Fix build warning:
common/lcd.c: In function 'lcd_clear':
common/lcd.c:166:6: warning: variable 'bg_color' set but not used [-Wunused-but-set-variable]
int bg_color;
common/lcd.c: In function 'lcd_setmem':
common/lcd.c:296:2: warning: format '%d' expects argument of type 'int', but argument 2 has type 'u_long' [-Wformat=]
debug("LCD panel info: %d x %d, %d bit/pix\n", panel_info.vl_col,
common/lcd.c:296:2: warning: format '%d' expects argument of type 'int', but argument 3 has type 'u_long' [-Wformat=]
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
LCD_MONOCHROME is removed in commit f4469f50b0367820121ef2d313517d422ed70e1d.
Add related code back to support epdc.
In this patch, also include crm_regs.h in mx6slevk.c to make epdc code
be compiled ok.
COLOR_MASK is also added from commit a7de2953f51e70754190d3516167d58d27d17219
lcd_logo() currently performs tasks well beyond just displaying the logo.
It has code which displays splash image, it has logic which determines
when the different display features are displayed, and it is coupled with
the lcd console because it holds the responsibility of returning the
lcd console base address.
Make lcd_logo() just about the logo by:
* Moving splash image display code into a dedicated function
* Moving the logic regarding when various features are displayed to
lcd_clear() (which is arguably not the correct name for housing such
code either, but it is currently the most fitting location code wise)
* Move the responsibility of setting the console base address to
lcd_clear() too.
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Tested-by: Bo Shen <voice.shen@atmel.com>
Tested-by: Josh Wu <josh.wu@atmel.com>
Cc: Bo Shen <voice.shen@atmel.com>
We now have api functions that can support compiling simplefb code as its own
module. Since this code is not part of the display functionality, extract it
to its own file.
Raspberry Pi is updated to accommodate the changes.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
The name "bitmap_plot" is misleading because it implies that this is a generic
function capable of dealing with any bitmap, but its implementation only works
with the logo data.
Rename the function to better reflect this.
This cleanup mostly focuses on removing unnecessary whitespace and comments
which are superfluous and/or do not conform to the coding style.
Remove unused includes.
Reduce the lcd_display_bitmap #ifdef complexity by extracting Atmel-specific
code for setting cmap for bitmap images into a new function lcd_set_cmap().
A default version is implemented with the remainder of the code.
Get rid of platform-specific #ifdefs in bitmap_plot() by moving the generic
case of setting cmap into the weak lcd_logo_set_cmap().
Reduce the bitmap_plot #ifdef complexity by extracting MPC823-specific code for
setting cmap into its own implementation of lcd_logo_set_cmap(), implemented in
mpc8xx_lcd.c. In the MPC823 implementation, ARRAY_SIZE(bmp_logo_palette) is
switched for BMP_LOGO_COLORS to avoid having to include bmp_logo_data.h, which
would cause a compilation error because the logo data and palette arrays would
be defined twice.
This is a step towards cleaning bitmap_plot() of platform-specific code.
Reduce the bitmap_plot #ifdef complexity by extracting Atmel-specific code for
setting cmap into a new function lcd_logo_set_cmap(), which is implemented in
atmel_lcdfb driver and defined as part of common/lcd.c api with a weak dummy
version. In the Atmel implementation, ARRAY_SIZE(bmp_logo_palette) is
be defined twice.
Reduce the amount of platform-specific code in common/lcd.c by moving MPC823
implementation of fb_put_byte() to mpc8xx_lcd.c. Since we must also have a
default implementation for everybody else, make the remainder of the code
into a weak function.
Reduce the amount of platform-specific code in common/lcd.c by moving Atmel
implementation of fb_put_word() to atmel_lcdfb.c. Since we must also have a
Acked-by: Bo Shen <voice.shen@atmel.com>
configuration_get_cmap() is multiple platform-specific functions stuffed into
one function. Split it into multiple versions, and move each version to the
appropriate driver to reduce the #ifdef complexity.
