path: root/common/kgdb.c
2014-09-16kgdb: Remove first_entry for kgdbPeng Fan
There are two ways to run into handle_exception, run command 'kgdb' and encounter a breakpoint which triggers exception handling. The origin source code only saves regs when first run command 'kgdb'. Take the following for example, When run 'kgdb', regs is saved to entry_regs. When run 'bootz', regs is not saved. However, if we set a breakpoint, then continue. When breakpoint is reached, run `quit`, and Now return to the instruction which follows kgdb, but not bootz.This may cause errors. So, save regs for each handle_exception call to return to the correct place. Example: Target | Host =>kgdb | (gdb)b bootz | (gdb)c =>bootz | | (gdb)Here stop because of breakpoint | (gdb)q Signed-off-by: Peng Fan <van.freenix@gmail.com>
2010-01-18kgdb: update mem2hex/hex2mem funcsRobin Getz
Convert the funcs to do the conversion inline so that we can do the copy all at once with memcpy. This let's us push out an weird arch-specific issue with accessing different regions of memory to the memcpy function like the MMRs on Blackfin systems, and it should be a bit faster. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-02-11common/{hush, kgdb, serial}.c: build by COBJS-$(...) in MakefileMike Frysinger
Move global '#ifdef CONFIG_xxx .... #endif' out of the .c files and into the COBJS-$(CONFIG_xxx) in the Makefile. Also delete unused var in kgdb code in the process. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-03-09common/kgdb.c: fix 'dereferencing type-punned pointer' warningWolfgang Denk
and get rid of a couple of unneeded casts. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/* non-cmd*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04common/ non-cmd: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2002-08-27Initial revisionwdenk
