On the tegra30, it appears that the "DVC" i2c controller has been
normalized and no longer requires special semantics for accessing it
(it has also just been renamed to "i2c5"). This change makes it so
that we don't pick DVC semantics based on the periperal ID, but
instead allow the device tree to specify.
BUG=chromium-os:21540
TEST=Compiled / booted on Kaen
Change-Id: Idfd96d1193b5ac267c61416544c63cc03dab396d
Signed-off-by: Doug Anderson <dianders@chromium.org>
Reviewed-on: http://gerrit.chromium.org/gerrit/10279
This moves debug messages from manually including their own
function name to using __func__ to get it. This is less error
prone. As a result of this, some error messages are now fixed
to list the proper function name.
BUG=None
TEST=Added '#define DEBUG 1' to this file and saw that several
of the debugs messages seemed fine; no compiler warnings found.
Change-Id: I548c3e2e8850ee558149b9879d2801c19fe21d63
Reviewed-on: http://gerrit.chromium.org/gerrit/10339
This region is now marked properly in the e820 table, so it doesn't need to be
explicitly preserved by u-boot any more.
BUG=None
TEST=Built and booted on Stumpy. Verified that the i915 DRM driver was able to
find the vbios tables, or at least didn't complain that it couldn't.
Change-Id: I2d5953e00d302e68f076f9bdd77a5efbbb93a64a
Signed-off-by: Gabe Black <gabeblack@google.com>
Reviewed-on: http://gerrit.chromium.org/gerrit/10334
Exclude kcrashmem from vboot unused memory wipe to allow for recovery of
kernel crash dumps. If the kcrashmem size changes, then the corresponding
fdt must be updated.
BUG=chrome-os-partner:5168
TEST=Manually observed kcrash preserved
Signed-off-by: Katie Roberts-Hoffman <katierh@chromium.org>
Change-Id: Iecb2bd7f7df958125ed3cb3bf0b789602e314e7c
Reviewed-on: http://gerrit.chromium.org/gerrit/8942
Commit-Ready: Katie Roberts-Hoffman <katierh@chromium.org>
Tested-by: Katie Roberts-Hoffman <katierh@chromium.org>
BUG=None
TEST=Ran vboot_test memwipe on Stumpy and saw it pass.
Change-Id: Ibac1d9ae10804b87b31127af2f60cb6d3dd565c7
Reviewed-on: http://gerrit.chromium.org/gerrit/10068
Reviewed-by: Che-Liang Chiou <clchiou@chromium.org>
Reviewed-by: Stefan Reinauer <reinauer@google.com>
The implementation adds the e820 regions marked as RAM, removes the ones that
aren't, manually removes an area that is incorrectly left out of the e820 map,
and then uses the the protect_u_boot_memory function to protect the generic
u-boot memory regions.
BUG=chrome-os-partner:6194
BUG=chrome-os-partner:6195
TEST=Boot on Stumpy. Manually check the wipe areas reported during boot.
Change-Id: Icaf7b9167282f9ab418d98491aa0493f020e287d
Reviewed-on: http://gerrit.chromium.org/gerrit/10007
This new organization will allow x86 to do things differently, and also avoid
duplicating code.
TEST=Built and booted on Stumpy and Kaen.
Change-Id: Ifb47d08c2df9116a10f6090b15614828e3cba9e1
Reviewed-on: http://gerrit.chromium.org/gerrit/10005
The recovery key is needed to display recovery reason information when the tab
key is pressed. If it's not loaded, the data in the in-memory copy of the GBB
can be anything, and vboot may take a very long time to process a malformed
key. This workaround, provided by clchiou, ensures that the recovery key is
loaded when in developer mode so that when the tab key is pressed vboot doesn't
get stuck.
BUG=chrome-os-partner:6266
TEST=Booted into dev mode and pressed tab. Saw the recovery info and that the
system didn't hang and could continue to boot once Ctrl+D was pressed.
