path: root/common
2011-07-26scaled down version of generic libraries for SPLAneesh V
Signed-off-by: Aneesh V <aneesh@ti.com>
2011-07-26Fix: watchdog timed out, if using md5 commandJens Scharsig
* Fix: if using md5 command watchdog timed out * change function call md5(..) to the watchdog-safe variant md5_wd(..) to support watchdog reset Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
2011-07-26Fix: watchdog timed out, if using sha1 commandJens Scharsig
* Fix: if using sha1 command watchdog timed out * change function call sha1_csum(..) to the watchdog-safe variant sha1_csum_wd(..) to support watchdog reset Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
2011-07-26command/cmd_cache.c: Add optional flush argumentsMatthew McClintock
It might be desirable to have the ability to flush icache/dcache within u-boot, this patch gives each arch the ability to provide a flush_dcache/flush_icache function to let u-boot flush caches from the prompt Signed-off-by: Matthew McClintock <msm@freescale.com>
2011-07-26common/cmd_ximg.c: add ifdef protection for gzip uncompressionMatthew McClintock
Print a message if we do not have the ability to uncompress a gzip image. Before, u-boot would just assume the routines were available Signed-off-by: Matthew McClintock <msm@freescale.com>
2011-07-26disk/part.c: Make features optionalMatthew McClintock
If we don't want to build support for any partition types we can now add #undef CONFIG_PARTITIONS in a board config file to keep this from being compiled in. Otherwise boards assume this is compiled in by default Signed-off-by: Matthew McClintock <msm@freescale.com>
2011-07-26miiphy: use strncpy() not sprintf()Laurence Withers
In miiphy_register() the new device's name was initialised by passing a string parameter as the format string to sprintf(). As this would cause problems if it ever contained a '%' symbol, switch to using strncpy() instead. Signed-off-by: Laurence Withers <lwithers@guralp.com> Cc: Andy Fleming <afleming@freescale.com>
2011-07-26Fix: if using crc32 command watchdog timed outJens Scharsig
* Fix: if using crc32 command watchdog timed out * change function call crc32(..) to the watchdog-safe variant crc_32_wd(..) to support watchdog reset Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
2011-07-26scsi/ahci: add support for non-PCI controllersRob Herring
Add support for AHCI controllers that are not PCI based. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Wolfgang Denk <wd@denx.de>
2011-07-25cosmetic, main: correct indentation/spacing issuesJason Hobbs
Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-07-25cosmetic, main: clean up declarations of abortbootJason Hobbs
Remove an unneeded prototype declaration from the top of main.c, and use plain inline instead of __inline__ to please checkpatch. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-07-25autostart: unify duplicated logic into the bootm codeMike Frysinger
Rather than having a bunch of random commands handle autostart behavior, unify the logic in a single place. This also fixes building of these different commands when bootm is disabled. Acked-by: Matthew McClintock <msm@freescale.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-19Merge branch 'master' of git://git.denx.de/u-boot-mmcWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mmc: mmc: rescan fails on empty slot AT91:mmc:fix multiple read/write error mmc: Access mode validation for eMMC cards > 2 GiB mmc: sh_mmcif: add support for Renesas MMCIF mmc: fix the condition for MMC version 4 MMC: add marvell sdhci driver MMC: add sdhci generic framework MMC: add erase function to both mmc and sd MMC: unify mmc read and write operation mmc: Tegra2: Enable SD/MMC driver for Seaboard and Harmony mmc: Tegra2: SD/MMC driver for Seaboard - eMMC on SDMMC4, SDIO on SDMMC3
2011-07-19Fix typo from 'mb_alloc' -> 'lmb_alloc'Matthew McClintock
2011-07-18Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: ARM: MX5: Fix broken leftover TO-2 errata workaround MX31: Cleanup clock function scb9328: Add ARM relocation support am3517evm: change console device from ttyS2 to ttyO2 Remove volatile qualifier in get_ram_size() calls TI: TNETV107X Fix Build Error ARM: add missing CONFIG_SKIP_LOWLEVEL_INIT for armv7 arm: add CONFIG_MACH_TYPE setting and documentation arm: add __ilog2 function Timer: Fix misuse of ARM *timer_masked() functions outside arch/arm EfikaMX: Enable EXT2 booting EfikaMX: Add missing CONFIG_SYS_TEXT_BASE EfikaMX: Use correct imximage.cfg MX27: Update to autogenerated asm-offsets.h MX5: Update to autogenerated asm-offsets.h imx: Add support for zmx25 board imx: Make imx25 compatible to mxc_gpio driver and fix in tx25 imx: Add auto generation of asm-offsets.h for imx25 imx: Add support for USB EHCI on imx25 imx: Use correct imx25 reset.c imx: Add get_tbclk() function for imx25 ARM: Update maintainer of board scb9328 mx27: Make the UART port number explicit build: Add targets for auto gen of asm-offsets.h and use it in imx35 mx31pdk: cosmetic: Fix line over 80 characters
