path: root/common
2012-01-05env: factor out the env_get_char_spec() functionIgor Grinberg
env_get_char_spec() function is duplicated across multiple environment files. Remove the duplication by providing a default implementation. Add "weak" declaration, so the default implementation can be overridden. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-05FPGA: use debug() instead of module debug printfStefano Babic
Replace also __FUNCTION__ with standard __func__ Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-12-23Merge branch 'next' of ../nextWolfgang Denk
* 'next' of ../next: mkenvimage: Add version info switch (-V) mkenvimage: Fix getopt() error handling mkenvimage: Fix some typos phy: add Micrel KS8721BL phy definition net: introduce per device index mvgbe: remove setting of ethaddr within the driver x86: Add support for specifying an initrd with the zboot command x86: Refactor the zboot innards so they can be reused with a vboot image x86: Add infrastructure to extract an e820 table from the coreboot tables x86: Add support for booting Linux using the 32 bit boot protocol x86: Clean up the x86 zimage code in preparation to extend it x86: Import code from coreboot's libpayload to parse the coreboot table x86: Initial commit for running as a coreboot payload CHECKPATCH: ./board/esd/hh405/logo_320_240_8bpp.c CHECKPATCH: ./board/esd/hh405/logo_1024_768_8bpp.c CHECKPATCH: ./board/esd/hh405/logo_320_240_4bpp.c CHECKPATCH: ./board/esd/hh405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/apc405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/voh405/logo_320_240_4bpp.c CHECKPATCH: ./board/esd/voh405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/hh405/fpgadata.c CHECKPATCH: ./board/esd/pci405/fpgadata.c CHECKPATCH: ./board/esd/tasreg/fpgadata.c CHECKPATCH: ./board/esd/apc405/fpgadata.c CHECKPATCH: ./board/esd/voh405/fpgadata.c CHECKPATCH: ./board/esd/ash405/fpgadata.c CHECKPATCH: ./board/esd/dasa_sim/fpgadata.c CHECKPATCH: ./board/esd/ar405/fpgadata_xl30.c CHECKPATCH: ./board/esd/ar405/fpgadata.c CHECKPATCH: ./board/esd/plu405/fpgadata.c CHECKPATCH: ./board/esd/wuh405/fpgadata.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405ab.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci4052.c CHECKPATCH: ./board/esd/canbt/fpgadata.c CHECKPATCH: ./board/esd/du405/fpgadata.c CHECKPATCH: ./board/esd/cpciiser4/fpgadata.c CHECKPATCH: ./board/dave/PPChameleonEVB/fpgadata.c avr32:mmu.c: fix printf() length modifier fat.c: fix printf() length modifier cmd_sf.c: fix printf() length modifier Make printf and vprintf safe from buffer overruns vsprintf: Move function documentation into header file Add safe vsnprintf and snprintf library functions Move vsprintf functions into their own header Conflicts: tools/mkenvimage.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-20Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
* 'master' of /home/wd/git/u-boot/custodians: common/cmd_pxe.c: Fix GCC 4.6 build warnings AVR32: fix timer_init() function
2011-12-20net: Fix arguments in tftpput commandSimon Glass
The switch to strict_strtoul() was not done correctly - this fixes the compile error when CONFIG_CMD_TFTPPUT is active. There appears to very little use of strict_strtoul() in commands, so it might be easier to switch to simple_strtoul(). If not, we should decide the best way to use strict_strtoul(). For now I have added a friendly message which will of course increase code size. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-12-20common/cmd_pxe.c: Fix GCC 4.6 build warningsHeiko Schocher
Fix: cmd_pxe.c: In function 'parse_pxefile_top': cmd_pxe.c:941:5: warning: 'err' may be used uninitialized in this function [-Wuninitialized] cmd_pxe.c:921:6: note: 'err' was declared here Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Jason Hobbs <jason.hobbs@calxeda.com> Acked-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-12-19common/cmd_nvedit.c: Fix size calculation in do_env_import()Horst Kronstorfer
