2006-10-20 | MCC200: Fix uninitialized variable problem in LCD driver | Wolfgang Denk | |
2006-10-20 | Add board/cpu specific NAND chip select function to 440 NDFC | Stefan Roese | |
Based on idea and implementation from Jeff Mann Patch by Stefan Roese, 20 Oct 2006 | |||
2006-10-20 | Coding style cleanup | Wolfgang Denk | |
2006-10-12 | Fix spelling; minor code cleanup. | Wolfgang Denk | |
2006-10-11 | Cleanup of NAND update patch (remove changelog from cmd_nand.c) | Stefan Roese | |
Patch by Guido Classen, 10 Oct 2006 | |||
2006-10-10 | * Several improvements to the new NAND subsystem: | Stefan Roese | |
- JFFS2 related commands implemented in mtd-utils style - Support for bad blocks - Bad block testing commands - NAND lock commands Please take a look at doc/README.nand for more details Patch by Guido Classen, 10 Oct 2006 | |||
2006-10-09 | Merge with /home/sr/git/u-boot/avr32 | Wolfgang Denk | |
2006-10-09 | Define IH_CPU_AVR32 | Stefan Roese | |
Make it possible to generate AVR32 uImage files with mkimage and make cmd_bootm recognize them. Patch by Haavard Skinnemoen, 22 Sep 2006 | |||
2006-10-09 | Fix buffer overflow problem in ft_build.c | Wolfgang Denk | |
Patch by Fredrik Roubert, 09 Oct 2006 | |||
2006-10-09 | Move "ar" flags to config.mk to allow for silent "make -s" | Wolfgang Denk | |
Based on patch by Mike Frysinger, 20 Jun 2006 | |||
2006-10-09 | Coding style cleanup | Wolfgang Denk | |
2006-09-13 | Merge with /home/sr/git/u-boot/denx | Wolfgang Denk | |
2006-09-13 | Fix alignment problem in "mtdparts" command | Wolfgang Denk | |
2006-09-12 | Add NAND environment support for PPC440EPx Sequoia NAND boot config | Stefan Roese | |
Patch by Stefan Roese, 12 Sep 2006 | |||
2006-09-07 | Add support for AMCC Sequoia PPC440EPx eval board | Stefan Roese | |
- Add support for PPC440EPx & PPC440GRx - Add support for PPC440EP(x)/GR(x) NAND controller in cpu/ppc4xx directory - Add NAND boot functionality for Sequoia board, please see doc/README.nand-boot-ppc440 for details - This Sequoia NAND image doesn't support environment in NAND for now. This will be added in a short while. Patch by Stefan Roese, 07 Sep 2006 | |||
2006-09-04 | Merge with /home/m8/git/u-boot | Wolfgang Denk | |
2006-09-03 | Merge with /home/wd/git/u-boot/master | Wolfgang Denk | |
2006-09-01 | Add support for a saving build objects in a separate directory. | Marian Balakowicz | |
Modifications are based on the linux kernel approach and support two use cases: 1) Add O= to the make command line 'make O=/tmp/build all' 2) Set environement variable BUILD_DIR to point to the desired location 'export BUILD_DIR=/tmp/build' 'make' The second approach can also be used with a MAKEALL script 'export BUILD_DIR=/tmp/build' './MAKEALL' Command line 'O=' setting overrides BUILD_DIR environent variable. When none of the above methods is used the local build is performed and the object files are placed in the source directory. | |||
2006-09-01 | Added simple_strtoul(), getenv() and setenv() to the exported functions. | Detlev Zundel | |
Also bumped up ABI version to reflect this change. | |||
2006-08-31 | Coding Style cleanup. | Wolfgang Denk | |
Patch by Stefano Babic, 31 Aug 2006 | |||
2006-08-30 | Add splashscreen support for MCC200 board. | Wolfgang Denk | |
2006-08-30 | Make the serial driver framework work with CONFIG_SERIAL_MULTI enabled | Wolfgang Denk | |
2006-08-22 | Add a fix for a buggy USB device on the FO300 board. | Bartlomiej Sieka | |
2006-08-13 | Merge with /home/sr/git/u-boot/denx | Wolfgang Denk | |
2006-08-07 | Merge with /home/tur/proj/usb_sticks/u-boot | Wolfgang Denk | |
2006-08-07 | Fix control-c handing in CONFIG_CMDLINE_EDITING | Stefan Roese | |
