path: root/common/image-fdt.c
2015-08-13image-fdt.c: store returned error valueMax Krummenacher
This fixes the following warning (and the runtime error reporting): ../common/image-fdt.c:491:4: warning: 'fdt_ret' may be used uninitialized in this function [-Wmaybe-uninitialized] Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-05fdt: Pass the device serial number through devicetreePaul Kocialkowski
Before device-tree, the device serial number used to be passed to the kernel using ATAGs (on ARM). This is now deprecated and all the handover to the kernel should now be done using device-tree. Thus, this passes the serial-number property to the kernel using the serial-number property of the root node, as expected by the kernel. The serial number is a string that somewhat represents the device's serial number. It might come from some form of storage (e.g. an eeprom) and be programmed at factory-time by the manufacturer or come from identification bits available in e.g. the SoC. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Simon Glass <sgj@chromium.org>
2015-04-18common: Make sure arch-specific map_sysmem() is definedJoe Hershberger
In the case where the arch defines a custom map_sysmem(), make sure that including just mapmem.h is sufficient to have these functions as they are when the arch does not override it. Also split the non-arch specific functions out of common.h Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-17cmd_fdt: Actually fix fdt command in sandboxJoe Hershberger
Commit 90bac29a76bc8d649b41a55f2786c0abef9bb2c1 claims to fix this bug that was introduced in commit a92fd6577ea17751ead9b50243e3c562125cf581 but doesn't actually make the change that the commit message describes. Actually fix the bug this time. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-08fdt: Allow non-FDT kernels to boot when CONFIG_OF_LIBFDT is definedSuriyan Ramasami
The boot commands - bootz/bootm mandate a third argument which is the address to the FDT blob. In cases where this argument is not specified, boot fails with a message indicating a missing FDT. This causes non-FDT kernels to fail to boot. This patch allows both FDT and non-FDT kernels to boot by making the third parameter to the bootm/bootz optional. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Update again for covering appended DTB case after last revert in this area] Signed-off-by: Tom Rini <trini@ti.com>
2014-12-03Revert "image-fdt: boot_get_fdt() return value when no DTB exists"Tom Rini
It has been found that this change breaks the case of an appended device tree file, so for the problem in question some other solution must be found. This reverts commit c6150aaf2f2745141a7c2ceded58d7efbfeace7d. Reported-by: Bill Pringlemeir <bpringlemeir@nbsps.com> Reported-by: Pantelis Antoniou <panto@antoniou-consulting.com> Confirmed-by: Bill Pringlemeir <bpringlemeir@nbsps.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-11-21fdt: Add ft_system_setup() function for system device tree additionsSimon Glass
Add an additional function for adding information to the device tree before booting. This permits additions which are not board-specific. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-21fdt: Tidy up error handling in image_setup_libfdt()Simon Glass
The message about needing to reset should be printed no matter what error is printed. Also, an error should always be printed. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-07image-fdt: boot_get_fdt() return value when no DTB existsNoam Camus
I believe that when no DTB is around we should return 1. This why I fixed such scenarious to not return zero anymore. Else kernel might get NULL pointer to DTB which doesn't exists. Signed-off-by: Noam Camus <noamc@ezchip.com>
2014-08-09fdt: Rename fdt_resize() to fdt_shrink_to_minimum()Simon Glass
Since libfdt now has an fdt_resize() function, we need to rename the U-Boot one. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-28ARM: convert arch_fixup_memory_node to a generic FDT fixup functionMa Haijun
Some architecture needs extra device tree setup. Instead of adding yet another hook, convert arch_fixup_memory_node to be a generic FDT fixup function. [maz: collapsed 3 patches into one, rewrote commit message] Signed-off-by: Ma Haijun <mahaijuns@gmail.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-25keystone2: use CONFIG_SOC_KEYSTONE in common placesKhoronzhuk, Ivan
Use CONFIG_SOC_KEYSTONE in common places instead of defining a lot of "if def .. || if def " for different Keystone2 SoC types. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-06-19image: Remove the fit_load_image() property parameterSimon Glass
This can be obtained by looking up the image type, so is redundant. It is better to centralise this lookup to avoid errors. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-19fdt_support: delete force argument of fdt_chosen()Masahiro Yamada
After all, we have realized "force" argument is completely useless. fdt_chosen() was always called with force = 1. We should always want to do the same thing (set appropriate value to the property) even if the property already exists. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-19fdt_support: delete force argument of fdt_initrd()Masahiro Yamada
After all, we have realized "force" argument is completely useless. fdt_initrd() was always called with force = 1. We should always want to do the same thing (set appropriate value to the property) even if the property already exists. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-05bootm: make use of legacy image format configurableHeiko Schocher
make the use of legacy image format configurable through the config define CONFIG_IMAGE_FORMAT_LEGACY. When relying on signed FIT images with required signature check the legacy image format should be disabled. Therefore introduce this new define and enable legacy image format if CONFIG_FIT_SIGNATURE is not set. If CONFIG_FIT_SIGNATURE is set disable per default the legacy image format. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Lars Steubesand <lars.steubesand@philips.com> Cc: Mike Pearce <mike@kaew.be> Cc: Wolfgang Denk <wd@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Michal Simek <monstr@monstr.eu> Acked-by: Simon Glass <sjg@chromium.org>
2014-04-17fdt: call ft_board_setup_ex() at the end of image_setup_libfdt()Vitaly Andrianov
The keystone2 SOC requires to fix all 32 bit aliased addresses to their 36 physical format. This has to happen after all fdt nodes are added or modified. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Acked-by: Tom Rini <trini@ti.com>
2014-02-19fdt: rename IMAAGE_OF_BOARD_SETUP to IMAGE_OF_BOARD_SETUPMasahiro Yamada
2013-09-20FIT: delete unnecessary castsMasahiro Yamada
Becuase fdt_check_header function takes (const void *) type argument, the argument should be passed to it without being casted to (char *). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-07-12bootm: Use selected configuration for ramdisk and fdtSimon Glass
If a specific configuraion is selected by the bootm command, e.g. with 'bootm 84000000#recoveryconf' we must honour this for not just the kernel, but also the ramdisk and FDT. In the conversion to using a common fit_image_load() function for loading images from FITs (commits a51ec63 and 53f375f) this feature was lost. Reinstate it by passing the selected configuration back from fit_image_load() to boot_get_kernel(), then use this configuration (which is stored in images->fit_uname_cfg) in both boot_get_ramdisk() and boot_get_fdt(). Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26Clarify bootm OS argumentsSimon Glass
At present the arguments to bootm are processed in a somewhat confusing way. Sub-functions must know how many arguments their calling functions have processed, and the OS boot function must also have this information. Also it isn't obvious that 'bootm' and 'bootm start' provide arguments in the same way. Adjust the code so that arguments are removed from the list before calling a sub-function. This means that all functions can know that argv[0] is the first argument of which they need to take notice. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-04image: Use fit_image_load() to load FDTSimon Glass
Use the new common code to load a flat device tree. Also fix up a few casts so that this code works with sandbox. Other than that the functionality should not change. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-14image: Add device tree setup to image librarySimon Glass
This seems to be a common function for several architectures, so create a common function rather than duplicating the code in each arch. Also make an attempt to avoid introducing #ifdefs in the new code, partly by removing useless #ifdefs around function declarations in the image.h header. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-14image: Split libfdt code into image-fdt.cSimon Glass
The image file is still very large, and some of the code is only used when libfdt is in use. Move this code into a new file. Signed-off-by: Simon Glass <sjg@chromium.org>
