path: root/common
2007-12-27Merge branch 'master' of /home/stefan/git/u-boot/u-boot into for-1.3.2-ver2Stefan Roese
2007-12-27Merge branch 'master' of git://www.denx.de/git/u-boot-shWolfgang Denk
Conflicts: MAINTAINERS Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-12-11Merge commit 'u-boot/master' into for-1.3.1Stefan Roese
Conflicts: drivers/rtc/Makefile
2007-12-07Conditionally compile fdt_fixup_ethernet()Gerald Van Baren
Fix compiler warnings: On boards that don't have ethernets defined, don't compile fdt_fixup_ethernet().
2007-12-07Added fdt_fixup_stdout that uses aliases to set linux,stdout-pathKumar Gala
We use a combination of the serialN alias and CONFIG_CONS_INDEX to determine which serial alias we should set linux,stdout-path to. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-07Add common memory fixup functionKumar Gala
Add the function fdt_fixup_memory() to fixup the /memory node of the fdt Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-07Conditionally compile fdt_support.cKumar Gala
Modify common/Makefile to conditionally compile fdt_support.c based on CONFIG_OF_LIBFDT. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-07Add spaces around the = in the fdt print format.Gerald Van Baren
Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2007-12-07Merge git://www.denx.de/git/u-bootNobuhiro Iwamatsu
Conflicts: drivers/Makefile
2007-11-29Merge git://www.denx.de/git/u-bootNobuhiro Iwamatsu
2007-11-22Fix fdt printing for updated libfdtGerald Van Baren
Also improve printing (adopt dtc v1 "c style" hex format), whitespace cleanup. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2007-11-21Add additional fdt fixup helper functionsKumar Gala
Added the following fdt fixup helpers: * do_fixup_by_prop{_u32} - Find matching nodes by property name/value * do_fixup_by_compat{_u32} - Find matching nodes by compat The _u32 variants work the same only the property they are setting is know to be a 32-bit integer instead of a byte buffer. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-11-21Add fdt_fixup_ethernet helper to set mac addressesKumar Gala
Added a fixup helper that uses aliases to set mac addresses in the device tree based on the bd_t Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-11-21Fix warnings from import of libfdtKumar Gala
cmd_fdt.c: In function fdt_print: cmd_fdt.c:586: warning: assignment discards qualifiers from pointer target type cmd_fdt.c:613: warning: assignment discards qualifiers from pointer target type cmd_fdt.c:635: warning: assignment discards qualifiers from pointer target type cmd_fdt.c:636: warning: assignment discards qualifiers from pointer target type Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-11-21Update libfdt from device tree compiler (dtc)Kumar Gala
Update libfdt to commit 8eaf5e358366017aa2e846c5038d1aa19958314e from the device tree compiler (dtc) project. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-11-21Move do_fixup* for libfdt into common codeKumar Gala
Moved the generic fixup handling code out of cpu/mpc5xxx and cpu/mpc8260 into common/fdt_support.c and renamed: do_fixup() -> do_fixup_by_path() do_fixup_u32() -> do_fixup_by_path_u32() Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-11-21Make no options to fdt print default to '/'Kumar Gala
2007-11-21Removed some nonused fdt functions and moved fdt_find_and_setprop out of libfdtKumar Gala
Removed: fdt_node_is_compatible fdt_find_node_by_type fdt_find_compatible_node To ease merge of newer libfdt as we aren't using them anywhere at this time. Also moved fdt_find_and_setprop out of libfdt into fdt_support.c for the same reason. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-11-20[BUILD] conditionally compile common/cmd_*.c in common/MakefileGrant Likely
Modify common/Makefile to conditionally compile the cmd_*.c files based on the board config. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-20Merge branch 'origin' into kconfig-for-1.3.1Grant Likely
2007-11-18Fix compiler warnings for PPC systems. Update CHANGELOG.Wolfgang Denk
2007-11-18Fix warning differ in signedness in common/cmd_scsi.cStefan Roese
2007-11-16Merge branch 'origin' into kconfig-for-1.3.1Grant Likely
2007-11-17Fixed mips_io_port_base build errors.Jean-Christophe PLAGNIOL-VILLARD
This patch has been sent on: - 29 Sep 2007 Although mips_io_port_base is currently a part of IDE command, it is quite fundamental for MIPS I/O port access such as in[bwl] and out[bwl]. So move it to MIPS general part, and introduce `set_io_port_base()' from Linux. This patch is triggered by multiple definition of `mips_io_port_base' build error on gth2 (and tb0229 also needs this fix.) board/gth2/libgth2.a(gth2.o): In function `log_serial_char': /home/skuribay/devel/u-boot.git/board/gth2/gth2.c:47: multiple definition of `mips_io_port_base' common/libcommon.a(cmd_ide.o):/home/skuribay/devel/u-boot.git/common/cmd_ide.c:712: first defined here make: *** [u-boot] Error 1 Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-11-17Fix a bug in the slave serial programming mode for the XilinxWolfgang Denk
Spartan2/3 FPGAs. The old code used "< 0" on a "char" type to test if the most significant bit was set, which did not work on any architecture where "char" defaulted to be an unsigned type. Based on a patch by Angelos Manousaridis <amanous@inaccessnetworks.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-11-17Merge branch 'master' of /home/wd/git/u-boot/workWolfgang Denk
2007-11-16Fix warning differ in signedness in common/cmd_ide.cJean-Christophe PLAGNIOL-VILLARD
2007-11-15Build: split COBJS value into multiple linesGrant Likely