Properly pass break code back from readline. Patch by Roger Blofeld, 31 Jul 2006 | |||
2006-08-07 | Change "mii info" to not print an error upon missing PHY at address | Stefan Roese | |
Patch by Stefan Roese, 07 Aug 2006 | |||
2006-08-03 | Prevent USB commands from working when USB is stopped. | Bartlomiej Sieka | |
2006-08-02 | Add rudimentary handling of alternate settings of USB interfaces - to fix | Bartlomiej Sieka | |
problems with some USB storage devices. Some code readability improvements. | |||
2006-07-27 | Fix CONFIG_CMDLINE_EDITING implementation | Stefan Roese | |
Patch by Stefan Roese, 27 Jul 2006 | |||
2006-07-21 | More code cleanup | Wolfgang Denk | |
2006-07-21 | Code cleanup | Wolfgang Denk | |
2006-07-21 | Make code better readable. | Wolfgang Denk | |
Patch by Ladislav Michl, 14 Sep 2005 | |||
2006-07-21 | Minor code cleanup. | Wolfgang Denk | |
2006-07-21 | Add readline cmdline-editing extension | Wolfgang Denk | |
Patch by JinHua Luo, 01 Sep 2005 | |||
2006-07-21 | Check argument count in "mii" command. | Wolfgang Denk | |
Problem pointed out by Andrew Dyer, 13 Jun 2005 | |||
2006-07-19 | Add support for new TQM5200 revisions | Wolfgang Denk | |
- Support for TQM5200S (short version without graphic controller) - Support for modules with 'N' type S29GL128N Spansion flashes (requires changes to flash layout) - Support for MPC5200B cpu (mostly support for second SDRAM bank) | |||
2006-07-13 | Fix problems with SanDisk Corporation Cruzer Micro USB memory stick. | Bartlomiej Sieka | |
2006-07-10 | Major PCMCIA Cleanup to make code better readable and maintainable. | Wolfgang Denk | |
Notes: - Board-dependend code for RPXLITE and RPXCLASSIC-based boards placed to the drivers/rpx_pmcia.c file to avoid duplication. Same for TQM8xx-based boards (drivers/tqm8xx_pmcia.c). - drivers/i82365.c has been split into two parts located at board/atc/ti113x.c and board/cpc45/pd67290.c (ATC and CPC45 are the only boards using CONFIG_82365). - Changes were tested for clean build and *very* *few* boards. | |||
2006-06-30 | Merge: Add support for AMCC 440SPe CPU based eval board (Yucca). | Marian Balakowicz | |
2006-06-30 | Add support for AMCC 440SPe CPU based eval board (Yucca). | Marian Balakowicz | |
2006-06-16 | Add support for gth2 board | Wolfgang Denk | |
Patch by Thomas Lange, Aug 11 2005 | |||
2006-06-16 | Add support for CONFIG_SERIAL_MULTI on MPC5xxx | Wolfgang Denk | |
Patch by Martin Krause, 8 Jun 2006 This patch supports two serial consoles on boards with a MPC5xxx CPU. The console can be switched at runtime by setting stdin, stdout and stderr to the desired serial interface (serial0 or serial1). The PSCs to be used as console port are definded by CONFIG_PSC_CONSOLE and CONFIG_PSC_CONSOLE2. See README.serial_multi for details. | |||
2006-05-30 | * Update Intel IXP4xx support | Wolfgang Denk | |
- Add IXP4xx NPE ethernet MAC support - Add support for Intel IXDPG425 board - Add support for Prodrive PDNB3 board - Add IRQ support Patch by Stefan Roese, 23 May 2006 [This patch does not include cpu/ixp/npe/IxNpeMicrocode.c which still sufferes from licensing issues. Blame Intel.] | |||
2006-05-15 | Fix PCMCIA support on virtlab2 | Wolfgang Denk | |
2006-05-12 | Cleanup compile warning. | Wolfgang Denk | |
2006-05-12 | Add support for VirtLab2 board | Wolfgang Denk | |
(needed because of differences in the PCMCIA hardware). | |||
2006-05-10 | Fix compile warnings in common/xyzModem.c | Stefan Roese | |
Patch by Stefan Roese, 10 May 2006 | |||
2006-05-09 | Merge with /home/m8/git/u-boot | Wolfgang Denk | |
2006-05-09 | Add M5271EVB board support. | Marian Balakowicz | |
