README
Added support to disable the start of application by using
a environment variable autostart
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
This fixes a regression of e310b93ec1, affecting Ethernet on the Jetson
TK1, e.g.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
This commit introduces new config: CONFIG_SYS_MALLOC_CLEAR_ON_INIT.
This config is an expert option and is enabled by default.
The all amount of memory reserved for the malloc, is by default set
to zero in mem_malloc_init(). When the malloc reserved memory exceeds
few MiB, then the boot process can slow down.
So disabling this config, is an expert option to reduce the boot time,
and can be disabled by Kconfig.
Note:
After disable this option, only calloc() will return the pointer
to the zeroed memory area. Previously, without this option,
the memory pointed to untouched malloc memory region, was filled
with zeros. So it means, that code with malloc() calls should
be reexamined.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Currently the usage text for the 'ums' command looks like this:
Usage:
ums ums <USB_controller> [<devtype>] <devnum> e.g. ums 0 mmc 0
,so remove the extra 'ums' in the text.
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
In case of global data structure defined as "register volatile" compiler
throws an warning about incorrect type used:
--->8---
common/board_f.c: In function "board_init_f_r":
common/board_f.c:1073:2: warning: passing argument 1 of "&board_init_r
+(sizetype)gd->reloc_off" discards "volatile" qualifier from pointer
target type [enabled by default]
(board_init_r + gd->reloc_off)(gd, gd->relocaddr);
common/board_f.c:1073:2: note: expected "struct gd_t *" but argument is
of type "volatile struct gd_t *"
--->8---
An obvious fix is manual casting to "gd_t *".
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Tom Rini <trini@ti.com>
running "spl export ..." more than once fails with:
Trying to execute a command out of order
ERROR prep subcommand failed!
Subcommand failed
reason is commmit:
35fc84fa1f: Refactor the bootm command to reduce code duplication
It used "state != BOOTM_STATE_START" but state is a bitfield, so
check if the bit BOOTM_STATE_START is not set. With this fix,
"spl export ..." can called more than once ...
This patch adds generic board support for MCF547X/8X and MCF5445X.
It is based on the patch about common generic board support for
M68K architecture sent by Angelo.
Signed-off-by: Alison Wang <alison.wang@freescale.com>
Add generic-board support for the m68k architecture.
Signed-off-by: Angelo Dureghello <angelo@sysam.it>
Remove duplicate command names in usage messages to fix issues such as:
=> help yls
yls - yaffs ls
Usage:
yls yls [-l] dirname
Sometimes we do not want redirect u-boot's console to screen but anyway we want
write out some status information out of a u-boot script to the display.
So we cannot use the normal "echo ....", instead we write explicitly using
"lcdputs ..." for writing to the actual cursor position on LCD.
Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
To define the specific position of the string to be written, we have to set
the cursor with "setcurs" before writing.
Currently, an environment variable must be used to store the randomly
generated UUID for each partition. This is not necessary, so make storing
the UUID optional. Now passing uuid_disk and uuid are optional when random
UUIDs are enabled.
Signed-off-by: Rob Herring <robh@kernel.org>
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
The gpt command always reports success even if writing the partition table
failed. Propagate the return value of gpt_restore so we get proper status
reported.
Reviewed-by: Przemyslaw Marczak <p.marczak@samsung.com>
Fix the name appearing in menuconfig for memtest command
Signed-off-by: Nikolaos Pasaloukos <Nikolaos.Pasaloukos@imgtec.com>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com
At present SPL uses a single stack, either CONFIG_SPL_STACK or
CONFIG_SYS_INIT_SP_ADDR. Since some SPL features (such as MMC and
environment) require a lot of stack, some boards set CONFIG_SPL_STACK to
point into SDRAM. They then set up SDRAM very early, before board_init_f(),
so that the larger stack can be used.
This is an abuse of lowlevel_init(). That function should only be used for
essential start-up code which cannot be delayed. An example of a valid use is
when only part of the SPL code is visible/executable, and the SoC must be set
up so that board_init_f() can be reached. It should not be used for SDRAM
init, console init, etc.
Add a CONFIG_SPL_STACK_R option, which allows the stack to be moved to a new
address before board_init_r() is called in SPL.
The expected SPL flow (for CONFIG_SPL_FRAMEWORK) is documented in the README.
For version 1:
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Tested-by: Bo Shen <voice.shen@atmel.com>
Acked-by: Bo Shen <voice.shen@atmel.com>
Acked-by: Heiko Schocher <hs@denx.de>
Tested-by: Heiko Schocher <hs@denx.de>
Some systems have so much RAM that the end of RAM is beyond 4GB. An
example would be a Tegra124 system (where RAM starts at 2GB physical)
that has more than 2GB of RAM.
In this case, we can gd->ram_size to represent the actual RAM size, so
that the actual RAM size is passed to the OS. This is useful if the OS
implements LPAE, and can actually use the "extra" RAM.
However, U-Boot does not implement LPAE and so must deal with 32-bit
physical addresses. To this end, we enhance board_get_usable_ram_top() to
detect the "over-sized" case, and limit the relocation addres so that it
fits into 32-bits of physical address space.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Currently only normal hashing is supported using hardware acceleration.
Added support for progressive hashing using hardware.
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com>
CC: Simon Glass <sjg@chromium.org>
Reviewed-by: York Sun <yorksun@freescale.com>
This patch does the following:
1. The function names for encapsulation and decapsulation
were inconsitent in freescale's implementation and cmd_blob file.