Change-Id: I2b85933d38d879a33d3ae369a8249a86af3e9caf
Reviewed-on: http://gerrit.chromium.org/gerrit/10008
Reviewed-by: Randall Spangler <rspangler@chromium.org>
The memory wipe infrastructure in u-boot makes some assumptions about how
memory is arranged that make it not quite fit with x86. Specifically, it
assumes that there is a single region of memory, and with certain exceptions
that's what should be wiped. In x86, specifically in the e820 map, there are
multiple regions of RAM, possibly multiple regions to exclued from that that
may completely, partially, or not overlap with the others, and then u-boot
related regions.
This is addressed by making the memory wipe infrastructure a little more
generic. Now, areas can be added and subtracted arbitrarily, and will
accumulate in the order they're encountered. In the x86 use case, we can add
the e820 regions marked as RAM, subtract the areas marked as anything else, and
subtract the u-boot related regions.
Rather than tracking the actual regions of the address space, this
implementation tracks the boundaries between the regions using a linked list.
The code itself is short and relatively simple, and I tried to ensure that it
was as clear as possible to make any memory (or other) bugs easier to see and
fix.
TEST=Built and booted on kaen using the A-A cable. Ran vboot_test memwipe, and
a modified version that took advantage of the new API.
Change-Id: I122fbf499ef473350afa27b612cb0e565366b1ad
Reviewed-on: http://gerrit.chromium.org/gerrit/9715
Verified boot requires writing to GPT attributes (success / tries), so we need
to implement *_write.
"scsi write" command is also added to console for testing.
BUG=chrome-os-partner:6258
TEST=(1) Modified GPT to trigger VBOOT updating GPT, and verified
GPT changed successfully (by firmware) after reboot
(2) ext2load usb 1:1 10000000 /part2.bin # load kernel partition dump
scsi write 10000000 5000 5000 # write into kernel partition in #2
Change-Id: I8027b6075cdabf8df81ea1ba620ca0dcd3d33232
Signed-off-by: Hung-Te Lin <hungte@chromium.org>
Reviewed-on: http://gerrit.chromium.org/gerrit/8841
Reviewed-by: Vadim Bendebury <vbendeb@chromium.org>
This makes fixup_silent_linux() use malloc() to allocate its
working space, meaning that our maximum kernel command line
should only be limited by malloc(). Previously it was silently
overflowing the stack.
BUG=chromium-os:21313
TEST=Manual:
1. Built with:
USE="-cros-debug" emerge-${BOARD} \
chromeos-u-boot \
chromeos-bootimage
2. Flashed with:
cros_write_firmware --board=${BOARD} /build/${BOARD}/firmware/image.bin
3. Saw that I could boot.
TEST=Manually copied unittest code (included in next checkin) to a
C file and then ran it. All tests pass. Note that there is no
automated way to run unittests like this in u-boot yet.
Change-Id: I0b5fd0d4a3cd09b7545d676a201a11b4a9b7dada
Reviewed-on: http://gerrit.chromium.org/gerrit/8815
This reverts commit 8e93aec313c2807704b14fbd21123a9ffc86a087.
The bios-base setting has been deprecated.
BUG=None
Change-Id: I792761ac44763b06bf1d3abb4db8e9e1a3f113c5
Reviewed-on: http://gerrit.chromium.org/gerrit/8823
BUG=None
TEST=Compile u-boot.
Change-Id: I696e6795d80fc93a37093fdf5274addeacbe2b6f
Reviewed-on: http://gerrit.chromium.org/gerrit/8814
Reviewed-by: Anton Staaf <robotboy@chromium.org>
Allow redirection of console output prior to console initialisation to a
temporary buffer.
To enable this functionality, the board (or arch) must define:
- CONFIG_PRE_CONSOLE_BUFFER - Enable pre-console buffer
- CONFIG_PRE_CON_BUF_ADDR - Base address of pre-console buffer
- CONFIG_PRE_CON_BUF_SZ - Size of pre-console buffer (in bytes)
The pre-console buffer will buffer the last CONFIG_PRE_CON_BUF_SZ bytes
Any earlier characters are silently dropped.
