path: root/common/stdio.c
2013-08-13serial: arm_dcc: Remove stdio structure supportJagannadha Sutradharudu Teki
Removed stdio structure ops support on arm_dcc driver, and need to register with serial core so-that it can access like remianing serial drivers. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c: common changes for multibus/multiadapter supportHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org> Cc: Henrik Nordström <henrik@henriknordstrom.net>
2013-02-04serial: arm_dcc: Remove CONFIG_ARM_DCC_MULTI optionMichal Simek
CONFIG_ARM_DCC_MULTI should be also removed in the patch "serial: Remove CONFIG_SERIAL_MULTI from serial drivers" (sha1: a3827250606895ec2dd4b8d867342b7cabf3692f) Because the driver defines serial_* functions which cause conflict with serial.c (multiple definition of serial_*) Removing CONFIG_SERIAL_MULTI function also require to define default_serial_console for cases where another serial driver is not available in the system. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Marek Vasut <marex@denx.de>
2012-12-11stdio: remove useless strncpyVincent Palatin
The name is already copied when we memcpy() the whole structure. This is because struct stdio_dev has this field: char name[16]; /* Device name */ So the data is inline, rather than being a pointer. Signed-off-by: Vincent Palatin <vpalatin@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-30x86: Add CBMEM console driver for corebootVadim Bendebury
This patch builds upon the recently introduced CBMEM console feature of coreboot. CBMEM console uses a memry area allocated by coreboot to store the console output. The memory area has a certain structure, which allows to determine where the buffer is, the buffer size and the location of the pointer in the buffer. This allows different phases of the firmware (rom based coreboot, ram based coreboot, u-boot after relocation with this change) to keep adding text to the same buffer. Note that this patch introduces a new console driver and adds the driver to the list of drivers to be used for console output, i.e. it engages only after u-boot relocates. Usiong CBMEM console for capturing the pre-relocation console output will be done under a separate change. >From Linux, run the cbmem.py utility (which is a part of the coreboot package) to see the output, e.g.: vvvvvvvvvvvvvvvvv SCSI: AHCI 0001.0300 32 slots 6 ports ? Gbps 0xf impl SATA mode flags: 64bit ilck stag led pmp pio ... Magic signature found Kernel command line: "cros_secure quiet loglevel=1 console=tty2... ^^^^^^^^^^^^^^^^^ Note that the entire u-boot output fits into the buffer only if the coreboot log level is reduced from the most verbose. Ether the buffer size will have to be increased, or the coreboot verbosity permanently reduced. Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from remaining sourcesMarek Vasut
Remove the parts depending either on disabled CONFIG_SERIAL_MULTI or ifdefs around CONFIG_SERIAL_MULTI parts since CONFIG_SERIAL_MULTI is now enabled by default. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de>
2011-09-04stdio: Fix a possible buffer overflowBradley Bolen
Signed-off-by: Bradley Bolen <bradleybolen at yahoo.com>
2010-11-28stdio: constify "name" arg in public apiMike Frysinger
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2009-10-03arm/microblaze/nios/nios2/sh: Remove relocation fixupsPeter Tyser
These architectures don't need relocation fixups, so reduce their codesize a bit by defining CONFIG_RELOC_FIXUP_WORKS. Also remove the reloc_off field from their global data structures as it is no longer needed. Note that the location of the standalone application jump table pointer in the global data structure is affected by this change, breaking execution of standalone applications compiled for previous versions of U-Boot. We will therefore increment XF_VERSION in the next commit, which also touches this area. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-10-03Conditionally perform common relocation fixupsPeter Tyser
Add #ifdefs where necessary to not perform relocation fixups. This allows boards/architectures which support relocation to trim a decent chunk of code. Note that this patch doesn't add #ifdefs to architecture-specific code which does not support relocation. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