2011-07-17Remove volatile qualifier in get_ram_size() callsAlbert ARIBAUD
Checkpatch.pl complains about the volatile qualifier in calls to get_ram_size(). Remove this qualifier in the prototype and in the calls where it is useless, and leave it only in the function body where it is needed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-07-16Add uboot "fdt_high" enviroment variableDavid A. Long
Add a new "fdt_high" enviroment variable. This can be used to control (or prevent) the relocation of the flattened device tree on boot. It can be used to prevent relocation of the fdt into highmem. The variable behaves similarly to the existing "initrd_high" variable. Signed-off-by: David A. Long <dave.long@linaro.org>
2011-07-15mmc: rescan fails on empty slotMichael Jones
Fail in 'mmc rescan' if mmc_init() returns error Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Andy Fleming <afleming@freescale.com>
2011-07-15MMC: add erase function to both mmc and sdLei Wen
Erase is a very basic function since the begin of sd specification is announced. Although we could write a bulk of full 0xff memory to the range to take place of erase, it is more convenient and safe to implement the erase function itself. Signed-off-by: Lei Wen <leiwen@marvell.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-15MMC: unify mmc read and write operationLei Wen
mmc read and write command has so many in common, unfiy those two to force consistency across the those two. Signed-off-by: Lei Wen <leiwen@marvell.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Andy Fleming <afleming@freescale.com>
2011-07-14fdt: introduce fdt_create_phandle()Gerald Van Baren
The ePAPR specification says that phandle properties should be called "phandle", and not "linux,phandle". To facilitate the migration from "linux,phandle" to "phandle", introduce function fdt_create_phandle(), which creates a phandle in a given node. For now, we create both the "phandle" and "linux,phandle" properties. A later version of this function will remove support for "linux,phandle". Signed-off-by: Timur Tabi <timur@freescale.com>
2011-07-14fdt: introduce fdt_verify_alias_address() and fdt_get_base_address()Timur Tabi
Introduce two functions, fdt_verify_alias_address() and fdt_get_base_address(), which can be used to verify the physical address of a device in a device tree. fdt_get_base_address() returns the base address of an SOC or PCI node. fdt_verify_alias_address() prints a message if the address of a node specified by an alias does not match the given physical address. Signed-off-by: Timur Tabi <timur@freescale.com>
2011-07-04armv7: rename cache related CONFIG flagsAneesh V
Replace the cache related CONFIG flags with more meaningful names. Following are the changes: CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF CONFIG_SYS_NO_ICACHE -> CONFIG_SYS_ICACHE_OFF CONFIG_SYS_NO_DCACHE -> CONFIG_SYS_DCACHE_OFF Signed-off-by: Aneesh V <aneesh@ti.com> V2: * Changed CONFIG_L2_OFF -> CONFIG_SYS_NO_L2CACHE V4: * Changed all three flags to the final names suggested as above and accordingly changed the commit message
2011-07-01cmd_nand: add nand write.trimffs commandBen Gardiner
Add another nand write. variant, trimffs. This command will request of nand_write_skip_bad() that all trailing all-0xff pages will be dropped from eraseblocks when they are written to flash as-per the reccommended behaviour of the UBI FAQ [1]. The function that implements this timming is the drop_ffs() function by Artem Bityutskiy, ported from the mtd-utils tree. [1] http://www.linux-mtd.infradead.org/doc/ubi.html#L_flasher_algo Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> CC: Artem Bityutskiy <dedekind1@gmail.com> CC: Detlev Zundel <dzu@denx.de> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-07-01nand_util: convert nand_write_skip_bad() to flagsBen Gardiner
In a future commit the behaviour of nand_write_skip_bad() will be further extended. Convert the only flag currently passed to the nand_write_ skip_bad() function to a bitfield of only one allocated member. This should avoid an explosion of int's at the end of the parameter list or the ambiguous calls like nand_write_skip_bad(info, offset, len, buf, 0, 1, 1); nand_write_skip_bad(info, offset, len, buf, 0, 1, 0); Instead there will be: nand_write_skip_bad(info, offset, len, buf, WITH_YAFFS_OOB | WITH_OTHER); Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Acked-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-06-22ARM: drop unsupported 'trab' boardWolfgang Denk
