path: root/common/xyzModem.c
2017-04-08common/xyzModem.c: Do not use hard-coded address for debug bufferAlexandru Gagniuc
Under the plethora of #ifdefs, the xyzModem code hid this pearl: static char *zm_out = (char *) 0x00380000; This was only enabled when DEBUG is defined, so it's probably why it went unnoticed for so long. No idea what platform had memory at that exact location, but the this approach is extremely hacky. Use a static buffer instead. Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
2017-04-08common/xyzModem.c: unifdef (Remove useless #ifdefs)Alexandru Gagniuc
2016-11-28xyz-modem: Change getc timeout loop waitingtomas.melin@vaisala.com
This fixes the loop delay when using a hw watchdog. In case a watchdog is used that accesses CPU registers, the defined delay of 20us in a tight loop will cause a huge delay in the actual timeout seen. This is caused by the fact that udelay will inheritantly call WATCHDOG_RESET. Together with the omap wdt implementation, the seen timeout increases up to around 30s. This makes the loop very slow and causes long delays when using the modem. Instead, implement the 2 sec loop by using the timer interface to know when to break out of the timeout loop. Watchdog kicking is taken care of by getc(). Signed-off-by: Tomas Melin <tomas.melin@vaisala.com>
2016-03-14lib/crc16.c: Rename cyg_crc16() to crc16_ccitt() and add crc start valueStefan Roese
The original name of this function is unclear. This patch renames this CRC16 function to crc16_ccitt() matching its name with its implementation. To make the usage of this function more flexible, lets add the CRC start value as parameter to this function. This way it can be used by other functions requiring different start values than 0 as well. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2014-06-11common/xyzModem.c: move empty statements to newlineJeroen Hofstee
To prevent a warning for clang the loop without a body is made more clear by moving it to a line of its own. This prevents a clang warning. cc: sbabic@denx.de Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-07-24Add eCos-2.0 SPDX-License-Identifier to source filesWolfgang Denk
2012-11-04common/misc: sparse fixesKim Phillips
command.c:44:38: error: bad constant expression dlmalloc.c:1468:2: warning: Using plain integer as NULL pointer dlmalloc.c:1468:5: warning: Using plain integer as NULL pointer dlmalloc.c:2176:12: warning: Using plain integer as NULL pointer dlmalloc.c:2179:31: warning: Using plain integer as NULL pointer dlmalloc.c:2382:14: warning: Using plain integer as NULL pointer dlmalloc.c:2436:14: warning: Using plain integer as NULL pointer dlmalloc.c:2582:31: warning: Using plain integer as NULL pointer dlmalloc.c:2585:17: warning: Using plain integer as NULL pointer dlmalloc.c:2646:14: warning: Using plain integer as NULL pointer dlmalloc.c:2659:19: warning: Using plain integer as NULL pointer dlmalloc.c:2692:19: warning: Using plain integer as NULL pointer dlmalloc.c:2707:19: warning: Using plain integer as NULL pointer dlmalloc.c:2708:14: warning: Using plain integer as NULL pointer dlmalloc.c:2786:31: warning: Using plain integer as NULL pointer dlmalloc.c:2801:12: warning: Using plain integer as NULL pointer dlmalloc.c:2801:22: warning: Using plain integer as NULL pointer dlmalloc.c:2926:27: warning: Using plain integer as NULL pointer dlmalloc.c:2928:14: warning: Using plain integer as NULL pointer dlmalloc.c:2929:12: warning: Using plain integer as NULL pointer dlmalloc.c:3075:14: warning: Using plain integer as NULL pointer hush.c:292:14: warning: symbol 'last_return_code' was not declared. Should it be static? hush.c:293:5: warning: symbol 'nesting_level' was not declared. Should it be static? hush.c:2175:20: warning: Using plain integer as NULL pointer hush.c:2175:34: warning: Using plain integer as NULL pointer hush.c:2210:41: warning: Using plain integer as NULL pointer hush.c:2216:45: warning: Using plain integer as NULL pointer hush.c:2249:25: warning: Using plain integer as NULL pointer hush.c:2332:13: warning: symbol 'new_pipe' was not declared. Should it be static? hush.c:2390:5: warning: symbol 'reserved_word' was not declared. Should it be static? hush.c:2927:5: warning: symbol 'parse_stream' was not declared. Should it be static? hush.c:3127:6: warning: symbol 'mapset' was not declared. Should it be static? hush.c:3133:6: warning: symbol 'update_ifs_map' was not declared. Should it be static? hush.c:3161:5: warning: symbol 'parse_stream_outer' was not declared. Should it be static? hush.c:3295:34: warning: Using plain integer as NULL pointer hush.c:3631:5: warning: symbol 'do_showvar' was not declared. Should it be static image.c:1282:29: warning: Using plain integer as NULL pointer image.c:1315:41: warning: Using plain integer as NULL pointer image.c:1330:25: warning: Using plain integer as NULL pointer image.c:1706:25: warning: Using plain integer as NULL pointer main.c:510:10: warning: symbol 'hist_num' was not declared. Should it be static? main.c:512:5: warning: symbol 'hist_list' was not declared. Should it be static? main.c:513:6: warning: symbol 'hist_lines' was not declared. Should it be static? usb_storage.c:195:6: warning: symbol 'usb_show_progress' was not declared. Should it be static? usb_storage.c:440:48: warning: Using plain integer as NULL pointer usb_storage.c:503:5: warning: symbol 'usb_stor_BBB_comdat' was not declared. Should it be static? usb_storage.c:551:5: warning: symbol 'usb_stor_CB_comdat' was not declared. Should it be static? usb_storage.c:629:55: warning: Using plain integer as NULL pointer usb_storage.c:620:5: warning: symbol 'usb_stor_CBI_get_status' was not declared. Should it be static? usb_storage.c:675:43: warning: Using plain integer as NULL pointer usb_storage.c:668:5: warning: symbol 'usb_stor_BBB_clear_endpt_stall' was not declared. Should it be static? usb_storage.c:679:5: warning: symbol 'usb_stor_BBB_transport' was not declared. Should it be static? usb_storage.c:801:5: warning: symbol 'usb_stor_CB_transport' was not declared. Sh xyzModem.c:104:1: warning: symbol 'CYGACC_COMM_IF_GETC_TIMEOUT' was not declared. Should it be static? xyzModem.c:122:1: warning: symbol 'CYGACC_COMM_IF_PUTC' was not declared. Should it be static? xyzModem.c:169:1: warning: symbol 'parse_num' was not declared. Should it be stat note: hush.c's nesting_level deleted because not used. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-07-28cleanup: Fix typos and misspellings in various files.Mike Williams
Recieve/Receive recieve/receive Interupt/Interrupt interupt/interrupt Addres/Address addres/address Signed-off-by: Mike Williams <mike@mikebwilliams.com>
2009-07-19common: fix 'dummy' is used uninitialized in this function warningKim Phillips
fix this gcc 4.4 warning: xyzModem.c: In function 'xyzModem_stream_open': xyzModem.c:564: warning: 'dummy' is used uninitialized in this function Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2006-08-31Coding Style cleanup.Wolfgang Denk
Patch by Stefano Babic, 31 Aug 2006
2006-07-21More code cleanupWolfgang Denk
2006-05-10Fix compile warnings in common/xyzModem.cStefan Roese
Patch by Stefan Roese, 10 May 2006
2006-04-16Some code cleanupWolfgang Denk
2006-03-30Add support for ymodem protocol (loady command).Markus Klotzbuecher
Patch by Stefano Babic, 29 Mar 2006
