path: root/common/image.c
2010-05-06Move test for unnecessary memmove to memmove_wd()Larry Johnson
Signed-off-by: Larry Johnson <lrj@acm.org>
2010-01-25mkimage: Add Freescale imx Boot Image support (imximage)Stefano Babic
This patch adds support for "imximage" (MX Boot Image) to the mkimage utility. The imximage is used on the Freescales's MX.25, MX.35 and MX.51 processors. Further details under doc/README.imximage. This patch was tested on a Freescale mx51evk board. Signed-off-by: Stefano Babic <sbabic@denx.de>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-12-05add lzop decompression supportPeter Korsgaard
Add lzop decompression support to the existing lzo bitstream handling (think gzip versus zlib), and support it for uImage decompression if CONFIG_LZO is enabled. Lzop doesn't compress as good as gzip (~10% worse), but decompression is very fast (~0.7s faster here on a slow ppc). The lzop decompression code is based on Albin Tonnerre's recent ARM Linux lzo support patch. Cc: albin.tonnerre@free-electrons.com Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
2009-10-03Conditionally perform common relocation fixupsPeter Tyser
Add #ifdefs where necessary to not perform relocation fixups. This allows boards/architectures which support relocation to trim a decent chunk of code. Note that this patch doesn't add #ifdefs to architecture-specific code which does not support relocation. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-10mkimage: Add Kirkwood Boot Image support (kwbimage)Prafulla Wadaskar
This patch adds support for "kwbimage" (Kirkwood Boot Image) image types to the mkimage code. For details refer to docs/README.kwbimage This patch is tested with Sheevaplug board Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Ron Lee <ron@debian.org> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-09-10mkimage: Make table_entry code globalPrafulla Wadaskar
- make get_table_entry_id() global - make get_table_entry_name() global - move struct table_entry to image.h Currently this code is used by image.c only. This patch makes this API global so it can be used by other parts of code, too. Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Ron Lee <ron.debian.org> Edit comments and commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-10mkimage: Make genimg_print_size() globalPrafulla Wadaskar
Currently it is used by image.c only, but the the function can be used to support additional mkimage types like for example kwbimage, so make this function globally visible. Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-10tools/mkimage: fix compiler warnings, use "const"Wolfgang Denk
This fixes some compiler warnings: tools/default_image.c:141: warning: initialization from incompatible pointer type tools/fit_image.c:202: warning: initialization from incompatible pointer type and changes to code to use "const" attributes in a few places where it's appropriate. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-04-04common/image.c: Relocate strings in tables.Scott Wood
Without this, u-boot can crash or print garbage if the original link address no longer points to a valid string. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-12-13Fix FIT and FDT support to have CONFIG_OF_LIBFDT and CONFIG_FIT independentJean-Christophe PLAGNIOL-VILLARD
FDT support is used for both FIT style images and for architectures that can pass a fdt blob to an OS (ppc, m68k, sparc). For other architectures and boards which do not pass a fdt blob to an OS but want to use the new uImage format, we just need FIT support. Now we can have the 4 following configurations : 1) FIT only CONFIG_FIT 2) fdt blob only CONFIG_OF_LIBFDT 3) both CONFIG_OF_LIBFDT & CONFIG_FIT 4) none none Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-10-18FIT: output image load address for type 'firmware', fix message while thereBartlomiej Sieka
Now that the auto-update feature uses the 'firmware' type for updates, it is useful to inspect the load address of such images. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-09-13Add support for LZMA uncompression algorithm.Luigi 'Comio' Mantellini
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-09Fix printf errors under -DDEBUGAndrew Klossner