do_env_import() missed the final '\0' terminator when calculating the size of an environment data block. This led to an erroneous 'bad CRC, import failed' message for a checksum protected environment (-c.) Signed-off-by: Horst Kronstorfer <hkronsto@frequentis.com>
2011-12-17cmd_sf.c: fix printf() length modifierAndreas Bießmann
size_t is not always 'unsigned int', use corret length modifer. This patch fixes following warning: ---8<--- cmd_sf.c: In function 'spi_flash_update_block': cmd_sf.c:130: warning: format '%#x' expects type 'unsigend int', but argument 4 has type 'size_t' cmd_sf.c:135: warning: format '%x' expects type 'unsigned int', but argument 3 has type 'size_t' --->8--- Signed-off-by: Andreas Bießmann <biessmann@corscience.de> cc: Mike Frysinger <vapier@gentoo.org> cc: Thomas Chou <thomas@wytron.com.tw> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-12-17Make printf and vprintf safe from buffer overrunsSonny Rao
From: Sonny Rao <sonnyrao@chromium.org> utilize the added vscnprintf functions to avoid buffer overruns The implementation is fairly dumb in that it doesn't detect that the buffer is too small, but at least will not cause crashes. Signed-off-by: Sonny Rao <sonnyrao@chromium.org>
2011-12-16USB: Use (get|put)_unaligned for accessing wMaxPacketSizeTom Rini
In 9792987721c7980453fe6447c3fa6593b44f8458 Stefan describes a usecase where the previous behavior of leaving wMaxPacketSize be unaligned caused fatal problems. The initial fix for this problem was incomplete however as it showed another cases of non-aligned access that previously worked implicitly. This switches to making sure that all access of wMaxPacketSize are done via (get|put)_unaligned. In order to maintain a level of readability to the code in some cases we now use a variable for the value of wMaxPacketSize and in others, a macro. Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Remy Bohmer <linux@bohmer.net> OpenRISC: Tested-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Beagleboard xM, Pandaboard run-tested, s5p_goni build-tested. Signed-off-by: Tom Rini <trini@ti.com>
2011-12-12common/cmd_nvedit.c: Add missing 'env save' preproc guardHorst Kronstorfer
2011-12-12powerpc/bootm: Flush ramdisk and device tree image when booting on MPKumar Gala
We already flush the kernel image after we've loaded it to ensure visiblity to the other cores. We need to do the same thing for the ramdisk and device tree images. In AMP boot scenarios we might not be HW cache coherent with the secondary core that we are loading and setting the ramdisk and device tree up for. Thus we need to ensure we've flushed the regions of memory utilized by ramdisk and device tree so the loadding and any modifications (from decompression or fdt updates) are made visible to the secondary cores. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-12-12Merge branch 'master' of git://git.denx.de/u-boot-usbWolfgang Denk
* 'master' of git://git.denx.de/u-boot-usb: USB: efikamx: Enable USB on EfikaMX and EfikaSB USB: Add generic ULPI layer and a viewport USB: EHCI: Allow EHCI post-powerup configuration in board files USB: mx51evk: add end enable USB host support on port 1 USB: mx53loco: add end enable USB host support on port 1 USB: MX5: Add MX5 usb post-init callback USB: MX5: Abstract out mx51 USB pixmux configuration USB: MX5: add generic USB EHCI support for mx51 and mx53 USB: MX5: add helper functions to enable USB clocks usb:gadget:s5p Enable the USB Gadget framework at GONI usb:gadget:s5p USB Device Controller (UDC) implementation ehci: speed up initialization usb: add help for missing start subcommand cosmetic: remove excess whitespace from usb command help usb: align usb_endpoint_descriptor to 16-bit boundary usbtty: init endpoints prior to startup events pxa: convert pxa27x_udc to use read and write functions pxa: activate the first usb host port on pxa27x by default pxa: fix usb host register mismatch ehci-fsl: correct size of ehci caplength USB: Add usb_event_poll() to get keyboards working with EHCI USB: gadaget: add Marvell controller support USB: Fix complaints about strict aliasing in OHCI-HCD USB: Drop dead code from usb_kbd.c USB: Rework usb_kbd.c USB: Add functionality to poll the USB keyboard via control EP
