path: root/common/log.c
2018-02-03log: add category LOGC_EFIHeinrich Schuchardt
The EFI implementation does not fit into any of the existing categories. Provide LOGC_EFI so that EFI related message can be filtered. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-02-03log: Add control over log formattingSimon Glass
It is useful to be able to control the output format of log records on the console. As a starting point, add definitions for controlling which elements of the log record are displayed. Use function and message as the default, since these are the most useful fields. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-02-03log: Add functions to convert IDs to/from namesSimon Glass
Category and level both use an enum for their ID values. Add functions to convert these IDs to strings and vice versa. This will allow the log to output the strings instead of the (inscrutable) values. At the same time, add a new 'driver-model' category, to cover core driver-model functions and fix an incorrect value for LOGL_MAX. Tests will be added with the new 'log' subcommands. Signed-off-by: Simon Glass <sjg@chromium.org> (Updated to correct clang warnings)
2017-12-07log: Plumb logging into the init sequenceSimon Glass
Set up logging both before and after relocation. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-12-07log: Add an implementation of loggingSimon Glass
Add the logging header file and implementation with some configuration options to control it. Signed-off-by: Simon Glass <sjg@chromium.org>
