path: root/common/log_console.c
2018-02-03log: Update log_console to honour the log formatSimon Glass
At present this just outputs the message. Update it to output whatever the format requests. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-07log: Add a console driverSimon Glass
It is useful to display log messages on the console. Add a simple driver to handle this. Note that this driver outputs to the console, which may be serial or video. It does not specifically select serial output. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
