path: root/common/spl/spl_xip.c
2017-11-06stm32: fix STMicroelectronics copyrightPatrice Chotard
Uniformize STMicroelectronics copyrights headers for STM32 related code. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-06-09SPL: Add XIP booting supportVikas Manocha
Enable support for XIP (execute in place) of U-Boot or kernel image. There is no need to copy image from flash to ram if flash supports execute in place. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Alexandru Gagniuc <alex.g@adaptrum.com>
