path: root/common
2008-11-02common/Makefile: create others group for non core, environment and command filesJean-Christophe PLAGNIOL-VILLARD
2008-11-02Consolidate MAX/MIN definitionsAndy Fleming
There were several, now there is one (two if you count the lower-case versions). Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-11-02Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-10-30fdt_resize(): ensure minimum paddingPeter Korsgaard
fdt_add_mem_rsv() requires space for a struct fdt_reserve_entry (16 bytes), so make sure that fdt_resize at least adds that much padding, no matter what the location or size of the fdt is. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Andy Fleming <afleming@freescale.com>
2008-10-29NAND: Align right column of the shorthelp with other commands.Scott Wood
I accidentally broke this in when making consistent the partial alignment of the longhelp. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-10-29bootm: Added CONFIG_BOOTM_{LINUX, NETBSD, RTEMS}Kumar Gala
Added the ability to config out bootm support for Linux, NetBSD, RTEMS Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-29bootm: Add subcommandsKumar Gala
Add the ability to break the steps of the bootm command into several subcommands: start, loados, ramdisk, fdt, bdt, cmdline, prep, go. This allows us to do things like manipulate device trees before they are passed to a booting kernel or setup memory for a secondary core in multicore situations. Not all OS types support all subcommands (currently only start, loados, ramdisk, fdt, and go are supported). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-29bootm: Move to using a function pointer table for the boot os functionKumar Gala
This removes a bit of code and makes it easier for the upcoming sub bootm command support to call into the proper OS specific handler. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-28Merge branch 'master' of git://git.denx.de/u-boot-videoWolfgang Denk
2008-10-27lcd: Let the board code show board-specific infoHaavard Skinnemoen
The information displayed when CONFIG_LCD_INFO is set is inherently board-specific, so it should be done by the board code. The current code dealing with this only handles two cases, and is already a horrible mess of #ifdeffery. Yes, this duplicates some code, but it also allows boards to print more board-specific information; this used to be very difficult. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-10-25lcd: Set lcd_is_enabled before clearing the screenHaavard Skinnemoen
This allows the logo/info rendering routines to use the regular lcd_putc/lcd_puts/lcd_printf calls. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-10-25lcd: Implement lcd_printf()Haavard Skinnemoen
lcd_printf() has a prototype in include/lcd.h but no implementation. Fix this by borrowing the lcd_printf() implementation from the cogent board code (which appears to use its own LCD framework.) Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-10-24fdt: Added helper to set PCI dma-ranges propertyKumar Gala
Added fdt_pci_dma_ranges() that parses the pci_region info from the struct pci_controller and populates the dma-ranges based on it. The max # of windws/dma-ranges we support is 3 since on embedded PowerPC based systems this is the max number of windows. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Fleming-AFLEMING <afleming@freescale.com>
2008-10-24fdt: Add fdt_getprop_u32_default helpersKumar Gala
Add helper functions to return find a node and return it's property or a default value. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Fleming-AFLEMING <afleming@freescale.com> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2008-10-21Merge git://git.denx.de/u-boot into x1Markus Klotzbuecher
Conflicts: drivers/usb/usb_ohci.c
2008-10-18Added arch_lmb_reserve to allow arch specific memory regions protectionKumar Gala
Each architecture has different ways of determine what regions of memory might not be valid to get overwritten when we boot. This provides a hook to allow them to reserve any regions they care about. Currently only ppc, m68k and sparc need/use this. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-18Expose command table search for sub-commandsKumar Gala
Sub-command can benefit from using the same table and search functions that top level commands have. Expose this functionality by refactoring find_cmd() and introducing find_cmd_tbl() that sub-command processing can call. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-18hush: add showvar command for hush shell.Heiko Schocher
This new command shows the local variables defined in the hush shell: => help showvar showvar - print values of all hushshell variables showvar name ... - print value of hushshell variable 'name' Also make the set_local_var() and unset_local_var () no longer static, so it is possible to define local hush shell variables at boot time. If CONFIG_HUSH_INIT_VAR is defined, u-boot calls hush_init_var (), where boardspecific code can define local hush shell variables at boottime. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-10-18I2C: adding new "i2c bus" Command to the I2C Subsystem.Heiko Schocher
With this Command it is possible to add new I2C Busses, which are behind 1 .. n I2C Muxes. Details see README. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-10-18I2C: add new command i2c reset.Heiko Schocher
If I2C Bus is blocked (see doc/I2C_Edge_Conditions), it is not possible to get out of this, until the complete Hardware gets a reset. This new commando calls again i2c_init (and that calls i2c_init_board if defined), which will deblock the I2C Bus. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-18CONFIG_EFI_PARTITION: Added support for EFI partition in cmd_ext2fs.crichardretanubun
Added support for CONFIG_EFI_PARTITION to ext2 commands. Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com>
2008-10-18FIT: output image load address for type 'firmware', fix message while thereBartlomiej Sieka
Now that the auto-update feature uses the 'firmware' type for updates, it is useful to inspect the load address of such images. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-10-18Automatic software update from TFTP serverBartlomiej Sieka
The auto-update feature allows to automatically download software updates from a TFTP server and store them in Flash memory during boot. Updates are contained in a FIT file and protected with SHA-1 checksum. More detailed description can be found in doc/README.update. Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-10-18flash: factor out adjusting of Flash address to the end of sectorBartlomiej Sieka
