Hush is a command-line interpreter, so rename it to make that clearer.
console_buffer array is defined to be CONFIG_SYS_CBSIZE + 1 long,
whereas the_command array only CONFIG_SYS_CBSIZE long. Subsequent
use of strcpy(the_command, console_buffer) will write final \0
terminating byte outside the_command array when entering a command
of max length.
Signed-off-by: Kristian Otnes <kotnes <at> cisco <dot> com>
The following shell command fails:
if test -z "$x"; then echo "zero"; else echo "non-zero"; fi
(assuming $x does not exist, it prints "non-zero" rather than "zero").
... since "$x" expands to nothing, and the argument is completely
dropped, causing too few to be passed to -z, causing cmd_test() to
error out early.
This is because when variable expansions are processed by make_string(),
the expanded results are concatenated back into a new string. However,
no quoting is applied when doing so, so any empty variables simply don't
generate any parameter when the combined string is parsed again.
Fix this by explicitly replacing quoting any argument that was originally
quoted when re-generating a string from the already-parsed argument list.
This also fixes loss of whitespace in commands such as:
setenv space " "
setenv var " 1${space}${space} 2 "
echo ">>${var}<<"
Reported-by: Russell King <linux@arm.linux.org.uk>
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
[trini: Fixup common/cmd_io.c]
As far as every arch has a get_timer function,
run_command_and_time_it code can now disappear.
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
Acked-By: Che-Liang Chiou <clchiou@chromium.org>
[trini: s/ulong/unsigned long/ in command.h portion]
command.c:44:38: error: bad constant expression
dlmalloc.c:1468:2: warning: Using plain integer as NULL pointer
dlmalloc.c:1468:5: warning: Using plain integer as NULL pointer
dlmalloc.c:2176:12: warning: Using plain integer as NULL pointer
dlmalloc.c:2179:31: warning: Using plain integer as NULL pointer
dlmalloc.c:2382:14: warning: Using plain integer as NULL pointer
dlmalloc.c:2436:14: warning: Using plain integer as NULL pointer
dlmalloc.c:2582:31: warning: Using plain integer as NULL pointer
dlmalloc.c:2585:17: warning: Using plain integer as NULL pointer
dlmalloc.c:2646:14: warning: Using plain integer as NULL pointer
dlmalloc.c:2659:19: warning: Using plain integer as NULL pointer
dlmalloc.c:2692:19: warning: Using plain integer as NULL pointer
dlmalloc.c:2707:19: warning: Using plain integer as NULL pointer
dlmalloc.c:2708:14: warning: Using plain integer as NULL pointer
dlmalloc.c:2786:31: warning: Using plain integer as NULL pointer
dlmalloc.c:2801:12: warning: Using plain integer as NULL pointer
dlmalloc.c:2801:22: warning: Using plain integer as NULL pointer
dlmalloc.c:2926:27: warning: Using plain integer as NULL pointer
dlmalloc.c:2928:14: warning: Using plain integer as NULL pointer
dlmalloc.c:2929:12: warning: Using plain integer as NULL pointer
dlmalloc.c:3075:14: warning: Using plain integer as NULL pointer
hush.c:292:14: warning: symbol 'last_return_code' was not declared. Should it be static?
hush.c:293:5: warning: symbol 'nesting_level' was not declared. Should it be static?
hush.c:2175:20: warning: Using plain integer as NULL pointer
hush.c:2175:34: warning: Using plain integer as NULL pointer
hush.c:2210:41: warning: Using plain integer as NULL pointer
hush.c:2216:45: warning: Using plain integer as NULL pointer
hush.c:2249:25: warning: Using plain integer as NULL pointer
hush.c:2332:13: warning: symbol 'new_pipe' was not declared. Should it be static?
hush.c:2390:5: warning: symbol 'reserved_word' was not declared. Should it be static?
hush.c:2927:5: warning: symbol 'parse_stream' was not declared. Should it be static?
hush.c:3127:6: warning: symbol 'mapset' was not declared. Should it be static?
hush.c:3133:6: warning: symbol 'update_ifs_map' was not declared. Should it be static?
hush.c:3161:5: warning: symbol 'parse_stream_outer' was not declared. Should it be static?
hush.c:3295:34: warning: Using plain integer as NULL pointer
hush.c:3631:5: warning: symbol 'do_showvar' was not declared. Should it be static
image.c:1282:29: warning: Using plain integer as NULL pointer
image.c:1315:41: warning: Using plain integer as NULL pointer
image.c:1330:25: warning: Using plain integer as NULL pointer
image.c:1706:25: warning: Using plain integer as NULL pointer
main.c:510:10: warning: symbol 'hist_num' was not declared. Should it be static?