This commit 904672e (lcd: refactor lcd console stuff into its
own file), which cause lcd console address is not initialized.
This patch initialize the lcd console use the default value,
will be update when splash screen is enabled.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
common/lcd.c is a mix of code portions that do different but related
things. To improve modularity, the various code portions should be split
into their own modules. Separate lcd console code into its own file.
lcd_logo() has the following return value:
#if defined(CONFIG_LCD_LOGO) && !defined(CONFIG_LCD_INFO_BELOW_LOGO)
return (void *)((ulong)lcd_base + BMP_LOGO_HEIGHT * lcd_line_length);
#else
return (void *)lcd_base;
#endif
This return value gets assigned to lcd_console_address.
lcd_console_address is not assigned or modified anywhere else.
Thus:
#if defined(CONFIG_LCD_LOGO) && !defined(CONFIG_LCD_INFO_BELOW_LOGO):
y' = BMP_LOGO_HEIGHT + y;
lcd_base + y' * lcd_line_length ==
lcd_base + (BMP_LOGO_HEIGHT + y) * lcd_line_length ==
lcd_base + BMP_LOGO_HEIGHT * lcd_line_length + y * lcd_line_length ==
lcd_console_address + y * lcd_line_length
#else
lcd_base + y * lcd_line_length == lcd_console_address + y * lcd_line_length
#endif
This is a preparatory step for extracting lcd console code into its own
file.
Introduce lcd_getbgcolor() and lcd_getfgcolor(), and use them where
applicable.
file.
COLOR_MASK macro doesn't do anything; Remove it to reduce visual
complexity.
file.
Introduce set_console_row(), set_console_col(), and lcd_init_console().
Use these functions in lcd functions: lcd_init(), lcd_clear(), lcd_logo().
file.
Replace CONSOLE_(ROWS|COLS) macros with variables, and assign the
original macro values.
file.
Rename console_(row|col) to console_curr_(row|col) to better distinguish
it from console_(rows|cols).
This is a preparatory step for extracting lcd console code into its own file.
No one is using LCD_MONOCHROME; remove related code.
Remove code duplication from lcd_drawchars().
No one is using CONFIG_SYS_INVERT_COLORS; remove related code.
The U-Boot port runs on a variety of RPi models, not just the B. So,
rename the port to something slightly more generic.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Change lcd_dt_simplefb_configure_node into a wrapper around the new generic
fdt_setup_simplefb_node helper function.
Tested-by: Stephen Warren <swarren@wwwdotorg.org>
U-Boot has never cared about the type when we get max/min of two
values, but Linux Kernel does. This commit gets min, max, min3, max3
macros synced with the kernel introducing type checks.
Many of references of those macros must be fixed to suppress warnings.
We have two options:
- Use min, max, min3, max3 only when the arguments have the same type
(or add casts to the arguments)
- Use min_t/max_t instead with the appropriate type for the first
argument
Acked-by: Pavel Machek <pavel@denx.de>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Tested-by: Lukasz Majewski <l.majewski@samsung.com>
[trini: Fixup arch/blackfin/lib/string.c]
mcc200 and prs200 are old and have no maintainer. Remove the boards.
This also removes the mcc200 specific 1bpp BMP support from
common/lcd.c
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: York Sun <yorksun@freescale.com>
This commit introduces a Kconfig symbol for each ARM CPU:
CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136,
CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100.
Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected
for CPU_ARM1176 and CPU_V7.
For each target, the corresponding CPU is selected and the definition of
SYS_CPU in the corresponding Kconfig file is removed.
Also, it removes redundant "string" type in some Kconfig files.
Signed-off-by: Georges Savoundararadj <savoundg@gmail.com>
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Add a block to avoid a build error with the variable declaration.
Enable the option on sandbox to prevent an error being introduced in
future.
most todays LCDs support 32bpp e.g. the framebuffer memory is 32bpp
organized.