This patch corrects the issues.
2. The function protopye is also modified to change the length parameter
from u8 to u32 to allow encapsulation and decapsulation of larger images.
3. Modified the description of km paramter in the command usage for better
readability.
Reviewed-by: Ruchika Gupta <ruchika.gupta@freescale.com>
If the string is copied without NULL termination using strncpy(),
then strncat() on the next line, may concatenate the string after
some stale (or random) data, if the response string was not
zero-initialized.
Signed-off-by: Dileep Katta <dileep.katta@linaro.org>
Reviewed-by: Steve Rae <srae@broadcom.com>
Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
Add a check for USB cable attached and only enter fastboot when a cable
is attached.
Adds the fastboot erase functionality, to erase a partition
specified by name. The erase is performed based on erase group size,
to avoid erasing other partitions. The start address and the size
is aligned to the erase group size for this.
Currently only supports erasing from eMMC.
Now CONFIG_SPL_BUILD is not defined in Kconfig, so
"!depends on SPL_BUILD" and "if !SPL_BUILD" are redundant.
The SD/MMC version scheme was buggy when dealing with standard
major.minor.change cases. Fix it by using something similar to
the linux's kernel versioning method.
Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
Tested-by: Jaehoon Chung <jh80.chung@samsung.com>
Reported-by: Stephen Warren <swarren@nvidia.com>
I2C chips do exist that require a write of some multi-byte data to occur in
a single bus transaction (aka atomic transfer), otherwise either the write
does not come into effect at all, or normal operation of internal circuitry
cannot be guaranteed. The current implementation of the 'i2c write' command
(transfer of multiple bytes from a memory buffer) in fact performs a separate
transaction for each byte to be written and thus cannot support such types of
I2C slave devices.
This patch provides an alternative by allowing 'i2c write' to execute the
write transfer of the given number of bytes in a single bus transaction if
the '-s' option is specified as a final command argument. Else the current
re-addressing method is used.
Signed-off-by: Lubomir Popov <l-popov@ti.com>
hs: adapt to CONFIG_DM_I2C
If the i2c driver returns an error status, error out immediately.
Continuing the loop just results in printing error messages
again and again.
If you want to inspect the control device tree using the fdt command,
the "fdt address -c" command previously unhelpfully printed the phys
memory address of the device tree. That address could not then be used
to set the fdt address for inspection. Changed the resulting print to
one that can be copied directly to the 'fdt address <addr>' command.
Commit 90bac29a76bc8d649b41a55f2786c0abef9bb2c1 claims to fix this bug
that was introduced in commit a92fd6577ea17751ead9b50243e3c562125cf581
but doesn't actually make the change that the commit message describes.
Actually fix the bug this time.
Introduce arch_reserve_stacks() to tailor gd->start_addr_sp and gd->irq_sp to
the architecture needs.
A SoC like the i.MX6 supports more then one i2c bus. In oder to be
able to use the eeprom command add a new define to specify the
i2c bus to use. If CONFIG_SYS_I2C_EEPROM_BUS is not defined there
is no functional change, else a call to i2c_set_bus_num(..) is
done before calling i2c_read(..) and i2c_write(..).
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
executing "tools/buildman/buildman mpc5xx" drops this warning:
common/spl/spl_nor.c: In function 'spl_nor_load_image':
common/spl/spl_nor.c:26:10: warning: assignment discards 'const' qualifier from pointer target type [enabled by default]
fix this.
Some boards have a special way of loading U-Boot that does not fit with
the existing SPL code. For example sunxi uses an 'FEL' mode where U-Boot
is loaded over USB. Add a CONFIG option and boot mode for this.
Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
Acked-by: Hans de Goede <hdegoede@redhat.com>
Use fdt_for_each_subnode macro to simplify the code a bit.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Add Kconfig settings for these two options.
Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
As with i2c_read() and i2c_write(), add a dm_ prefix to the driver model
versions of these functions to avoid conflicts.
At present on some architectures we set up the following before calling
board_init_f():
- global_data
- stack
- early malloc memory
Adding the code to support early malloc and global data setup to every
arch's assembler start-up is a pain. Also this code is not actually
architecture-specific. We can use common code for all architectures and
with a bit of care we can write this code in C.
Add a new function to deal with this. It should be called after memory
is available, with a pointer to the top of the area that should be used
before relocation. The function will set things up and return the lowest
memory address that it allocated/used. That can then be set as the top
of the stack.
Note that on some archs this function will use the stack, so the stack
pointer should be set to same value as is pased to board_init_f_mem().
A margin of 128 bytes will be left for this stack, so that it is not
overwritten. This means that 64 bytes is wasted by this early call.
This is not strictly necessary on several more modern archs, so we could
remove this at the cost of some arch-dependent code.
With this function there is no-longer any need for the assembler code to
zero global_data or set up the early malloc pointers.
All callers of malloc should already do error checking, and may even be able
to continue without the alloc succeeding.
Moreover, common/malloc_simple.c is the only user of .rodata.str1.1 in
common/built-in.o when building the SPL, triggering this gcc bug:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=54303
Causing .rodata to grow with e.g. 0xc21 bytes, nullifying all benefits of
using malloc_simple in the first place.
Segfaults can occur when a mandatory argument is not provided to
"demo hello" and "demo status". Eg:
=> demo hello
Segmentation fault (core dumped)
Add a check to ensure all required arguments are provided.
include/splash.h
