After years of unsuccessful research I've finally shamelessly stolen other
peoples intellectual properties to present the all-new and world-changing
updated version command:
U-Boot>> version
U-Boot 2010.12-00014-g7435056-dirty (Jan 18 2011 - 23:19:38)
MyBoard
gcc (GCC) 0.42 (Distro foobar)
GNU ld (GNU Binutils) 0.314159265
May the toolchain bugs rest in peace.
Signed-off-by: Alexander Holler <holler@ahsoftware.de>
CONFIG_SPLASH_SCREEN_ALIGN makes uboot support display
offset for splashimage. The framebuffer writing address
should be calculated according to different kinds of
framebuffer pixel format, i.e., bits per pixel value.
Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
There are several users of the hwconfig APIs (8xxx DDR) before we have
the environment properly setup. This causes issues because of the
numerous ways the environment might be accessed because of the
non-volatile memory it might be stored in. Additionally the access
might be so early that memory isn't even properly setup for us.
Towards resolving these issues we provide versions of all the hwconfig
APIs that can be passed in a buffer to parse and leave it to the caller
to determine how to allocate and populate the buffer.
We use the _f naming convention for these new APIs even though they are
perfectly useable after relocation and the environment being ready.
We also now warn if the non-f APIs are called before the environment is
ready to allow users to address the issues.
Finally, we convert the 8xxx DDR code to utilize the new APIs to
hopefully address the issue once and for all. We have the 8xxx DDR code
create a buffer on the stack and populate it via getenv_f().
Acked-by: Wolfgang Denk <wd@denx.de>
Documented is CONFIG_CMD_SHA1, through confusion in the source
CONFIG_CMD_SHA1 and CONFIG_CMD_SHA1SUM has to be used to enable
sha1sum.
Fix both, the documentation and the source, so that only
CONFIG_CMD_SHA1SUM is needed to enable the command sha1sum.
When a flash partition was positioned at the very top of a 32-bit memory
map (eg located at 0xf8000000 with a size of 0x8000000)
get_part_sector_size_nor() would incorrectly calculate the partition's
ending address to 0x0 due to overflow. When the overflow occurred
get_part_sector_size_nor() would falsely return a sector size of 0.
A sector size of 0 results in subsequent jffs2 operations failing.
To workaround the overflow subtract 1 from calculated address of
the partition endpoint.
This patch add addition suffix to nand write to give the uboot
the power to directly burn the yaffs image to nand.
Signed-off-by: Lei Wen <leiwen@marvell.com>
This reverts commit 5a442c0addc69d0c4b58e98e5aec1cf07576debb.
This commit changed the behaviour of getenv_yesno() (both the default
behaviour and the documented behaviour for abbreviated arguments)
which resulted in problems in several areas.
The include/miiphy.h header duplicates a lot of things from linux/mii.h.
So punt all the things that overlap to keep the API simple and to make
merging between U-Boot and Linux simpler.
These strings are only read, so no need to have them be writable.
These "last" variables aren't used outside of this file, so add static.
Rather than keep the load_addr definition with the bootm code (which
just happens to use this), move it to the common env code. This way
we can disable bootm support completely while retaining load_addr
usage with many other commands.
We have config_defaults.h which are random configuration settings that
everyone gets by default. We also have config_cmd_default.h which is a
recommended list of defaults but boards have to opt into. Now we have
config_cmd_defaults.h which is a list of defaults that everyone gets
and has to actively opt out of.
For now, we populate it with the bootm command which previously was
unable to be disabled.
Currently, only basic completion is supported (no globs), but this is
what we had previously.
Commit 722b061 "autocomplete: remove runtime handler install" caused
some boards (like NETTA2_V2) to break with errors like these:
cmd_net.c:296: error: expected expression before ',' token
Fix this.
Cc: Mike Frysinger <vapier@gentoo.org>
Yaffs image require to use the oob to store some info, so when we
burn the yaffs image, we need to also write the image's oob part
into flash.
This patch add addition suffix to onenand write to give the uboot
the power to directly burn the yaffs image to onenand.