2011-12-11usb: add help for missing start subcommandVeli-Pekka Peltola
Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com> Cc: Remy Bohmer <linux@bohmer.net>
2011-12-11cosmetic: remove excess whitespace from usb command helpVeli-Pekka Peltola
2011-12-11USB: Drop dead code from usb_kbd.cMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Remy Bohmer <linux@bohmer.net> Cc: Wolfgang Denk <wd@denx.de>
2011-12-11USB: Rework usb_kbd.cMarek Vasut
* Support dynamic allocation of devices * Passing data via usb device privptr * Reorder functions to avoid forward declarations * Introduce generic polling mechanism to fix musb and ehci-hcd breakage due to using "extern new;" to access keyboard driver data! Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Remy Bohmer <linux@bohmer.net> Cc: Wolfgang Denk <wd@denx.de>
2011-12-11USB: Add functionality to poll the USB keyboard via control EPMarek Vasut
This allows the keyboard to avoid requests via Interrupt Endpoint altogether and run all requests via Control Endpoint. This uses the Get_Report request. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Remy Bohmer <linux@bohmer.net> Rebased on current code. Signed-off-by: Remy Bohmer <linux@bohmer.net>
2011-12-10sandbox: Add improved RAM simulationMatthias Weisser
Using mmap to allocate memory from the OS for RAM simulation we can use u-boot own malloc implementation. Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Matthias Weisser <weisserm@arcor.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-12-09Add board_pre_console_putc to deal with early console outputSimon Glass
This patch adds support for console output before the console is inited. The main purpose of this is to deal with a very early panic() which would otherwise cause a silent hang. A new board_pre_console_putc() function is added to the board API. If provided by the board it will be called in the event of console output before the console is ready. This function should turn on all UARTs and spray the character out if it possibly can. The feature is controlled by a new CONFIG_PRE_CONSOLE_PUTC option. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Graeme Russ <graeme.russ@gmail.com>
2011-12-09common/usb_kbd.c: fix bug introduced in commit 00b7d6eWolfgang Denk
During the rebase of commit 00b7d6e "USB: Squash checkpatch warnings in usb_kbd.c" I missed a brace, resulting in a number of build errors. Fix these. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-09USB: Squash checkpatch warnings in usb_kbd.cMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Remy Bohmer <linux@bohmer.net> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Rebased to current code. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-07Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: davinci: Remove unwanted memsize.c from hawkboard's nand spl build devkit8000: Move CONFIG_SYS_TEXT_BASE out of bss da850evm: pass board revision info to kernel arch/arm/include/asm/arch-omap5/clocks.h: Fix GCC 4.2 warnings arch/arm/cpu/armv7/omap-common/clocks-common.c: Fix GCC 4.6 warnings arch/arm/cpu/armv7/omap-common/spl.c: Fix GCC 4.2 warnings MX35: flea3: changes due to hardware revision B MX: serial_mxc: cleanup removing nasty #ifdef M28: Fix OB1 bug in GPIO driver MXS: Add static annotations to dma driver apbh_dma: return error value on timeout Efika: Configure additional regulators for HDMI output mx5: Correct a warning in clock.c MC13892: Add REGMODE0 bits definitions mx51evk: Configure the pins as GPIOs prior to using gpio_get_value mx53smd: