This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
Signed-off-by: Detlev Zundel <dzu@denx.de>
Signed-off-by: Piotr Kruszynski <ppk@semihalf.com>
Acked-by: Bartlomiej Sieka <tur@semihalf.com>
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Properly pass break code back from readline.
Patch by Roger Blofeld, 31 Jul 2006
Patch by Stefan Roese, 27 Jul 2006
Patch by JinHua Luo, 01 Sep 2005
Patch by Andrew Dyer, 13 Jun 2005
Patch by Ladislav Michl, 22 Feb 2005
- Add RESET/PREBOOT/AUTOBOOT support for RPXlite_DW board
- Adjust CPU:BUS frequency ratio 1:1 when core frequency
less than 50MHz
* Patch by Sam Song, 10 Oct 2004:
Fix a parameter error in run_command() in main.c
sticks (including FAT / VFAT filesystem support)
* Add SL811 Host Controller Interface driver for USB
* Add CFG_I2C_EEPROM_ADDR_OVERFLOW desription to README
* Patch by Pantelis Antoniou, 19 Apr 2004:
Allow to use shell style syntax (i. e. ${var} ) with standard parser.
Minor patches for Intracom boards.
* Patch by Christian Pell, 19 Apr 2004:
cleanup support for CF/IDE on PCMCIA for PXA25X
- add auto-complete support to the U-Boot CLI
- add support for NETTA and NETPHONE boards; fix NETVIA board
* Patch by Yuli Barcohen, 28 Mar 2004:
- Add support for MPC8272 family including MPC8247/8248/8271/8272
- Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS)
- Change configuration method for MPC8260ADS family
Ignore '\0' characters in console input for use with telnet and
telco pads.
* Patch by Leon Kukovec, 17 Mar 2004:
typo fix for strswab prototype #ifdef
- show PCI clock frequency on MPC8260 systems
- add FCC_PSMR_RMII flag for HiP7 processors
- in do_jffs2_fsload(), take load address from load_addr if not set
explicit, update load_addr otherwise
- replaced printf by putc/puts when no formatting is needed
(smaller code size, faster execution)
"revive" U-Boot support for old Motorola MPC860ADS board
* Patch by Cam(ilo?), 03 Dec 2003:
make examples build even with broken Montavista objcopy
* Patch by Pavel Bartusek, 27 Nov 2003:
fix conversion problem with "bootretry" evironment variable
* Make CONFIG_SILENT_CONSOLE work with CONFIG_AUTOBOOT_KEYED
for more information
* Patch by Brad Parker, 02 Aug 2003:
fix sc520_cdp problems
* Implement Boot Cycle Detection (Req. 2.3 of OSDL CGL Reqirements)
* Allow erase command to cross flash bank boundaries
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
- Hymod board database mods: add "who" field and new xilinx chip types
- provide new "init_cmd_timeout()" function so code external to
"common/main.c" can use the "reset_cmd_timeout()" function before
entering the main loop
- add DTT support for adm1021 (new file dtt/adm1021.c; config
slightly different. see include/configs/hymod.h for an example
(requires CONFIG_DTT_ADM1021, CONFIG_DTT_SENSORS, and
CFG_DTT_ADM1021 defined)
- add new "eeprom_probe()" function which has similar args and
behaves in a similar way to "eeprom_read()" etc.