The non-reentrant versions of the hashtable functions operate on a single
shared hashtable. So if two different people try using these funcs for
two different purposes, they'll cause problems for the other.
Avoid this by converting all existing hashtable consumers over to the
reentrant versions and then punting the non-reentrant ones.
The handling of env_hwconfig, board_hwconfig, and cpu_hwconfig got
broken when we removed the boards defining dummy board_hwconfig
& cpu_hwconfig values.
We fix this by handling the various strings in priority order. If
hwconfig_parse returns NULL for a given string we check the next one
in order (env_hwconfig, board_hwconfig, followed by cpu_hwconfig).
Seems original implementation forget to set the pointer to point
to the oobbuf, so when we want to see oob buf, we see nothing...
Fix it by get pointer as the oobbuf set.
The nand-read function returns an error code if correctable errors have occurred.
This is not desirable, since the errors have been corrected!
This patch switches to the nand_read_skip_bad function which does not
return an error code if the errors are correctable.
Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org>
Acked-by: Scott Wood <scottwood@freescale.com>
Automatically unmount UBIFS partition when user changes the UBI device.
Otherwise the following UBIFS commands will crash.
This new ubifsumount command allows the user to unmount a previously
mounted UBIFS volume.
Since board_hwconfig & cpu_hwconfig are defined as weak and dont have a
default value they will get put into the BSS if they aren't defined
elsewhere. This is problematic as we try to utilize hwconfig before
we've relocated and thus BSS isn't setup.
Instead of giving dummy values in the board files that utilize this
feature, we can just initialize the variables to an empty string and
thus move them out of the BSS if they aren't defined elsewhere.
Also made board_hwconfig & cpu_hwconfig arrays to reduce size associated
with string pointers vs arrays.
Use the new helper func to clean up duplicate logic handling of the
autostart env var.
These are pure lookup tables -- no need to be writable.
No one else needs this table. While we're here, use the standard
ARRAY_SIZE helper macro.
Many strings in this file need not be writable.
Rather than add runtime overhead of installing completion handlers, do it
statically at build time. This requires a new build time helper macro to
declare a command and the completion handler at the same time. Then we
convert the env related funcs over to this.
This gives an opportunity to also unify the U_BOOT_CMD macros.
The duplication of the do_reset prototype has gotten out of hand,
and they're not all in sync. Unify them all in command.h.
The duplication of the do_bootm prototype has gotten out of hand,
and they're pretty much all outdated (wrt constness). Unify them
all in command.h.
No need for these structures to be writable or global.
While we're here, also drop local versions of the ARRAY_SIZE macro.
Fix compiler warning
fdt_support.c: In function 'of_bus_default_count_cells':
fdt_support.c:957: warning: passing argument 1 of '__swab32p' discards qualifiers from pointer target type
fdt_support.c:965: warning: passing argument 1 of '__swab32p' discards qualifiers from pointer target type
be32_to_cpup() expects an 'u32 *' while prop is 'const u32 *'.
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Use the return value of cmd_usage instead of ignoring this
and returning a 1.
Signed-off-by: Thomas Weber <weber@corscience.de>
Guard strchr/strlen from being called with NULL pointer.
This line is crashing when command "env" is called without subcommand.
The cmd is NULL in this case because the calling function "do_env"
decremented the argc without checking if there are still arguments available.
The env command needs one subcommand. If this is not available
print the usage help.
Some boards use an embedded environment, where env_embedded.o has to
be linked at a special position in the U-Boot image; to make this
possible, we do not include it into libcommon.o for such boards.
Since we set #define MORECORE_CLEARS 1, the code assumes 'sbrk' always
returns zero'd out memory. However since its possible that free()
returns memory back to sbrk() via malloc_trim we could possible get
non-zero'd memory from sbrk(). This is a problem for when code might
call calloc() and expect the memory to have been zero'd out.
There are two possible solutions to this problem.
1. change #define MORECORE_CLEARS 0
2. memset to zero memory returned to sbrk.
