If CONFIG_SPL_LIBCOMMON_SUPPORT is not defined there is a lone case statement
at the end of the switch leading to a compile error.
Remove the offending case statement.
| common/spl/spl_mmc.c:339:7: error: label at end of compound statement
(cherry picked from commit c8d7647f639813cff08a4a7de62db815829ec72b)
Upda the SPL FIT code to use the spl_image parameter.
Update the fat loader to avoid using the spl_image global variable.
Update the ext loader to avoid using the spl_image global variable.
Rather than having a global variable, pass the spl_image as a parameter.
This avoids BSS use, and makes it clearer what the function is actually
doing.
Add a linker list declaration for this method and remove the explicit
switch() code.
At present some spl_xxx_load_image() functions take a parameter and some
don't. Of those that do, most take an integer but one takes a string.
Convert this parameter into a struct so that we can pass all functions the
same thing. This will allow us to use a common function signature.
Instead of using the global spl_image variable, pass the required struct in
as an argument.
Fix up the call in mmc_load_image_raw_partition() to use the correct
function to obtain the MMC device, so that this code can support driver
model.
Update the method of accessing the block device so that it works with
CONFIG_BLK enabled.
The SPL code already knows which boot device it calls the spl_boot_mode()
on, so pass that information into the function. This allows the code of
spl_boot_mode() avoid invoking spl_boot_device() again, but it also lets
board_boot_order() correctly alter the behavior of the boot process.
The later one is important, since in certain cases, it is desired that
spl_boot_device() return value be overriden using board_boot_order().
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
[add newly introduced zynq variant]
Signed-aff-by: Andreas Bießmann <andreas@biessmann.org>
For odroid-c2 (arch-meson) for now disable designware eth as meson
now needs to do some harder GPIO work.
lib/efi_loader/efi_disk.c
Modified:
configs/odroid-c2_defconfig
This provides a way to load a FIT containing U-Boot and a selection of device
tree files from a File system. Making sure that all the reads and writes
are aligned to their respective needs.
Tested-by: Michal Simek <michal.simek@xilinx.com>
[trini: Make this still apply with Michal's alignment change for 'fit']
Allow driver model to be used for block devices in SPL.
Avoid calling directly into the MMC code - use the new API call instead.
Allow the spl_parse_image_header() to return value. This is convenient
for controlling the SPL boot flow if the loaded image is corrupted.
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Peng Fan <van.freenix@gmail.com>
The error message "spl: mmc block read error" may come from two
different functions, so we should better annotate the function name
where the error comes from to help debugging.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
If CONFIG_SPL_OS_BOOT is enabled and Linux image is not flashed at
RAW_MODE_KERNEL_SECTOR in MMC, spl still assumes that Linux is
available and tries to boot it and hangs. In order to avoid this,
adding a check to verify if parsed image header is of type IH_OS_LINUX.
If it fails then fall back to load u-boot image.
The function spl_parse_image_header() falls back to a raw image
if the U-Boot header is missing and CONFIG_SPL_PANIC_ON_RAW_IMAGE
is undefined. While, mmc_load_image_raw_sector() only accepts a
U-Boot legacy image or an FIT image, preventing us from loading a
raw image.
Detect a FIT when loading from MMC and handle it using the new FIT SPL
support.
Rename three partition functions so that they start with part_. This makes
it clear what they relate to.
Since commit fd61d39970b9901217efc7536d9f3a61b4e1752a:
spl: mmc: add break statements in spl_mmc_load_image()
RAW and FS boot modes are now exclusive again. So, if MMCSD_MODE_RAW fails, the
board hangs. This patch allows to try MMCSD_MODE_FS then.
It has been tested on a beaglebone black to boot on an EXT partition.
