path: root/common
2016-10-28Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: common/Kconfig configs/dms-ba16_defconfig
2016-10-26config: Move CONFIG_DEFAULT_FDT_FILE to defconfigsJagan Teki
- Add DEFAULT_FDT_FILE kconfig entry - Move CONFIG_DEFAULT_FDT_FILE from include/configs to defconfigs Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-23Convert CONFIG_SYS_STDIO_DEREGISTER to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_STDIO_DEREGISTER This option should never be enabled in SPL, so use CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Re-sync] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_ENV_OVERWRITE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_ENV_OVERWRITE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONSOLE_PRE_CONSOLE_BUFFER options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-17watchdog: Fix Watchdog Reset while in U-Boot PromptAndreas J. Reichel
Hardware: CM-FX6 Module from Compulab This patch fixes unwanted watchdog resets while the user enters a command at the U-Boot prompt. As found on the CM-FX6 board from Compulab, when having enabled the watchdog, a missing WATCHDOG_RESET call in common/console.c causes this and alike boards to reset when the watchdog's timeout has elapsed while waiting at the U-Boot prompt. Despite the user could press several keys within the watchdog timeout limit, the while loop in cli_readline.c, line 261, does only call WATCHDOG_RESET if first == 1, which gets set to 0 in the 1st loop iteration. This leads to a watchdog timeout no matter if the user presses keys or not. Although, this affects other boards as well as it touches common/console.c, the macro WATCHDOG_RESET expands to {} if watchdog support isn't configured. Hence, there's no harm caused and no need to surround it by #ifdef in this case. * Symptom: U-Boot resets after watchdog times out when in commandline prompt and watchdog is enabled. * Reasoning: When U-Boot shows the commandline prompt, the following function call stack is executed while waiting for a keypress: common/main.c: main_loop => common/cli.c: cli_loop() => common/cli_hush.c: parse_file_outer => parse_stream_outer => parse_stream => b_getch(i) => i->get(i) => file_get => get_user_input => cmdedit_read_input => uboot_cli_readline => common/cli_readline.c: cli_readline => cli_readline_into_buffer => cread_line => getcmd_getch (== getc) => common/console.c: fgetc => console_tstc common/console.c: (with CONFIG_CONSOLE_MUX is set) - in console_tstc line 181: If dev->tstc(dev) returns 0, the global tstcdev variable doesn't get set. This is the case if no character is in the serial buffer. - in fgetc(int file), line 297: Program flow keeps looping because tstcdev does not get set. Therefore WATCHDOG_RESET is not called, as mx_serial_tstc from drivers/serial/serial_mxc.c does not call it. * Solution: Add WATCHDOG_RESET into the loop of console_tstc. Note: Macro expands to {} if not configured, so no #ifdef is needed. * Comment: Signed-off-by: Christian Storm <christian.storm@tngtech.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Andreas J. Reichel <Andreas.Reichel@tngtech.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-15spl: move SYS_OS_BASE to KconfigHeiko Schocher
Move SYS_OS_BASE to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de> [trini: Also migrate a4m2k] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-14spl: move SPL_OS_BOOT to KconfigHeiko Schocher
Move SPL_OS_BOOT to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-10-13libfdt: Sync fdt_for_each_subnode() with upstreamSimon Glass
The signature for this macro has changed. Bring in the upstream version and adjust U-Boot's usages to suit. Signed-off-by: Simon Glass <sjg@chromium.org> Update to drivers/power/pmic/palmas.c: Signed-off-by: Keerthy <j-keerthy@ti.com> Change-Id: I6cc9021339bfe686f9df21d61a1095ca2b3776e8
2016-10-13libfdt: Bring in upstream stringlist functionsSimon Glass
These have now landed upstream. The naming is different and in one case the function signature has changed. Update the code to match. This applies the following upstream commits by Thierry Reding <treding@nvidia.com> : 604e61e fdt: Add functions to retrieve strings 8702bd1 fdt: Add a function to get the index of a string 2218387 fdt: Add a function to count strings Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-13cmd/fdt: add possibilty to have 'extrasize' on fdt resizeHannes Schmelzer
Sometimes devicetree nodes and or properties are added out of the u-boot console, maybe through some script or manual interaction. The devicetree as loaded or embedded is quite small, so the devicetree has to be resized to take up those new nodes/properties. In original the devicetree was only extended by effective 4 * add_mem_rsv. With this commit we can add an argument to the "fdt resize" command, which takes the extrasize to be added. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-12Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2016-10-11board_f: Drop the extra fdtdec_prepare_fdt()Simon Glass
This is already called earlier, from fdtdec_setup(), so drop this unnecessary call from the init sequence. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-11dm: stdio: Allow lazy probing of video devicesSimon Glass
At present all video devices are probed on start-up. It would be better to probe a device only when it is needed. This can happen if it is referenced in the stdout environment variable, for example. Add support for this by searching for a suitable device when needed, probing it, and finding the stdio device it creates. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-08Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-10-08spl: saveenv: adding saveenv support in SPLB, Ravi
By default saveenv option is not supported for SPL. This patch enable the support for save environment variable for SPL build. Enable save environment support in SPL after setenv. By default the saveenv option is not provided in SPL, but some boards need this support in 'Falcon' boot, where SPL need to boot from different images based on environment variable set by OS. For example OS may set "reboot_image" environment variable to "recovery" inorder to boot recovery image by SPL. The SPL read "reboot_image" and act accordingly and change the reboot_image to default mode using setenv and save the environemnt. Signed-off-by: Ravi Babu <ravibabu@ti.com> Reviewed-by: Simon Glass <sig@chromium.org> change in v1: - dropped SUPPORT, use CONFIG_SPL_SAVEENV - updates the comments in mmc_private.h