The upcoming automatic update feature needs the ability to adjust an address within Flash to the end of its respective sector. Factor out this functionality to a new function flash_sect_roundb(). Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-18Adds two more ethernet interface to 83xxrichardretanubun
Added as a convenience for other platforms that uses MPC8360 (has 8 UCC). Six eth interface is chosen because the platform I am using combines UCC1&2 and UCC3&4 as 1000 Eth and the other four UCCs as 10/100 Eth. Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-14cmd_i2c: Fix help for CONFIG_I2C_CMD_TREE && !CONFIG_I2C_MULTI_BUSPeter Tyser
Original code displayed: => help i2c i2c i2c speed [speed] - show or set I2C bus speed i2c md chip address[.0, .1, .2] [# of objects] - read from I2C device ... Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-10-14fix USB initialisation procedureRemy Bohmer
The max packet size is encoded as 0,1,2,3 for 8,16,32,64 bytes. At some places directly 8,16,32,64 was used instead of the encoded value. Made a enum for the options to make this more clear and to help preventing similar errors in the future. After fixing this bug it became clear that another bug existed where the 'pipe' is and-ed with PIPE_* flags, where it should have been 'usb_pipetype(pipe)', or even better usb_pipeint(pipe). Also removed the triple 'get_device_descriptor' sequence, it has no use, and Windows nor Linux behaves that way. There is also a poll going on with a timeout when usb_control_msg() fails. However, the poll is useless, because the flag will never be set on a error, because there is no code that runs in a parallel that can set this flag. Changed this to something more logical. Tested on AT91SAM9261ek and compared the flow on the USB bus to what Linux is doing. There is no difference anymore in the early initialisation sequence. Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2008-10-14cmd_spi: remove broken signed casting for displayMike Frysinger
Since we're working with unsigned data, you can't apply a signed pointer cast and then attempt to print the result. Otherwise you get wrong output when the sign bit is set like "0xFF" incorrectly extended to "0xFFFFFFFF". Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-14strings cmd: drop old CONFIG_CFG_STRINGS defineMike Frysinger
We don't need CONFIG_CFG_STRINGS anymore now that we have the define CONFIG_CMD_STRINGS and Makefile control. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-13Fix lzma uncompress call (image_start wrongly used instead image_len)Luigi 'Comio' Mantellini
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com>
2008-09-17USB layer of U-Boot causes USB protocol errors while using USB memory sticksRemy Bohmer
There are several differences between Linux, Windows and U-boot for initialising the USB devices. While analysing the behaviour of U-boot it turned out that U-boot does things really different, and some are wrong (compared to the USB standard). This patch fixes some errors: * The NEW_init procedure that was already in the code is good, while the old procedure is wrong. See code comments for more info. * On a Control request the data returned by the device can be more than 8 bytes, while the host limits it to 8 bytes. This caused the host to generate a DataOverrun error. This results in a lot of USB sticks not being recognised, and the transmission ended frequently with a CTL:TIMEOUT Error. * Added a flag CONFIG_LEGACY_USB_INIT_SEQ to allow users to use the old init procedure. Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2008-09-17Refactoring parts of the common USB OHCI codeRemy Bohmer
This patch refactors some large routines of the USB OHCI code by making some routines smaller and more readable which helps debugging and understanding the code. (Makes the code looks somewhat more like the Linux implementation.) Also made entire file compliant to Linux Coding Rules (checkpatch.pl compliant) Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2008-09-17Fix for USB sticks not working on ARM while using GCC 4.x compilersRemy Bohmer
The GCC-compiler makes an optimisation error while optimising the routine usb_set_maxpacket(). This should be fixed in the compiler in the first place, but there lots of compilers out there that makes this error, that it is probably wiser to workaround it in U-boot itself. What happens is that the register r3 is used as loop-counter 'i', but gets overwritten later on. From there it starts using register r3 for several other things and the assembler code is becoming a big mess. This is clearly a compiler bug. This error occurs on at least several versions of Code Sourcery Lite compilers for ARM. Like the Edition 2008q1, and 2008q3, It has also been seen on other compilers, while compiling for armv4t, or armv5te with Os, O1 and O2. We work around it by splitting up this routine in 2 parts, and making sure that the split out part is NOT inlined any longer. This will make GCC spit out assembler that do not show this problem. Another possibility is to adapt the Makefile to stop optimisation for the complete file. I think this solution is nicer. Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2008-09-13powerpc: Fix bootm to boot up again with a RamdiskHeiko Schocher
Commit 2a1a2cb6 didnt remove the dummy mem reservation in fdt_chosen, and this stopped Linux from booting with a Ramdisk. This patch fixes this, by deleting the useless dummy mem reservation. When booting with a Ramdisk, a fix offset FDT_RAMDISK_OVERHEAD is now added to of_size, so we dont need anymore a dummy mem reservation. I measured the value of FDT_RAMDISK_OVERHEAD on a MPC8270 based system (=0x44 bytes) and rounded it up to 0x80). Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-13Add support for LZMA uncompression algorithm.Luigi 'Comio' Mantellini
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-10nvedit: rename error comment to CONFIG_ENV_IS_IN_Jean-Christophe PLAGNIOL-VILLARD
2008-09-10cmd_mem: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10move cmd_get_data_size to command.cJean-Christophe PLAGNIOL-VILLARD
add CMD_DATA_SIZE macro to enable it Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-10env_flash: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10env_nowhere: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2008-09-10env_sf: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_SPI_FLASH in CONFIG_ENV_IS_IN_SPI_FLASHJean-Christophe PLAGNIOL-VILLARD
2008-09-10env_onenand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_ONENAND in CONFIG_ENV_IS_IN_ONENANDJean-Christophe PLAGNIOL-VILLARD
2008-09-10env_nvram: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
