The signature for this macro has changed. Bring in the upstream version and
adjust U-Boot's usages to suit.
Update to drivers/power/pmic/palmas.c:
Signed-off-by: Keerthy <j-keerthy@ti.com>
Change-Id: I6cc9021339bfe686f9df21d61a1095ca2b3776e8
These have now landed upstream. The naming is different and in one case the
function signature has changed. Update the code to match.
This applies the following upstream commits by
Thierry Reding <treding@nvidia.com> :
604e61e fdt: Add functions to retrieve strings
8702bd1 fdt: Add a function to get the index of a string
2218387 fdt: Add a function to count strings
Commit bac17b78dace ("image-fit: switch ENOLINK to ENOENT") changed
fit_get_node_from_config to return -ENOENT when a property doesn't
exist, but didn't change any of its callers which check return values.
Notably it didn't change boot_get_ramdisk, which leads to U-Boot failing
to boot FIT images which don't include ramdisks with the following
message:
Ramdisk image is corrupt or invalid
It also didn't take into account that by returning -ENOENT to denote the
lack of a property we lost the ability to determine from the return
value of fit_get_node_from_config whether it was the property or the
configuration node that was missing, which may potentially lead callers
to accept invalid FIT images.
Fix this by having fit_get_node_from_config return -EINVAL when the
configuration node isn't found and -ENOENT when the property isn't
found, which seems to make semantic sense. Callers that previously
checked for -ENOLINK are adjusted to check for -ENOENT, which fixes the
breakage introduced by commit bac17b78dace ("image-fit: switch ENOLINK
to ENOENT").
The only other user of the return fit_get_node_from_config return value,
indirectly, is bootm_find_os which already checked for -ENOENT. From a
read-through of the code I suspect it ought to have been checking for
-ENOLINK prior to bac17b78dace ("image-fit: switch ENOLINK to ENOENT")
anyway, which would make it right after this patch, but this would be
good to get verified by someone who knows this x86 code or is able to
test it.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Cc: Jonathan Gray <jsg@jsg.id.au>
Acked-by: George McCollister <george.mccollister@gmail.com>
Tested-by: George McCollister <george.mccollister@gmail.com>
ENOLINK is not required by POSIX and does not exist on OpenBSD
and likely other systems.
Signed-off-by: Jonathan Gray <jsg@jsg.id.au>
Commit 62afc601883e788f3f22291202d5b2a23c1a8b06 introduced fpga image load via
bootm but broke the OS check in fit_image_load().
This commit removes following compiler warning:
---8<---
In file included from tools/common/image-fit.c:1:
/Volumes/devel/u-boot/tools/../common/image-fit.c:1715:39: warning: use of logical '||' with constant operand [-Wconstant-logical-operand]
os_ok = image_type == IH_TYPE_FLATDT || IH_TYPE_FPGA ||
/Volumes/devel/u-boot/tools/../common/image-fit.c:1715:39: note: use '|' for a bitwise operation
1 warning generated.
--->8---
Signed-off-by: Andreas Bießmann <andreas@biessmann.org>
Cc: Michal Simek <michal.simek@xilinx.com>
Acked-by: Michal Simek <michal.simek@xilinx.com>
This commit allows injecting a board/platform/device-specific post-
processing function into the FIT image data loading process, which can
include modifying the size and altering the starting source address of
an image data artifact. This might be desired to do things like strip
headers or footers attached to the images before they were packaged into
the FIT, or to perform operations such as decryption or authentication.
Introduce new configuration option CONFIG_FIT_IMAGE_POST_PROCESS to
allow controlling this feature. If enabled, a platform-specific post-
process function must be provided.
Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
In certain circumstances it comes in handy to be able to boot into a second
U-Boot. But as of now it is not possible to boot a U-Boot binary that is inside
a FIT image, which is problematic for projects that e.g. need to guarantee a
unbroken chain of trust from SOC all the way into the OS, since the FIT signing
mechanism cannot be used.
This patch adds the capability to load such FIT images.
