There is more and more usage of printing 64bit values,
so enable this feature generally, and delete the
CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL
defines.
Add lzop decompression support to the existing lzo bitstream handling
(think gzip versus zlib), and support it for uImage decompression if
CONFIG_LZO is enabled.
Lzop doesn't compress as good as gzip (~10% worse), but decompression
is very fast (~0.7s faster here on a slow ppc). The lzop decompression
code is based on Albin Tonnerre's recent ARM Linux lzo support patch.
Cc: albin.tonnerre@free-electrons.com
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Add #ifdefs where necessary to not perform relocation fixups. This
allows boards/architectures which support relocation to trim a decent
chunk of code.
Note that this patch doesn't add #ifdefs to architecture-specific code
which does not support relocation.
This patch adds support for "kwbimage" (Kirkwood Boot Image)
image types to the mkimage code.
For details refer to docs/README.kwbimage
This patch is tested with Sheevaplug board
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
Acked-by: Ron Lee <ron@debian.org>
- make get_table_entry_id() global
- make get_table_entry_name() global
- move struct table_entry to image.h
Currently this code is used by image.c only.
This patch makes this API global so it can be used by other parts of
code, too.
Acked-by: Ron Lee <ron.debian.org>
Edit comments and commit message.
Currently it is used by image.c only, but the the function can be
used to support additional mkimage types like for example kwbimage,
so make this function globally visible.
Edited commit message.
This fixes some compiler warnings:
tools/default_image.c:141: warning: initialization from incompatible pointer type
tools/fit_image.c:202: warning: initialization from incompatible pointer type
and changes to code to use "const" attributes in a few places where
it's appropriate.
Without this, u-boot can crash or print garbage if the original link
address no longer points to a valid string.
FDT support is used for both FIT style images and for architectures
that can pass a fdt blob to an OS (ppc, m68k, sparc).
For other architectures and boards which do not pass a fdt blob to an
OS but want to use the new uImage format, we just need FIT support.
Now we can have the 4 following configurations :
1) FIT only CONFIG_FIT
2) fdt blob only CONFIG_OF_LIBFDT
3) both CONFIG_OF_LIBFDT & CONFIG_FIT
4) none none
Now that the auto-update feature uses the 'firmware' type for updates, it is
useful to inspect the load address of such images.
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com>
Fix printf format-string/arg mismatches under -DDEBUG.
These warnings occur with DEBUG defined for a platform using
cpu/mpc85xx. Users of other architectures can unearth similar
problems by adding the line "CFLAGS += -DDEBUG=1" in config.mk right
after "CFLAGS += $(call cc-option,-fno-stack-protector)".
Signed-off-by: Andrew Klossner <andrew@cesa.opbu.xerox.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
- add function fit_all_image_check_hashes() that verifies if all
hashes of all images in the FIT are valid
- improve output of fit_image_check_hashes() when the hash check fails
Pantelis Antoniou stated:
AFAIK, it is still used but the products using PPC are long gone.
Nuke it plz (from orbit).
So remove it since it cleans up a usage of env_get_char outside of
the environment code.
Adds returning an error from the ramdisk detection code if
its not a real ramdisk (invalid). There is no reason we can't
just return back to the console if we detect an invalid
ramdisk or CRC error.
This patch adds bootm_start() return value check. If
error status is returned, we do not proceed further to
prevent board reset or crash as we still can recover
at this point.
Set the fdt working address so "fdt FOO" commands can be used as part
of the bootm flow. Also set an the environment variable "fdtaddr"
with the value.
Move the code that handles finding a device tree blob and relocating
it (if needed) into common code so all arch's have access to it.
The autostart revert caused a bit of duplicated code as well as
code that was using images->autostart that needs to get removed so
we can build again.
This reverts commit f5614e7926863bf0225ec860d9b319741a9c4004.
The commit was based on a misunderstanding of the (documented)
meaning of the 'autostart' environment variable. It might cause
boards to hang if 'autostart' was used, with the potential to brick
them. Go back to the documented behaviour.
common/cmd_bootm.c
common/image.c
include/image.h
boot_get_ramdisk() should not treat the case when a FIT image does
not contain a ramdisk as an error.
Acked-by: Michal Simek <monstr@monstr.eu>
Microblaze and PowerPC use boot_get_ramdisk for loading
ramdisk to memory with checking return value.
Return 0 means success. Return 1 means failed.
Here is correspond part of code from bootm.c which check
return code.
ret = boot_get_ramdisk (argc, argv, images, IH_ARCH_PPC,
&rd_data_start, &rd_data_end);
if (ret)
goto error;
This updates the lmb code to use phys_size_t
and phys_addr_t instead of unsigned long. Other code
which interacts with this code, like getenv_bootm_size()
is also updated.