- add 8260 FCC ethernet loopback code (new "eth_loopback_test()"
function which is enabled by defining CONFIG_ETHER_LOOPBACK_TEST)
- gdbtools copyright update
- ensure that set_msr() executes the "sync" and "isync" instructions
after the "mtmsr" instruction in cpu/mpc8260/interrupts.c
- 8260 I/O ports fix: Open Drain should be set last when configuring
- add SIU IRQ defines for 8260
- allow LDSCRIPT override and OBJCFLAGS initialization: change to
config.mk to allow board configurations to override the GNU
linker script, selected via the LDSCRIPT, make variable, and to
give an initial value to the OBJCFLAGS make variable
- 8260 i2c enhancement:
o correctly extends the timeout depending on the size of all
queued messages for both transmit and receive
o will not continue with receive if transmit times out
o ensures that the error callback is done for all queued tx
and rx messages
o correctly detects both tx and rx timeouts, only delivers one to
the callback, and does not overwrite an earlier error
o logic in i2c_probe now correct
- add "vprintf()" function so that "panic()" function can be
technically correct
- many Hymod board changes
* Fix alignment problems with flash driver for TRAB board
* Patch by Donald White, 21 May 2003:
fix calculation of base address in pci_hose_config_device()
* Fix bug in command line parsing: "cmd1;cmd2" is supposed to always
execute "cmd2", even if "cmd1" fails. Note that this is different
to "run var1 var2" where the contents of "var2" will NOT be
executed when a command in "var1" fails.
* Patch by Keith Outwater, 28 Apr 2003:
- Miscellaneous corrections and additions to GEN860T board specific code.
- Added GEN860_SC variant to GEN860T.
- Miscellaneous corrections to GEN860T documentation.
- Correct duplicate entry in U-Boot CREDITS file.
- Add GEN860T_SC entry in MAINTAINERS file.
- Update CREDITS file with GEN860T_SC info.
* Update Smiths Aerospace addresses in MAINTAINERS file
* Fix error handling in hush's version of "run" command
Add IDMA example code (tested on 8260 only)
* Add support for Purple Board (MIPS64 5Kc)
* Add support for MIPS64 5Kc CPUs
* Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS
* Patch by Denis Peter, 04 Apr 2003:
- update MIP405-4 board
* Patches by Denis Peter, 03 April 2003:
- fix PCI IRQs on MPL boards
- fix two more un-relocated pointer problems
* Fix behaviour of "run" command:
- print error message iv variable does not exist
- terminate processing of arguments in case of error
* Patches by Peter Figuli, 10 Mar 2003
- Add support for BTUART on PXA platform
- Add support for WEP EP250 (PXA) board
* Fix flash problems on INCA-IP; add tool to allow bruning images to
flash using a BDI2000
* Implement fix for I2C Edge Conditions problem for all boards that
use the bit-banging driver (common/soft_i2c.c)
* Add patches by Robert Schwebel, 31 Mar 2003:
- csb226 board: bring in sync with innokom/memsetup.S
- csb226 board: fix MDREFR handling
- misc doc fixes / extensions
- innokom board: cleanup, MDREFR fix in memsetup.S, config update
- add BOOT_PROGRESS to armlinux.c
- 16/32 MB and 50/80 MHz support with auto-detection for IP860
- ETH05 and BEDBUG support for CU824
- added support for MicroSys CPC45
- new BOOTROM/FLASH0 and DOC base for PM826
* Patch by Robert Schwebel, 12 Mar 2003:
Fix the chpart command on innokom board
* Name cleanup:
mv include/asm-i386/ppcboot-i386.h include/asm-i386/u-boot-i386.h
s/PPCBoot/U-Boot/ in some files
s/pImage/uImage/ in some files
* Patch by Detlev Zundel, 15 Jan 2003:
Fix '' command line quoting
* Patch by The LEOX team, 19 Jan 2003:
- add support for the ELPT860 board
- add support for Dallas ds164x RTC
Add single quote support for (old) command line parser
* Patch by Pierre Aubert, 20 Nov 2002
Add driver for Epson SED13806 graphic controller.
Add support for BMP logos in cfb_console driver.
Add code for AmigaOne board
(preliminary merge to U-Boot, still WIP)
* Patch by Jon Diekema, 12 Nov 2002:
- Adding URL for IEEE OUI lookup
- Making the autoboot #defines dependent on CONFIG_AUTOBOOT_KEYED
being defined.
- In the CONFIG_EXTRA_ENV_SETTINGS #define, the root-on-initrd and
root-on-nfs macros are designed to switch how the default boot
method gets defined.
