path: root/common/spartan3.c
2007-11-17Fix a bug in the slave serial programming mode for the XilinxWolfgang Denk
Spartan2/3 FPGAs. The old code used "< 0" on a "char" type to test if the most significant bit was set, which did not work on any architecture where "char" defaulted to be an unsigned type. Based on a patch by Angelos Manousaridis <amanous@inaccessnetworks.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2005-09-25CleanupWolfgang Denk
2005-09-25Add Xilinx Spartan3 family FPGA supportWolfgang Denk
Patch by Kurt Stremerch, 14 February 2005
