path: root/common/main.c
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2009-01-24common/main: support bootdelay=0 for CONFIG_AUTOBOOT_KEYEDPeter Korsgaard
Support bootdelay=0 in abortboot for the CONFIG_AUTOBOOT_KEYED case similar to the CONFIG_ZERO_BOOTDELAY_CHECK support for the !CONFIG_AUTOBOOT_KEYED case. Do this by reversing the loop so we do at least one iteration before checking for timeout. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
2008-10-18hush: add showvar command for hush shell.Heiko Schocher
This new command shows the local variables defined in the hush shell: => help showvar showvar - print values of all hushshell variables showvar name ... - print value of hushshell variable 'name' Also make the set_local_var() and unset_local_var () no longer static, so it is possible to define local hush shell variables at boot time. If CONFIG_HUSH_INIT_VAR is defined, u-boot calls hush_init_var (), where boardspecific code can define local hush shell variables at boottime. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-10-18Automatic software update from TFTP serverBartlomiej Sieka
The auto-update feature allows to automatically download software updates from a TFTP server and store them in Flash memory during boot. Updates are contained in a FIT file and protected with SHA-1 checksum. More detailed description can be found in doc/README.update. Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-08-06Fix merge problemsStefan Roese
2008-07-09Fix printf errors.Andrew Klossner
The compiler will help find mismatches between printf formats and arguments if you let it. This patch adds the necessary attributes to declarations in include/common.h, then begins to correct the resulting compiler warnings. Some of these were bugs, e.g., "$d" instead of "%d" and incorrect arguments. Others were just annoying, like int-long mismatches on a system where both are 32 bits. It's worth fixing the annoying errors to catch the real ones. Signed-off-by: Andrew Klossner <andrew@cesa.opbu.xerox.com>
2008-06-03Additional fix to readline_into_buffer() with CONFIG_CMDLINE_EDITING before ↵Peter Tyser
relocating Removed unneeded command line history initialization. Also, the original code would access the 'initted' variable before relocation to SDRAM which resulted in erratic behavior since the bss is not initialized when executing from flash. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-05-09Fix readline_into_buffer() with CONFIG_CMDLINE_EDITING before relocatingJames Yang
When CONFIG_CMDLINE_EDITING is enabled, readline_into_buffer() doesn't work before relocating to RAM because command history is written into a global array that is not writable before relocation. This patch defers to the no-editing and no-history code in readline_into_buffer() if it is called before relocation. Signed-off-by: James Yang <James.Yang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-18The patch introduces the CRITICAL feature of POST tests. If the test marked ↵Yuri Tikhonov
as POST_CRITICAL fails then the alternative, post_critical, boot-command is used. If this command is not defined then U-Boot enters into interactive mode. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-01-12Make bootretry work when command line editing is enabledAndreas Engel
Currently, when CONFIG_CMDLINE_EDITING is set, bootretry doesn't work. This patch fixes the problem. Signed-off-by: Andreas Engel <andreas.engel@ericsson.com>
2008-01-11Fix compiler warningKumar Gala
main.c: In function 'readline_into_buffer': main.c:927: warning: unused variable 'p_buf' Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-09Expose parse_line() globally.James Yang
Add new function readline_into_buffer() that allows the output of readline to be put into a pointer to char buffer. This refactoring allows other functions besides the main command loop to also use the same input mechanism. Signed-off-by: James Yang <James.Yang@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com>
2008-01-09Allow CONFIG_AUTO_COMPLETE and command history CONFIG_CMDLINE_EDITING at the ↵Jean-Christophe PLAGNIOL-VILLARD
sametime Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-08-06Merge with /home/wd/git/u-boot/custodian/u-boot-testingWolfgang Denk
2007-07-13make show_boot_progress () weak.Heiko Schocher
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/* non-cmd*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04common/ non-cmd: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-07-03Merge with /home/wd/git/u-boot/custodian/u-boot-testingWolfgang Denk
2007-06-22Coding stylke cleanup; rebuild CHANGELOGWolfgang Denk
2007-06-12Fix 'run' not to continue after interrupted commandDetlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2007-05-28Merge with /home/tur/git/u-boot#motionproWolfgang Denk
2007-05-27Fix: Add missing NULL termination in strings expanded by macros parser.Bartlomiej Sieka
Signed-off-by: Piotr Kruszynski <ppk@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2007-05-05Merge with /home/git/u-bootWolfgang Denk
2007-05-05[PATCH] simplify silent consoleLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Acked-by: Stefan Roese <sr@denx.de>
2007-04-25[PATCH] simplify silent consoleLadislav Michl
2006-10-28Minor code cleanup.Wolfgang Denk
2006-08-07Fix control-c handing in CONFIG_CMDLINE_EDITINGStefan Roese
