Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
Move this header out of the common header.
Move env_set() over to the new header file.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
We are now using an env_ prefix for environment functions. Rename these
two functions for consistency. Also add function comments in common.h.
Quite a few places use getenv() in a condition context, provoking a
warning from checkpatch. These are fixed up in this patch also.
Suggested-by: Wolfgang Denk <wd@denx.de>
We are now using an env_ prefix for environment functions. Rename setenv()
[trini: Fixup common/cmd_io.c]
There are several users of the hwconfig APIs (8xxx DDR) before we have
the environment properly setup. This causes issues because of the
numerous ways the environment might be accessed because of the
non-volatile memory it might be stored in. Additionally the access
might be so early that memory isn't even properly setup for us.
Towards resolving these issues we provide versions of all the hwconfig
APIs that can be passed in a buffer to parse and leave it to the caller
to determine how to allocate and populate the buffer.
We use the _f naming convention for these new APIs even though they are
perfectly useable after relocation and the environment being ready.
We also now warn if the non-f APIs are called before the environment is
ready to allow users to address the issues.
Finally, we convert the 8xxx DDR code to utilize the new APIs to
hopefully address the issue once and for all. We have the 8xxx DDR code
create a buffer on the stack and populate it via getenv_f().
Acked-by: Wolfgang Denk <wd@denx.de>
The handling of env_hwconfig, board_hwconfig, and cpu_hwconfig got
broken when we removed the boards defining dummy board_hwconfig
& cpu_hwconfig values.
We fix this by handling the various strings in priority order. If
hwconfig_parse returns NULL for a given string we check the next one
in order (env_hwconfig, board_hwconfig, followed by cpu_hwconfig).
Since board_hwconfig & cpu_hwconfig are defined as weak and dont have a
default value they will get put into the BSS if they aren't defined
elsewhere. This is problematic as we try to utilize hwconfig before
we've relocated and thus BSS isn't setup.
Instead of giving dummy values in the board files that utilize this
feature, we can just initialize the variables to an empty string and
thus move them out of the BSS if they aren't defined elsewhere.
Also made board_hwconfig & cpu_hwconfig arrays to reduce size associated
with string pointers vs arrays.
Since we use hwconfig in cases before relocation (like getting DDR
params on FSL PPC systems), we can have strings that exceed the early
small (32 byte) buffer size that getenv will handle.
So we explicitly allocate our own buffer on the stack and use if to
handle getting the hwconfig env string. We currently utilize a string
length of 128 bytes.
This allows us to get rid of boot messages like:
env_buf too small [32]
I use this for testing, and I think this might be useful in the
future.
Signed-off-by: Anton Vorontsov <avorontsov@mvista.com>
For the following hwconfig string:
key1:subkey1=value1,subkey2=value2;key2:value3
The subkey2 cannot be extracted correctly. The parsing code looks
for comma as a stopch, but there may be two kind of stop characters:
a comma and a semicolon.
Currently the code would return "value2;key2:value3", while just
"value2" is the correct answer.
This patch fixes the issue by making the code aware of multiple
stop characters.
For old U-Boots, the issue can be workarounded by placing a comma
before a semicolon, i.e.:
hwconfig=key1:subkey1=value1,subkey2=value2,;key2:value3
Reported-by: York Sun <yorksun@freescale.com>
This patch implements simple hwconfig infrastructure: an
interface for software knobs to control a hardware.
This is very simple implementation, i.e. it is implemented
via `hwconfig' environment variable. Later we could write
some "hwconfig <enable|disable|list>" commands, ncurses
interface for Award BIOS-like interface, and frame-buffer
interface for AMI GUI[1] BIOS-like interface with mouse
support[2].
Current implementation details/limitations:
1. Doesn't support options dependencies and mutual exclusion.
We can implement this by integrating apt-get[3] into the
u-boot. But I didn't bother yet.
2. Since we don't implement hwconfig command, i.e. we're working
with the environement directly, there is no way to tell that
toggling a particular option will need a reboot to take
an effect. So, for now it's advised to always reboot the
target after modifying hwconfig variable.
3. We support hwconfig options with arguments. For example,
set hwconfig dr_usb:mode=peripheral,phy_type=ulpi
That means:
- dr_usb - enable Dual-Role USB controller;
- dr_usb:mode=peripheral - USB in Function mode;
- dr_usb:phy_type=ulpi - USB should work with ULPI PHYs;
The purpose of this simple implementation is to define some
internal API and then we can continue improving user experience
by adding more mature interface, like hwconfig command with
bells and whistles. Or not adding, if we feel that current
interface fits its needs.
[1] http://en.wikipedia.org/wiki/American_Megatrends
[2] Regarding ncurses and GUI with mouse support -- I'm just
kidding.
[3] The comment regarding apt-get is also a joke, meaning that
dependency tracking could be non-trivial. For example, for
enabling HW feature X we may need to disable Y, and turn Z
into reduced mode (like RMII-only interface for ethernet,
no MII).
It's quite trivial to implement simple cases though.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