Configure the pins as GPIOs prior to using gpio_get_value mx53evk: Configure the pins as GPIOs prior to using gpio_get_value mx53ard: Configure the pins as GPIOs prior to using gpio_get_value mx53loco: Configure the pins as GPIOs prior to using gpio_get_value OMAP3: Add SPL_BOARD_INIT hook AM3517 CraneBoard: Add SPL support AM3517: Add SPL support OMAP3: Add SPL support to omap3_evm OMAP3: Add SPL support to Beagleboard OMAP3 SPL: Add identify_nand_chip function OMAP3 SPL: Rework memory initalization and devkit8000 support OMAP3: Suffix all Micron memory timing parts with their speed OMAP3: Add optimal SDRC autorefresh control values omap3: mem: Add MCFG helper macro OMAP3: Remove get_mem_type prototype OMAP3: Change mem_ok to clear again after reading back OMAP3: Add a helper function to set timings in SDRC OMAP3: Update SDRC dram_init to always call make_cs1_contiguous() omap3: mem: Comment enable_gpmc_cs_config more ARM: davici_emac: Fix condition for number of phy detects arm: printf() is not available in some SPL configurations arm, davinci: add support for am1808 based enbw_cmc board arm, davinci: move misc function in arch tree arm, board/davinci/common/misc.c: Codingstyle cleanup arm, davinci, da850: add uart1 tx rx pinmux config arm, davinci: move davinci_rtc struct to hardware.h arm, davinci: Remove duplication of pinmux configuration code arm, hawkboard: Use the pinmux configurations defined in the arch tree arm, da850evm: Use the pinmux configurations defined in the arch tree arm, da850: Add pinmux configurations to the arch tree arm, da850evm: Do pinmux configuration for EMAC together with other pinmuxes arm, hawkboard: Remove obsolete struct pinmux_config i2c_pins arm, davinci: Move pinmux functions from board to arch tree arm, arm926ejs: always do cpu critical inits omap_gpmc: use SOFTECC in SPL if it's enabled nand_spl_simple: add support for software ECC AM3517: move AM3517 specific mux defines to generic header AM35xx: add EMAC support davinci_emac: hardcode 100Mbps for AM35xx and RMII davinci_emac: fix for running with dcache enabled arm926ejs: add noop implementation for dcache ops davinci_emac: conditionally compile specific PHY support davinci_emac: use internal addresses in buffer descriptors davinci_emac: move arch-independent defines to separate header BeagleBoard: config: Really switch to ttyO2 ARM: davinci_dm6467Tevm: Fix build breakage ARM: OMAP: Remove STACKSIZE for IRQ and FIQ if unused ARM: OMAP3: Remove unused define SDRC_R_C_B ARM: OMAP3: Remove unused define CONFIG_OMAP3430 omap4: fix IO setting omap4+: streamline CONFIG_SYS_TEXT_BASE and other SDRAM addresses omap4460: add ES1.1 identification omap4: emif: fix error in driver omap: remove I2C from SPL omap4460: fix TPS initialization omap: fix cache line size for omap3/omap4 boards omap4: ttyO2 instead of ttyS2 in default bootargs omap: Improve PLL parameter calculation tool start.S: remove omap3 specific code from start.S armv7: setup vector armv7: include armv7/cpu.c in SPL build armv7: disable L2 cache in cleanup_before_linux() arm, arm926ejs: Fix clear bss loop for zero length bss PXA: Move colibri_pxa270 to board/toradex/ PXA: Flip colibri_pxa27x to pxa-common.h PXA: Introduce common configuration header for PXA PXA: Rename pxa_dram_init to pxa2xx_dram_init PXA: Squash extern pxa_dram_init() PXA: Export cpu_is_ and pxa_dram_init functions PXA: Cleanup Colibri PXA270 PXA: Replace timer driver PXA: Add cpuinfo display for PXA2xx PXA: Separate PXA2xx CPU init PXA: Rename CONFIG_PXA2[57]X to CONFIG_CPU_PXA2[57]X PXA: Unify vpac270 environment size PXA: Enable command line editing for vpac270 PXA: Adapt Voipac PXA270 to OneNAND SPL PXA: Drop Voipac PXA270 OneNAND IPL PXA: Fixup PXA25x boards after start.S update PXA: Re-add the Dcache locking as RAM for pxa250 PXA: Rework start.S to be closer to other ARMs PXA: Drop XM250 board PXA: Drop PLEB2 board PXA: Drop CRADLE board PXA: Drop CERF250 board Fix regression in SMDK6400 nand: Add common functions to linux/mtd/nand.h Ethernut 5 board support net: Armada100: Fix compilation warnings ARM: remove duplicated code for LaCie boards ARM: add support for LaCie 2Big Network v2 mvsata: fix ide_preinit for missing disks netspace_v2: Read Ethernet MAC address from EEPROM omap3evm: Add support for EFI partitions part_efi: Fix compile errors