The 'trab' board configuration is broken, and there is nobody who is interested and willing to fix it. Drop it. This includes support for VFD displays which have always been used by this board only. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-06-01common/cmd_fdt.c: fix wrong data displayed in fdt printHaojian Zhuang
All data in dtb is big endian. Some ARM devices are little-endian. In print_data(), it displays data with big-endian format. For ARM device, data should be converted to little-endian first. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Cc: Gerald Van Baren <vanbaren@cideas.com>
2011-06-01sntp: avoid use of uninitialized variableLuuk Paulussen
When we use the ntpserverip environment variable argv[1] may not be set. Printing the error message using the NetNtpServerIP variable ensures the correct output in both cases. Signed-off-by: Luuk Paulussen <luuk.paulussen@alliedtelesis.co.nz> Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Cc: Ben Warren <biggerbadderben@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de>
2011-05-24cmd_nand: fix help of nand erase subcommandDaniel Hobi
Since commit 30486322 (nand erase: .spread, .part, .chip subcommands) the arguments off and size are no longer optional. Signed-off-by: Daniel Hobi <daniel.hobi@schmid-telecom.ch> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-05-24env_nand: zero-initialize variable nand_erase_optionsDaniel Hobi
Commit 30486322 (nand erase: .spread, .part, .chip subcommands) added a new field to struct nand_erase_options, but forgot to update common/env_nand.c. Depending on the stack state and bad block distribution, saveenv() can thus erase more than CONFIG_ENV_RANGE bytes which may corrupt the following NAND sectors/partitions. Signed-off-by: Daniel Hobi <daniel.hobi@schmid-telecom.ch> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-05-19Minor coding style cleanup.Wolfgang Denk
2011-05-19TFTP: add tftpsrv commandLuca Ceresoli
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-05-18mmc: enable partition switch function for emmcLei Wen
For emmc, it may have up to 7 partitions: two boot partitions, one user partition, one RPMB partition and four general purpose partitions. (Refer to JESD84-A44.pdf/page 154) As bootloader may need to read out or reflashing images on those different partitions, it is better to enable the partition switch with console command support. Also for partition would be restore to user partition(part 0) when CMD0 is used, so change mmc_init routine to perform normal initialization only once for each slot, unless use the rescan command to force init again. Signed-off-by: Lei Wen <leiwen@marvell.com> Acked-by: Andy Fleming <afleming@freescale.com>
2011-05-18cmd_mmc: eliminate device num in the mmc commandLei Wen
mmc command applied device, like ide and usb... Signed-off-by: Lei Wen <leiwen@marvell.com> Acked-by: Andy Fleming <afleming@freescale.com>
2011-05-12cosmetic: cmd_bdinfo.c: clean up by using checkpatch.plMacpaul Lin
cmd_bdinfo.c: clean up with 2.6.38 checkpatch.pl Signed-off-by: Macpaul Lin <macpaul@andestech.com> Acked-by: Detlev Zundel <dzu@denx.de>
2011-05-12cmd_nvedit.c: make error message more helpfulWolfgang Denk
When calling getenv_f() with a too small buffer, it would print an error message like this: env_buf too small [32] This is not really helpful as it does not give any indication which of the calls might have failed. Change this into: env_buf [32 bytes] too small for value of "hwconfig" so we know at least which variable caused the overflow; this usually allows to quickly find the related code as well. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-05-10common/hush: make get_local_var visible for other usersHolger Brunck
Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-05-10cramfs: make cramfs usable without a NOR flashHeiko Schocher
cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-05-10cramfs: fix bug in using CONFIG_CRAMFS_CMDLINEHeiko Schocher
do not define own flash_info variable, instead use the flash_info variable defined in your flash driver. Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-30IDE: fix compiler warningsWolfgang Denk
The changes introduced by commit 0abddf8 ``cmd_ide: enhance new feature "CONFIG_IDE_AHB"'' caused compiler warnings like cmd_ide.c: In function 'ide_init': cmd_ide.c:716: warning: assignment from incompatible pointer type Constify the respective function arguments to fix this. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-04-30common/cmd_mdio.c: fix compile warningAnatolij Gustschin
cmd_mdio.c: In function 'mdio_read_ranges': cmd_mdio.c:97: warning: comparison is always false due to limited range of data type Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Andy Fleming <afleming@freescale.com>
2011-04-30miiphy: miiphyutil.c: fix compile warningAnatolij Gustschin
