path: root/common/splash.c
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-26splash: Introduce default_splash_locationsAlexey Brodkin
This change introduces default_splash_locations which simplifies splash recovery from the first partition of USB/MMC/SATA drive. Given usual mapping of the first partition of external media for basic boot stuff like uImage/zImage, .dtb etc it looks quite obvious option to put there splash.bmp as well. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Simon Glass <sjg@chromium.org> Cc: Jeroen Hofstee <jeroen@myspectrum.nl> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2015-02-10lcd: split splash code into its own functionNikita Kiryanov
lcd_logo() currently performs tasks well beyond just displaying the logo. It has code which displays splash image, it has logic which determines when the different display features are displayed, and it is coupled with the lcd console because it holds the responsibility of returning the lcd console base address. Make lcd_logo() just about the logo by: * Moving splash image display code into a dedicated function * Moving the logic regarding when various features are displayed to lcd_clear() (which is arguably not the correct name for housing such code either, but it is currently the most fitting location code wise) * Move the responsibility of setting the console base address to lcd_clear() too. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
2014-07-18common:splash: use __weakJeroen Hofstee
This not only looks a bit better it also prevents a warning with W=1 (no previous prototype). cc: agust@denx.de Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-07-08video: consolidate splash screen alignment codeAnatolij Gustschin
Code for checking "splashpos" environment variable is duplicated in drivers, move it to the common function. Call this function also in the bmp display command to consider "splashpos" settings. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-07-01video: lcd: Make splash_screen_prepare weak, remove config macroRobert Winkler
Remove CONFIG_SPLASH_SCREEN_PREPARE from README Add doc/README.splashprepare to document functionality Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-07-01video: lcd: Add CONFIG_SPLASH_SCREEN_PREPARE support to CONFIG_VIDEORobert Winkler
Create splash.c/h to put the function and any future common splash screen code in. Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