Fix printf format-string/arg mismatches under -DDEBUG. These warnings occur with DEBUG defined for a platform using cpu/mpc85xx. Users of other architectures can unearth similar problems by adding the line "CFLAGS += -DDEBUG=1" in config.mk right after "CFLAGS += $(call cc-option,-fno-stack-protector)". Signed-off-by: Andrew Klossner <andrew@cesa.opbu.xerox.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-09-09FIT: add ability to check hashes of all images in FIT, improve outputBartlomiej Sieka
- add function fit_all_image_check_hashes() that verifies if all hashes of all images in the FIT are valid - improve output of fit_image_check_hashes() when the hash check fails Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-09-09Add support for booting of INTEGRITY operating system uImagesPeter Tyser
2008-09-09Remove support for booting ARTOS imagesKumar Gala
Pantelis Antoniou stated: AFAIK, it is still used but the products using PPC are long gone. Nuke it plz (from orbit). So remove it since it cleans up a usage of env_get_char outside of the environment code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-07Prevent crash if random/invalid ramdisks are passed to bootmKumar Gala
Adds returning an error from the ramdisk detection code if its not a real ramdisk (invalid). There is no reason we can't just return back to the console if we detect an invalid ramdisk or CRC error. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-07Prevent crash if random DTB address is passed to bootmAnatolij Gustschin
This patch adds bootm_start() return value check. If error status is returned, we do not proceed further to prevent board reset or crash as we still can recover at this point. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-08-26bootm: Set working fdt address as part of the bootm flowKumar Gala
Set the fdt working address so "fdt FOO" commands can be used as part of the bootm flow. Also set an the environment variable "fdtaddr" with the value. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-26bootm: refactor fdt locating and relocation codeKumar Gala
Move the code that handles finding a device tree blob and relocating it (if needed) into common code so all arch's have access to it. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-12Fix fallout from autostart revertKumar Gala
The autostart revert caused a bit of duplicated code as well as code that was using images->autostart that needs to get removed so we can build again. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-10Revert "[new uImage] Add autostart flag to bootm_headers structure"Wolfgang Denk
This reverts commit f5614e7926863bf0225ec860d9b319741a9c4004. The commit was based on a misunderstanding of the (documented) meaning of the 'autostart' environment variable. It might cause boards to hang if 'autostart' was used, with the potential to brick them. Go back to the documented behaviour. Conflicts: common/cmd_bootm.c common/image.c include/image.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-08-09FIT: Fix handling of images without ramdisksPeter Tyser
boot_get_ramdisk() should not treat the case when a FIT image does not contain a ramdisk as an error. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Michal Simek <monstr@monstr.eu>
2008-07-13FIS: repare incorrect return value with ramdisk handlingMichal Simek
Microblaze and PowerPC use boot_get_ramdisk for loading ramdisk to memory with checking return value. Return 0 means success. Return 1 means failed. Here is correspond part of code from bootm.c which check return code. ret = boot_get_ramdisk (argc, argv, images, IH_ARCH_PPC, &rd_data_start, &rd_data_end); if (ret) goto error; Signed-off-by: Michal Simek <monstr@monstr.eu>
2008-06-12Change lmb to use phys_size_t/phys_addr_tBecky Bruce
This updates the lmb code to use phys_size_t and phys_addr_t instead of unsigned long. Other code which interacts with this code, like getenv_bootm_size() is also updated. Booted on MPC8641HPCN, build-tested ppc, arm, mips. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-06-03Avoid initrd and logbuffer area overlapsMarian Balakowicz
Add logbuffer to reserved LMB areas to prevent initrd allocation from overlaping with it. Make sure to use correct logbuffer base address. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-05-12Revert "Avoid initrd and logbuffer area overlaps"Wolfgang Denk
This reverts commit 1b5605ca57fbb364f4d78eeee28b974ed875e888 which breaks building on all PPC boards that don't use a log buffer.
