path: root/common/image-android.c
2016-06-24common: image: minimal android image iminfo supportMichael Trimarchi
We already support iminfo for other images. The idea of this patch is start to have a minimal support for android image format. We still need to print id[] array Signed-off-by: Michael Trimarchi <michael@amarulasolutions.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-11image: fix support for Android boot images with no ramdiskRob Herring
If an Android boot image does not contain a ramdisk, make sure rd_len and rd_data are returned to indicate no ramdisk rather than just relying on returning an error. Signed-off-by: Rob Herring <robh@kernel.org>
2015-05-08image: android: handle default kernel addressMaxime Ripard
The two tools that create android boot images, mkbootimg and the fastboot client, set the kernel address by default to 0x10008000. U-boot always honors this field, and will try to relocate the kernel to whatever value is set in the header, which won't be mapped to the actual RAM on most platforms, resulting in the kernel obviously not booting. All the targets in U-Boot right now will download the android boot image to CONFIG_SYS_LOAD_ADDR, which means that it will already have been downloaded to some location that is suitable for execution. In order to have the kernel booting even with the default boot image kernel address, if that address is used, just execute the kernel where it is. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2014-10-27image: Fix Android boot image supportAhmad Draidi
This patch makes the following changes: - Set kernel entry point correctly - Append bootargs from image to global bootargs instead of replacing them - Return end address instead of size from android_image_get_end() - Give correct parameter to genimg_get_format() in boot_get_ramdisk() - Move ramdisk message printing from android_image_get_kernel() to android_image_get_ramdisk() Signed-off-by: Ahmad Draidi <ar2000jp@gmail.com> Cc: Tom Rini <trini@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-05-08image: add support for Android's boot image formatSebastian Siewior
This patch adds support for the Android boot-image format. The header file is from the Android project and got slightly alterted so the struct + its defines are not generic but have something like a namespace. The header file is from bootloader/legacy/include/boot/bootimg.h. The header parsing has been written from scratch and I looked at bootloader/legacy/usbloader/usbloader.c for some details. The image contains the physical address (load address) of the kernel and ramdisk. This address is considered only for the kernel image. The "second image" defined in the image header is currently not supported. I haven't found anything that is creating this. v3 (Rob Herring): This is based on http://patchwork.ozlabs.org/patch/126797/ with the following changes: - Rebased to current mainline - Moved android image handling to separate functions in common/image-android.c - s/u8/char/ in header to fix string function warnings - Use SPDX identifiers for licenses - Cleaned-up file source information: android_image.h is from file include/boot/bootimg.h in repository: https://android.googlesource.com/platform/bootable/bootloader/legacy The git commit hash is 4205b865141ff2e255fe1d3bd16de18e217ef06a usbloader.c would be from the same commit, but it does not appear to have been used for any actual code. v4: - s/andriod/android/ - Use a separate flag ep_found to track if the entry point has been set rather than using a magic value. Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Rob Herring <robh@kernel.org> Reviewed-by: Tom Rini <trini@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
