If the bmp pointer is null then U-Boot will get stuck when trying
to load the image.
What's worse, it will get stuck before the U-Boot shell becomes
available to the user, thus making it difficult to correct the
situation.
To protect from the above scenario, check if the pointer is valid.
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
After further investigation this change is not correct and results in
get_ram_size returning incorrectly large values. Reported first by
Gerlando Falauto.
This reverts commit b8496cced856ff411f1eb2e4eff20f5abe7080b0.
usb_hub_descriptor has to be packed as it's used for
communication with the device. Member wHubCharacteristics
violates the natural alignment rules.
Use explicit unaligned access functions for this member.
Fixes ARMv7 traping while using USB.
v2: fix typo found by Thomas Langer
v3: rebased on top of u-boot-usb/master
Signed-off-by: Lucas Stach <dev@lynxeye.de>
Update Makefile change for LIBS -> LIBS-y change.
Makefile
Change the syntax (user API) for "env default":
-f: override write-once variables
var... : accept individual variable(s)
-a: all (resetting the whole env is NOT the default behavior)
Enable variable checking and make changes effective by
enabling do_apply argument to himport_r().
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
Change hashtable so that a callback function will decide whether a
variable can be overwritten, and possibly apply the changes.
So add a new field to struct hsearch_data:
o "apply" callback function to check whether a variable can be
overwritten, and possibly immediately apply the changes;
when NULL, no check is performed.
And a new argument to himport_r():
o "do_apply": whether to call the apply callback function
NOTE: This patch does not change the current behavior.
Add 2 new arguments to himport_r():
o "nvars", "vars": number and list of variables to take into account
(0 means ALL)
NOTE: This patch does not change the current behaviour.
The logic of checking special parameters (e.g. baudrate, stdin, stdout,
for a valid value and/or whether can be overwritten) and applying the
new value to the running system is now all within a single function
env_check_apply() which can be called whenever changes are made
to the environment, no matter if by set, default or import.
With this patch env_check_apply() is only called by "env set",
retaining previous behavior.
iomux_doenv() can only return 0 or 1.
So there is no need to save its return value in variable i, as checking
its truth value within an if statement is enough.
The ethprime env var was missing from env_common.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
The original memory sizing code in get_ram_size clobbers the word
at the base address, but forgets to restore it.
Signed-off-by: Iwo Mergler <Iwo.Mergler@netcommwireless.com>
The third parameter to ALLOC_CACHE_ALIGN_BUFFER is not size (as named),
but rather count (number of elements of the type to allocate). The
current code ends up allocating one copy of env_t for each byte in its
size, which quite possibly ends up overflowing RAM.
This fixes a bug in commit 3801a15 "env_nand: align NAND buffers".
Reported-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
Reported-by: Prabhakar Lad <prabhakar.lad@ti.com>
cmd_bdinfo.c: In function ‘do_bdinfo’:
cmd_bdinfo.c:220:9: warning: format ‘%lx’ expects argument of type ‘long unsigned int’, but argument 2 has type ‘int’ [-Wformat]
cmd_bdinfo.c:222:9: warning: format ‘%lx’ expects argument of type ‘long unsigned int’, but argument 2 has type ‘int’ [-Wformat]
cmd_bdinfo.c:224:9: warning: format ‘%lx’ expects argument of type ‘long unsigned int’, but argument 2 has type ‘int’ [-Wformat]
cmd_bdinfo.c:226:9: warning: format ‘%lx’ expects argument of type ‘long unsigned int’, but argument 2 has type ‘int’ [-Wformat]
cmd_bdinfo.c:228:9: warning: format ‘%lx’ expects argument of type ‘long unsigned int’, but argument 2 has type ‘int’ [-Wformat]
Cc: Daniel Hellstrom <daniel@gaisler.com>
Cc: u-boot-dm@lists.denx.de
Micron NAND flash (e.g. MT29F4G08ABADAH4) BLOCK LOCK READ STATUS is not
the same as others. Instead of bit 1 being lock, it is #lock_tight.
To make the driver support either format, ignore bit 1 and use only
bit 0 and bit 2.
NAND unlock command allows an invert bit to be set to unlock all but
the selected page range.
[scottwood@freescale.com: updated docs and added comment about invert bit]
In case the "fdt addr" command wasn't ran yet and any other "fdt"
subcommand was issued, the system crashed due to NULL pointer being
used.