We go with the second since the sbrk being called to free up memory
should be pretty rare.
The following code problems an example test to show the issue. This
test code was inserted right after the call to mem_malloc_init().
u8 *p2;
int i;
printf("MALLOC TEST\n");
p1 = malloc(135176);
printf("P1 = %p\n", p1);
memset(p1, 0xab, 135176);
free(p1);
p2 = calloc(4097, 1);
printf("P2 = %p %p\n", p2, p2 + 4097);
for (i = 0; i < 4097; i++) {
if (p2[i] != 0)
printf("miscompare at byte %d got %x\n", i, p2[i]);
free(p2);
printf("END MALLOC TEST\n\n");
Tested-by: Wolfgang Denk <wd@denx.de>
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
This change does the following:
- Removes the printing of the PCI interrupt line value. This is
normally set to 0 by U-Boot on bootup and is rarely used during
everyday operation.
- Prints out the PCI function number of a device. Previously a device
with multiple functions would be printed identically 2 times, which is
generally confusing. For example, on an Intel 2 port gigabit Ethernet
card the following was displayed:
04 01 8086 1010 0200 00
- Prints a text description of each device's PCI class instead of the
raw PCI class code. The textual description makes it much easier to
determine what devices are installed on a PCI bus.
- Changes the general formatting of the PCI device output.
Previous output:
PCIE1: connected as Root Complex
03 00 10b5 8112 0604 00
02 01 10b5 8518 0604 00
02 02 10b5 8518 0604 00
08 00 1957 0040 0b20 00
07 00 10b5 8518 0604 00
09 00 10b5 8112 0604 00
07 01 10b5 8518 0604 00
07 02 10b5 8518 0604 00
06 00 10b5 8518 0604 00
02 03 10b5 8518 0604 00
01 00 10b5 8518 0604 00
PCIE1: Bus 00 - 0b
PCIE2: connected as Root Complex
0d 00 1957 0040 0b20 00
PCIE2: Bus 0c - 0d
Updated output:
04:01.0 - 8086:1010 - Network controller
04:01.1 - 8086:1010 - Network controller
03:00.0 - 10b5:8112 - Bridge device
02:01.0 - 10b5:8518 - Bridge device
02:02.0 - 10b5:8518 - Bridge device
08:00.0 - 1957:0040 - Processor
07:00.0 - 10b5:8518 - Bridge device
09:00.0 - 10b5:8112 - Bridge device
07:01.0 - 10b5:8518 - Bridge device
07:02.0 - 10b5:8518 - Bridge device
06:00.0 - 10b5:8518 - Bridge device
02:03.0 - 10b5:8518 - Bridge device
01:00.0 - 10b5:8518 - Bridge device
PCIE1: Bus 00 - 0b
0d:00.0 - 1957:0040 - Processor
PCIE2: Bus 0c - 0d
hexport would complain implicit declaration, if we don't add the
include file.
env_mmc.c: In function 'saveenv':
env_mmc.c:109: warning: implicit declaration of function 'hexport'
When this define was introduced, the idea was to provide a soft
migration path for ARM boards to get adapted to the new relocation
support. However, other recent changes led to a different
implementation (ELF relocation), where this no longer works. By now
CONFIG_SYS_ARM_WITHOUT_RELOC does not only not help any more, but it
actually hurts because it obfuscates the actual code by sprinkling it
with lots of dead and non-working debris.
So let's make a clean cut and drop CONFIG_SYS_ARM_WITHOUT_RELOC.
Tested-by: Heiko Schocher <hs@denx.de>
Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
By now, the majority of architectures have working relocation
support, so the few remaining architectures have become exceptions.
To make this more obvious, we make working relocation now the default
case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC.
Running the onenand command without arguments does nothing, with this
patch shows the command usage.
Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Functions to store/retrieve the environment from a SPI flash was not updated
to the new environment code. The non-redundant case was
not working correctly, reporting ""Environment SPI flash not initialized"
and the code was not compiled clean in the redundant case.
The patch fixes these issue and makes the code more coherent
with other environment storage (nand, flash).
