path: root/common/spl/Makefile
2017-11-26spl: rename config item SPL_ATF_SUPPORT to SPL_ATFPhilipp Tomsich
Having CONFIG_SPL_ATF seems more natural. Rename it, while it it is easy and there's few boards that use it (only RK3399 and RK3368 boards). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-23spl: add serial download protocol (SDP) supportStefan Agner
Add USB serial download protocol support to SPL. If the SoC started in recovery mode the SPL will immediately switch to SDP and wait for further downloads/commands from the host side. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Ɓukasz Majewski <lukma@denx.de>
2017-08-17spl: fix Makefile for NOR, XIP and YMODEMPhilipp Tomsich
During the the conversion to $(SPL_TPL_), the SPL_ fragment was left over for the NOR, XIP and YMODEM boot methods in SPL, making these unselectable. This commit fixes this by dropping the spurious 'SPL_' fragment from each line. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reported-by: Bo Shen <voice.shen@gmail.com> Fixes: f94e643 (spl: consistently use $(SPL_TPL_) to select features for SPL and TPL builds)
2017-08-13spl: consistently use $(SPL_TPL_) to select features for SPL and TPL buildsPhilipp Tomsich
To allow for a finer-grained control of features for TPL and SPL builds all modules/boot-methods/etc. need to be consistently selected based on the $(SPL_TPL_) macros. This allows splitting the associated config-options in Kconfig: we don't split the Kconfig options here and now, as this should happen on an as-needed basis, whenever someone needs a feature/boot-method/etc. in their TPL. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-13spl: add a 'return to bootrom' boot methodPhilipp Tomsich
Some devices (e.g. the RK3368) have only limited SRAM, but provide support for loading the next boot stage after our SPL performs basic setup (e.g. DRAM). For target systems like these, we add a boot device BOOTROM that will invoke a board-specific hook to return to the bootrom (if supported). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-09SPL: Add XIP booting supportVikas Manocha
Enable support for XIP (execute in place) of U-Boot or kernel image. There is no need to copy image from flash to ram if flash supports execute in place. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Alexandru Gagniuc <alex.g@adaptrum.com>
2017-05-15spl: add support to booting with ATFKever Yang
ATF(ARM Trusted Firmware) is used by ARM arch64 SoCs, find more infomation about ATF at: https://github.com/ARM-software/arm-trusted-firmware SPL is considered as BL2 in ATF terminology, it needs to load other parts of ATF binary like BL31, BL32, SCP-BL30, and BL33(U-Boot). And needs to prepare the parameter for BL31 which including entry and image information for all other images. Then the SPL handle PC to BL31 with the parameter, the BL31 will do the rest of work and at last get into U-Boot(BL33). This patch needs work with patches from Andre for SPL support multi binary in FIT. The entry point of bl31 and bl33 are still using hard code because we still can not get them from the FIT image information. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Tested-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-14spl: move RAM boot support in separate fileStefan Agner
Add a new top-level config option so support booting an image stored in RAM. This allows to move the RAM boot support into a sparate file and having a single condition to compile that file. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-10-06spl: spi: Move the generic SPI loader into common/splSimon Glass
All the other SPL loaders are in this directory, so move the SPI one in there too. There are two board-specific SPI loaders (fsl and sunxi). These remain in the drivers/mtd/spi directory, since they do not contain generic code. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-27spl: dfu: adding dfu support functions for SPL-DFUB, Ravi
Adding support functions to run dfu spl commands. Signed-off-by: Ravi Babu <ravibabu@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-07-22spl: support loading from UBI volumesLadislav Michl
Add support for loading from UBI volumes on the top of NAND and OneNAND. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Reviewed-by: Heiko Schocher <hs@denx.de>
2016-03-14spl: Add an option to load a FIT containing U-BootSimon Glass
This provides a way to load a FIT containing U-Boot and a selection of device tree files. The board can select the correct device tree by probing the hardware. Then U-Boot is started with the selected device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-27spl: Add EXT support to SPLGuillaume GARDET
Add EXT filesystem support to SPL. Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> [trini: Fix a warning and checkpatch problems] Signed-off-by: Tom Rini <trini@ti.com>
2014-02-19common: spl: Add spl sata boot supportDan Murphy
Add spl_sata to read a fat partition from a bootable SATA drive. Signed-off-by: Dan Murphy <dmurphy@ti.com> Reviewed-by: Roger Quadros <rogerq@ti.com>
2014-01-24spl: common: Support for USB MSD FAT image loadingDan Murphy
Add SPL support to be able to detect a USB Mass Storage device connected to a USB host. Once a USB Mass storage device is detected the SPL will load the u-boot.img from a FAT partition to target address. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2014-01-24spl: common: Move FAT funcs to a common fileDan Murphy
Move the FAT functions to a common location for reuse. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-10-31common: convert makefiles to Kbuild styleMasahiro Yamada
2013-05-15drivers/mmc: move spl_mmc.c to common/splYing Zhang
The mpc85xx repuires a special layout on the memory device that is connected to the eSDHC controller interface. But the file spl_mmc.c didn't handle this specfic case, there needs a special treatmen, in the powerpc drictory. So, there is no longer to keep spl_mmc.c on mpc85xx, CONFIG_SPL_FRAMEWORK is not set. When CONFIG_SPL_MMC_SUPPORT is set and CONFIG_SPL_FRAMEWORK is not set, there was an error in drivers/mmc/spl_mmc.c: drivers/mmc/libmmc.o:(.got2+0x8): undefined reference to `spl_image'. Now, the solution is to move the file "spl_mmc.c" to directory "common/spl". Signed-off-by: Ying Zhang <b40530@freescale.com>
2013-03-11SPL: ONENAND: Support SPL to boot u-boot from OneNAND.Enric Balletbo i Serra
This patch will allow use SPL to boot an u-boot from the OneNAND. Tested with IGEPv2 board with a OneNAND from Numonyx Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> [trini: Add <spl.h> hunk to fix warning] Signed-off-by: Tom Rini <trini@ti.com>
2012-10-01OMAP: networking support for SPLIlya Yanok
This patch adds support for networking in SPL. Some devices are capable of loading SPL via network so it makes sense to load the main U-Boot binary via network too. This patch tries to use existing network code as much as possible. Unfortunately, it depends on environment which in turn depends on other code so SPL size is increased significantly. No effort was done to decouple network code and environment so far. Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-27SPL: Add NOR flash booting supportStefan Roese
SPL NOR flash booting support is quite simple. Only copying of the images is needed. On MPC5xxx we need to make sure to only use the standard memcpy() implementation and not the MPC5xxx specific one. As the MPC5xxx version has some complexity which is not needed for this SPL booting. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-27SPL: NAND: Move arch/arm/cpu/armv7/omap-common/spl_nand.c to common/splTom Rini
We move the spl_nand_load_image function to common/spl. This will allow for easier integration of SPL-boots-Linux code on other arches. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-27SPL: Move the omap SPL framework to common/splTom Rini
Add a new flag, CONFIG_SPL_FRAMEWORK to opt into the common/spl SPL framework, enable on all of the previously using boards. We move the spl_ymodem.c portion to common/ and spl_mmc.c to drivers/mmc/. We leave the NAND one in-place as we plan to replace it later in this series. We use common/spl to avoid linker problems with respect to merging constant strings in objects. Otherwise all strings in common/ will be linked in and kept which grows SPL in size too much. Signed-off-by: Tom Rini <trini@ti.com>