Fix warning introduced while recent PHY Lib changes: miiphyutil.c: In function 'miiphy_read': miiphyutil.c:304: warning: comparison is always false due to limited range of data type Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Andy Fleming <afleming@freescale.com>
2011-04-30cmd_nvedit.c: clean up with checkpatchMacpaul Lin
Code clean up of cmd_nvedit.c by using checkpatch.pl. Signed-off-by: Macpaul Lin <macpaul@andestech.com> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-30cmd_ide: enhance new feature "CONFIG_IDE_AHB"Macpaul Lin
Although most IDE controller is designed to be connected to PCI bridge, there are still some IDE controller support AHB interface for SoC design. The driver implementation of these IDE-AHB controllers differ from other IDE-PCI controller, some additional registers and commands access is required during CMD/DATA I/O. Hence a configuration "CONFIG_IDE_AHB" in cmd_ide.c is required to be defined to support these kinds of SoC controllers. Such as Faraday's FTIDE020 series and Global Unichip's UINF-0301. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-04-29Merge branch 'master' of git://git.denx.de/u-boot-mmcWolfgang Denk
2011-04-29mmc_spi: add mmc_init callThomas Chou
As Andy Fleming suggested, we can call mmc_init() in mmc_spi command. So that we don't need to run mmcinfo command next. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2011-04-28i2c: add i2c deblock sequence before and after every mux configStefan Bigler
To make sure that the mux can be configured a deblocking sequence is done before the mux configuration. After the mux switch the new leaf of, the i2c tree must be again deblocked. Signed-off-by: Stefan Bigler <stefan.bigler@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-28common: add a grepenv commandKim Phillips
u-boot environments, esp. when boards are shared across multiple users, can get pretty large and time consuming to visually parse. The grepenv command this patch adds can be used in lieu of printenv to facilitate searching. grepenv works like printenv but limits its output only to environment strings (variable name and value pairs) that match the user specified substring. the following examples are on a board with a 5313 byte environment that spans multiple screen pages: Example 1: summarize ethernet configuration: => grepenv eth TSEC etact=FM1@DTSEC2 eth=FM1@DTSEC4 ethact=FM1@DTSEC2 eth1addr=00:E0:0C:00:8b:01 eth2addr=00:E0:0C:00:8b:02 eth3addr=00:E0:0C:00:8b:03 eth4addr=00:E0:0C:00:8b:04 eth5addr=00:E0:0C:00:8b:05 eth6addr=00:E0:0C:00:8b:06 eth7addr=00:E0:0C:00:8b:07 eth8addr=00:E0:0C:00:8b:08 eth9addr=00:E0:0C:00:8b:09 ethaddr=00:E0:0C:00:8b:00 netdev=eth0 uprcw=setenv ethact $eth;setenv filename p4080ds/R_PPSXX_0xe/rcw_0xe_2sgmii_rev2_high.bin;setenv start 0xe8000000;protect off all;run upimage;protect on all upuboot=setenv ethact $eth;setenv filename u-boot.bin;setenv start eff80000;protect off all;run upimage;protect on all upucode=setenv ethact $eth;setenv filename fsl_fman_ucode_P4080_101_6.bin;setenv start 0xef000000;protect off all;run upimage;protect on all usdboot=setenv ethact $eth;tftp 1000000 $dir/$bootfile;tftp 2000000 $dir/initramfs.cpio.gz.uboot;tftp c00000 $dir/p4080ds-usdpaa.dtb;setenv bootargs root=/dev/ram rw console=ttyS0,115200 $othbootargs;bootm 1000000 2000000 c00000; => Example 2: detect unused env vars: => grepenv etact etact=FM1@DTSEC2 => Example 3: reveal hardcoded variables; e.g., for fdtaddr: => grepenv fdtaddr fdtaddr=c00000 nfsboot=setenv bootargs root=/dev/nfs rw nfsroot=$serverip:$rootpath ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off console=$consoledev,$baudrate $othbootargs;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr - $fdtaddr ramboot=setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr => grep $fdtaddr fdtaddr=c00000 my_boot=bootm 0x40000000 0x41000000 0x00c00000 my_dtb=tftp 0x00c00000 $prefix/p4080ds.dtb nohvboot=tftp 1000000 $dir/$bootfile;tftp 2000000 $dir/$ramdiskfile;tftp c00000 $dir/$fdtfile;setenv bootargs root=/dev/ram rw ramdisk_size=0x10000000 console=ttyS0,115200;bootm 1000000 2000000 c00000; => This patch also enables the grepenv command by default on corenet_ds based boards (and repositions the DHCP command entry to keep the list sorted). Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Kumar Gala <kumar.gala@freescale.com> Cc: Andy Fleming <afleming@freescale.com>
2011-04-28fix redundant environment for serial flashthomas.langer@lantiq.com
This patch fixes problems in the handling of redundant environment in env_sf.c The major problem are double calls of free() on the allocated buffers, which damages the internal data of malloc and crashes on next call. In addition, the selection of the active environment had errors and compiler warnings, which are corrected by this patch. Signed-off-by: Thomas Langer <thomas.langer@lantiq.com>
2011-04-27Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
