path: root/common/image.c
2020-04-17image: Add a common compression type detection function.Atish Patra
Currently, there is no method that can detect compression types given a file. This is very useful where a compressed kernel image is loaded directly to the memory. Inspect initial few bytes to figure out compression type of the image. It will be used in booti method for now but can be reused any other function in future as well. Signed-off-by: Atish Patra <atish.patra@wdc.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-02-05dm: core: Create a new header file for 'compat' featuresSimon Glass
At present dm/device.h includes the linux-compatible features. This requires including linux/compat.h which in turn includes a lot of headers. One of these is malloc.h which we thus end up including in every file in U-Boot. Apart from the inefficiency of this, it is problematic for sandbox which needs to use the system malloc() in some files. Move the compatibility features into a separate header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17image: Rename load_addr, save_addr, save_sizeSimon Glass
These global variables are quite short and generic. In fact the same name is more often used locally for struct members and function arguments. Add a image_ prefix to make them easier to distinguish. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-07image: Add IH_OS_EFI for EFI chain-load bootCristian Ciocaltea
Add a new OS type to be used for chain-loading an EFI compatible firmware or boot loader like GRUB2, possibly in a verified boot scenario. Bellow is sample ITS file that generates a FIT image supporting secure boot. Please note the presence of 'os = "efi";' line, which identifies the currently introduced OS type: / { #address-cells = <1>; images { efi-grub { description = "GRUB EFI"; data = /incbin/("bootarm.efi"); type = "kernel_noload"; arch = "arm"; os = "efi"; compression = "none"; load = <0x0>; entry = <0x0>; hash-1 { algo = "sha256"; }; }; }; configurations { default = "config-grub"; config-grub { kernel = "efi-grub"; signature-1 { algo = "sha256,rsa2048"; sign-images = "kernel"; }; }; }; }; Signed-off-by: Cristian Ciocaltea <cristian.ciocaltea@gmail.com> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-12-02common: Move ARM cache operations out of common.hSimon Glass
These functions are CPU-related and do not use driver model. Move them to cpu_func.h Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Add a new lz4.h header fileSimon Glass
Add a header file to house the lz4 compression function. Add a comment while we are here, since it not even clear from the name what the function actuall does. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02crc32: Use the crc.h header for crc functionsSimon Glass
Drop inclusion of crc.h in common.h and use the correct header directly instead. With this we can drop the conflicting definition in fw_env.h and rely on the crc.h header, which is already included. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-10-09Merge tag 'xilinx-for-v2020.01' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze Xilinx/FPGA changes for v2020.01 FPGA: - Enable fpga loading on Versal - Minor fix Microblaze: - Fix LMB configurations to support initrds - Some other cleanups Zynq: - Minor config/dt changes - Add distro boot support for usb1 and mmc1 - Remove Xilinx private boot commands and use only distro boot ZynqMP: - Kconfig cleanups, defconfig updates - Update some dt files - Add firmware driver for talking to PMUFW - Extend distro boot support for jtag - Add new IDs - Add system controller configurations - Convert code to talk firmware via mailbox or SMCs Versal: - Add board_late_init() - Add run time DT memory setup - Add DFU support - Extend distro boot support for jtag and dfu - Add clock driver - Tune mini configurations Xilinx: - Improve documentation (boot scripts, dt binding) - Enable run time initrd_high calculation - Define default SYS_PROMPT - Add zynq/zynqmp virtual defconfig Drivers: - Add Xilinx mailbox driver for talking to firmware - Clean zynq_gem for Versal - Move ZYNQ_HISPD_BROKEN to Kconfig - Wire genphy_init() in phy.c - Add Xilinx gii2rgmii bridge - Cleanup zynq_sdhci - dwc3 fix - zynq_gpio fix - axi_emac fix Others: - apalis-tk1 - clean config file
2019-10-08imx: Kconfig: Reduce default CONFIG_CSF_SIZEBreno Matheus Lima
The default CSF_SIZE defined in Kconfig is too high and SPL cannot fit into the OCRAM in certain cases. The CSF cannot achieve 0x2000 length when using RSA 4K key which is the largest key size supported by HABv4. According to AN12056 "Encrypted Boot on HABv4 and CAAM Enabled Devices" it's recommended to pad CSF binary to 0x2000 and append DEK blob to deploy encrypted boot images. As the maximum DEK blob size is 0x58 we can reduce CSF_SIZE to 0x2060 which should cover both CSF and DEK blob length. Update default_image.c and image.c to align with this change and avoid a U-Boot proper authentication failure in HAB closed devices: Authenticate image from DDR location 0x877fffc0... bad magic magic=0x32 length=0x6131 version=0x38 bad length magic=0x32 length=0x6131 version=0x38 bad version magic=0x32 length=0x6131 version=0x38 spl: ERROR: image authentication fail Fixes: 96d27fb218 (Revert "habv4: tools: Avoid hardcoded CSF size for SPL targets") Reported-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Breno Lima <breno.lima@nxp.com>
2019-10-08Revert "habv4: tools: Avoid hardcoded CSF size for SPL targets"Stefano Babic
This reverts commit 62a52f3f85bf33e286632e99f0d39b2c166af0c4.
