CONFIG_PHY_RESET_DELAY
Cc: Ramon Fried <rfried.dev@gmail.com>
Move this uncommon header out of the common header.
Move this header out of the common header.
In upcoming freescale board LX2160AQDS, the MDIO bus is muxed.
i.e. same MDIO bus can be routed to eight different slots depending
on mux register settings.
To support this mdio mux behavior, we add each MDIO bus mux as a
separate MDIO bus.
Now, various phy devices can be attached to each of these slots(mux).
The information about these devices is passed to OS via device tree.
To do the fdt fixups related to MDIO bus, its necessary that MDIO bus
list is accessed.Therefore, add a function to retrieve the list head.
Signed-off-by: Pankaj Bansal <pankaj.bansal@nxp.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
The most of ethernet drivers are using this mdio registration sequence.
strcpy(priv->bus->name, "emac");
mdio_register(priv->bus);
Where driver can be used only with one MDIO bus because only unique
name should be used.
Other drivers are using unique device name for MDIO registration to
support multiple instances.
snprintf(priv->bus->name, sizeof(bus->name), "%s", name);
With DM dev->seq is used more even in logs
(like random MAC address generation:
printf("\nWarning: %s (eth%d) using random MAC address - %pM\n",
dev->name, dev->seq, pdata->enetaddr);
where eth%d prefix is used.
Simplify driver code to register mdio device with dev->seq number
to simplify mdio registration and reduce code duplication across
all drivers. With DM_SEQ_ALIAS enabled dev->seq reflects alias setting.
This reverts commit 3edc0c252257e4afed163a3a74aba24a5509b198, reversing
changes made to bb135a0180c31fbd7456021fb9700b49bba7f533.
For example:
Board: Xilinx Zynq
Net: ZYNQ GEM: e000b000, phyaddr 7, interface rgmii-id
Warning: ethernet@e000b000 (eth0) using random MAC address -
7a:fc:90:53:6a:41
eth0: ethernet@e000b000ZYNQ GEM: e000c000, phyaddr ffffffff, interface
rgmii-id
Warning: ethernet@e000c000 (eth3) using random MAC address -
1a:ff:d7:1a:a1:b2
, eth3: ethernet@e000c000
** Bad device size - mmc 0 **
Checking if uenvcmd is set ...
Hit any key to stop autoboot: 0
Zynq> mdio list
eth0:
17 - Marvell 88E1111S <--> ethernet@e000b000
eth3:
17 - Marvell 88E1111S <--> ethernet@e000c000
Zynq>
It is confusing that mdio commands work and report phy id as
decimal value when mii is working with hex values.
For example:
ZynqMP> mdio list
gem:
21 - TI DP83867 <--> ethernet@ff0e0000
ZynqMP> mdio read ethernet@ff0e0000 0
Reading from bus gem
PHY at address 21:
0 - 0x1140
ZynqMP> mii dump 21 0
Incorrect PHY address. Range should be 0-31
ZynqMP> mii dump 15
0. (1140) -- PHY control register --
(8000:0000) 0.15 = 0 reset
U-Boot normally takes hex values that's why this patch is changing mdio
command to handle hex instead of changing mii command to handle decimal
values.
When phy autoneg on, the link speed and duplex should be
determined by phy advertising register and
phy link partner ability register.
Check phy advertising register when geting phy link speed and
duplex if autoneg on.
Signed-off-by: Dongpo Li <lidongpo@hisilicon.com>
The cleanup of the legacy mii registration API that's no longer used now
that the drivers have been converted to use the (more) modern API.
The following code will alloc memory for new_dev and ldev:
new_dev = mdio_alloc();
ldev = malloc(sizeof(*ldev));
Either new_dev or ldev is NULL, directly return, but this may leak memory.
So before return, using free(ldev) and mdio_free(new_dev) to avoid
leaking memory, also free can handle NULL pointer.
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
The entry name of mii_dev is an array not pointer, so
no need to check.
Currently there is no API to uninitialize mdio. Add two APIs for this.
When driver model is used for Ethernet a few functions are passed a udevice
instead of an eth_device. Also add a function to find a PHY type given its
name. This will be used to decode the device tree node.
Finally, put a phy_interface field in struct eth_pdata since this is an
important part of the platform data for Ethernet.
[trini: Fixup common/cmd_io.c]
This reverts commit 5c45a22b9203351a32aec4600514341b91175542.
