path: root/common/miiphyutil.c
2008-02-14common/miiphyutil.c: Cleanup MII_DEBUG and debug()Shinya Kuribayashi
Current MII_DEBUG is confusing in two ways. One is useless define-then- undef at the top of the file. The other is there is only one debug() in this file, and that doesn't seem worthwhile to bother having MII_DEBUG. While there are many useful printf()/puts() debug codes, but they are for DEBUG, not for MII_DEBUG. This patch tries to put them all together into MII_DEBUG and debug(). Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2007-11-06NET: Add Ethernet 1000BASE-X support for PPC4xxLarry Johnson
This patch adds support for 1000BASE-X to functions "miiphy_speed ()" and "miiphy_duplex()". It also adds function "miiphy_is_1000base_x ()", which returns non-zero iff the PHY registers are configured for 1000BASE-X. The "mii info" command is modified to distinguish between 1000BASE-T and -X. Signed-off-by: Larry Johnson <lrj@acm.org> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2007-11-06NET: Cosmetic changesLarry Johnson
2007-07-08common/* non-cmd*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04common/ non-cmd: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2005-11-30Fix miiphy global data initialization (problem on 4xx boards when noMarian Balakowicz
ethaddr is assigned). Initialization moved from miiphy_register() to eth_initialize(). Based on initial patch for 4xx platform by Matthias Fuchs.
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-08-12Preserve PHY_BMCR during a soft reset.Wolfgang Denk
Patch by Carl Riechers, 24 Jun 2005
2004-06-06* Patch by Dave Peverley, 30 Apr 2004:wdenk
Add support for OMAP730 Perseus2 Development board * Patch by Alan J. Luse, 29 Apr 2004: Fix flash chip-select (OR0) option register setting on FADS boards. * Patch by Alan J. Luse, 29 Apr 2004: Report MII network speed and duplex setting properly when auto-negotiate is not enabled. * Patch by Jarrett Redd, 29 Apr 2004: Fix hang on reset on Ocotea board due to flash in wrong mode.
2004-04-15Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
add networking support for VLANs (802.1q), and CDP (Cisco Discovery Protocol)
2004-03-23* Patch by Stephen Williams, 19 March 2004wdenk
Increase speed of sector reads from SystemACE, shorten poll timeout and remove a useless reset * Patch by Tolunay Orkun, 19 Mar 2004: Make GigE PHY 1000Mbps Speed/Duplex detection conditional (CONFIG_PHY_GIGE) * Patch by Brad Kemp, 18 Mar 2004: prevent machine checks during a PCI scan * Patch by Pierre Aubert, 18 Mar 2004: Fix string cleaning in IDE identification
2004-03-23* Patches by Thomas Viehweger, 16 Mar 2004:wdenk
- show PCI clock frequency on MPC8260 systems - add FCC_PSMR_RMII flag for HiP7 processors - in do_jffs2_fsload(), take load address from load_addr if not set explicit, update load_addr otherwise - replaced printf by putc/puts when no formatting is needed (smaller code size, faster execution)
2004-03-14* Patches by Travis Sawyer, 12 Mar 2004:wdenk
- Fix Gigabit Ethernet support for 440GX - Add Gigabit Ethernet Support to MII PHY utilities * Patch by Brad Kemp, 12 Mar 2004: Fixes for drivers/cfi_flash.c: - Better support for x8/x16 implementations - Added failure for AMD chips attempting to use CFG_FLASH_USE_BUFFER_WRITE - Added defines for AMD command and address constants * Patch by Leon Kukovec, 12 Mar 2004: Fix get_dentfromdir() to correctly handle deleted dentries * Patch by George G. Davis, 11 Mar 2004: Remove hard coded network settings in TI OMAP1610 H2 default board config * Patch by George G. Davis, 11 Mar 2004: add support for ADS GraphicsClient+ board.
2004-02-08* Patch by Yuli Barcohen, 26 Jan 2004:wdenk
Allow bzip2 compression for small memory footprint boards * Patch by Brad Kemp, 21 Jan 2004: Add support for CFI flash driver for both the Intel and the AMD command sets. * Patch by Travis Sawyer, 20 Jan 2004: Fix pci bridge auto enumeration of sibling p2p bridges. * Patch by Tolunay Orkun, 12 Jan 2004: Add some delays as needed for Intel LXT971A PHY support * Patches by Stephan Linz, 09 Jan 2004: - avoid warning: unused variable `piop' in board/altera/common/sevenseg.c - make DK1C20 board configuration related to ASMI conform to documentation
2003-12-06* Patches by Stephan Linz, 3 Nov 2003:wdenk
- more endianess fixes for LAN91C111 driver - CFG_HZ configuration patch for NIOS Cyclone board * Patch by Stephan Linz, 28 Oct 2003: fix PHY_INT_REG vs. PHY_MASK_REG bug in drivers/smc91111.c * Patch by Steven Scholz, 20 Oct 2003: - make "mii info <addr>" show infor for PHY at "addr" only - Endian fix for miiphy_info()
2003-10-08* Patch by Sangmoon Kim, 23 Sep 2003:wdenk
fix pll_pci_to_mem_multiplier table for MPC8245 * Patch by Anders Larsen, 22 Sep 2003: enable timed autoboot on PXA * Patch by David Müller, 22 Sep 2003: - add $(CFLAGS) to "-print-libgcc-filename" so compiler driver returns correct libgcc file path - "latency" reduction of busy-loop waiting to improve "U-Boot" boot time on s3c24x0 systems * Patch by Jon Diekema, 19 Sep 2003: - Add CFG_FAULT_ECHO_LINK_DOWN option to echo the inverted Ethernet link state to the fault LED. - In NetLoop, make the Fault LED reflect the link status. The link status gets updated on entry, and on timeouts.