2019-10-08habv4: tools: Avoid hardcoded CSF size for SPL targetsBreno Matheus Lima
Currently it's not possible to authenticate the U-Boot proper of mx6ul_14x14_evk_defconfig target: Authenticate image from DDR location 0x877fffc0... bad magic magic=0x0 length=0x00 version=0x3 bad length magic=0x0 length=0x00 version=0x3 bad version magic=0x0 length=0x00 version=0x3 spl: ERROR: image authentication fail Commit 0633e134784a ("imx: hab: Increase CSF_SIZE for i.MX6 and i.MX7 devices") has increased CSF_SIZE to avoid a possible issue when booting encrypted boot images. Commit d21bd69b6e95 ("tools: mkimage: add firmware-ivt image type for HAB verification") is hardcoding the CSF and IVT sizes, the new CSF size is not being considered and u-boot-ivt.img fails to boot. Avoid hardcoded CSF and IVT size to fix this issue. Signed-off-by: Breno Lima <breno.lima@nxp.com> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-10-08microblaze: Fix lmb memory initializationMichal Simek
Microblaze as Arm is using multiple memory banks which are read from DT that's why there is a need to initialized LMB based on bd->bi_dram[]. Without this fix memory base/size is all the time 0 and image relocation is not possible. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-08-27image: add new "copro" image typePatrick Delaunay
Define new image type for coprocessor images. It is used in FIT to identify the files loaded with remoteproc command (elf or bin). Signed-off-by: Loic Pallardy <loic.pallardy@st.com> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-08-26spl: support booting via RISC-V OpenSBILukas Auer
RISC-V OpenSBI is an open-source implementation of the RISC-V Supervisor Binary Interface (SBI) specification. It is required by Linux and U-Boot running in supervisor mode. This patch adds support for booting via the OpenSBI FW_DYNAMIC firmware. It supports OpenSBI version 0.4 and higher. In this configuration, U-Boot SPL starts in machine mode. After loading OpenSBI and U-Boot proper, it will start OpenSBI. All necessary parameters are generated by U-Boot SPL and are passed to OpenSBI. U-Boot proper is started in supervisor mode by OpenSBI. Support for OpenSBI is enabled with CONFIG_SPL_OPENSBI. An additional configuration entry, CONFIG_SPL_OPENSBI_LOAD_ADDR, is used to specify the load address of the OpenSBI firmware binary. It is not used directly in U-Boot and instead is intended to make the value available to scripts such as FIT configuration generators. The header file include/opensbi.h is based on header files from the OpenSBI project. They are recent, as of commit bae54f764570 ("firmware: Add fw_dynamic firmware"). Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Anup Patel <anup.patel@wdc.com>
2019-08-11env: Drop environment.h header file where not neededSimon Glass
This header file is now only used by files that access internal environment features. Drop it from various places where it is not needed. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_get() to env.hSimon Glass
Move env_get() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11common: Move gzip functions into a new gzip headerSimon Glass
As part of the effort to remove things from common.h, create a new header for the gzip functions. Move the function declarations to it and add missing documentation. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2019-07-29common: Move bootm_decomp_image() to image.c (as image_decomp())Julius Werner
Upcoming patches want to add decompression to use cases that are no longer directly related to booting. It makes sense to retain a single decompression routine, but it should no longer be in bootm.c (which is not compiled for all configurations). This patch moves bootm_decomp_image() to image.c and renames it to image_decomp() in preparation of those upcoming patches. Signed-off-by: Julius Werner <jwerner@chromium.org> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> [trini: Fix warning around handle_decomp_error being unused] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-07-11configs: Rename CONFIG_IMAGE_FORMAT_LEGACY to CONFIG_LEGACY_IMAGE_FORMATTom Rini