This change is in preparation for condtitionial compile support in the build system. By spliting them all into seperate lines now, subsequent patches that change 'COBJS-y += ' into 'COBJS-$(CONFIG_<blah>) += ' will be less invasive and easier to review Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-06NET: Add Ethernet 1000BASE-X support for PPC4xxLarry Johnson
This patch adds support for 1000BASE-X to functions "miiphy_speed ()" and "miiphy_duplex()". It also adds function "miiphy_is_1000base_x ()", which returns non-zero iff the PHY registers are configured for 1000BASE-X. The "mii info" command is modified to distinguish between 1000BASE-T and -X. Signed-off-by: Larry Johnson <lrj@acm.org> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2007-11-06NET: Cosmetic changesLarry Johnson
2007-11-03Fix the issue of usb_kbd driver missing the scan code of key 'z'.Zhang Wei
The scan code of the key 'z' is 0x1d, which should be handled. The change has be tested on NOVATEK USB keyboard and ULI PCI OHCI controller. Signed-off-by: Zhang Wei <wei.zhang@freescale.com>
2007-10-31ppc4xx: Add PPC405EX supportStefan Roese
2007-10-31ppc4xx: Rename 405gp_pci to 4xx_pci since its used on all 4xx platformsStefan Roese
These files were introduced with the IBM 405GP but are currently used on all 4xx PPC platforms. So the name doesn't match the content anymore. This patch renames the files to 4xx_pci.c/h. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-19Fix two typos.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2007-10-13Merge branch 'merge' of git://www.denx.de/git/u-boot-microblazeWolfgang Denk
2007-10-13Merge branch 'master' of git://www.denx.de/git/u-boot-nand-flashWolfgang Denk
2007-09-26Fpga: fix incorrect test of CFG_FPGA_XILINX macroGrant Likely
CFG_FPGA_XILINX is a bit value used to test against the value in CONFIG_FPGA. Testing for a value will always return TRUE. I don't think that is the intention in this code. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-09-24[FIX] repair MFSL commandsMichal Simek
2007-09-24synchronizition with mainlineMichal Simek
2007-09-24Merge ../u-bootMichal Simek
2007-09-23sh: Add support command of ide with shNobuhiro Iwamatsu
2007-09-23Merge git://www.denx.de/git/u-bootNobuhiro Iwamatsu
Conflicts: CREDITS
2007-09-17OneNAND support (take #2)Kyungmin Park
[PATCH 3/3] OneNAND support (take #2) OneNAND support at U-Boot Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2007-09-16TQM8xx[LM]: Fix broken environment alignment.Wolfgang Denk
With recent toolchains, the environment sectors were no longer aligned to sector boundaries. The reason was a combination of two bugs: 1) common/environment.c assumed that CONFIG_TQM8xxL would be defined for all TQM8xxL and TQM8xxM boards. But "include/common.h", where this gets defined, is not included here (and cannot be included without causing lots of problems). Added a new #define CFG_USE_PPCENV for all boards which really want to put the environment is a ".ppcenv" section. 2) The linker scripts just include environment.o, silently assuming that the objects in that file are really in the order in which they are coded in the C file, i. e. "environment" first, then "redundand_environment", and "env_size" last. However, current toolchains (GCC-4.x) reorder the objects, causing the environment data not to start on a flash sector boundary: Instead of: we got: 40008000 T environment 40008000 T env_size 4000c000 T redundand_environment 40008004 T redundand_environment 40010000 T env_size 4000c004 T environment Note: this patch fixes just the first part, and cures the alignment problem by making sure that "env_size" gets placed correctly. However, we still have a potential issue because primary and redundant environment sectors are actually swapped, i. e. we have now: 40008000 T redundand_environment 4000c000 T environment 40010000 T env_size This shall be fixed in the next version. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-09-15Fix do_div() usage in nand process outputMatthias Fuchs
Fix usage of do_div() in nand erase|read|write process output. The last patch to nand_util.c introduced do_div() instead of libgcc's implementation. But do_div() returns the quotient in its first macro parameter and not as result. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-09-15NAND: Add CFG_NAND_QUIET optionMatthias Fuchs
This config option sets the default for the progress information output behavior that can also be configured through the 'quiet' environment variable. The legacy NAND code does not print the current progress info on the console. So this option is for backward compatibility for units that are in the field and where setting the quiet variable is not an option. With CFG_NAND_QUIET set to '1' the console progress info is turned off. This can still be overwritten through the environment variable. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-09-11Merge git://www.denx.de/git/u-bootMichal Simek
2007-09-09Bugfix: make bootm+libfdt compile on boards with no flashGrant Likely
2007-09-07PXA270: Add support for multiple serial ports.stefano babic
This patch adds support for multiple serial ports to the PXA target. FFUART, BTUART and STUART are supported. Signed-off-by: Stefano Babic <sbabic@denx.de>
2007-09-07Fix do_bootm_linux() so that multi-file images with FDT blob boot.Bartlomiej Sieka
Fix incorrect blob address calculation in do_bootm_linux() that prevents booting the kernel from a multi-file image (kernel + initrd + blob). Also, make minor updates to the U-Boot's output and to the coding style. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