Booted on MPC8641HPCN, build-tested ppc, arm, mips.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Add logbuffer to reserved LMB areas to prevent initrd allocation
from overlaping with it.
Make sure to use correct logbuffer base address.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
This reverts commit 1b5605ca57fbb364f4d78eeee28b974ed875e888
which breaks building on all PPC boards that don't use a log buffer.
Calculation of tail was incorrect when size % 4 == 0.
New code removes the conditional and does the same thing but with arithmetic
Signed-off-by: Nick Spence <nick.spence@freescale.com>
Recent modifcations to LOGBUFFER handling code were incorrecly
introduced to fit_check_kernel() routine during
"Merge branch 'new-image' of git://www.denx.de/git/u-boot-testing",
commit 27f33e9f45ef7f9685cbdc65066a1828e85dde4f.
This patch cleans up this merge issue.
Add support for the recognition of 'powerpc' as an alias for the PowerPC
architecture type since Linux is already trending in that direction,
preferring 'powerpc' to 'ppc'.
Signed-off-by: Grant Erickson <gerickson@nuovations.com>
Some files didn't get updated properly with the "Use watchdog-aware
functions when calculating hashes of images" commit, this commit
fixes this.
As suggested by Wolfgang Denk:
- image printing functions:
- remove wrappers
- remove indentation prefix from functions' signatures
- merge getenv_verify and getenv_autostart into one parametrized function
The envcrc.c does sizeof(unsigned long) when calculating the crc, but
this is done with the build toolchain instead of the target tool
chain, so if the build is a 64bit system but the target is 32bits,
the size will obviously be wrong. This converts all unsigned long
stuff related to crc32 to uint32_t types. Compile tested only: output
of ./tools/envcrc when run on a 32bit build system matches that of a
64bit build system.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Before new uImage code was merged, bootm code allowed for the kernel image to
get overwritten during decompresion. new uImage introduced a check for image
overwrites and refused to boot the image that got overwritten. This patch
restores the old behavior. It also adds a warning when the image overwriten is
a multi-image file, because in such case accessing componentes other than the
first one will fail.
Some systems have md5.h installed in /usr/include/. This isn't the
desired file (we want the one in include/md5.h). This will avoid the
conflict. This fixes the host tools building problem by creating a new
directory for U-Boot specific header files.
[Patch by Andy Fleming, modified to use separate directory by Wolfgang
Denk]
Acked-by: Timur Tabi <timur@freescale.com>
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
ARM platforms don't have a bd->bi_memsize so use bd->bi_dram[0].size instead.
Save FIT configuration provied in the first bootm argument and use it
when to get ramdisk/FDT subimages when second and third (ramdisk/FDT)
arguments are not specified.
This patch allocates a set of show_boot_progress() IDs for new uImage format
and adds show_boot_progress() calls in new uImage format handling code.
This patch adds new node offset fields to struct bootm_headers
and updates bootm_headers processing code to make use of them.
Saved node offsets allow to avoid repeating fit_image_get_node() calls.
boot_get_ramdisk() and image_get_ramdisk() do not need all
cmdtp, flag, argc and argv arguments. Simplify routines definition.
This patch updates boot_get_ramdisk() routine adding format
verification and handling for new (FIT) uImages.
Add FDT-based functions for handling new format component images,
configurations, node operations, property get/set, etc.
fit_ - routines handling global new format uImage operations
like get/set top level property, process all nodes, etc.
fit_image_ - routines handling component images subnodes
fit_conf_ - routines handling configurations node
Use uint32_t when accessing size table in image_multi_count() and
image_multi_getimg() for multi component images.
Add missing uimage_to_cpu() endianness conversion.
This patch adds the following common routines:
1) Dedicated mkimage print_header() is replaced with common
image_print_contents()
image_print_contents_noindent()
2) Common os/arch/type/comp fields name <--> id translation routines
genimg_get_os_name()
genimg_get_arch_name()
genimg_get_type_name()
genimg_get_comp_name()
genimg_get_os_id()
genimg_get_arch_id()
genimg_get_type_id()
genimg_get_comp_id()
This patch introduces the following prefix convention for the
image format handling and bootm related code:
genimg_ - dual format shared code
image_ - legacy uImage format specific code
fit_ - new uImage format specific code
boot_ - booting process related code
Related routines are renamed and a few pieces of code are moved around and
re-grouped.
Allow the user to set 'bootm_low' and 'bootm_size' env vars as a way
to restrict what memory range is used for bootm.
Acked-by: Marian Balakowicz <m8@semihalf.com>