This is caused by "fdt addr" command setting up a pointer to the
FDT memory location. Prior issuing "fdt addr", the pointer is NULL
so calling any other subcommands crashed the u-boot.
This fixes the following warnings in dlmalloc seen with my gcc 4.6.
dlmalloc.c: In function 'malloc_bin_reloc':
dlmalloc.c:1493: warning: dereferencing pointer 'p' does break strict-aliasing rules
dlmalloc.c:1490: note: initialized from here
dlmalloc.c:1493: note: initialized from here
This version is tested on avr32 arch boards.
eMMC devices may have hardware-level partitions: 2 boot partitions,
up to 4 general partitions, plus the user area. This change introduces
optional config variable CONFIG_SYS_MMC_ENV_PART to indicate which
partition the environment should be stored in: 0=user, 1=boot0, 2=boot1,
4..7=general0..3. This allows the environment to be kept out of the user
area, which simplifies the management of OS-/user-level (MBR/GPT)
partitions within the user area.
Signed-off-by: Tom Warren <twarren@nvidia.com>
In order for cache invalidation and flushing to work properly, the data
and OOB buffers must be aligned to full cache lines.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Cc: Andy Fleming <afleming@gmail.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
Move highly platform dependant code into its own functions to reduce the
number of #ifdefs in lcd_display_bitmap
To avoid breaking the mcc200 board which does not #define
CONFIG_CMD_BMP, this patch also implements bmp_display() for mcc200.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Move highly platform dependant code into its own function to reduce the
number of #ifdefs in the bigger functions
Simplify lcd_display by centralizing code into a funciton
Simplify lcd_logo by extracting bmp unzip into its own function.
Check for ctrlc() in operations that take time and loop over the flash
addresses.
In netconsole, tstc() is expensive. Only check once in a while to not
slow down the operation significantly.
When a variable which contains a user-supplied value is dereferenced
(e.g. to be echo'ed), make sure that the value is not further parsed
by hush.
Set the hush local variable "HUSH_NO_EVAL=1" to enable this behavior.
Without this patch, a sequence like this occurs:
Panda # env set my_user_string Bob\'s favorite device
Panda # print my_user_string
my_user_string=Bob's favorite device
Panda # echo $my_user_string
syntax error hush.c:3007
With this patch, it looks like this:
Panda # HUSH_NO_EVAL=1
Use standard sh syntax:
${VAR:-default}
Use default value: if VAR is set and non-null, expands to $VAR.
Otherwise, expands to default.
${VAR:=default}
Set default value: if VAR is set and non-null, expands to $VAR.
Otherwise, sets hush VAR to default and expands to default.
${VAR:+default}
If VAR is set and non-null, expands to the empty string.
This allows cache flush/invalidate operations to succeed on the buffers.
Acked-by: Scott Wood <scottwood@freescale.com>
This patch adds support to include Load, Entry address and OS tag
of ramdisk on to FIT image through mkimage tool.
Signed-off-by: Jagannadha Sutradharudu Teki <402jagan@gmail.com>
Trim down the IO times by removing uneeded
test unit reeady calls.
Signed-off-by: Jim Shimer <mgi2475@motorola.com>
There is a 5-ms delay in usb_stor_BBB_transport, which occurs every 10 kiB of
data for fragmented fatload usb, i.e. roughly 500 ms of delay per MiB. This adds
up to quite a bit of delay if you're loading a large ramdisk.
The purpose of this delay should be to debounce the 5-V/100-mA USB power up.
This patch skips the delay if the device has already been queried as ready.
Rework following the review:
- Rebase against the latest u-boot-usb master.
- Replace typedef with #define.
- Use the existing flags struct field instead of adding a new field.
- Remove the setter function.
- Remove the typecasts.
Cc: Ilya Yanok <ilya.yanok@cogentembedded.com>
Cc: Stefan Herbrechtsmeier <stefan@herbrechtsmeier.net>
Cc: Jim Shimer <mgi2475@motorola.com>
Now that the EHCI driver allocates its qTDs from the heap, the MSC driver is
only limited by the SCSI commands it uses.
The commit 5dd95cf made the MSC driver EHCI-specific. This patch restores a
basic support of non-EHCI HCDs, like before that commit.
The fallback transfer size is certainly not optimal, but at least it should work
like before.
Support for u-boot's command line command "dfu <interface> <dev> [list]".
