path: root/common/main.c
2008-05-09Fix readline_into_buffer() with CONFIG_CMDLINE_EDITING before relocatingJames Yang
When CONFIG_CMDLINE_EDITING is enabled, readline_into_buffer() doesn't work before relocating to RAM because command history is written into a global array that is not writable before relocation. This patch defers to the no-editing and no-history code in readline_into_buffer() if it is called before relocation. Signed-off-by: James Yang <James.Yang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-18The patch introduces the CRITICAL feature of POST tests. If the test marked ↵Yuri Tikhonov
as POST_CRITICAL fails then the alternative, post_critical, boot-command is used. If this command is not defined then U-Boot enters into interactive mode. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-01-12Make bootretry work when command line editing is enabledAndreas Engel
Currently, when CONFIG_CMDLINE_EDITING is set, bootretry doesn't work. This patch fixes the problem. Signed-off-by: Andreas Engel <andreas.engel@ericsson.com>
2008-01-11Fix compiler warningKumar Gala
main.c: In function 'readline_into_buffer': main.c:927: warning: unused variable 'p_buf' Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-09Expose parse_line() globally.James Yang
Add new function readline_into_buffer() that allows the output of readline to be put into a pointer to char buffer. This refactoring allows other functions besides the main command loop to also use the same input mechanism. Signed-off-by: James Yang <James.Yang@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com>
2008-01-09Allow CONFIG_AUTO_COMPLETE and command history CONFIG_CMDLINE_EDITING at the ↵Jean-Christophe PLAGNIOL-VILLARD
sametime Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-08-06Merge with /home/wd/git/u-boot/custodian/u-boot-testingWolfgang Denk
2007-07-13make show_boot_progress () weak.Heiko Schocher
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/* non-cmd*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04common/ non-cmd: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-07-03Merge with /home/wd/git/u-boot/custodian/u-boot-testingWolfgang Denk
2007-06-22Coding stylke cleanup; rebuild CHANGELOGWolfgang Denk
2007-06-12Fix 'run' not to continue after interrupted commandDetlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2007-05-28Merge with /home/tur/git/u-boot#motionproWolfgang Denk
2007-05-27Fix: Add missing NULL termination in strings expanded by macros parser.Bartlomiej Sieka
Signed-off-by: Piotr Kruszynski <ppk@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2007-05-05Merge with /home/git/u-bootWolfgang Denk
2007-05-05[PATCH] simplify silent consoleLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Acked-by: Stefan Roese <sr@denx.de>
2007-04-25[PATCH] simplify silent consoleLadislav Michl
2006-10-28Minor code cleanup.Wolfgang Denk
2006-08-07Fix control-c handing in CONFIG_CMDLINE_EDITINGStefan Roese
Properly pass break code back from readline. Patch by Roger Blofeld, 31 Jul 2006
2006-07-27Fix CONFIG_CMDLINE_EDITING implementationStefan Roese
Patch by Stefan Roese, 27 Jul 2006
2006-07-21Minor code cleanup.Wolfgang Denk
2006-07-21Add readline cmdline-editing extensionWolfgang Denk
Patch by JinHua Luo, 01 Sep 2005
2006-03-12Avoid dereferencing NULL in find_cmd() if no valid commands were foundWolfgang Denk
Patch by Andrew Dyer, 13 Jun 2005
2005-09-30Fix compiler warningWolfgang Denk
2005-09-25Remove unneeded #include <malloc.h>Wolfgang Denk
Patch by Ladislav Michl, 22 Feb 2005
2005-01-09* Patch by Sam Song, 11 October 2004:wdenk
- Add RESET/PREBOOT/AUTOBOOT support for RPXlite_DW board - Adjust CPU:BUS frequency ratio 1:1 when core frequency less than 50MHz * Patch by Sam Song, 10 Oct 2004: Fix a parameter error in run_command() in main.c
2004-04-23* Modify KUP4X board configuration to use SL811 driver for USB memoryLABEL_2004_04_23_2240wdenk
sticks (including FAT / VFAT filesystem support) * Add SL811 Host Controller Interface driver for USB * Add CFG_I2C_EEPROM_ADDR_OVERFLOW desription to README * Patch by Pantelis Antoniou, 19 Apr 2004: Allow to use shell style syntax (i. e. ${var} ) with standard parser. Minor patches for Intracom boards. * Patch by Christian Pell, 19 Apr 2004: cleanup support for CF/IDE on PCMCIA for PXA25X
2004-04-15* Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
- add auto-complete support to the U-Boot CLI - add support for NETTA and NETPHONE boards; fix NETVIA board * Patch by Yuli Barcohen, 28 Mar 2004: - Add support for MPC8272 family including MPC8247/8248/8271/8272 - Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS) - Change configuration method for MPC8260ADS family
2004-03-23* Patch by Carl Riechers, 17 Mar 2004:wdenk
Ignore '\0' characters in console input for use with telnet and telco pads. * Patch by Leon Kukovec, 17 Mar 2004: typo fix for strswab prototype #ifdef
2004-03-23* Patches by Thomas Viehweger, 16 Mar 2004:wdenk
- show PCI clock frequency on MPC8260 systems - add FCC_PSMR_RMII flag for HiP7 processors - in do_jffs2_fsload(), take load address from load_addr if not set explicit, update load_addr otherwise - replaced printf by putc/puts when no formatting is needed (smaller code size, faster execution)