2016-10-07common/console.c: ensure GD_FLG_SILENT is set or clearedChris Packham
When CONFIG_SILENT_CONSOLE is defined and the default environment has silent=1 it is not possible for a user to make the console un-silent if the environment is not available when console_init_f() is called (for example because the environment is in SPI). Add a new helper function console_update_silent() and call it from both console_init_f() and console_init_r(). Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-06Various, accumulated typos collected from around the tree.Robert P. J. Day
Fix various misspellings of: * deprecated * partition * preceding,preceded * preparation * its versus it's * export * existing * scenario * redundant * remaining * value * architecture Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Stefan Roese <sr@denx.de>
2016-10-06spl: Make spl_boot_list a local variableSimon Glass
There is no need for this to be in the BSS region. By moving it we can delay use of BSS in SPL. This is useful for machines where the BSS region is not in writeable space. On 64-bit x86, SPL runs from SPI flash and it is easier to eliminate BSS use than link SPL to run with BSS at a particular cache-as-RAM (CAR) address. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Update spl_load_simple_fit() to take an spl_image paramSimon Glass
Upda the SPL FIT code to use the spl_image parameter. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Update fat functions to take an spl_image parameterSimon Glass
Update the fat loader to avoid using the spl_image global variable. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Update ext functions to take an spl_image parameterSimon Glass
Update the ext loader to avoid using the spl_image global variable. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Pass spl_image as a parameter to load_image() methodsSimon Glass
Rather than having a global variable, pass the spl_image as a parameter. This avoids BSS use, and makes it clearer what the function is actually doing. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Convert spl_board_load_image() to use linker listSimon Glass
Add a linker list declaration for this method and remove the explicit switch() code. Update existing users. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Convert spl_net_load_image() to use linker listSimon Glass
Add a linker list declaration for this method and remove the explicit switch() code. We need two variants - one for BOOT_DEVICE_CPGMAC and one for BOOT_DEVICE_USBETH. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Convert spl_spi_load_image() to use linker listSimon Glass
Add a linker list declaration for this method and remove the explicit switch() code. Also set up the sunxi function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: spi: Move the generic SPI loader into common/splSimon Glass
All the other SPL loaders are in this directory, so move the SPI one in there too. There are two board-specific SPI loaders (fsl and sunxi). These remain in the drivers/mtd/spi directory, since they do not contain generic code. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Convert spl_sata_load_image() to use linker listSimon Glass
Add a linker list declaration for this method and remove the explicit switch() code. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Convert spl_usb_load_image() to use linker listSimon Glass
2016-10-06spl: Convert spl_ymodem_load_image() to use linker listSimon Glass
2016-10-06spl: Convert spl_nor_load_image() to use linker listSimon Glass
2016-10-06spl: Convert spl_onenand_load_image() to use linker listSimon Glass
2016-10-06spl: Convert spl_nand_load_image() to use linker listSimon Glass
2016-10-06spl: Convert spl_ubi_load_image() to use linker listSimon Glass
2016-10-06spl: Convert spl_mmc_load_image() to use linker listSimon Glass
2016-10-06spl: Convert spl_ram_load_image() to use linker listSimon Glass
Add a linker list declaration for this method and remove the explicit switch() code. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Include updating the DFU case] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Add a way to declare an SPL image loaderSimon Glass
Add a linker list macro which can be used to declare an SPL image loader. Update spl_load_image() to search available loaders for the correct one. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Convert boot_device into a structSimon Glass
At present some spl_xxx_load_image() functions take a parameter and some don't. Of those that do, most take an integer but one takes a string. Convert this parameter into a struct so that we can pass all functions the same thing. This will allow us to use a common function signature. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Kconfig: Move SPL_DISPLAY_PRINT to KconfigSimon Glass
Move this option to Kconfig and tidy up existing uses. Also add a function comment to the header file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Add a parameter to jump_to_image_linux()Simon Glass
Instead of using the global spl_image variable, pass the required struct in as an argument. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Add a parameter to spl_parse_image_header()Simon Glass
2016-10-06spl: Add a parameter to spl_set_header_raw_uboot()Simon Glass
Rather than act on the global variable, pass the required struct in as a parameter. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06tools: mkimage: add support for Vybrid image formatAlbert ARIBAUD \(3ADEV\)
This format can be flashed directly at address 0 of the NAND FLASH, as it contains all necessary headers. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2016-10-01fastboot: move FASTBOOT_FLASH options into KconfigPetr Kulhavy
Move FASTBOOT_MBR_NAME and FASTBOOT_GPT_NAME into Kconfig. Add dependency on the FASTBOOT_FLASH setting (also for FASTBOOT_MBR_NAME). Remove the now redundant GPT_ENTRY_NAME. Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Add FIXME about xxx_PARTITION needing to be in Kconfig] Signed-off-by: Tom Rini <trini@konsulko.com>