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
Change-Id: I3c4caad276b9e981ebea0a0fb79d85ee3a3bcb7d
Reviewed-on: http://gerrit.chromium.org/gerrit/8686
There are some locations in the code which anticipate printf() being called
before the console is ready by squelching printf() on gd->have_console.
Move this squelching into printf(), vprintf(), puts() and putc(). Also
make tstc() and getc() return 0 if console is not yet initialised
Change-Id: If62863017eaa48915b721675a5d520f9caa7e5e0
Reviewed-on: http://gerrit.chromium.org/gerrit/8685
This patch builds upon the recently introduced CBMEM console
feature of coreboot.
CBMEM console uses a memry area allocated by coreboot to store
the console output. The memory area has a certain structure,
which allows to determine where the buffer is, the buffer size
and the location of the pointer in the buffer. This allows
different phases of the firmware (rom based coreboot, ram based
coreboot, u-boot after relocation with this change) to keep
adding text to the same buffer.
Note that this patch introduces a new console driver and adds the
driver to the list of drivers to be used for console output, i.e.
it engages only after u-boot relocates. Usiong CBMEM console for
capturing the pre-relocation console output will be done under a
separate change.
BUG=chrome-os-partner:4200
TEST=manual
. build the new firmware and program it on a stumpy
. restart the machine
. after it comes up to ChromeOS, run the cbmem.py utility (which
is a part of the coreboot package).
Observe u-boot console output in the log, starting with
vvvvvvvvvvvvvvvvv
SCSI: AHCI 0001.0300 32 slots 6 ports ? Gbps 0xf impl SATA mode
flags: 64bit ilck stag led pmp pio
and ending with
vvvvvvvvvvvvvvvvv
Magic signature found
Kernel command line: "cros_secure quiet loglevel=1 console=tty2...
Note that the entire u-boot output fits into the buffer only if
the coreboot log level is reduced from the most verbose. Ether
the buffer size will have to be increased, or the coreboot
verbosity permanently reduced.
Change-Id: I399a90f3aeef9fae074db3e0842d876101c1a85e
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
Reviewed-on: http://gerrit.chromium.org/gerrit/8720
Reviewed-by: Stefan Reinauer <reinauer@chromium.org>
This line is a NC on Asymptote, but right now we're using the pwm line
(incorrectly). This CL removes the backlight-vdd line from Asymptote
dts and ensures that it's safely ignored if it's missing.
BUG=None
TEST=Built u-boot for Asymptote and flashed it on the device. Ensured that the
backlight still works in u-boot.
Change-Id: Id751b6756bac120e2211b7b32c58f356ff30b767
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Reviewed-on: http://gerrit.chromium.org/gerrit/8063
Reviewed-by: Jon Kliegman <kliegs@chromium.org>
Some functions in fdt_support.c use fdt_getprop to read 32 bit values out of
the device tree, but then use them directly without doing any endian
conversion. Because they check for a value that doesn't actually appear in
practice, the functions continued to work even though they're incorrect. This
change adds the missing conversions.
BUG=None
TEST=Built and booted on Alex and Stumpy
Change-Id: I467f68ad1eda7ef25c23341952c87b1a0a135285
Reviewed-on: http://gerrit.chromium.org/gerrit/8077
Commit-Ready: Gabe Black <gabeblack@chromium.org>
Tested-by: Gabe Black <gabeblack@chromium.org>
This fixes problems in these files when building on 64-bit machines.
BUG=chromium-os:19353
TEST=build for Seaboard
Change-Id: Ib013db127505b326436ab4f650ce72e40963e208
Reviewed-on: http://gerrit.chromium.org/gerrit/7644
This moves the last remaining hard-coded CONFIG to the fdt.
BUG=chromium-os:17062
Change-Id: Ic152ce12a0f87211e4cc98eef15601f0703137b1
Reviewed-on: http://gerrit.chromium.org/gerrit/7642
Some constants are actually better of with generic Tegra family names.
This also cleans up a few addresses which were in drivers rather than
in the tegra.h header file.
