path: root/common/usb_storage.c
2018-11-14blk: Call part_init() in the post_probe() methodBin Meng
part_init() is currently called in every DM BLK driver, either in its bind() or probe() method. However we can use the BLK uclass driver's post_probe() method to do it automatically. Update all DM BLK drivers to adopt this change. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-10Remove <inttypes.h> includes and PRI* usages in printf() entirelyMasahiro Yamada
In int-ll64.h, we always use the following typedefs: typedef unsigned int u32; typedef unsigned long uintptr_t; typedef unsigned long long u64; This does not need to match to the compiler's <inttypes.h>. Do not include it. The use of PRI* makes the code super-ugly. You can simply use "l" for printing uintptr_t, "ll" for u64, and no modifier for u32. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-01usb: storage: Fix overwritten in usb_stor_set_max_xfer_blk()Bin Meng
The stored 'blk' value is overwritten to 'size / 512' before it can be used in usb_stor_set_max_xfer_blk(). This is not what we want. In fact, when 'size' exceeds the upper limit (USHRT_MAX * 512), we should simply assign 'size' to the upper limit. Reported-by: Coverity (CID: 167250) Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-27dm: usb: storage: Fix broken read/write when both EHCD and xHCD are enabledBin Meng
When EHCD and xHCD are enabled at the same time, USB storage device driver will fail to read/write from/to the storage device attached to the xHCI interface, due to its transfer blocks exceeds the xHCD driver limitation. With driver model, we have an API to get the controller's maximum transfer size and we can use that to determine the storage driver's capability of read/write. Note: the non-DM version driver is still broken with xHCD and the intent here is not to fix the non-DM one, since the xHCD itself is already broken in places like 3.0 hub support, etc. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-27usb: storage: Refactor to use max_xfer_blk from struct us_dataBin Meng
This adds a new memeber max_xfer_blk in struct us_data to record the maximum number of transfer blocks for the storage device. It is set per HCD setting, and so far is to 65535 for EHCD and 20 for everything else. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11dm: scsi: Drop the ccb typedefSimon Glass
We should not be using typedefs in U-Boot and 'ccb' is a pretty short name. It is also used with variables. Drop the typedef and use 'struct' instead. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-04-14usb: return 0 from usb_stor_get_info even if removable mediaTroy Kisky
This fixes a regression caused by commit 07b2b78ce4bc8ae25e066c65245eaf58c0d9a67c dm: usb: Convert USB storage to use driver-model for block devs which caused part_init to be called when it was not previously. Without this patch, the following happens when a USB sd card reader is used. => usb start starting USB... USB0: Port not available. USB1: USB EHCI 1.00 scanning bus 1 for devices... 3 USB Device(s) found scanning usb for storage devices... Device NOT ready Request Sense returned 02 3A 00 ### ERROR ### Please RESET the board ### This happens because dev_desc->blksz is 0. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2017-01-17usb: storage: Show number of storage devices detected for DM_USBMichal Simek
By enabling DM_USB information about number of storage devices was lost. Get this information back simply by printing number of devices detected via BLK uclass. For example: scanning bus 0 for devices... 7 USB Device(s) found scanning usb for storage devices... 3 Storage Device(s) found scanning usb for ethernet devices... 0 Ethernet Device(s) found Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-09-23usb: squash lines for immediate returnMasahiro Yamada
This makes functions much simpler. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-17dm: blk: Add a easier way to create a named block deviceSimon Glass
Add a function that automatically builds the device name given the parent and a supplied string. Most callers will want to do this, so putting this functionality in one place makes more sense. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: usb: Drop the get_dev() functionSimon Glass
This function is implemented by the legacy block functions now. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: usb: Add a legacy block interface for USB storageSimon Glass
Add a legacy block interface for USB storage. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-22usb: Correct return value in usb_stor_info()Simon Glass
This should return 0 on success, not 1. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-22Fix spelling of "transferred".Vagrant Cascadian
Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14dm: usb: Convert USB storage to use driver-model for block devsSimon Glass
Update this code to support CONFIG_BLK. Each USB storage device can have one or more block devices as children, each one representing a LUN (logical unit) of the USB device. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: usb: Tidy up storage code ready for driver model conversionSimon Glass
Adjust a few things so that the addition of driver-models support involved adding code rather than also changing it. This makes the patches easier to review. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: usb: Avoid exceeding available array size for storage devicesSimon Glass
The limit on storage devices is USB_MAX_STOR_DEV but we use one extra element while probing to see if a device is a storage device. Avoid this, since it causes memory corruption. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: block: Rename device number member dev to devnumSimon Glass
This is a device number, and we want to use 'dev' to mean a driver model device. Rename the member. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: part: Rename some partition functionsSimon Glass
Rename three partition functions so that they start with part_. This makes it clear what they relate to. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: Drop the block_dev_desc_t typedefSimon Glass
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long and causes 80-column violations, rename it to struct blk_desc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-01-20usb: Define USB_MAX_STOR_DEV in only one placeSimon Glass
We can define this in the header file and use it in usb_storage.c. There is no need to define it twice. Remove the #define from usb_storage.c. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2016-01-13block: pass block dev not num to read/write/erase()Stephen Warren
This will allow the implementation to make use of data in the block_dev structure beyond the base device number. This will be useful so that eMMC block devices can encompass the HW partition ID rather than treating this out-of-band. Equally, the existence of the priv field is crying out for this patch to exist. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-07usb: Allow up to 7 storage devicesSimon Glass
The current limit of 5 is not enough for the driver model USB tests. Really we should not have a limit but the driver model code still uses the usb_dev_desc[] array, which has a limit. Increasing the limit by 2 should not bother anyone. Adjust it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-11-03common/usb_storage.c: Clean up usb_storage_probe()Tom Rini
We have the protocol and subclass variables which are used only in disabled debug code. This code dates back to the initial git import and seemingly dead code so remove it. This was detected by Coverity (CID 131117) Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-23dm: Rename dev_get_parentdata() to dev_get_parent_priv()Simon Glass
The current name is inconsistent with other driver model data access functions. Rename it and fix up all users. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2015-09-11Move ALLOC_CACHE_ALIGN_BUFFER() to the new memalign.h headerSimon Glass
Now that we have a new header file for cache-aligned allocation, we should move the stack-based allocation macro there also. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21dm: usb: Adjust the USB_DEVICE() macro namingSimon Glass
In Linux USB_DEVICE() is used to declare a USB device by vendor/device ID. We should follow the same convention in U-Boot. Rename the existing USB_DEVICE() macro to U_BOOT_USB_DEVICE() and bring in the USB_DEVICE() macro from Linux for use in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: usb: Convert usb_storage to driver modelSimon Glass
Add support for scanning USB storage devices with driver model. This mostly involves adding a USB device ID for storage devices. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Move storage device scanning into its own functionSimon Glass
The usb_stor_scan() function is quite long, so split out the code that scans each device into its own function. Also, rather than setting up the block device list once at the start, set it up as each device is scanned. This makes it possible to use this code from driver model. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18Revert "usb_storage : scan all interfaces to find a storage device"Simon Glass
This reverts commit cd749658d5994978579628a6333e5c2a6c8ec632. The conflicts with this commit are hard for me to figure out. I will re-apply it later.
