path: root/common/soft_spi.c
2007-07-26ppc4xx: Add support for AMCC 405EP Taihu boardJohn Otken
Signed-off-by: John Otken <john@softadvances.com>
2002-11-11* Patch by Andreas Oberritter, 09 Nov 2002:wdenk
Change behaviour of NetLoop(): return -1 for errors, filesize otherwise; return code 0 is valid an means no file loaded - in this case the environment still gets updated! * Patches by Jon Diekema, 9 Nov 2002: - improve ADC/DAC clocking on the SACSng board to align the failing edges of LRCLK and SCLK - sbc8260 configuration tweaks - add status LED support for 82xx systems - wire sspi/sspo commands into command handler; improved error handlering - add timestamp support and alternate memory test to the SACSng configuration
2002-10-01Initial revisionwdenk