It causes a lot of "incompatible pointer type" warnings for a large
number of Ethernet drivers, which are not really worth fixing
especially as this patch was only supposed to help the old,
deprecated miiphy API. Instead of adding more efforts to a lost case
we rather revert it.
This patch is added for PHY whose register offset value exceeds 0xFF and
cannot be used with "unsigned char" datatype in miiphy_read, miiphy_write
and miiphy_register functions. Datatype of register offset is changed to
unsigned short instead of unsigned char so that offset value greater then
0xFF can be used.
Signed-off-by: Chandan Nath <chandan.nath@ti.com>
We want to move everything to phylib, and we definitely don't want
new drivers using the miiphy infrastructure.
Signed-off-by: Andy Fleming <afleming@freescale.com>
In miiphy_register() the new device's name was initialised by passing a
string parameter as the format string to sprintf(). As this would cause
problems if it ever contained a '%' symbol, switch to using strncpy()
instead.
Signed-off-by: Laurence Withers <lwithers@guralp.com>
Cc: Andy Fleming <afleming@freescale.com>
Fix warning introduced while recent PHY Lib changes:
miiphyutil.c: In function 'miiphy_read':
miiphyutil.c:304: warning: comparison is always false due to limited range of data type
Extends the mii_dev structure to participate in a full-blown MDIO and
PHY driver scheme. The mii_dev structure and miiphy calls are modified
in such a way to allow the original mii command and miiphy
infrastructure to work as before, but also to support a new set of APIs
which allow (among other things) sharing of PHY driver code and 10G support
The mii command will continue to support normal PHY management functions
(Clause 22 of 802.3), but will not be changed to support 10G
(Clause 45).
The basic design is similar to PHY Lib from Linux, but simplified for
U-Boot's network and driver infrastructure.
We now have MDIO drivers and PHY drivers
An MDIO driver provides:
read
write
reset
A PHY driver provides:
(optionally): probe
config - initial setup, starting of auto-negotiation
startup - waiting for AN, and reading link state
shutdown - any cleanup needed
The ethernet drivers interact with the PHY Lib using these functions:
phy_connect()
phy_config()
phy_startup()
phy_shutdown()
Each PHY driver can be configured separately, or all at once using
config_phylib_all_drivers.h (added in the patch which adds the drivers)
We also provide generic drivers for Clause 22 (10/100/1000), and
Clause 45 (10G) PHYs.
We also implement phy_reset(), and call it in phy_connect(). Because
phy_reset() is essentially the same as miiphy_reset, but:
a) must support 10G PHYs, and
b) should use the phylib primitives,
we implement miiphy_reset, using phy_reset(), but only when
CONFIG_PHYLIB is set. Otherwise, we just use the old version. In this
way, we save on compile size, even if we don't manage to save code size.
Pulled ethtool.h and mdio.h from:
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6
782d640afd15af7a1faf01cfe566ca4ac511319d
With many, many deletions so as to enable compilation under u-boot
Acked-by: Detlev Zundel <dzu@denx.de>
Mostly putting a space between function name and "(", and
doing return (foo)
The include/miiphy.h header duplicates a lot of things from linux/mii.h.
So punt all the things that overlap to keep the API simple and to make
merging between U-Boot and Linux simpler.
For code that uses miiphy_{read,write}, every call invokes a full look up
of the mii list. There is already a "current_mii" cache that is used by
some code, but have the miiphy_{read,write} function use it as well. This
does increase the code size slightly, but I think it's worth it.
Rather than have every func re-implement the list walking code, do it one
local function. This shrinks the resulting object code a little while
making the source much more manageable.
The driver name does not need to be writable, so constify it.
Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com>
This patch fixes a problem I've notived on a buggy PPC4xx system. This
system has problems with the PHY MDIO communication and seemed to be
stuck/crashed in miiphy_reset(). But degugging revealed, that the CPU
didn't crash, but "only" hung in this counting loop for about 2 minutes.
This patch now uses a real timeout of 0.5 seconds (as mentioned in the
comment in miiphy_reset).
Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
Current MII_DEBUG is confusing in two ways. One is useless define-then-
undef at the top of the file. The other is there is only one debug() in
this file, and that doesn't seem worthwhile to bother having MII_DEBUG.
While there are many useful printf()/puts() debug codes, but they are for
DEBUG, not for MII_DEBUG.
This patch tries to put them all together into MII_DEBUG and debug().
