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Łukasz Majewski <l.majewski@samsung.com>
2015-03-18Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-03-13common/board_f.c: Enable IMX watchdog in init_func_watchdog_init()Stefan Roese
Without this patch, the IMX watchdog will not be initialized. And therefor not active. This patch fixes this by calling hw_watchdog_init() also when CONFIG_IMX_WATCHDOG is defined. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2015-03-10Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
Conflicts: README Signed-off-by: Tom Rini <trini@konsulko.com>
2015-03-09common: cmd_elf: Add support to disable start of applicationSiva Durga Prasad Paladugu
Added support to disable the start of application by using a environment variable autostart Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-03-09common/board_r: Restore non-cached memory setupJan Kiszka
This fixes a regression of e310b93ec1, affecting Ethernet on the Jetson TK1, e.g. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
2015-03-09dlmalloc: do memset in malloc init as new default configPrzemyslaw Marczak
This commit introduces new config: CONFIG_SYS_MALLOC_CLEAR_ON_INIT. This config is an expert option and is enabled by default. The all amount of memory reserved for the malloc, is by default set to zero in mem_malloc_init(). When the malloc reserved memory exceeds few MiB, then the boot process can slow down. So disabling this config, is an expert option to reduce the boot time, and can be disabled by Kconfig. Note: After disable this option, only calloc() will return the pointer to the zeroed memory area. Previously, without this option, the memory pointed to untouched malloc memory region, was filled with zeros. So it means, that code with malloc() calls should be reexamined. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-03-05cmd_usb_mass_storage: Remove extra 'ums' string in the usage textFabio Estevam
Currently the usage text for the 'ums' command looks like this: Usage: ums ums <USB_controller> [<devtype>] <devnum> e.g. ums 0 mmc 0 ,so remove the extra 'ums' in the text. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Marek Vasut <marex@denx.de>
2015-03-05common/board_f: implement type casting for gd structureAlexey Brodkin
In case of global data structure defined as "register volatile" compiler throws an warning about incorrect type used: --->8--- common/board_f.c: In function "board_init_f_r": common/board_f.c:1073:2: warning: passing argument 1 of "&board_init_r +(sizetype)gd->reloc_off" discards "volatile" qualifier from pointer target type [enabled by default] (board_init_r + gd->reloc_off)(gd, gd->relocaddr); ^ common/board_f.c:1073:2: note: expected "struct gd_t *" but argument is of type "volatile struct gd_t *" --->8--- An obvious fix is manual casting to "gd_t *". Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-05spl: fix calling "spl export .." more than onceHeiko Schocher
running "spl export ..." more than once fails with: Trying to execute a command out of order Trying to execute a command out of order Trying to execute a command out of order Trying to execute a command out of order Trying to execute a command out of order Trying to execute a command out of order ERROR prep subcommand failed! Subcommand failed reason is commmit: 35fc84fa1f: Refactor the bootm command to reduce code duplication It used "state != BOOTM_STATE_START" but state is a bitfield, so check if the bit BOOTM_STATE_START is not set. With this fix, "spl export ..." can called more than once ... Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-03-05m68k: Add generic board support for MCF547X/8X and MCF5445XAlison Wang
This patch adds generic board support for MCF547X/8X and MCF5445X. It is based on the patch about common generic board support for M68K architecture sent by Angelo. Signed-off-by: Alison Wang <alison.wang@freescale.com>
2015-03-05m68k: add generic-board supportangelo@sysam.it
Add generic-board support for the m68k architecture. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2015-03-05cmd_yaffs: Clean up command usage messagesPeter Tyser
Remove duplicate command names in usage messages to fix issues such as: => help yls yls - yaffs ls Usage: yls yls [-l] dirname Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2015-03-05common/lcd: Add command for writing to lcd-displayHannes Petermaier
Sometimes we do not want redirect u-boot's console to screen but anyway we want write out some status information out of a u-boot script to the display. So we cannot use the normal "echo ....", instead we write explicitly using "lcdputs ..." for writing to the actual cursor position on LCD. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-05common/lcd: Add command for setting cursor within lcd-consoleHannes Petermaier
Sometimes we do not want redirect u-boot's console to screen but anyway we want write out some status information out of a u-boot script to the display. To define the specific position of the string to be written, we have to set the cursor with "setcurs" before writing. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2015-03-05gpt: support random UUIDs without setting environment variablesRob Herring
Currently, an environment variable must be used to store the randomly generated UUID for each partition. This is not necessary, so make storing the UUID optional. Now passing uuid_disk and uuid are optional when random UUIDs are enabled. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-03-05gpt: fix error reporting on partition table write failuresRob Herring
