path: root/common/image-android-dt.c
2019-08-07common: image-android-dt: Fix logic in print fdt info routineSam Protsenko
Do not attempt to print fdt info if root node wasn't found. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2019-03-22common: image-android-dt: Fix out-of-bounds accessEugeniu Rosca
Currently, 'dtimg' allows users to check indexes equal to dt_entry_count [1]. Forbid that [2]. [1] Behavior w/o the patch: => ext2load mmc 0:1 0x48000000 dtb.img 105695 bytes read in 5 ms (20.2 MiB/s) => dtimg dump 0x48000000 dt_table_header: magic = d7b7ab1e total_size = 105695 header_size = 32 dt_entry_size = 32 dt_entry_count = 2 dt_entries_offset = 32 page_size = 4096 version = 0 dt_table_entry[0]: dt_size = 105599 dt_offset = 96 id = 0b779520 rev = 00000000 custom[0] = 00000000 custom[1] = 00000000 custom[2] = 00000000 custom[3] = 00000000 (FDT)size = 105599 (FDT)compatible = shimafuji,kingfisher dt_table_entry[1]: dt_size = 105599 dt_offset = 96 id = 0b779530 rev = 00000000 custom[0] = 00000000 custom[1] = 00000000 custom[2] = 00000000 custom[3] = 00000000 (FDT)size = 105599 (FDT)compatible = shimafuji,kingfisher => dtimg size 0x48000000 0 z; print z z=19c7f => dtimg size 0x48000000 1 z; print z z=19c7f => dtimg size 0x48000000 2 z; print z z=d00dfeed => dtimg size 0x48000000 3 z Error: index > dt_entry_count (3 > 2) [2] Behavior with the patch: => dtimg size 0x48000000 0 z; print z z=19c7f => dtimg size 0x48000000 1 z; print z z=19c7f => dtimg size 0x48000000 2 z Error: index >= dt_entry_count (2 >= 2) Fixes: c04473345712 ("common: Add support for Android DT image") Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com>
2018-08-20common: Add support for Android DT imageSam Protsenko
Android documentation recommends new image format for storing DTB/DTBO files: [1]. To support that format, this patch adds helper functions for Android DTB/DTBO format. In image-android-dt.* files you can find helper functions to work with Android DT image format, such us routines for: - printing the dump of image structure - getting the address and size of desired dtb/dtbo file This patch uses dt_table.h file, that was added in commit 643cefa4d848 ("Import Android's dt_table.h for DT image format") by Alex Deymo. [1] https://source.android.com/devices/architecture/dto/partitions Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com>