2011-12-07Fix unused function in cmd_bdinfo.cSimon Glass
It is fine to use __maybe_unused instead of #ifdef, but we also need one for print_eth() since not all boards have Ethernet. This fixes this warning: cmd_bdinfo.c:39:13: warning: 'print_eth' defined but not used [-Wunused-function] Signed-off-by: Simon Glass <sjg@chromium.org>
2011-12-07Fix SPI build errors in exports.cSimon Glass
The spi.h include is no longer included in exports.h, so must be included here. This fixes these errors: In file included from exports.c:41:0: /home/sjg/trunk/src/third_party/u-boot/files/include/_exports.h: In function 'jumptable_init': /home/sjg/trunk/src/third_party/u-boot/files/include/_exports.h:27:1: error: 'spi_init' undeclared (first use in this function) /home/sjg/trunk/src/third_party/u-boot/files/include/_exports.h:27:1: note: each undeclared identifier is reported only once for each function it appears in /home/sjg/trunk/src/third_party/u-boot/files/include/_exports.h:28:1: error: 'spi_setup_slave' undeclared (first use in this function) /home/sjg/trunk/src/third_party/u-boot/files/include/_exports.h:29:1: error: 'spi_free_slave' undeclared (first use in this function) /home/sjg/trunk/src/third_party/u-boot/files/include/_exports.h:30:1: error: 'spi_claim_bus' undeclared (first use in this function) /home/sjg/trunk/src/third_party/u-boot/files/include/_exports.h:31:1: error: 'spi_release_bus' undeclared (first use in this function) /home/sjg/trunk/src/third_party/u-boot/files/include/_exports.h:32:1: error: 'spi_xfer' undeclared (first use in this function) Signed-off-by: Simon Glass <sjg@chromium.org>
2011-12-07Revert "mii: miiphy register address width change"Wolfgang Denk
This reverts commit 5c45a22b9203351a32aec4600514341b91175542. It causes a lot of "incompatible pointer type" warnings for a large number of Ethernet drivers, which are not really worth fixing especially as this patch was only supposed to help the old, deprecated miiphy API. Instead of adding more efforts to a lost case we rather revert it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-06PXA: Rename CONFIG_PXA2[57]X to CONFIG_CPU_PXA2[57]XMarek Vasut
2011-12-06Add a cli command to test the TPM device.Vadim Bendebury
The command gets an arbitrary number of arguments (up to 30), which are interpreted as byte values and are feed into the TPM device after proper initialization. Then the return value and data of the TPM driver is examined. TPM commands are described in the TCG specification. For instance, the following sequence is the 'TPM Startup' command, it is processed by the TPM and a response is generated: boot > tpm 0x0 0xc1 0x0 0x0 0x0 0xc 0x0 0x0 0x0 0x99 0x0 0x1 Found TPM SLB9635 TT 1.2 by Infineon Got TPM response: 00 c4 00 00 00 0a 00 00 00 00 If the command is corrupted (fed one byte short), an error is reported: boot > tpm 0x0 0xc1 0x0 0x0 0x0 0xc 0x0 0x0 0x0 0x99 0x0 generic_lpc_tpm.c:311 unexpected TPM status 0xff000888 generic_lpc_tpm.c:516 failed sending data to TPM tpm command failed boot > Change-Id: I3f3c5bfec8b852e208c4e99ba37b0f2b875140b0 Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> CC: Wolfgang Denk <wd@denx.de>
2011-12-06pxe: make the first label the implicit defaultJason Hobbs
If no default label is specified, but a situation arises where the default label should be used, treat the first label specified as the default label. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com> Cc: Ricardo Salveti de Araujo <ricardo.salveti@linaro.org> Cc: Wolfgang Denk <wd@denx.de>