The name CONFIG_LEGACY_IMAGE_FORMAT reads slightly better along with allowing us to avoid a rather nasty Kbuild/Kconfig issue down the line with CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY). In a few places outside of cmd/ switch to using CONFIG_IS_ENABLED() to test what is set. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-22Support boot Android image without address on bootm commandShawn Guo
It works perfectly fine to boot an Android boot.img with bootm command followed by an explicit address argument that holds the image. But if we have boot.img downloaded into default 'loadaddr', and then boot it using bootm command without the address argument, we will run into problem, because U-Boot fails to find ramdisk and fdt (second area) in boot.img. The current Android image support assumes there is always an address argument on bootm command. However just like booting any other images, 'loadaddr' should be used when address argument is missing from bootm command. It patches boot_get_ramdisk() and boot_get_fdt() a bit to support this quite common usage of bootm command for Android image. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-01-01tools: add i.MX8M image supportPeng Fan
i.MX8M bootable image type is like i.MX6/7, but there is signed HDMI firmware image in front of A53 bootable image, which is also has an IVT header. Here we also include fit image to generate a bootable image. Signed-off-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Stefano Babic <sbabic@denx.de>
2018-11-28tools: MediaTek: add MTK boot header generation to mkimageRyder Lee
This patch adds support for MTK boot image generation. Signed-off-by: Weijie Gao <weijie.gao@mediatek.com> Signed-off-by: Ryder Lee <ryder.lee@mediatek.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-22tools: add i.MX8/8X image supportPeng Fan
i.MX8/8X bootable image type is container type. The bootable image, containers a container set which supports two container. The 1st container is for SECO firmware, the 2nd container needs to include scfw, m4_0/1 image, ACore images per your requirement. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-06-13u-boot: Fix several typosShyam Saini
's/environemnt/environment/' and 's/Environemnt/Environment/' Signed-off-by: Shyam Saini <shyam@amarulasolutions.com>
2018-05-11Merge tag 'xilinx-for-v2018.07' of git://www.denx.de/git/u-boot-microblazeTom Rini
Xilinx changes for v2018.07 microblaze: - Align defconfig zynq: - Rework fpga initialization and cpuinfo handling zynqmp: - Add ZynqMP R5 support - Wire and enable watchdog on zcu100-revC - Setup MMU map for DDR at run time - Show board info based on DT and cleanup IDENT_STRING zynqmp tools: - Add read partition support - Add initial support for Xilinx bif format for boot.bin generation mmc: - Fix get_timer usage on 64bit cpus - Add support for SD3.0 UHS mode nand-zynq: - Add support for 16bit buswidth - Use address cycles from onfi params scsi: - convert ceva sata to UCLASS_AHCI timer: - Add Cadence TTC for ZynqMP r5 watchdog: - Minor cadence driver cleanup
2018-05-11tools: zynqmpimage: Add bif supportAlexander Graf
The officially described way to generate boot.bin files for ZynqMP is to describe the contents of the target binary using a file of the "bif" format. This file then links to other files that all get packed into a bootable image. This patch adds support to read such a .bif file and generate a respective ZynqMP boot.bin file that can include the normal image and pmu files, but also supports image partitions now. This makes it a handy replacement for the proprietary "bootgen" utility that is currently used to generate boot.bin files with FSBL. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-05-08image: socfpga: Add SFP image version 1 definitionMarek Vasut
Add support for the SoCFPGA header v1, which is used on Arria 10. The layout of the v0 and v1 header is similar, yet there are a few differences which make it incompatible with previous v0 header, so add a new entry. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Chin Liang See <chin.liang.see@intel.com>
2018-03-30tools: mkimage: Support RISC-V archRick Chen
Add riscv uimage arch to support riscv-linux booting. It can Convert riscv-linux to image which can be booted by bootm command. Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com>