BUG=chromium-os:19004
TEST=build and boot on Seaboard
Change-Id: I1cabb5191a2b36648a37268069beb3b43c12d0e1
Reviewed-on: http://gerrit.chromium.org/gerrit/7128
This setting specifies where the bios image described by the "flash" section
starts in the ROM. When the device tree is consumed by u-boot, this value is
added to the given offset of accesses to the flash so that it ends up in the
right place in the ROM. The binary fmap will reflect that address directly so
that tools like flashrom can use it without modification. By not modifying the
locations of the sections in the "flash" node of the device tree directly, we
can continue to share definitions between boards that have the same layout for
the BIOS image itself but who may be offset differently in the ROM. If not
present, a default value of 0 is used. Unmodified device trees will continue
to behave like they always have.
The name bios-base isn't perfect since on ARM there is no bios. Another
alternative firmware-base is also flawed because there are multiple firmwares
in the ROM on x86. Yet another option, flashmap-base, doesn't quite work either
because flashmap already has a very similarly named field which describes where
the image described by the flashmap appears in the physical address space.
Because bios-base fits the best on x86 and x86 is currently the only place it's
used, that's the name I went with.
BUG=chrome-os-partner:5844
TEST=Used this and other changes to compensate for the image offset and vboot
on stumpy. Vbooted on x86-alex. Built with vboot_test and vbexport_test built
in to verify that they still compile.
Change-Id: Ie727fc2db27f7d0db8ebf7ed2b98bc97052b4923
Reviewed-on: http://gerrit.chromium.org/gerrit/7239
This function looks up a property in a node which contains a memory region
address and size. It returns a pointer to this address, but if the address
is zero, it is allocated with malloc() instead.
It is used to allocate Chrome OS GBB memory regions and the like.
Change-Id: I91fe8656f3ea50839998ab0e16b023635adbc119
Reviewed-on: http://gerrit.chromium.org/gerrit/7640
This corrects a compile erron when DEBUG is defined in fdt_decode.
Also change property to prop_name throughout, for consistency.
Change-Id: I7503343cea20b556afeb0e507ce9d2cf2165c837
Reviewed-on: http://gerrit.chromium.org/gerrit/7639
This fixes what would become a build break if a board did not have NS16550
serial support included. T30 needs this change.
Change-Id: I6e06dd7f7fce7e475c0cbe48edae8d068ca5b7e8
Reviewed-on: http://gerrit.chromium.org/gerrit/7637
Change-Id: I7aa667fc608d3c42b4e16b0b9af3ef34df425cd0
Reviewed-on: http://gerrit.chromium.org/gerrit/6070
Reviewed-on: http://gerrit.chromium.org/gerrit/7453
BUG=chromium-os:20072
TEST=emerged chromeos-u-boot
Signed-off-by: Reviewers
Change-Id: I7afcb0b6b6ae614e7a32089abac2f44eb3251330
Reviewed-on: http://gerrit.chromium.org/gerrit/7354
Tested-by: asharif <asharif@chromium.org>
Many AHCI controllers are identical, the main (and often the
only) difference being the PCI Vendor ID/Device ID combination
reported by the device.
This change allows the config file to define a list of PCI vendor
ID/device ID pairs. The driver would scan the list and initialize
the first device it finds.
No actual multiple device list is introduced yet, this change
just add the framework.
BUG=chromium-os:19837
TEST=manual
. program updated image on an Alex.
. restart the machine and enter `vboot_twostop' at u-boot prompt.
Observe ChromeOS booting all the way to login screen.
Change-Id: I5253a3da798d7602dd09694fa3c029e92e1e0c65
Reviewed-on: http://gerrit.chromium.org/gerrit/7297
Reviewed-by: Gabe Black (Do Not Use) <gabeblack@google.com>
First - make sure the ahci driver compiles and links properly when
building for x86 platforms.
Then it turned out that when trying to use AHCI driver on an x86
platform with an Intel AHCI controller, the driver does not operate
properly if the requested amount of blocks to read was exceeding 255.