2008-05-12Fix offset calculation for multi-type legacy images.Nick Spence
Calculation of tail was incorrect when size % 4 == 0. New code removes the conditional and does the same thing but with arithmetic Signed-off-by: Nick Spence <nick.spence@freescale.com>
2008-05-10Avoid initrd and logbuffer area overlapsMarian Balakowicz
2008-05-10Fix build errors when CONFIG_LOGBUFFER and CONFIG_FIT are enabledMarian Balakowicz
Recent modifcations to LOGBUFFER handling code were incorrecly introduced to fit_check_kernel() routine during "Merge branch 'new-image' of git://www.denx.de/git/u-boot-testing", commit 27f33e9f45ef7f9685cbdc65066a1828e85dde4f. This patch cleans up this merge issue. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-05-09Recognize 'powerpc' As an Alias for IH_ARCH_PPCGrant Erickson
Add support for the recognition of 'powerpc' as an alias for the PowerPC architecture type since Linux is already trending in that direction, preferring 'powerpc' to 'ppc'. Signed-off-by: Grant Erickson <gerickson@nuovations.com>
2008-04-25Use watchdog-aware functions when calculating hashes of images - take twoBartlomiej Sieka
Some files didn't get updated properly with the "Use watchdog-aware functions when calculating hashes of images" commit, this commit fixes this. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-24Memory footprint optimizationsBartlomiej Sieka
As suggested by Wolfgang Denk: - image printing functions: - remove wrappers - remove indentation prefix from functions' signatures - merge getenv_verify and getenv_autostart into one parametrized function Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-04-24crc32: use uint32_t rather than unsigned longMike Frysinger
The envcrc.c does sizeof(unsigned long) when calculating the crc, but this is done with the build toolchain instead of the target tool chain, so if the build is a 64bit system but the target is 32bits, the size will obviously be wrong. This converts all unsigned long stuff related to crc32 to uint32_t types. Compile tested only: output of ./tools/envcrc when run on a 32bit build system matches that of a 64bit build system. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-04-17Restore the ability to continue booting after legacy image overwriteMarian Balakowicz
Before new uImage code was merged, bootm code allowed for the kernel image to get overwritten during decompresion. new uImage introduced a check for image overwrites and refused to boot the image that got overwritten. This patch restores the old behavior. It also adds a warning when the image overwriten is a multi-image file, because in such case accessing componentes other than the first one will fail. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-04-13Rename include/md5.h to include/u-boot/md5.hAndy Fleming
Some systems have md5.h installed in /usr/include/. This isn't the desired file (we want the one in include/md5.h). This will avoid the conflict. This fixes the host tools building problem by creating a new directory for U-Boot specific header files. [Patch by Andy Fleming, modified to use separate directory by Wolfgang Denk] Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Timur Tabi <timur@freescale.com>
2008-04-08SPARC: added SPARC support for new uimage in common code.Daniel Hellstrom
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-03-20[new uImage] Disable debuging output in preparation for merge with masterBartlomiej Sieka
2008-03-14Add MD5 support to the new uImage formatBartlomiej Sieka
2008-03-12[new uImage] Fix build issue on ARMMarian Balakowicz
ARM platforms don't have a bd->bi_memsize so use bd->bi_dram[0].size instead. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-12[new uImage] Add proper ramdisk/FDT handling when FIT configuration is usedMarian Balakowicz
Save FIT configuration provied in the first bootm argument and use it when to get ramdisk/FDT subimages when second and third (ramdisk/FDT) arguments are not specified. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-03-12[new uImage] Use show_boot_progress() for new uImage formatMarian Balakowicz
This patch allocates a set of show_boot_progress() IDs for new uImage format and adds show_boot_progress() calls in new uImage format handling code. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-03-12[new uImage] Add node offsets for FIT images listed in struct bootm_headersMarian Balakowicz
This patch adds new node offset fields to struct bootm_headers and updates bootm_headers processing code to make use of them. Saved node offsets allow to avoid repeating fit_image_get_node() calls. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-03-12[new uImage] Remove unnecessary arguments passed to ramdisk routinesMarian Balakowicz
boot_get_ramdisk() and image_get_ramdisk() do not need all cmdtp, flag, argc and argv arguments. Simplify routines definition. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-03-12[new uImage] Add new uImage format support for ramdisk handlingMarian Balakowicz
This patch updates boot_get_ramdisk() routine adding format verification and handling for new (FIT) uImages. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-03-10[new uImage] New uImage low-level APIMarian Balakowicz
Add FDT-based functions for handling new format component images, configurations, node operations, property get/set, etc. fit_ - routines handling global new format uImage operations like get/set top level property, process all nodes, etc. fit_image_ - routines handling component images subnodes fit_conf_ - routines handling configurations node Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Fix component handling for legacy multi component imagesMarian Balakowicz
Use uint32_t when accessing size table in image_multi_count() and image_multi_getimg() for multi component images. Add missing uimage_to_cpu() endianness conversion. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Share common uImage code between mkimage and U-bootMarian Balakowicz
This patch adds the following common routines: 1) Dedicated mkimage print_header() is replaced with common image_print_contents() image_print_contents_noindent() 2) Common os/arch/type/comp fields name <--> id translation routines genimg_get_os_name() genimg_get_arch_name() genimg_get_type_name() genimg_get_comp_name() genimg_get_os_id() genimg_get_arch_id() genimg_get_type_id() genimg_get_comp_id() Signed-off-by: Marian Balakowicz <m8@semihalf.com>