2011-12-06cmd_bdinfo: simplify local static funcs a bitMike Frysinger
If we move the local funcs to the top of the file, and use the __maybe_unused define, we can drop a lot of ugly ifdef logic and duplicated prototypes. Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-12-06mii: miiphy register address width changeChandan Nath
This patch is added for PHY whose register offset value exceeds 0xFF and cannot be used with "unsigned char" datatype in miiphy_read, miiphy_write and miiphy_register functions. Datatype of register offset is changed to unsigned short instead of unsigned char so that offset value greater then 0xFF can be used. Signed-off-by: Chandan Nath <chandan.nath@ti.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-12-06env_nand: Remove DEBUG definitionThomas Weber
Signed-off-by: Thomas Weber <weber@corscience.de>
2011-12-05common/menu.c: Fix build warningAnatolij Gustschin
Fix: menu.c: In function 'menu_item_print': menu.c:91: warning: passing argument 1 of 'putc' makes integer from pointer without a cast Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Heiko Schocher <hs@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-12-05serial: constify serial_assign()Gerlando Falauto
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-12-05serial: cosmetic checkpatch complianceGerlando Falauto
2011-12-05miiphy: Note that miiphy_* API is deprecatedAndy Fleming
We want to move everything to phylib, and we definitely don't want new drivers using the miiphy infrastructure. Signed-off-by: Andy Fleming <afleming@freescale.com>
2011-12-02Merge branch 'sr@denx.de' of git://git.denx.de/u-boot-stagingWolfgang Denk
* 'sr@denx.de' of git://git.denx.de/u-boot-staging: image: Don't detect XIP images as overlapping. image: Implement IH_TYPE_KERNEL_NOLOAD
2011-12-01image: Don't detect XIP images as overlapping.Stephen Warren
bootm_load_os() detects when it writes the decompressed image over the top of the compressed image. If this happens, the original image is corrupted. When the original image is a multi-component legacy image, or a (potentially multi-component) FIT image, this implies that other components may be corrupted. In turn, this means that booting is unlikely to be successful. However, in the case of no image compresssion coupled with an image with load address equal to where the image is already located (e.g. an XIP kernel, or IH_TYPE_KERNEL_ANYLOAD), there has been no copy and hence no corruption, no matter whether it's a single-component legacy image, a multi-component legacy image, or a FIT image. In this case, disable the overlap detection, and allow boot to continue. Without this change, when booting a single-component legacy image that contains an IH_TYPE_KERNEL_ANYLOAD, bootm_load_os() would have returned BOOTM_ERR_OVERLAP, but the caller ignores this, and boot continues and succeeds. Now, the false error is no longer even returned. Without this change, when booting a FIT image that contains an IH_TYPE_KERNEL_ANYLOAD, bootm_load_os() would have returned BOOTM_ERR_OVERLAP, which would then cause the caller to reset the board. Now, the false error is no longer returned, and boot succeeds. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Stefan Roese <sr@denx.de>
2011-12-01image: Implement IH_TYPE_KERNEL_NOLOADStephen Warren
The legacy uImage format includes an absolute load and entry-point address. When bootm operates on a kernel uImage in memory that isn't loaded at the address in the image's load address, U-Boot will copy the image to its address in the header. Some kernel images can actually be loaded and used at any arbitrary address. An example is an ARM Linux kernel zImage file. To represent this capability, IH_TYPE_KERNEL_NOLOAD is implemented, which operates just like IH_TYPE_KERNEL, except that the load address header is ignored, and U-Boot does not copy the image to its load address, but rather uses it in-place. This is useful when sharing a single (uImage-wrapped) zImage across multiple boards with different memory layouts; in this case, a specific load address need not be picked when creating the uImage, but instead is selected by the board-specific U-Boot environment used to load and boot that image. v2: Rename from IH_TYPE_KERNEL_ANYLOAD to IH_TYPE_KERNEL_NOLOAD. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Stefan Roese <sr@denx.de>