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
This patch adds support for 1000BASE-X to functions "miiphy_speed ()" and
"miiphy_duplex()". It also adds function "miiphy_is_1000base_x ()", which
returns non-zero iff the PHY registers are configured for 1000BASE-X. The
"mii info" command is modified to distinguish between 1000BASE-T and -X.
Signed-off-by: Larry Johnson <lrj@acm.org>
Signed-off-by: Ben Warren <bwarren@qstreams.com>
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
ethaddr is assigned). Initialization moved from miiphy_register() to
eth_initialize().
Based on initial patch for 4xx platform by Matthias Fuchs.
Patch by Carl Riechers, 24 Jun 2005
Add support for OMAP730 Perseus2 Development board
* Patch by Alan J. Luse, 29 Apr 2004:
Fix flash chip-select (OR0) option register setting on FADS boards.
Report MII network speed and duplex setting properly when
auto-negotiate is not enabled.
* Patch by Jarrett Redd, 29 Apr 2004:
Fix hang on reset on Ocotea board due to flash in wrong mode.
add networking support for VLANs (802.1q), and CDP (Cisco Discovery Protocol)
Increase speed of sector reads from SystemACE,
shorten poll timeout and remove a useless reset
* Patch by Tolunay Orkun, 19 Mar 2004:
Make GigE PHY 1000Mbps Speed/Duplex detection conditional
(CONFIG_PHY_GIGE)
* Patch by Brad Kemp, 18 Mar 2004:
prevent machine checks during a PCI scan
* Patch by Pierre Aubert, 18 Mar 2004:
Fix string cleaning in IDE identification
- show PCI clock frequency on MPC8260 systems
- add FCC_PSMR_RMII flag for HiP7 processors
- in do_jffs2_fsload(), take load address from load_addr if not set
explicit, update load_addr otherwise
- replaced printf by putc/puts when no formatting is needed
(smaller code size, faster execution)
- Fix Gigabit Ethernet support for 440GX
- Add Gigabit Ethernet Support to MII PHY utilities
* Patch by Brad Kemp, 12 Mar 2004:
Fixes for drivers/cfi_flash.c:
- Better support for x8/x16 implementations
- Added failure for AMD chips attempting to use CFG_FLASH_USE_BUFFER_WRITE
- Added defines for AMD command and address constants
* Patch by Leon Kukovec, 12 Mar 2004:
Fix get_dentfromdir() to correctly handle deleted dentries
* Patch by George G. Davis, 11 Mar 2004:
Remove hard coded network settings in TI OMAP1610 H2
default board config
add support for ADS GraphicsClient+ board.
Allow bzip2 compression for small memory footprint boards
* Patch by Brad Kemp, 21 Jan 2004:
Add support for CFI flash driver for both the Intel and the AMD
command sets.
* Patch by Travis Sawyer, 20 Jan 2004:
Fix pci bridge auto enumeration of sibling p2p bridges.
* Patch by Tolunay Orkun, 12 Jan 2004:
Add some delays as needed for Intel LXT971A PHY support
* Patches by Stephan Linz, 09 Jan 2004:
- avoid warning: unused variable `piop' in board/altera/common/sevenseg.c
- make DK1C20 board configuration related to ASMI conform to
documentation
- more endianess fixes for LAN91C111 driver
- CFG_HZ configuration patch for NIOS Cyclone board
* Patch by Stephan Linz, 28 Oct 2003:
fix PHY_INT_REG vs. PHY_MASK_REG bug in drivers/smc91111.c
* Patch by Steven Scholz, 20 Oct 2003:
- make "mii info <addr>" show infor for PHY at "addr" only
- Endian fix for miiphy_info()
fix pll_pci_to_mem_multiplier table for MPC8245
* Patch by Anders Larsen, 22 Sep 2003:
enable timed autoboot on PXA
* Patch by David Müller, 22 Sep 2003:
- add $(CFLAGS) to "-print-libgcc-filename" so compiler driver
returns correct libgcc file path
- "latency" reduction of busy-loop waiting to improve "U-Boot" boot
time on s3c24x0 systems
* Patch by Jon Diekema, 19 Sep 2003:
- Add CFG_FAULT_ECHO_LINK_DOWN option to echo the inverted Ethernet
link state to the fault LED.
- In NetLoop, make the Fault LED reflect the link status. The link
status gets updated on entry, and on timeouts.