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Provides a tool to build boot Image for PBL(Pre boot loader) which is
used on Freescale CoreNet SoCs, PBL can be used to load some instructions
and/or data for pre-initialization. The default output image is u-boot.pbl,
for more details please refer to doc/README.pblimage.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
When boot from PCIE, slave's core should be in holdoff after powered on for
some specific requirements. Master will release the slave's core at the
right time by PCIE interface.
Slave's ucode and ENV can be stored in master's memory space, then slave
can fetch them through PCIE interface. For the corenet platform, ucode is
for Fman.
NOTE: Because the slave can not erase, write master's NOR flash by
PCIE interface, so it can not modify the ENV parameters stored
in master's NOR flash using "saveenv" or other commands.
environment and requirement:
master:
1. NOR flash for its own u-boot image, ucode and ENV space.
2. Slave's u-boot image is in master NOR flash.
3. Put the slave's ucode and ENV into it's own memory space.
4. Normally boot from local NOR flash.
5. Configure PCIE system if needed.
slave:
1. Just has EEPROM for RCW. No flash for u-boot image, ucode and ENV.
2. Boot location should be set to one PCIE interface by RCW.
3. RCW should configure the SerDes, PCIE interfaces correctly.
4. Must set all the cores in holdoff by RCW.
5. Must be powered on before master's boot.
For the slave module, need to finish these processes:
1. Set the boot location to one PCIE interface by RCW.
2. Set a specific TLB entry for the boot process.
3. Set a LAW entry with the TargetID of one PCIE for the boot.
4. Set a specific TLB entry in order to fetch ucode and ENV from
master.
5. Set a LAW entry with the TargetID one of the PCIE ports for
ucode and ENV.
6. Slave's u-boot image should be generated specifically by
make xxxx_SRIO_PCIE_BOOT_config.
This will set SYS_TEXT_BASE=0xFFF80000 and other configurations.
In addition, the processes are very similar between boot from SRIO and
boot from PCIE. Some configurations like the address spaces can be set to
the same. So the module of boot from PCIE was added based on the existing
module of boot from SRIO, and the following changes were needed:
1. Updated the README.srio-boot-corenet to add descriptions about
boot from PCIE, and change the name to
README.srio-pcie-boot-corenet.
2. Changed the compile config "xxxx_SRIOBOOT_SLAVE" to
"xxxx_SRIO_PCIE_BOOT", and the image builded with
"xxxx_SRIO_PCIE_BOOT" can support both the boot from SRIO and
from PCIE.
3. Updated other macros and documents if needed to add information
about boot from PCIE.
Signed-off-by: Liu Gang <Gang.Liu@freescale.com>
Reported-by: James Miller <jamesmiller@chromium.org>
Signed-off-by: Uma Shankar <uma.shankar@samsung.com>
Signed-off-by: Manjunatha C Achar <a.manjunatha@samsung.com>
Signed-off-by: Iqbal Shareef <iqbal.ams@samsung.com>
Signed-off-by: Hakgoo Lee <goodguy.lee@samsung.com>
U-Boot port is based on sources forked from GRUB-0.97 by Sun in 2004,
which can be found here:
http://src.opensolaris.org/source/xref/onnv/onnv-gate/usr/src/grub/grub-0.97/stage2/zfs-include/zfs.h
Released by Sun for GRUB under the license:
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
GRUB official releases include ZFS in version:
ftp://alpha.gnu.org/gnu/grub/grub-1.99~rc1.tar.gz
And patched against GRUB Bazaar repository for ashift fixes (4KB HDDs)
more conveniently found at github:
https://github.com/pendor/grub-zfs/commit/e7b6ef3ac3b9685ac4c394c897b1d4221b7381f1
Signed-off-by: Jorgen Lundman <lundman@lundman.net>
This patch updates the yaffs2 in u-boot to correspond to
git://www.aleph1.co.uk/yaffs2
commit id 9ee5d0643e559568dbe62215f76e0a7bd5a63d93
Signed-off-by: Charles Manning <cdhmanning@gmail.com>
When CONFIG_ZERO_BOOTDELAY_CHECK is not defined, bootdelay==0
prevents the check for console input (as stated in README.autoboot).
This must also work in CONFIG_AUTOBOOT_KEYED mode.
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
Any environment variable can hold commands to be executed by the 'run'
command. The environment variables preboot, bootcmd and menucmd have
special code for triggering execution in certain circumstances.
We adjust these calls to use run_command_list() instead of run_command().
This change permits these variables to have embedded newlines so that
they work the same as the 'source' command.