2015-04-18dm: usb: Adjust usb_storage to work with sandboxSimon Glass
With a few tweaks we can compile this code with sandbox and enable testing of the USB storage layer. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Simply device finding code in usb_storageSimon Glass
The for() loop is not needed since the value is immediately accessible. Use this instead to simplify the code. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Fix type problems in usb_stor_get_info()Simon Glass
This function assumes that unsigned long is 32-bits wide, but it is not on 64-bit machines. Use the correct type, and add a few debug() lines also. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Move USB storage definitions to usb_defs.hSimon Glass
These are better off in a header file so they can be used by other code (e.g. the sandbox USB storage emulator). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-14usb_storage:Fix USB storage capacity detection on 64 bit architecturesSergey Temerkhanov
This patch fixes USB storage capacity detection breakage on 64-bit systems which arises due to 'unsigned long' length difference. Old code assumes that to be 32 bit and breaks because of inappropriate response buffer layout. Also this fixes a number of build warnings and changes big-endian values treatment style to be architecture-independent Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com> Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com>
2015-04-14usb_storage : scan all interfaces to find a storage deviceFranck Jullien
Mass storage is not necessary present on interface 0. This patch allow usb_stor_scan to look in every available interface. Signed-off-by: Franck Jullien <franck.jullien@gmail.com>
2014-11-08usb_storage: blacklist Enclosure Service DevicesSoeren Moch
Skip enclosure service devices when probing for usb storage devices. This avoids long timeouts when probing for external usb harddisks which provide "Enclosure Services". Signed-off-by: Soeren Moch <smoch@web.de> -- This is a new version of the patch "usb_storage: skip all unknown devices when probing" http://http://lists.denx.de/pipermail/u-boot/2014-November/194622.html Cc: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com>
2014-10-27usb: Use correct printf() format string for uintptr_tSimon Glass
Use the inttypes header file to provide this. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26Fix block device accesses beyond 2TiBSascha Silbe
With CONFIG_SYS_64BIT_LBA, lbaint_t gets defined as a 64-bit type, which is required to represent block numbers for storage devices that exceed 2TiB (the block size usually is 512B), e.g. recent hard drives. For some obscure reason, the current U-Boot code uses lbaint_t for the number of blocks to read (a rather optimistic estimation of how RAM sizes will evolve), but not for the starting address. Trying to access blocks beyond the 2TiB boundary will simply wrap around and read a block within the 0..2TiB range. We now use lbaint_t for block start addresses, too. This required changes to all block drivers as the signature of block_read(), block_write() and block_erase() in block_dev_desc_t changed. Signed-off-by: Sascha Silbe <t-uboot@infra-silbe.de>
2013-05-05USB: Some cleanup prior to USB 3.0 interface additionVivek Gautam
Some cleanup in usb framework, nothing much on feature side. Signed-off-by: Vikas C Sajjan <vikas.sajjan@samsung.com> Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
2013-05-05usb: common: Weed out USB_**_PRINTFs from usb frameworkVivek Gautam
USB_PRINTF, USB_HUB_PRINTF, USB_STOR_PRINTF, USB_KBD_PRINTF are nothing but conditional debug prints, depending on DEBUG. So better remove them and use debug() simply. Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
2013-05-01part/dev_desc: Add log2 of blocksize to block_dev_desc data structEgbert Eich
log2 of the device block size serves as the shift value used to calculate the block number to read in file systems when implementing avaiable block sizes. It is needed quite often in file systems thus it is pre-calculated and stored in the block device descriptor. Signed-off-by: Egbert Eich <eich@suse.com>
2012-12-17usb: properly detect empty mass storage media readerVincent Palatin
When a USB card reader is empty, it will return "Not Ready - medium not present" as Key Code Qualifier. In that situation, it's useless waiting for the full timeout since the result won't change until the user inserts a card. Signed-off-by: Vincent Palatin <vpalatin@chromium.org> Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-04common/misc: sparse fixesKim Phillips