It is probably possible to specify 0 as the block count and the driver
will read 256 blocks, but it was decided to limit the number of blocks
read at once to 128 (it should be a power of 2 for the optimal
performance of solid state drives).
TEST=manual
. program updated image (including vbexport SATA support extension)
on an Alex.
Change-Id: I7224ca14ae60f414db6dbe9e2f0a649312a9459c
Reviewed-on: http://gerrit.chromium.org/gerrit/7232
Reviewed-by: Duncan Laurie <dlaurie@chromium.org>
The function fdt_getprop_u32_default doesn't modify the fdt, so it can use a
const void * for its fdt argument.
BUG=None
TEST=Built with no errors.
Change-Id: I1987a7aa9e9fa9f5042e7fa2bf650e4cbc0bad0e
Reviewed-on: http://gerrit.chromium.org/gerrit/7238
On X86 systems where VDAT address is passed to the kernel through
ACPI the u-boot must retrieve the address from the coreboot table
and make it available to the vboot wrapper.
This change accomplishes just that utilizing the coreboot changes
which include the vdat area address and size into the coreboot
table.
Another modification is removing conditional compilation for
including fields in the sysinfo table. The thing is that the code
is not conditionally compiled anyways, so keeping an extra
pointer in a table even if not needed is not a problem.
BUG=chrome-os-partner:5707
TEST=manual
. program the new firmware on an Alex
. bring up ChromeOS
. try running crossystem
It was reporting errors before (when displaying data retrieved
from VDAT). It displays sensible values now.
Change-Id: Ib4090049092f7963a1b1705409d2beea8a9abfac
Reviewed-on: http://gerrit.chromium.org/gerrit/6868
Tested-by: Vadim Bendebury <vbendeb@google.com>
Reviewed-on: http://gerrit.chromium.org/gerrit/6919
This code was not guarded with CONFIG_LMB so failed to build on x86.
BUG=chromium-os:19599
TEST=manual:
make ARCH=x86 CROSS_COMPILE=i686-pc-linux-gnu- VBOOT=/build/x86-mario/usr VBOOT_DEBUG=1
Change-Id: I67ec1e5349646f6432426c8fda4f83f85b38b368
and also change address from 3f8 to i3f8 to clarify that it's an IO
address.
BUG=none
TEST=boot coreboot on stumpy, see serial console output contain u-boot
messages.
Signed-off-by: Stefan Reinauer <reinauer@google.com>
Change-Id: Ib876e2812f05ded28de458ab2c38451ce85aed19
Reviewed-on: http://gerrit.chromium.org/gerrit/6606
Tested-by: Stefan Reinauer <reinauer@chromium.org>
This case was incorrect and gives warnings on 64-bit machines.
Change-Id: Id467aa27100701e971ddcddfec57347f79675d99
Reviewed-on: http://gerrit.chromium.org/gerrit/6522
This is needed to use the same config files for all x86 platforms,
while the right incarnation of register accesses is determined by
the device tree.
BUG=chrome-os-partner:4520
TEST=boot u-boot on Alex and Stumpy, get serial output on both.
Change-Id: Ibb8192657861713d656358c5f085f6dde2cb1365
Reviewed-on: http://gerrit.chromium.org/gerrit/6248
Reviewed-by: Gabe Black <gabeblack@chromium.org>
Early in development, we needed a driver for the OXPCIE952 UART which would be
left configured by coreboot and just needed to send and receive characters. It
was only partially developed and was somewhat redundant with the NS16550 UART
support already in u-boot. Now that we're using the device tree to configure
the serial console and it requires us to use the NS16550 driver, the OXPCIE952
driver is no longer necessary. Since it isn't likely to be useful in other
contexts, this change removes support for it entirely.
TEST=Built on x86-alex and tegra2_kaen. Installed and booted on x86-alex and
verified that the serial console still worked.
Change-Id: I124c4596b224f1b2a8d27b2b38e08ee2ce739c79
Reviewed-on: http://gerrit.chromium.org/gerrit/5871
This reverts commit 23cefdce356de66442d858abf12c72afc8d33cac.