Properly pass break code back from readline. Patch by Roger Blofeld, 31 Jul 2006
2006-07-27Fix CONFIG_CMDLINE_EDITING implementationStefan Roese
Patch by Stefan Roese, 27 Jul 2006
2006-07-21Minor code cleanup.Wolfgang Denk
2006-07-21Add readline cmdline-editing extensionWolfgang Denk
Patch by JinHua Luo, 01 Sep 2005
2006-03-12Avoid dereferencing NULL in find_cmd() if no valid commands were foundWolfgang Denk
Patch by Andrew Dyer, 13 Jun 2005
2005-09-30Fix compiler warningWolfgang Denk
2005-09-25Remove unneeded #include <malloc.h>Wolfgang Denk
Patch by Ladislav Michl, 22 Feb 2005
2005-01-09* Patch by Sam Song, 11 October 2004:wdenk
- Add RESET/PREBOOT/AUTOBOOT support for RPXlite_DW board - Adjust CPU:BUS frequency ratio 1:1 when core frequency less than 50MHz * Patch by Sam Song, 10 Oct 2004: Fix a parameter error in run_command() in main.c
2004-04-23* Modify KUP4X board configuration to use SL811 driver for USB memoryLABEL_2004_04_23_2240wdenk
sticks (including FAT / VFAT filesystem support) * Add SL811 Host Controller Interface driver for USB * Add CFG_I2C_EEPROM_ADDR_OVERFLOW desription to README * Patch by Pantelis Antoniou, 19 Apr 2004: Allow to use shell style syntax (i. e. ${var} ) with standard parser. Minor patches for Intracom boards. * Patch by Christian Pell, 19 Apr 2004: cleanup support for CF/IDE on PCMCIA for PXA25X
2004-04-15* Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
- add auto-complete support to the U-Boot CLI - add support for NETTA and NETPHONE boards; fix NETVIA board * Patch by Yuli Barcohen, 28 Mar 2004: - Add support for MPC8272 family including MPC8247/8248/8271/8272 - Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS) - Change configuration method for MPC8260ADS family
2004-03-23* Patch by Carl Riechers, 17 Mar 2004:wdenk
Ignore '\0' characters in console input for use with telnet and telco pads. * Patch by Leon Kukovec, 17 Mar 2004: typo fix for strswab prototype #ifdef
2004-03-23* Patches by Thomas Viehweger, 16 Mar 2004:wdenk
- show PCI clock frequency on MPC8260 systems - add FCC_PSMR_RMII flag for HiP7 processors - in do_jffs2_fsload(), take load address from load_addr if not set explicit, update load_addr otherwise - replaced printf by putc/puts when no formatting is needed (smaller code size, faster execution)
2003-12-07* Patch by Yuli Barcohen, 3 Dec 2003:wdenk
"revive" U-Boot support for old Motorola MPC860ADS board * Patch by Cam(ilo?), 03 Dec 2003: make examples build even with broken Montavista objcopy * Patch by Pavel Bartusek, 27 Nov 2003: fix conversion problem with "bootretry" evironment variable
2003-10-24* Correct header printing for multi-image files in do_bootm()dzu
* Make CONFIG_SILENT_CONSOLE work with CONFIG_AUTOBOOT_KEYED
2003-10-10Added config option CONFIG_SILENT_CONSOLE. See doc/README.silentLABEL_2003_10_10_1200wdenk
for more information
2003-08-05* Map ISP1362 USB OTG controller for NSCU boardwdenk
* Patch by Brad Parker, 02 Aug 2003: fix sc520_cdp problems * Implement Boot Cycle Detection (Req. 2.3 of OSDL CGL Reqirements) * Allow erase command to cross flash bank boundaries
2003-07-11- Fix bug in CONFIG_VERSION_VARIABLE.stroese
2003-06-19Patches by Murray Jensen, 17 Jun 2003:wdenk
- Hymod board database mods: add "who" field and new xilinx chip types - provide new "init_cmd_timeout()" function so code external to "common/main.c" can use the "reset_cmd_timeout()" function before entering the main loop - add DTT support for adm1021 (new file dtt/adm1021.c; config slightly different. see include/configs/hymod.h for an example (requires CONFIG_DTT_ADM1021, CONFIG_DTT_SENSORS, and CFG_DTT_ADM1021 defined) - add new "eeprom_probe()" function which has similar args and behaves in a similar way to "eeprom_read()" etc. - add 8260 FCC ethernet loopback code (new "eth_loopback_test()" function which is enabled by defining CONFIG_ETHER_LOOPBACK_TEST) - gdbtools copyright update - ensure that set_msr() executes the "sync" and "isync" instructions after the "mtmsr" instruction in cpu/mpc8260/interrupts.c - 8260 I/O ports fix: Open Drain should be set last when configuring - add SIU IRQ defines for 8260 - allow LDSCRIPT override and OBJCFLAGS initialization: change to config.mk to allow board configurations to override the GNU linker script, selected via the LDSCRIPT, make variable, and to give an initial value to the OBJCFLAGS make variable - 8260 i2c enhancement: o correctly extends the timeout depending on the size of all queued messages for both transmit and receive o will not continue with receive if transmit times out o ensures that the error callback is done for all queued tx and rx messages o correctly detects both tx and rx timeouts, only delivers one to the callback, and does not overwrite an earlier error o logic in i2c_probe now correct - add "vprintf()" function so that "panic()" function can be technically correct - many Hymod board changes
2003-05-28* Fix data abort exception handling for arm920t CPUwdenk
* Fix alignment problems with flash driver for TRAB board * Patch by Donald White, 21 May 2003: fix calculation of base address in pci_hose_config_device() * Fix bug in command line parsing: "cmd1;cmd2" is supposed to always execute "cmd2", even if "cmd1" fails. Note that this is different to "run var1 var2" where the contents of "var2" will NOT be executed when a command in "var1" fails.