The gpt command always reports success even if writing the partition table failed. Propagate the return value of gpt_restore so we get proper status reported. Signed-off-by: Rob Herring <robh@kernel.org> Reviewed-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-03-05Merge branch 'master' of git://git.denx.de/u-bootStefano Babic
2015-03-05kconfig: common: Fix memtest bool nameNikolaos Pasaloukos
Fix the name appearing in menuconfig for memtest command Signed-off-by: Nikolaos Pasaloukos <Nikolaos.Pasaloukos@imgtec.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com
2015-03-05Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-03-04arm: spl: Allow board_init_r() to run with a larger stackSimon Glass
At present SPL uses a single stack, either CONFIG_SPL_STACK or CONFIG_SYS_INIT_SP_ADDR. Since some SPL features (such as MMC and environment) require a lot of stack, some boards set CONFIG_SPL_STACK to point into SDRAM. They then set up SDRAM very early, before board_init_f(), so that the larger stack can be used. This is an abuse of lowlevel_init(). That function should only be used for essential start-up code which cannot be delayed. An example of a valid use is when only part of the SPL code is visible/executable, and the SoC must be set up so that board_init_f() can be reached. It should not be used for SDRAM init, console init, etc. Add a CONFIG_SPL_STACK_R option, which allows the stack to be moved to a new address before board_init_r() is called in SPL. The expected SPL flow (for CONFIG_SPL_FRAMEWORK) is documented in the README. Signed-off-by: Simon Glass <sjg@chromium.org> For version 1: Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Bo Shen <voice.shen@atmel.com> Acked-by: Bo Shen <voice.shen@atmel.com> Acked-by: Heiko Schocher <hs@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-03-04common: board: support systems with where RAM ends beyond 4GBStephen Warren
Some systems have so much RAM that the end of RAM is beyond 4GB. An example would be a Tegra124 system (where RAM starts at 2GB physical) that has more than 2GB of RAM. In this case, we can gd->ram_size to represent the actual RAM size, so that the actual RAM size is passed to the OS. This is useful if the OS implements LPAE, and can actually use the "extra" RAM. However, U-Boot does not implement LPAE and so must deal with 32-bit physical addresses. To this end, we enhance board_get_usable_ram_top() to detect the "over-sized" case, and limit the relocation addres so that it fits into 32-bits of physical address space. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-02Merge git://git.denx.de/u-boot-usbTom Rini
2015-03-02Merge branch 'master' of git://git.denx.de/u-bootStefano Babic
2015-02-25Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2015-02-25crypto/fsl - Add progressive hashing support using hardware acceleration.gaurav rana
Currently only normal hashing is supported using hardware acceleration. Added support for progressive hashing using hardware. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> CC: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <yorksun@freescale.com>
2015-02-25crypto/fsl: Make function names consistent for blob encapsulation/decapsulation.gaurav rana
This patch does the following: 1. The function names for encapsulation and decapsulation were inconsitent in freescale's implementation and cmd_blob file. This patch corrects the issues. 2. The function protopye is also modified to change the length parameter from u8 to u32 to allow encapsulation and decapsulation of larger images. 3. Modified the description of km paramter in the command usage for better readability. Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> Reviewed-by: Ruchika Gupta <ruchika.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-02-25fastboot: Correct fastboot_fail and fastboot_okay stringsDileep Katta
If the string is copied without NULL termination using strncpy(), then strncat() on the next line, may concatenate the string after some stale (or random) data, if the response string was not zero-initialized. Signed-off-by: Dileep Katta <dileep.katta@linaro.org> Reviewed-by: Steve Rae <srae@broadcom.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-02-25fastboot: Add USB cable detect checkRob Herring
Add a check for USB cable attached and only enter fastboot when a cable is attached. Signed-off-by: Rob Herring <robh@kernel.org> Reviewed-by: Steve Rae <srae@broadcom.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-02-25usb: gadget: fastboot: Add fastboot eraseDileep Katta
Adds the fastboot erase functionality, to erase a partition specified by name. The erase is performed based on erase group size, to avoid erasing other partitions. The start address and the size is aligned to the erase group size for this. Currently only supports erasing from eMMC. Signed-off-by: Dileep Katta <dileep.katta@linaro.org> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-02-24kconfig: remove unneeded dependency on !SPL_BUILDMasahiro Yamada
Now CONFIG_SPL_BUILD is not defined in Kconfig, so "!depends on SPL_BUILD" and "if !SPL_BUILD" are redundant. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-23mmc: Implement SD/MMC versioning properlyPantelis Antoniou
The SD/MMC version scheme was buggy when dealing with standard major.minor.change cases. Fix it by using something similar to the linux's kernel versioning method. Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Tested-by: Jaehoon Chung <jh80.chung@samsung.com> Reported-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com>