To support 24bpp BMPs we need to take only 3 byte from the bpp and set
one byte from the FB to 0.
Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
prevents a clang warning that the function is
never used.
cc: agust@denx.de
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
This patch removes following two functions:
- lcd_getbgcolor(...)
not used somewhere outside lcd.c, internally we use now the global
variable lcd_color_bg (was return value of function before)
- lcd_getfgcolor(...)
not used in any place of u-boot
[agust: rebased]
- Adds support for 32-bit organized framebuffers to the LCD-framework.
Cc: agust@denx.de
At present stdio device functions do not get any clue as to which stdio
device is being acted on. Some implementations go to great lengths to work
around this, such as defining a whole separate set of functions for each
possible device.
For driver model we need to associate a stdio_dev with a device. It doesn't
seem possible to continue with this work-around approach.
Instead, add a stdio_dev pointer to each of the stdio member functions.
Note: The serial drivers have the same problem, but it is not strictly
necessary to fix that to get driver model running. Also, if we convert
serial over to driver model the problem will go away.
Code size increases by 244 bytes for Thumb2 and 428 for PowerPC.
22: stdio: Pass device pointer to stdio methods
arm: (for 2/2 boards) all +244.0 bss -4.0 text +248.0
powerpc: (for 1/1 boards) all +428.0 text +428.0
Add a simple LCD driver which uses SDL to display the image. We update the
image regularly, while still providing for reasonable performance.
Adjust the common lcd code to support sandbox.
For command-line runs we do not want the LCD to be displayed, so add a
--show_lcd option to enable it.
Tested-by: Che-Liang Chiou <clchiou@chromium.org>
Changes:
- le16_to_cpu() to get_unaligned_le16()
- le32_to_cpu() to get_unaligned_le32()
when access fields in struct bmp header.
This changes avoids data abort exception caused by unaligned data access.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Acked-by: Anatolij Gustschin <agust@denx.de>
Remove the redundant lcd_line_length initialisation which
sneaked in when an earlier version of the patch of commit
6d330719 has been rebased.
Some lcd drivers need to setup lcd_line_length not from the
panel_info parameters but by different means. Make the
lcd_get_size() weak to allow setting lcd_line_length in
a driver specific way.
This patch moves all the font configuration values into video_font_data.h
so they are all in the right place with the font. The video_font.h now only
includes video_font_data.h and will allow us to select and include different
font once more fonts are added.
[agust: fixed build warning for mcc200]
[trini: Fixup common/cmd_io.c]
Code for checking "splashpos" environment variable is
duplicated in drivers, move it to the common function.
Call this function also in the bmp display command to
consider "splashpos" settings.
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
Create splash.c/h to put the function and any future common splash
screen code in.
Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com>
Some ARM compilers may emit code that makes unaligned accesses when
faced with constructs such as:
const char format[] = "r5g6b5";
Make this data static since it doesn't chagne; the compiler will simply
place it into the .rodata section directly, and avoid any unaligned run-
time initialization.
simple-framebuffer is a new device tree binding that describes a pre-
configured frame-buffer memory region and its format. The Linux kernel
contains a driver that supports this binding. Implement functions to
create a DT node (or fill in an existing node) with parameters that
describe the framebuffer format that U-Boot is using.
This will be immediately used by the Raspberry Pi board in U-Boot, and
likely will be used by the Samsung ARM ChromeBook support soon too. It
could well be used by many other boards (e.g. Tegra boards with built-in
LCD panels, which aren't yet supported by the Linux kernel).
After merging LCD patches for v2013.04 the bcm2835 video
driver building is broken due to removal of many global
variables. Fix the driver.
drivers/video/Makefile
Currently bitmap logos don't interpret the X coordinate
correctly if the bpp is anything other than 8.
Signed-off-by: Andre Renaud <andre@bluewatersys.com>