Since we changed our minds about loading FMAP information from CBFS, we can go
back to using the same mechanism on ARM and x86.
BUG=chrome-os-partner:5432
TEST=Built and booted on x86-alex and verified that the FMAP information showed
up in debugging output from vboot_twostop.
Change-Id: Id41c82ca24dbfa301559e24104b5e226ec9b7e03
Reviewed-on: http://gerrit.chromium.org/gerrit/5864
This adds a new SPI flash command which only rewrites blocks if the contents
need to change. This can speed up SPI flash programming when much of the
data is unchanged from what is already there.
Series-to: u-boot
Series-cc: mikef
Series-version: 5
Series-changes: 2
- Moved loop into a function
- Moved malloc outside loop
- Other minor changes from review comments
Series-changes: 3
- Change error message
- Style and function name change
Series-changes: 4
- tweak summary
- fix printf warnings with %d vs %zu
- fix help string and missing/extra newlines
Series-changes: 5
- Stop on first error, rather than continuing
Change-Id: I4e524783fe1fc10aa655a0fe2bb8b27fa44a4429
The vboot_api.h interface has changed, so we need to adapt. VbExDecompress()
now allows the vboot library access to native decompression routines. The
signature of VbExDisplayImage() has changed, so we now only need to support
uncompressed native-format bitmaps.
BUG=chromium-os:19134
TEST=manual
I tested by modifying the U-Boot build so I could get into the U-Boot prompt
and run "vbexport_test display". The GBB screens rendered correctly.
Change-Id: Iec605dee0af46e7d9eecc89b826e260f8a5930a4
Reviewed-on: http://gerrit.chromium.org/gerrit/6131
Reviewed-by: Bill Richardson <wfrichar@chromium.org>
Tested-by: Bill Richardson <wfrichar@chromium.org>
BUG=chromium-os:18126
TEST=run "cat /sys/kernel/debug/bootstage/report" in chromeos
to see the boot timing of u-boot.
Change-Id: Ie7b2677f2df58ae80305989ebe79cbe9f5c142fe
Reviewed-on: http://gerrit.chromium.org/gerrit/5504
Tested-by: Da Zheng <zhengda@chromium.org>
This change makes the Alex u-boot use configuration settings
coming from the device tree supplied by coreboot through the
coreboot table.
The device tree now includes the necessary console configuration
information.
Code is added to retrieve the device tree pointer from the
coreboot table, the appropriate coreboot structures and tag
values are being duplicated in
arch/i386/include/asm/ic/coreboot/tables.h. The pointer to the
FDT is added to the global data structure, it is initialized as
soon as it is retrieved from the coreboot table.
For some reason placing the global data structure anywhere but in
the .data segment causes the system to crash. This phenomenon
will be investigated shortly, this commit is an intermediate step
to get the device tree handover used by other coreboot/u-boot
contributors.
Core retrieving the device tree from CBFS is not needed anymore
and gets removed.
BUG=chrome-os-partner:5248
TEST=manual
. build the new image and program it on Alex
. restart the target, observe the console output
The target boots all the way to u-boot prompt.
Change-Id: I087cf70362ede0873be37fa5a98aa66a0b979d8f
Reviewed-on: http://gerrit.chromium.org/gerrit/6132
This was a nasty bug introduced during the previous code review.
BUG=chromium-os:17805
TEST=build, boot on Aebl
Change-Id: I9d600b7ac89c53598ac76f9031a988a4d27a66fa
Reviewed-on: http://gerrit.chromium.org/gerrit/6091
If puts() or printf() is called before the console is ready, U-Boot will
either hang or die. This adds a check for this so that debug() can be used
in early code without concern that it will hang.