command.c:44:38: error: bad constant expression dlmalloc.c:1468:2: warning: Using plain integer as NULL pointer dlmalloc.c:1468:5: warning: Using plain integer as NULL pointer dlmalloc.c:2176:12: warning: Using plain integer as NULL pointer dlmalloc.c:2179:31: warning: Using plain integer as NULL pointer dlmalloc.c:2382:14: warning: Using plain integer as NULL pointer dlmalloc.c:2436:14: warning: Using plain integer as NULL pointer dlmalloc.c:2582:31: warning: Using plain integer as NULL pointer dlmalloc.c:2585:17: warning: Using plain integer as NULL pointer dlmalloc.c:2646:14: warning: Using plain integer as NULL pointer dlmalloc.c:2659:19: warning: Using plain integer as NULL pointer dlmalloc.c:2692:19: warning: Using plain integer as NULL pointer dlmalloc.c:2707:19: warning: Using plain integer as NULL pointer dlmalloc.c:2708:14: warning: Using plain integer as NULL pointer dlmalloc.c:2786:31: warning: Using plain integer as NULL pointer dlmalloc.c:2801:12: warning: Using plain integer as NULL pointer dlmalloc.c:2801:22: warning: Using plain integer as NULL pointer dlmalloc.c:2926:27: warning: Using plain integer as NULL pointer dlmalloc.c:2928:14: warning: Using plain integer as NULL pointer dlmalloc.c:2929:12: warning: Using plain integer as NULL pointer dlmalloc.c:3075:14: warning: Using plain integer as NULL pointer hush.c:292:14: warning: symbol 'last_return_code' was not declared. Should it be static? hush.c:293:5: warning: symbol 'nesting_level' was not declared. Should it be static? hush.c:2175:20: warning: Using plain integer as NULL pointer hush.c:2175:34: warning: Using plain integer as NULL pointer hush.c:2210:41: warning: Using plain integer as NULL pointer hush.c:2216:45: warning: Using plain integer as NULL pointer hush.c:2249:25: warning: Using plain integer as NULL pointer hush.c:2332:13: warning: symbol 'new_pipe' was not declared. Should it be static? hush.c:2390:5: warning: symbol 'reserved_word' was not declared. Should it be static? hush.c:2927:5: warning: symbol 'parse_stream' was not declared. Should it be static? hush.c:3127:6: warning: symbol 'mapset' was not declared. Should it be static? hush.c:3133:6: warning: symbol 'update_ifs_map' was not declared. Should it be static? hush.c:3161:5: warning: symbol 'parse_stream_outer' was not declared. Should it be static? hush.c:3295:34: warning: Using plain integer as NULL pointer hush.c:3631:5: warning: symbol 'do_showvar' was not declared. Should it be static image.c:1282:29: warning: Using plain integer as NULL pointer image.c:1315:41: warning: Using plain integer as NULL pointer image.c:1330:25: warning: Using plain integer as NULL pointer image.c:1706:25: warning: Using plain integer as NULL pointer main.c:510:10: warning: symbol 'hist_num' was not declared. Should it be static? main.c:512:5: warning: symbol 'hist_list' was not declared. Should it be static? main.c:513:6: warning: symbol 'hist_lines' was not declared. Should it be static? usb_storage.c:195:6: warning: symbol 'usb_show_progress' was not declared. Should it be static? usb_storage.c:440:48: warning: Using plain integer as NULL pointer usb_storage.c:503:5: warning: symbol 'usb_stor_BBB_comdat' was not declared. Should it be static? usb_storage.c:551:5: warning: symbol 'usb_stor_CB_comdat' was not declared. Should it be static? usb_storage.c:629:55: warning: Using plain integer as NULL pointer usb_storage.c:620:5: warning: symbol 'usb_stor_CBI_get_status' was not declared. Should it be static? usb_storage.c:675:43: warning: Using plain integer as NULL pointer usb_storage.c:668:5: warning: symbol 'usb_stor_BBB_clear_endpt_stall' was not declared. Should it be static? usb_storage.c:679:5: warning: symbol 'usb_stor_BBB_transport' was not declared. Should it be static? usb_storage.c:801:5: warning: symbol 'usb_stor_CB_transport' was not declared. Sh xyzModem.c:104:1: warning: symbol 'CYGACC_COMM_IF_GETC_TIMEOUT' was not declared. Should it be static? xyzModem.c:122:1: warning: symbol 'CYGACC_COMM_IF_PUTC' was not declared. Should it be static? xyzModem.c:169:1: warning: symbol 'parse_num' was not declared. Should it be stat note: hush.c's nesting_level deleted because not used. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-10-22usb: Support the CONFIG_SYS_64BIT_LBA optionGabe Black
usb_storage wouldn't compile when the CONFIG_SYS_64BIT_LBA option is turned on because the used fixed size data types in their exported functions when they should have used lbaint_t for the block count parameter. That meant that when the sizes happened to be the same, when using a 28 bit LBA, the driver would build, but when it wasn't, a 48 bit LBA, things broke. This change adjusts the signatures to use the right type and makes small adjustments in the affected functions. Signed-off-by: Gabe Black <gabeblack@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2012-10-15usb: add support for multiple usb controllersLucas Stach
Allows to initialize more than one USB controller at once. v2: print message when controller stop fails Signed-off-by: Lucas Stach <dev@lynxeye.de> Reviewed-by: Marek Vasut <marex@denx.de>
2012-09-01usb: Optimize USB storage read/writeJim Shimer
Trim down the IO times by removing uneeded test unit reeady calls. Signed-off-by: Jim Shimer <mgi2475@motorola.com>