2018-03-19image: Add IH_OS_TEE for TEE chain-load bootBryan O'Donoghue
This patch adds a new type IH_OS_TEE. This new OS type will be used for chain-loading to Linux via a TEE. With this patch in-place you can generate a bootable OPTEE image like this: mkimage -A arm -T kernel -O tee -C none -d tee.bin uTee.optee where "tee.bin" is the input binary prefixed with an OPTEE header and uTee.optee is the output prefixed with a u-boot wrapper header. This image type "-T kernel -O tee" is differentiated from the existing IH_TYPE_TEE "-T tee" in that the IH_TYPE is installed by u-boot (flow control returns to u-boot) whereas for the new IH_OS_TEE control passes to the OPTEE firmware and the firmware chainloads onto Linux. Andrew Davis gave the following ASCII diagram: IH_OS_TEE: (mkimage -T kernel -O tee) Non-Secure Secure BootROM | ------------- | v SPL | v U-Boot ------> <----- OP-TEE | V Linux IH_TYPE_TEE: (mkimage -T tee) Non-Secure Secure BootROM | ------------- | v SPL -------> <----- OP-TEE | v U-Boot | V Linux Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org> Suggested-by: Andrew F. Davis <afd@ti.com> Cc: Harinarayan Bhatta <harinarayan@ti.com> Cc: Andrew F. Davis <afd@ti.com> Cc: Tom Rini <trini@konsulko.com> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Cc: Peng Fan <peng.fan@nxp.com> Link: http://mrvan.github.io/optee-imx6ul
2018-03-19tools/mkimage: add support for STM32 image formatPatrick Delaunay
STM32MP157 bootrom needs a specific header for first boot stage. This patch adds support of this header in mkimage. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-12-18common: image.c: Fix CACHE: Misaligned operation outputHeiko Schocher
When booting a itb file with a Ramdisk on a imx6 based board, U-Boot drops the warning: Loading Kernel Image ... OK Loading Ramdisk to 4ecf1000, end 4ef8b11f ... \ CACHE: Misaligned operation at range [4ecf1000, 4ef8b11f] Fix it! Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Ayoub Zaki <hs@denx.de>
2017-12-14fpga: allow programming fpga from FIT image for all FPGA driversGoldschmidt Simon
This drops the limit that fpga is only loaded from FIT images for Xilinx. This is done by moving the 'partial' check from 'common/image.c' to 'drivers/fpga/xilinx.c' (the only driver supporting partial images yet) and supplies a weak default implementation in 'drivers/fpga/fpga.c'. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Tested-by: Michal Simek <michal.simek@xilinx.com> (On zcu102) Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-12-07Drop the log bufferSimon Glass
This does not appear to be used by any boards. Before introducing a new log system, remove this old one. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-11-26image: add IH_OS_ARM_TRUSTED_FIRMWARE for ARM Trusted FirmwarePhilipp Tomsich
To boot on ARMv8 systems with ARM Trusted Firmware, we need to assemble an ATF-specific parameter structure and also provide the address of the images started by ATF (e.g. BL3-3, which may be the full U-Boot). To allow us to identify an ARM Trusted Firmware contained in a FIT image, this adds the necessary definitions. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-16common: Remove genimg_get_image()Tuomas Tynkkynen
Removal of the legacy DataFlash code turned genimg_get_image() into a no-op. Drop all calls to it and the function itself. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-10-16Drop CONFIG_HAS_DATAFLASHTuomas Tynkkynen
Last user of this option went away in commit: fdc7718999 ("board: usb_a9263: Update to support DT and DM") Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-09-12image: Add TI PMMC image typeAndrew F. Davis
Add a new image type representing TI Power Management Micro-Controller (PMMC) Firmware image type. Signed-off-by: Andrew F. Davis <afd@ti.com>
2017-08-16env: Rename some other getenv()-related functionsSimon Glass
We are now using an env_ prefix for environment functions. Rename these other functions as well, for consistency: getenv_vlan() getenv_bootm_size() getenv_bootm_low() getenv_bootm_mapsize() env_get_default() Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-20common/image.c: Use correct suffixes for binary sizesxypron.glpk@gmx.de