TEST=build and boot U-Boot, then #define DEBUG in fdt_decode and see that
U-Boot boots properly
Change-Id: I299cbbb074e31a1df2d742dec2e9aab5ac7ca0a5
Reviewed-on: http://gerrit.chromium.org/gerrit/6066
Reviewed-by: Mike Frysinger <vapier@chromium.org>
It is sometimes difficult to work out where an fdt decode is failing unless
you have a debugger running. This adds a simple debug/trace features to
the fdt_decode library. To use it #define DEBUG in fdt_decode.c
TEST=build U-Boot with this debugging enabled, see that output appears
Change-Id: I21a3f8668be33a0f09354be9f286abef73812684
Reviewed-on: http://gerrit.chromium.org/gerrit/5051
This tidies up duplicate code, and checks that default_serial_console() does
in fact produce a device.
TEST=build and boot U-Boot on Seaboard
Change-Id: Icc20e304049fc3568717457ad8366903a7a05bf8
Reviewed-on: http://gerrit.chromium.org/gerrit/6064
Since we can't easily control the order in which records are added to the
bootstage list, this sorts the list before display.
TEST=build and boot on Aebl, see that list is sorted
Timer summary in microseconds:
Mark Elapsed Stage
0 0 reset
316,789 316,789 arch_cpu_init AVP
321,096 4,307 arch_cpu_init A9
321,147 51 arch_cpu_init done
321,149 2 board_init_f start
393,588 72,439 board_init_r start
642,657 249,069 main_loop
647,449 4,792 do_vboot_twostop
649,768 2,319 twostop_init
661,083 11,315 twostop_select_and_set_main_firmware
886,859 225,776 twostop_main_firmware
1,324,964 438,105 select_and_load_kernel_exit
1,328,934 3,970 bootm_start
1,490,433 161,499 start_kernel
Change-Id: Ieea6c5f107243d81882207e85775e78924956e34
Reviewed-on: http://gerrit.chromium.org/gerrit/5777
This adds steps for arch_cpu_init() and board_init_f/r()
Change-Id: If29288b896585f7e1eb8c8bf67e48b76dd06fb48
Reviewed-on: http://gerrit.chromium.org/gerrit/5776
The removed codes are belong to an earlier prototype of integrating
vboot wrapper API, which is not compiled/used anymore. Besieds, the
prototype has a known vulnerability of buffer overflow when reading
key blocks. So there is no many referential value for keeping the
prototype codes in the codebase. And keeping the prototype also adds
costs to new patches, which have to changes two implementations. All
in all, I think it is time we retire this prototype.
This patch also fixes coreboot build failure due to the removal.
BUG=chromium-os:16542
TEST=emerge-{x86-alex,tegra2_aebl} chromeos-u-boot
Change-Id: Ib6be9457f2dbc2daa3213c3d9c80bcdc56c520c4
Reviewed-on: http://gerrit.chromium.org/gerrit/5874
Tested-by: Che-Liang Chiou <clchiou@chromium.org>
The framebuffer address should be specified in the device tree and not u-boot
assigned. This FDT value should be the same as the one defined in Linux kernel;
otherwise, it causes screen flicker. The FDT value overrides the framebuffer
allocated at the top of memory by board_init_f().
If the framebuffer address is not defined in the FDT, falls back to use the
address allocated by board_init_f().
BUG=chrome-os-partner:5338
TEST=build without error and boot Chrome OS on Aebl, see the screen not
corrupted and splash screen showed.
Change-Id: Ia6a996d127d74d6084900814d2c934fb95518e23
Reviewed-on: http://gerrit.chromium.org/gerrit/5877
Reviewed-by: Tom Wai-Hong Tam <waihong@chromium.org>
Tested-by: Tom Wai-Hong Tam <waihong@chromium.org>
The original description is to match the field holding "one address with
no trailing data". So the if condition should be equal length:
if (cell && len != sizeof(addr_t))
But it still worked fine except the lcd frame-buffer value because all
other fields are somethings like: reg = <0x70006040 0x40>, not exactly one
address.
So this CL fixed the matching to either one address or two addresses.
TEST=build without error and manually print the frame-buffer value to verify.
Change-Id: I7a1a64feafc4e883f23044c1d04da09b2122ff40
Reviewed-on: http://gerrit.chromium.org/gerrit/5875
Reviewed-by: Bryan Freed <bfreed@chromium.org>