2011-11-29x86: Provide more configuration granularityGraeme Russ
Planned future ports requires more granularity for some options Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2011-11-28menu.c: use puts() instead of printf() where possibleWolfgang Denk
common/menu.c used printf() in a number of places to print user provided, constant strings (like the "title" string). printf() is dangerous here for example in case the user unwittingly embeds some '%' caracters that printf() would interpret as formatting and then pick up random arguments. Use puts() instead. We also omit the trailing ':' in the title line - if a user wants this, he can provide it as part of the title string. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-27cmd_nvedit.c: Fix compiler warning introduced by checkpatch cleanupKumar Gala
cmd_nvedit.c: In function 'do_env_grep': cmd_nvedit.c:182:3: warning: suggest parentheses around assignment used as truth value Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2011-11-23Merge branch 'hs@denx.de' of git://git.denx.de/u-boot-stagingWolfgang Denk
* 'hs@denx.de' of git://git.denx.de/u-boot-staging: drivers/net/dnet.c: Fix GCC 4.6 warnings board/xaeniax/flash.c: Fix GCC 4.6 warnings net/bootp.c: Fix GCC 4.6 warning common/cmd_bootm.c: Fix GCC 4.6 warnings board/mx1ads/mx1ads.c: Fix GCC 4.6 warning board/mx1ads/syncflash.c: Fix GCC 4.6 warnings board/lubbock/flash.c: Fix GCC 4.6 warnings drivers/net/cs8900.c: Fix GCC 4.6 warning arch/arm/cpu/arm926ejs/omap/cpuinfo.c: Fix GCC 4.6 warnings drivers/net/lan91c96.c: Fix GCC 4.6 warning board/ronetix/pm9263/pm9263.c: Fix GCC 4.6 warning drivers/mtd/onenand/samsung.c: Fix GCC 4.6 warning drivers/usb/musb/musb_hcd.c: Fix GCC 4.6 warning
2011-11-23common/cmd_bootm.c: Fix GCC 4.6 warningsAnatolij Gustschin
Fix: cmd_bootm.c: In function 'bootm_load_os': cmd_bootm.c:315:7: warning: unused variable 'unc_len' [-Wunused-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-22env: clean env_common.c checkpatch and code styleIgor Grinberg
Cleanup the env_common.c checkpatch warnings, errors and coding style. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-11-22env: clean env_nand.c checkpatch and code styleIgor Grinberg
Cleanup the env_nand.c checkpatch warnings, errors and coding style. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-11-22env: clean env_flash.c checkpatch and code styleIgor Grinberg
Cleanup the env_flash.c checkpatch warnings, errors and coding style. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-11-22env: clean env_sf.c checkpatch and code styleIgor Grinberg
Cleanup the env_sf.c checkpatch warnings, errors and coding style. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-11-22env: clean env_eeprom.c checkpatch and code styleIgor Grinberg
Cleanup the env_eeprom.c checkpatch warnings, errors and coding style. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-11-22env: clean env_embedded.c checkpatch and code styleIgor Grinberg
Cleanup the env_embedded.c checkpatch warnings, errors and coding style. There is one error left though: ERROR: Macros with multiple statements should be enclosed in a do - while loop #79: FILE: u-boot/common/env_embedded.c:79: +#define GEN_ABS(name, value) \ + asm(".globl " GEN_SYMNAME(name)); \ + GEN_SET_VALUE(name, value) total: 1 errors, 0 warnings, 213 lines checked We cannot enclose that statement in a do - while loop, because these are a global assembly declarations. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