2003-12-07* Patch by Yuli Barcohen, 3 Dec 2003:wdenk
"revive" U-Boot support for old Motorola MPC860ADS board * Patch by Cam(ilo?), 03 Dec 2003: make examples build even with broken Montavista objcopy * Patch by Pavel Bartusek, 27 Nov 2003: fix conversion problem with "bootretry" evironment variable
2003-10-24* Correct header printing for multi-image files in do_bootm()dzu
* Make CONFIG_SILENT_CONSOLE work with CONFIG_AUTOBOOT_KEYED
2003-10-10Added config option CONFIG_SILENT_CONSOLE. See doc/README.silentLABEL_2003_10_10_1200wdenk
for more information
2003-08-05* Map ISP1362 USB OTG controller for NSCU boardwdenk
* Patch by Brad Parker, 02 Aug 2003: fix sc520_cdp problems * Implement Boot Cycle Detection (Req. 2.3 of OSDL CGL Reqirements) * Allow erase command to cross flash bank boundaries
2003-07-11- Fix bug in CONFIG_VERSION_VARIABLE.stroese
2003-06-19Patches by Murray Jensen, 17 Jun 2003:wdenk
- Hymod board database mods: add "who" field and new xilinx chip types - provide new "init_cmd_timeout()" function so code external to "common/main.c" can use the "reset_cmd_timeout()" function before entering the main loop - add DTT support for adm1021 (new file dtt/adm1021.c; config slightly different. see include/configs/hymod.h for an example (requires CONFIG_DTT_ADM1021, CONFIG_DTT_SENSORS, and CFG_DTT_ADM1021 defined) - add new "eeprom_probe()" function which has similar args and behaves in a similar way to "eeprom_read()" etc. - add 8260 FCC ethernet loopback code (new "eth_loopback_test()" function which is enabled by defining CONFIG_ETHER_LOOPBACK_TEST) - gdbtools copyright update - ensure that set_msr() executes the "sync" and "isync" instructions after the "mtmsr" instruction in cpu/mpc8260/interrupts.c - 8260 I/O ports fix: Open Drain should be set last when configuring - add SIU IRQ defines for 8260 - allow LDSCRIPT override and OBJCFLAGS initialization: change to config.mk to allow board configurations to override the GNU linker script, selected via the LDSCRIPT, make variable, and to give an initial value to the OBJCFLAGS make variable - 8260 i2c enhancement: o correctly extends the timeout depending on the size of all queued messages for both transmit and receive o will not continue with receive if transmit times out o ensures that the error callback is done for all queued tx and rx messages o correctly detects both tx and rx timeouts, only delivers one to the callback, and does not overwrite an earlier error o logic in i2c_probe now correct - add "vprintf()" function so that "panic()" function can be technically correct - many Hymod board changes
2003-05-28* Fix data abort exception handling for arm920t CPUwdenk
* Fix alignment problems with flash driver for TRAB board * Patch by Donald White, 21 May 2003: fix calculation of base address in pci_hose_config_device() * Fix bug in command line parsing: "cmd1;cmd2" is supposed to always execute "cmd2", even if "cmd1" fails. Note that this is different to "run var1 var2" where the contents of "var2" will NOT be executed when a command in "var1" fails.
2003-05-03* Add support for Promess ATC boardLABEL_2003_05_03_1700wdenk
* Patch by Keith Outwater, 28 Apr 2003: - Miscellaneous corrections and additions to GEN860T board specific code. - Added GEN860_SC variant to GEN860T. - Miscellaneous corrections to GEN860T documentation. - Correct duplicate entry in U-Boot CREDITS file. - Add GEN860T_SC entry in MAINTAINERS file. - Update CREDITS file with GEN860T_SC info. * Update Smiths Aerospace addresses in MAINTAINERS file * Fix error handling in hush's version of "run" command
2003-04-05* Patch by Arun Dharankar, 4 Apr 2003:LABEL_2003_04_05_0300wdenk
Add IDMA example code (tested on 8260 only) * Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs * Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS * Patch by Denis Peter, 04 Apr 2003: - update MIP405-4 board * Patches by Denis Peter, 03 April 2003: - fix PCI IRQs on MPL boards - fix two more un-relocated pointer problems * Fix behaviour of "run" command: - print error message iv variable does not exist - terminate processing of arguments in case of error * Patches by Peter Figuli, 10 Mar 2003 - Add support for BTUART on PXA platform - Add support for WEP EP250 (PXA) board * Fix flash problems on INCA-IP; add tool to allow bruning images to flash using a BDI2000 * Implement fix for I2C Edge Conditions problem for all boards that use the bit-banging driver (common/soft_i2c.c) * Add patches by Robert Schwebel, 31 Mar 2003: - csb226 board: bring in sync with innokom/memsetup.S - csb226 board: fix MDREFR handling - misc doc fixes / extensions - innokom board: cleanup, MDREFR fix in memsetup.S, config update - add BOOT_PROGRESS to armlinux.c
2003-04-04U-Boot version environment variable "ver" added (CONFIG_VERSION_VARIABLE).stroese
2003-01-02Patch by Detlev Zundel, 30 Dec 2002:wdenk
Add single quote support for (old) command line parser
2002-12-03* Fix startup problems with VFD display on TRABLABEL_2002_12_03_2230wdenk
* Patch by Pierre Aubert, 20 Nov 2002 Add driver for Epson SED13806 graphic controller. Add support for BMP logos in cfb_console driver.
