path: root/common/serial.c
2007-03-24[PATCH] Clean up 40EZ/Acadia supportStefan Roese
This patch cleans up all the open issue of the preliminary Acadia support. Signed-off-by: Stefan Roese <sr@denx.de>
2006-08-30Make the serial driver framework work with CONFIG_SERIAL_MULTI enabledWolfgang Denk
2006-06-30Merge: Add support for AMCC 440SPe CPU based eval board (Yucca).Marian Balakowicz
2006-06-30Add support for AMCC 440SPe CPU based eval board (Yucca).Marian Balakowicz
2006-06-16Add support for CONFIG_SERIAL_MULTI on MPC5xxxWolfgang Denk
Patch by Martin Krause, 8 Jun 2006 This patch supports two serial consoles on boards with a MPC5xxx CPU. The console can be switched at runtime by setting stdin, stdout and stderr to the desired serial interface (serial0 or serial1). The PSCs to be used as console port are definded by CONFIG_PSC_CONSOLE and CONFIG_PSC_CONSOLE2. See README.serial_multi for details.
2005-01-09* Patch by Leif Lindholm, 23 Sep 2004:wdenk
add support for the AMD db1550 board * Patch by Travis Sawyer, 15 Sep 2004: Add CONFIG_SERIAL_MULTI support for ppc4xx, update README.serial_multi
2004-10-11CleanupLABEL_2004_10_12_0110wdenk
2004-10-11* Patch by Pantelis Antoniou, 14 Sep 2004:wdenk
Fix early serial hang when CONFIG_SERIAL_MULTI is defined. * Patch by Pantelis Antoniou, 14 Sep 2004: Kick watchdog when bz-decompressing
2004-08-01* Code cleanupwdenk
* Patch by Sascha Hauer, 28 Jun: - add generic support for Motorola i.MX architecture - add support for mx1ads, mx1fs2 and scb9328 boards * Patches by Marc Leeman, 23 Jul 2004: - Add define for the PCI/Memory Buffer Configuration Register - corrected comments in cpu/mpc824x/cpu_init.c * Add support for multiple serial interfaces (for example to allow modem dial-in / dial-out)