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Paul Kocialkowski <contact@paulk.fr>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
Cc: Matwey V. Kornilov <matwey.kornilov@gmail.com>
Acked-by: Nikita Kiryanov <nikita@compulab.co.il>
This will allow the implementation to make use of data in the block_dev
structure beyond the base device number. This will be useful so that eMMC
block devices can encompass the HW partition ID rather than treating this
out-of-band. Equally, the existence of the priv field is crying out for
this patch to exist.
In order to support boot from multiple devices through board_boot_order,
it's necessary to use the block number of a device.
The use of a hard-coded 0 for the device number also creates a need
to re-order block devices for use in SPL like this:
http://git.denx.de/?p=u-boot.git;a=blob;f=board/freescale/mx6slevk/mx6slevk.c;hb=HEAD#l195
Signed-off-by: Eric Nelson <eric@nelint.com>
It is risky to have two different functions with much the same code. Future
authors may update one but not the other. It is hard to see which parts are
the same and which are different.
Unify the functions and drop the differences that are not really needed.
Note that one puts() becomes printf() as Tom mentioned that this does not
affect image size:
https://patchwork.ozlabs.org/patch/537276/
Note: It would be better to have an empty printf() and avoid the #ifdef for
CONFIG_SPL_LIBCOMMON_SUPPORT.
The 'p' suffix makes it more obvious that we are dealing with a pointer
to a (pointer) value that will be returned to its caller.
Since commit 4188ba3 we get the following warning on rockchip boards:
common/spl/spl_mmc.c:31:24: warning: ‘mmc’ may be used uninitialized in this function [-Wmaybe-uninitialized]
count = mmc->block_dev.block_read(0, sector, 1, header);
common/spl/spl_mmc.c:251:14: note: ‘mmc’ was declared here
struct mmc *mmc;
Correct this by move the variable init earlier.
Currently the mmc device that SPL looks at is always mmc0, regardless
of the BOOT_DEVICE_MMCx value. This forces some boards to
implement hacks in order to boot from other mmc devices.
Make SPL take into account the correct mmc device.
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Make spl_*_load_image() functions return a value instead of
hanging if a problem is encountered. This enables main spl code
to make the decision whether to hang or not, thus preparing
it to support alternative boot devices.
Some boot devices (namely nand and spi) do not hang on error.
Instead, they return normally and SPL proceeds to boot the
contents of the load address. This is considered a bug and
is rectified by hanging on error for these devices as well.
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Hans De Goede <hdegoede@redhat.com>
Cc: Jagan Teki <jteki@openedev.com>
Get rid of emmc boot code duplication in spl_mmc_load_image() using a switch
case fallthrough into MMCSD_MODE_RAW. Since the #ifdef CONFIG_SUPPORT_EMMC_BOOT
check is not really necessary, remove it in the process.
No functional changes.
Move the code that handles fs boot out of spl_mmc_load_image() and into its
own function to reduce the #ifdef complexity of spl_mmc_load_image().
Implement defaults for the raw partition image loading so that the #ifdef
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION in spl_mmc_load_image() will no
longer be necessary.
This change makes it possible for mmc_load_image_raw_partition() and
mmc_load_image_raw_sector() to coexist.
Implement default versions of falcon mode functions to make the
CONFIG_SPL_OS_BOOT check in spl_mmc_load_image() unnecessary, thus reducing
its #ifdef complexity.
Cc: Guillaume GARDET <guillaume.gardet@free.fr>
Cc: Suriyan Ramasami <suriyan.r@gmail.com>
Simplify spl_mmc_load_image() code by moving the part that finds the mmc device
into its own function spl_mmc_find_device(), available in two flavors: DM and
non-DM.
This refactor fixes a bug in which an error in the device location sequence
does not necessarily aborts the rest of the code. With this refactor, we fail
the moment there is an error.
The original intention of the mmc load_image() function was to try multiple
boot modes before failing. This is evident by the lack of break statements
in the switch, and the following line in the default case:
puts("spl: mmc: no boot mode left to try\n");
This implementation is problematic because:
- The availability of alternative boot modes is very arbitrary since it
depends on the specific order of the switch cases. If your boot mode happens to
be the first case, then you'll have a bunch of other boot modes as alternatives.
