Lots of code use this construct:
cmd_usage(cmdtp);
return 1;
Change cmd_usage() let it return 1 - then we can replace all these
ocurrances by
return cmd_usage(cmdtp);
This fixes a few places with incorrect return code handling, too.
The hush shell dynamically allocates (and re-allocates) memory for the
argument strings in the "char *argv[]" argument vector passed to
commands. Any code that modifies these pointers will cause serious
corruption of the malloc data structures and crash U-Boot, so make
sure the compiler can check that no such modifications are being done
by changing the code into "char * const argv[]".
This modification is the result of debugging a strange crash caused
after adding a new command, which used the following argument
processing code which has been working perfectly fine in all Unix
systems since version 6 - but not so in U-Boot:
int main (int argc, char **argv)
while (--argc > 0 && **++argv == '-') {
/* ====> */ while (*++*argv) {
switch (**argv) {
case 'd':
debug++;
break;
default:
usage ();
The line marked "====>" will corrupt the malloc data structures and
usually cause U-Boot to crash when the next command gets executed by
the shell. With the modification, the compiler will prevent this with
an
error: increment of read-only location '*argv'
N.B.: The code above can be trivially rewritten like this:
char *arg = *argv;
while (*++arg) {
switch (*arg) {
The console_buffer size is declared in common/main.c as
-- char console_buffer[CONFIG_SYS_CBSIZE + 1];
so this extern definition is wrong.
Signed-off-by: Remy Bohmer <linux@bohmer.net>
Add #ifdefs where necessary to not perform relocation fixups. This
allows boards/architectures which support relocation to trim a decent
chunk of code.
Note that this patch doesn't add #ifdefs to architecture-specific code
which does not support relocation.
An off-by-one error in hush.c resulted in an unintentional free() call
every time a command was executed
Many of the help messages were not really helpful; for example, many
commands that take no arguments would not print a correct synopsis
line, but "No additional help available." which is not exactly wrong,
but not helpful either.
Commit ``Make "usage" messages more helpful.'' changed this
partially. But it also became clear that lots of "Usage" and "Help"
messages (fields "usage" and "help" in struct cmd_tbl_s respective)
were actually redundant.
This patch cleans this up - for example:
Before:
=> help dtt
dtt - Digital Thermometer and Thermostat
Usage:
dtt - Read temperature from digital thermometer and thermostat.
After:
=> help dtt
dtt - Read temperature from Digital Thermometer and Thermostat
Usage:
dtt
Move global '#ifdef CONFIG_xxx .... #endif' out of the .c files and into
the COBJS-$(CONFIG_xxx) in the Makefile. Also delete unused var in kgdb
code in the process.
Remove command name from all command "usage" fields and update
common/command.c to display "name - usage" instead of
just "usage". Also remove newlines from command usage fields.
This new command shows the local variables defined in
the hush shell:
=> help showvar
showvar
- print values of all hushshell variables
showvar name ...
- print value of hushshell variable 'name'
Also make the set_local_var() and unset_local_var ()
no longer static, so it is possible to define local
hush shell variables at boot time. If CONFIG_HUSH_INIT_VAR
is defined, u-boot calls hush_init_var (), where
boardspecific code can define local hush shell
variables at boottime.
This patch changes the debug_printf() marco for U-Boot in hush.c and
moves the definition of DEBUG_SHELL to a place that is actually compiled
under U-Boot.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Fixed some broken instances of "#ifdef CMD_CFG_IDE" too.
Those always evaluated TRUE, and thus were always compiled
even when IDE really wasn't defined/wanted.
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
Patch by Lars Rostock, 26 Sep 2005
Caveat: this currently *requires* CONFIG_RESET_TO_RETRY to be set, too.
Patch by Andreas Engel, 19 Jul 2005
- add support for a new version of an Intracom board and fix
various other things on others.
- add verify support to the crc32 command (define
CONFIG_CRC32_VERIFY to enable it)
- fix FEC driver for MPC8xx systems:
1. fix compilation problems for boards that use dynamic
allocation of DPRAM
2. shut down FEC after network transfers
- HUSH parser fixes:
1. A new test command was added. This is a simplified version of
the one in the bourne shell.
2. A new exit command was added which terminates the current
executing script.
3. Fixed handing of $? (exit code of last executed command)
Add support for NET+50 CPU and ModNET50 board
* Patch by Sam Song, 10 Feb 2004:
Fix typos in cfi_flash.c
* Patch by Leon Kukovec, 10 Feb 2004
Fixed long dir entry slot id calculation in get_vfatname
* Patch by Robin Gilks, 10 Feb 2004:
add "itest" command (operators: -eq, -ne, -lt, -gt, -le, -ge, ==,
* Make 5200 reset command _really_ reset the board, without running
any other code after it
* Fix flash mapping and display on P3G4 board
* Patch by Kyle Harris, 15 Jul 2003:
- add support for Intel IXP425 CPU
- add support for IXDP425 eval board
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
Add IDMA example code (tested on 8260 only)
* Add support for Purple Board (MIPS64 5Kc)
* Add support for MIPS64 5Kc CPUs
* Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS
* Patch by Denis Peter, 04 Apr 2003:
- update MIP405-4 board
* Patches by Denis Peter, 03 April 2003:
- fix PCI IRQs on MPL boards
- fix two more un-relocated pointer problems
* Fix behaviour of "run" command:
- print error message iv variable does not exist
- terminate processing of arguments in case of error
* Patches by Peter Figuli, 10 Mar 2003
- Add support for BTUART on PXA platform
- Add support for WEP EP250 (PXA) board
* Fix flash problems on INCA-IP; add tool to allow bruning images to
flash using a BDI2000
* Implement fix for I2C Edge Conditions problem for all boards that
use the bit-banging driver (common/soft_i2c.c)
* Add patches by Robert Schwebel, 31 Mar 2003:
- csb226 board: bring in sync with innokom/memsetup.S
- csb226 board: fix MDREFR handling
- misc doc fixes / extensions
- innokom board: cleanup, MDREFR fix in memsetup.S, config update
- add BOOT_PROGRESS to armlinux.c
when watchdog is on
* Update baudrate in bd_info when it gets changed
* Add watchdog trigger points while waiting for serial port
(so far only 8xx -- needed on LWMON with 100ms watchdog)
* Improve command line tool to access the U-Boot's environment
(figuration of the utility, using a config file)
Add code for AmigaOne board
(preliminary merge to U-Boot, still WIP)
* Patch by Jon Diekema, 12 Nov 2002:
- Adding URL for IEEE OUI lookup
- Making the autoboot #defines dependent on CONFIG_AUTOBOOT_KEYED
being defined.
- In the CONFIG_EXTRA_ENV_SETTINGS #define, the root-on-initrd and
root-on-nfs macros are designed to switch how the default boot
method gets defined.