An example .its snippet (utilizing signature verification) might look
like the following:
images {
firmware@1 {
description = "2nd stage U-Boot image";
data = /incbin/("u-boot-dtb.img.gz");
type = "firmware";
arch = "arm";
os = "u-boot";
compression = "gzip";
load = <0x8FFFC0>;
entry = <0x900000>;
signature@1 {
algo = "sha256,rsa4096";
key-name-hint = "key";
Signed-off-by: Mario Six <mario.six@gdsys.cc>
The comments in the source file are riddled with spelling mistakes. Be
a good citizen and take a stab at cleaning up some of the more obvious
ones.
Add function boot_get_fpga() which find and load bitstream to
programmable logic if fpga entry is present.
Function is supported on Xilinx devices for full and partial bitstreams
in BIN and BIT format.
Remove additional blankline in image.h
Add FIT_FPGA_PROP that user can identify an optional
entry for fpga.
This function returns an error code and its caller may be able to fix the
error. For example fit_handle_file() expands the device tree to fit if there
is a lack of space.
In this case the caller does not want an error displayed. It is confusing,
since it suggests that something is wrong, when it fact everything is fine.
Drop the error.
FIT image supports more than 32 bits in addresses by using #address-cell
field. Fixing 64-bit support by using this field.
Signed-off-by: York Sun <york.sun@nxp.com>
FIT image supports load address and entry address. Getting these
addresses can use a common function.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
This reverts commit 84ca65aa4bd0d03867e9e49805201d0564d3ffb0.
On signature verification failures fit_image_verify() should NOT exit with
error. Only keys marked 'required' can cause image verification failure.
This logic is already there and works correctly.
Add a comment to make this clear.
Fixes: 84ca65aa (image-fit: Fix signature checking)
A recent change broke the 'bootm' command on sandbox. The root cause is
using a pointer as an address. Conversion from pointer to address needs to
use map_to_sysmem() so that sandbox can do the right thing. The problem was
pre-existing but uncovered by a recent commit.
Fix this. Also move fit_get_end() to the C file to avoid needing to include
mapmem.h (and thus asm/io.h) everywhere.
Fixes: 1fec3c5d (common/image.c: Make boot_get_ramdisk() perform a check for Android images)
exit with error.
Signed-off-by: Andrej Rosano <andrej@inversepath.com>
This fixes the following compiler warning:
In file included from tools/common/image-fit.c:1:0:
./tools/../common/image-fit.c: In function ‘fit_conf_print’:
./tools/../common/image-fit.c:1470:27: warning: logical not is only applied
to the left hand side of comparison [-Wlogical-not-parentheses]
(const char **)&uname) > 0;
Added a trimmed down instance of boot_get_<thing>() to satisfy the
minimum requierments of the added feature. The function follows the
normal patterns set by other boot_get<thing>'s, which should make it a
bit easier to combine them all together into one boot_get_image()
function in a later refactor.
Documentation for the new function can be found in source:
include/image.h
Signed-off-by: Karl Apsite <Karl.Apsite@dornerworks.com>
Added FIT_LOADABLE_PROP, so the user can identify an optional entry
named "loadables" in their .its configuration. "loadables" is a comma
separated list in the .its
Documentation can be found in doc/uImage.FIT/source_file_format.txt and
doc/uImage.Fit/multi-with-loadables.its
In the case where the arch defines a custom map_sysmem(), make sure that
including just mapmem.h is sufficient to have these functions as they
are when the arch does not override it.
Also split the non-arch specific functions out of common.h
Use fdt_for_each_subnode macro to simplify the code a bit.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
The dumpimage is able to extract components contained in a FIT image:
$ ./dumpimage -T flat_dt -i CONTAINER.ITB -p INDEX FILE
The CONTAINER.ITB is a regular FIT container file. The INDEX is the poisition
of the sub-image to be retrieved, and FILE is the file (path+name) to save the
extracted sub-image.
For example, given the following kernel.its to build a kernel.itb:
/dts-v1/;
images {
kernel@1 {
description = "Kernel 2.6.32-34";
data = /incbin/("/boot/vmlinuz-2.6.32-34-generic");
type = "kernel";
arch = "ppc";
os = "linux";
load = <00000000>;
entry = <00000000>;
hash@1 {
algo = "md5";
The dumpimage can extract the 'kernel@1' node through the following command:
$ ./dumpimage -T flat_dt -i kernel.itb -p 0 kernel
Extracted:
Image 0 (kernel@1)
Description: Kernel 2.6.32-34
Created: Wed Oct 22 15:50:26 2014
Type: Kernel Image
Compression: gzip compressed
Data Size: 4040128 Bytes = 3945.44 kB = 3.85 MB
Architecture: PowerPC
OS: Linux
Load Address: 0x00000000
Entry Point: 0x00000000
Hash algo: md5
Hash value: 22352ad39bdc03e2e50f9cc28c1c3652
Which results in the file 'kernel' being exactly the same as '/boot/vmlinuz-2.6.32-34-generic'.
Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
Allow booting the OpenRTOS payloads via fitImage image type.
Cc: Tom Rini <trini@ti.com>
This is a bit odd in that we are permitted to boot images for either, even
though they are separate architectures.
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
Add a new setup@ section to the FIT which can be used to provide a setup
binary for booting Linux on x86. This makes it possible to boot x86 from
a FIT.
Since sandbox is used for testing, it should be able to 'boot' an image
from any archhitecture. This allows us to test an image by loading it in
sandbox.
Commit e3a5bbce broke the FIT image tests by not loading a ramdisk even if
a load address is provided in the FIT. The rationale was that a load address
of 0 should be considered to mean 'do not load'.
Add a new load operation which supports this feature, so that the ramdisk
will be loaded if a non-zero load address is provided.
commit 18b06652cd "tools: include u-boot version of sha256.h"
unconditionally forced the sha256.h from u-boot to be used
for tools instead of the host version. This is fragile though
as it will also include the host version. Therefore move it
to include/u-boot to join u-boot/md5.h etc which were renamed
for the same reason.
cc: Simon Glass <sjg@chromium.org>
At present this tool only checks the configuration signing. Have it also
look at each of the images in the configuration and confirm that they
verify.
Acked-by: Heiko Schocher <hs@denx.de> (v1)
This typo makes the comment confusing. Fix it.
This can be obtained by looking up the image type, so is redundant. It is
better to centralise this lookup to avoid errors.
It is more common to have 0 mean OK, and -ve mean error. Change this
function to work the same way to avoid confusion.
When writing values into an FDT it is possible that there will be
insufficient space. If the caller gets a useful error then it can
potentially deal with the situation.
Adjust these functions to return -ENOSPC when the FDT is full.
add sha256 support to fit images
There is a strange comment in fit_image_load().
This function can be used for loading Kernel Image, FDT
as well as ramdisk.
Becuase fdt_check_header function takes (const void *)
type argument, the argument should be passed to it
without being casted to (char *).
Typoes fixed:
"partion" -> "partition"
"retrive", "retreive" -> "retrieve"
"th" -> "to"
The timestamp is shown in fit_print_contents() but for some reason not
in fit_image_print(). This seems to be an oversight, since it is the latter
which is used by bootm.
Add timestamp printing in this case.
(There is code duplication in these two function, for looking at in a future
patch).
[trini: Fixup common/cmd_io.c]
If a specific configuraion is selected by the bootm command, e.g. with
'bootm 84000000#recoveryconf' we must honour this for not just the kernel,
but also the ramdisk and FDT.
In the conversion to using a common fit_image_load() function for loading
images from FITs (commits a51ec63 and 53f375f) this feature was lost.
Reinstate it by passing the selected configuration back from
fit_image_load() to boot_get_kernel(), then use this configuration
(which is stored in images->fit_uname_cfg) in both boot_get_ramdisk()
and boot_get_fdt().
Add support for signing images using a new signature node. The process
is handled by fdt_add_verification_data() which now takes parameters to
provide the keys and related information.
This error may not be defined on some platforms such as MacOS so host
compilation will fail. Use one of the more common errors instead.
Tested-by: Andreas Bießmann <andreas.devel@googlemail.com>
Tested-by: Lubomir Popov <lpopov@mm-sol.com>
Use map_sysmem() to convert from address to pointer, so that sandbox can
print FIT information without crashing.
Use the new common code to load a kernel. The functionality should not
change.
Use the new common code to load a flat device tree. Also fix up a few casts
so that this code works with sandbox. Other than that the functionality
should not change.
Use the new common code to load a ramdisk. The functionality should not
change.
At present code to load an image from a FIT is duplicated in the three
places where it is needed (kernel, fdt, ramdisk).
The differences between these different code copies is fairly minor.
Create a new function in the fit code which can handle any of the
requirements of those cases.