If it happens to be the last case, then you have none.
- Opting in/out is tied to config options, so the only way for you to prevent an
alternative boot mode from being attempted is to give up on the feature completely.
- This implementation makes the code more complicated and difficult to
understand.
Address these issues by inserting a break statements between the cases to make the
function try only one boot mode.
Make the cast explicit for "warning: cast to pointer from integer of different size".
Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
This patch introduces the option to boot from a MMC card parition with
an offset. This can be done by using both defines together:
define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION 1
define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR ((160 << 10) / 512)
The example above loads the main U-Boot at offset 160KiB from the MMC
partition 1.
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Dirk Eibach <eibach@gdsys.de>
Enable MMC using driver model in SPL for consistency with U-Boot proper.
Add a few messages to indicate progress and failure.
This allows using only one of either raw or fs mode for SPL mmc boot, without
the need to have provisions for the other. In particular, a device may have
U-Boot installed on a file system on the mmc, without ever needing to read
U-Boot from raw memory. Thus, there is no reason to provide a sector or
partition for raw mode. This allows this behaviour and still provides a robust
fallback mechanism in case provisions for both modes are defined.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
This switches some printf calls to puts and avoids a test repetition.
This introduces a distinction between return codes that are read bytes counts
and errors. Read bytes counts are erroneous when null (no data was read) while
errors are erroneous when non-null.
Tested-by: Tim Harvey <tharvey@gateworks.com>
91199f4a5a21a7cf9dd9e7c05e295a042f8c2b7e broke mmc based Falcon mode.
The block_read function returns the number of blocks read thus the error
check needs to look for a return of 0 blocks read.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
Acked-by: Paul Kocialkowski <contact@paulk.fr>
This adds support for providing a partition number instead of a sector for eMMC.
This refactors spl_mmc_load_image to use a switch/case structure and easier
to understand spl_start_uboot checks. This also introduces some more automatic
fallback on the next mmc boot mode as long as it keeps failing.
Lines that go beyond 80 chars are also reduced by reducing the number of tabs.
Debug and error strings are refctored to match a common style.
[trini: Fix a thinko in the SPL_EXT_SUPPORT + SPL_OS conversion, make part be
__maybe_unused]
Various files are needlessly rebuilt every time due to the version and
build time changing. As version.h is not actually needed, remove the
include.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Macpaul Lin <macpaul@andestech.com>
Cc: York Sun <yorksun@freescale.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Cc: Philippe Reynes <tremyfr@yahoo.fr>
Cc: Eric Jarrige <eric.jarrige@armadeus.org>
Cc: "David Müller" <d.mueller@elsoft.ch>
Cc: Phil Edworthy <phil.edworthy@renesas.com>
Cc: Robert Baldyga <r.baldyga@samsung.com>
Cc: Torsten Koschorrek <koschorrek@synertronixx.de>
Reviewed-by: Łukasz Majewski <l.majewski@samsung.com>
4c5bbc2328a24f5e1ee990c9a9527e48e5fb3b5f)
As reported by Robert Nelson, commit 4c5bbc2328a24f5e1ee990c9a9527e48e5fb3b5f
may break MMC RAW boot mode.
This patch fixes the check path to fix MMC Raw boot mode.
Tested raw boot mode and FS boot mode on a pandaboard (rev. A3).
Reported-by: Robert Nelson <robertcnelson@gmail.com>
Cc: Tom Rini <trini@ti.com>
Cc: Robert Nelson <robertcnelson@gmail.com>
Tested-by: Robert Nelson <robertcnelson@gmail.com>
In SPL MMC, boot modes are exclusive. So, if MMCSD_MODE_RAW fails, the board hangs. This patch allows to
try MMCSD_MODE_FS then, if available.
It has been tested on a pandaboard (rev. A3).
