path: root/common/usb_storage.c
2008-04-13Coding Style cleanup; update CHANGELOGWolfgang Denk
2008-03-26USB, Storage: fix a bug introduced in commitMarkus Klotzbuecher
f6b44e0e4d18fe507833a0f76d24a9aa72c123f1 that will cause usb_stor_info to only print only information on one storage device, but not for multiple. Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2008-03-26USB Storage, add meaningful return valueAras Vaichas
This patch changes the "usb storage" command to return success if it finds a USB storage device, otherwise it returns error. Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2007-11-18Fix compiler warnings for PPC systems. Update CHANGELOG.Wolfgang Denk
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/* non-cmd*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04common/ non-cmd: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-02-20[PATCH 9_9] Use "void *" not "unsigned long *" for block dev read_write ↵Grant Likely
buffer pointers Block device read/write is anonymous data; there is no need to use a typed pointer. void * is fine. Also add a hook for block_read functions Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-02-20[PATCH 1_4] Merge common get_dev() routines for block devicesGrant Likely
Each of the filesystem drivers duplicate the get_dev routine. This change merges them into a single function in part.c Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2006-10-20Coding style cleanupWolfgang Denk
2006-08-22Add a fix for a buggy USB device on the FO300 board.Bartlomiej Sieka
2006-07-13Fix problems with SanDisk Corporation Cruzer Micro USB memory stick.Bartlomiej Sieka
2005-08-04(re)enabled scsi commands do_scsi() and do_scsiboot()Wolfgang Denk
Patch by Denis Peter, 06 Dec 2004
2005-08-02Coding style cleanupWolfgang Denk
2005-07-21Fix low-level OHCI transfers for ARM920t and MPC5xxxWolfgang Denk
A new, Windows compatible init sequence was also backported from Linux 2.6, but disabled with #undef NEW_INIT_SEQ as it wouldn't change the behaviour of the memopry sticks we tested. Maybe it's not relevant for mass storage devices. For recerence, see file common/usb.c, function usb_new_device(), section #ifdef NEW_INIT_SEQ.
2004-05-03* Fix minor NAND JFFS2 related issuewdenk
* Fixes for SL811 USB controller: - implement workaround for broken memory stick - improve error handling * Increase packet send timeout to 10 ms in cpu/mpc8xx/scc.c to better cope with congested networks.
2004-03-02* Fix SDRAM timings for LITE5200 / IceCube boardwdenk
* Handle Auti-MDIX / connection status for INCA-IP * Fix USB problems when attempting to read 0 bytes
2004-02-26* Patch by Markus Pietrek, 24 Feb 2004:wdenk
NS9750 DevBoard added * Patch by Pierre AUBERT, 24 Feb 2004 add USB support for MPC5200 * Patch by Steven Scholz, 24 Feb 2004: - fix MII commands to use values from last command * Patch by Torsten Demke, 24 Feb 2004: Add support for the eXalion platform (SPSW-8240, F-30, F-300)
2003-09-17Add auto-update code for TRAB board using USB memory stickswdenk
2003-09-11* Patch by Gary Jennejohn, 11 Sep 2003:wdenk
- allow for longer timeouts for USB mass storage devices * Patch by Denis Peter, 11 Sep 2003: - fix USB data pointer assignment for bulk only transfer. - prevent to display erased directories in FAT filesystem. * Change output format for NAND flash - make it look like for other memory, too
2003-09-10* Add support for USB Mass Storage Devices (BBB)wdenk
(tested with USB memory sticks only) * Avoid flicker on TRAB's VFD