IEC 80000-13:2008 Quantities and units Part 13: Information science and technology defines the prefixes to use for binary multiples. So instead of writing Data Size: 6726132 Bytes = 6568.49 kB = 6.41 MB in dumpimage we should write Data Size: 6726132 Bytes = 6568.49 KiB = 6.41 MiB. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-01-20bootm: relocate ramdisk if CONFIG_SYS_BOOT_RAMDISK_HIGH setRick Altherr
In 35fc84f, bootm was refactored so plain 'bootm' and 'bootm <subcommand>' shared a common implementation. The 'bootm ramdisk' command implementation is now part of the common implementation but not invoke by plain 'bootm' since the original implementation never did ramdisk relocation. Instead, ramdisk relocation happened in image_setup_linux() which is typically called during the OS portion of 'bootm'. On ARM, parameters to the Linux kernel can either be passed by FDT or ATAGS. When using FDT, image_setup_linux() is called which also triggers ramdisk relocation. When using ATAGS, image_setup_linux() is _not_ called because it mostly does FDT setup. Instead of calling image_setup_linux() in both FDT and ATAGS cases, include BOOTM_STATE_RAMDISK in the requested states during a plain 'bootm' if CONFIG_SYS_BOOT_RAMDISK_HIGH is set and remove the ramdisk relocation from image_setup_linux(). This causes ramdisk relocation to happen on any system where CONFIG_SYS_BOOT_RAMDISK_HIGH regardless of the OS being booted. Also remove IMAGE_ENABLE_RAMDISK_HIGH as it was only used by the now-removed code from image_setup_linux(). Signed-off-by: Rick Altherr <raltherr@google.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joel Stanley <joel@jms.id.au>
2017-01-02tools: mkimage: add firmware-ivt image type for HAB verificationSven Ebenfeld
When we want to use Secure Boot with HAB from SPL over U-Boot.img, we need to append the IVT to the image and leave space for the CSF. Images generated as firmware_ivt can directly be signed using the Freescale code signing tool. For creation of a CSF, mkimage outputs the correct HAB Blocks for the image. The changes to the usual firmware image class are quite small, that is why I implemented that directly into the default_image. Cc: sbabic@denx.de v2-Changes: None Signed-off-by: Sven Ebenfeld <sven.ebenfeld@gmail.com> Reviewed-by: George McCollister <george.mccollister@gmail.com> Tested-by: George McCollister <george.mccollister@gmail.com>
2016-12-20common: Fix logic in fpga programmingMichal Simek
Stop boot process if fpga programming fails. Without this patch boot process continues even if fpga programming failed. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-03image: Add Trusted Execution Environment image typeAndrew F. Davis
Add a new image type representing Trusted Execution Environment (TEE) image types. For example, an OP-TEE OS binary image. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-03image: Add FIT image loadable section custom processingAndrew F. Davis
To help automate the loading of custom image types we add the ability to define custom handlers for the loadable section types. When we find a compatible type while loading a "loadable" image from a FIT image we run its associated handlers to perform any additional steps needed for loading this image. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-11-05image: Protect against overflow in unknown_msg()Simon Glass
Coverity complains that this can overflow. If we later increase the size of one of the strings in the table, it could happen. Adjust the code to protect against this. Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Coverity (CID: 150964)
2016-10-13libfdt: Bring in upstream stringlist functionsSimon Glass
These have now landed upstream. The naming is different and in one case the function signature has changed. Update the code to match. This applies the following upstream commits by Thierry Reding <treding@nvidia.com> : 604e61e fdt: Add functions to retrieve strings 8702bd1 fdt: Add a function to get the index of a string 2218387 fdt: Add a function to count strings Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-06tools: mkimage: add support for Vybrid image formatAlbert ARIBAUD \(3ADEV\)
This format can be flashed directly at address 0 of the NAND FLASH, as it contains all necessary headers. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
