path: root/common/splash_source.c
2016-07-25splash: Accommodate DM_USB in splash_init_usb()Alexey Brodkin
Current implementation of splash_init_usb() requires usb_stor_scan() which doesn't exist in case of DM_USB simply because real probing happens right in usb_init(). So disable usage of usb_stor_scan() in case of DM_USB. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Simon Glass <sjg@chromium.org> Cc: Jeroen Hofstee <jeroen@myspectrum.nl> Cc: Anatolij Gustschin <agust@denx.de> Cc: Robert Winkler <robert.winkler@boundarydevices.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-06-14splash_source: add support for ubifs formatted nandEran Matityahu
Add support for loading splash image from NAND Flash formatted with a (UBI) filesystem. Signed-off-by: Eran Matityahu <eran.m@variscite.com> Cc: Heiko Schocher <hs@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@konsulko.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Nikita Kiryanov <nikita@compulab.co.il>
2016-06-03nand: Embed mtd_info in struct nand_chipScott Wood
nand_info[] is now an array of pointers, with the actual mtd_info instance embedded in struct nand_chip. This is in preparation for syncing the NAND code with Linux 4.6, which makes the same change to struct nand_chip. It's in a separate commit due to the large amount of changes required to accommodate the change to nand_info[]. Signed-off-by: Scott Wood <oss@buserror.net>
2015-11-16splash_source: add support for filesystem formatted sataNikita Kiryanov
Add support for loading splashimage from filesystem formatted sata storage. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2015-11-16splash_source: add support for filesystem formatted usbNikita Kiryanov
Add support for loading splash image from USB drive formatted with a filesystem. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2015-11-16splash_source: add support for filesystem formatted mmcNikita Kiryanov
Add support for loading splash image from an SD card formatted with a filesystem. Update boards to maintain original behavior where needed. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2015-11-16splash_source: rename *_read() to *_read_raw()Nikita Kiryanov
Rename raw read functions to *_read_raw() in preparation for supporting read_fs() feature. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-01-29common: convert compulab splash load code to common codeNikita Kiryanov
Move board/compulab/common/splash.c code to common/splash_source.c to make it available for everybody. This move renames cl_splash_screen_prepare() to splash_source_load(), and the compilation of this code is conditional on CONFIG_SPLASH_SOURCE. splash_source features: * Provide a standardized way for declaring board specific splash screen locations * Provide existing routines for auto loading the splash image from the locations as declared by the board * Introduce the "splashsource" environment variable, which makes it possible to select the splash image source. cm-t35 and cm-fx6 are updated to use the modified version. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Anatolij Gustschin <agust@denx.de> Reviewed-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
