path: root/common/log.c
2019-02-20log: Add a Kconfig option to set the default log levelSimon Glass
At present the default log level is set to LOGL_INFO on start-up. Allow this to be controlled from Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-10-09sandbox: Add a flag to set the default log levelSimon Glass
It is useful to be able to set the default log level from the command line when running sandbox. Add a new -L command-line flag for this. The log level is set using the enum log_level_t in log.h. At present a number must be specified, e.g. -L7 for debug. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-06-18log: Fix incorect range check in log_get_cat_name()Simon Glass
This allows access to an element after the end of the array. Fix it. Reported-by: Coverity (CID: 173279) Signed-off-by: Simon Glass <sjg@chromium.org>
2018-04-10log: Correct missing free() on error in log_add_filter()Simon Glass
If there is a problem with the parameters to log_add_filter(), the memory allocated is currently not freed. Fix this. Reported-by: Coverity (CID: 171962) Signed-off-by: Simon Glass <sjg@chromium.org>
2018-02-03log: add category LOGC_EFIHeinrich Schuchardt
The EFI implementation does not fit into any of the existing categories. Provide LOGC_EFI so that EFI related message can be filtered. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-02-03log: Add control over log formattingSimon Glass
It is useful to be able to control the output format of log records on the console. As a starting point, add definitions for controlling which elements of the log record are displayed. Use function and message as the default, since these are the most useful fields. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-02-03log: Add functions to convert IDs to/from namesSimon Glass
Category and level both use an enum for their ID values. Add functions to convert these IDs to strings and vice versa. This will allow the log to output the strings instead of the (inscrutable) values. At the same time, add a new 'driver-model' category, to cover core driver-model functions and fix an incorrect value for LOGL_MAX. Tests will be added with the new 'log' subcommands. Signed-off-by: Simon Glass <sjg@chromium.org> (Updated to correct clang warnings)
2017-12-07log: Plumb logging into the init sequenceSimon Glass
Set up logging both before and after relocation. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-12-07log: Add an implementation of loggingSimon Glass
Add the logging header file and implementation with some configuration options to control it. Signed-off-by: Simon Glass <sjg@chromium.org>