main.c:512:5: warning: symbol 'hist_list' was not declared. Should it be static?
main.c:513:6: warning: symbol 'hist_lines' was not declared. Should it be static?
usb_storage.c:195:6: warning: symbol 'usb_show_progress' was not declared. Should it be static?
usb_storage.c:440:48: warning: Using plain integer as NULL pointer
usb_storage.c:503:5: warning: symbol 'usb_stor_BBB_comdat' was not declared. Should it be static?
usb_storage.c:551:5: warning: symbol 'usb_stor_CB_comdat' was not declared. Should it be static?
usb_storage.c:629:55: warning: Using plain integer as NULL pointer
usb_storage.c:620:5: warning: symbol 'usb_stor_CBI_get_status' was not declared. Should it be static?
usb_storage.c:675:43: warning: Using plain integer as NULL pointer
usb_storage.c:668:5: warning: symbol 'usb_stor_BBB_clear_endpt_stall' was not declared. Should it be static?
usb_storage.c:679:5: warning: symbol 'usb_stor_BBB_transport' was not declared. Should it be static?
usb_storage.c:801:5: warning: symbol 'usb_stor_CB_transport' was not declared. Sh
xyzModem.c:104:1: warning: symbol 'CYGACC_COMM_IF_GETC_TIMEOUT' was not declared. Should it be static?
xyzModem.c:122:1: warning: symbol 'CYGACC_COMM_IF_PUTC' was not declared. Should it be static?
xyzModem.c:169:1: warning: symbol 'parse_num' was not declared. Should it be stat
note: hush.c's nesting_level deleted because not used.
When a variable which contains a user-supplied value is dereferenced
(e.g. to be echo'ed), make sure that the value is not further parsed
by hush.
Set the hush local variable "HUSH_NO_EVAL=1" to enable this behavior.
Without this patch, a sequence like this occurs:
Panda # env set my_user_string Bob\'s favorite device
Panda # print my_user_string
my_user_string=Bob's favorite device
Panda # echo $my_user_string
syntax error hush.c:3007
With this patch, it looks like this:
Panda # HUSH_NO_EVAL=1
Use standard sh syntax:
${VAR:-default}
Use default value: if VAR is set and non-null, expands to $VAR.
Otherwise, expands to default.
${VAR:=default}
Set default value: if VAR is set and non-null, expands to $VAR.
Otherwise, sets hush VAR to default and expands to default.
${VAR:+default}
If VAR is set and non-null, expands to the empty string.
Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
We currently have the same code in hush.c and main.c. This brings the
code into one place.
As an added feature, if the command function returns CMD_RET_USAGE then
cmd_process() will print a usage message for the command before
returning the standard failure code of 1.
ARM code size increases about 32 bytes with this clean-up.
There is a nasty interleave of #ifdefs in hush.c where the two code
paths have different indents. Remove this ickiness.
We should aim for a single point of entry to the commands, whichever
parser is used.
Extract all extern declarations for console_buffer[] out of c files into
the common.h header.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Cc: Frank Gottschling <fgottschling@eltec.de>
Cc: Murray Jensen <Murray.Jensen@csiro.au>
This function is generally useful and shouldn't hide away in hush. It
has been moved as is.
Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
Acked-by: Heiko Schocher <hs@denx.de>
cc: Wolfgang Denk <wd@denx.de>
cc: Detlev Zundel <dzu@denx.de>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
The duplication of the do_reset prototype has gotten out of hand,
and they're not all in sync. Unify them all in command.h.
By now, the majority of architectures have working relocation
support, so the few remaining architectures have become exceptions.
To make this more obvious, we make working relocation now the default
case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC.
Tested-by: Heiko Schocher <hs@denx.de>
Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
Lots of code use this construct:
cmd_usage(cmdtp);
return 1;
Change cmd_usage() let it return 1 - then we can replace all these
ocurrances by
return cmd_usage(cmdtp);
This fixes a few places with incorrect return code handling, too.
The hush shell dynamically allocates (and re-allocates) memory for the
argument strings in the "char *argv[]" argument vector passed to
commands. Any code that modifies these pointers will cause serious
corruption of the malloc data structures and crash U-Boot, so make
sure the compiler can check that no such modifications are being done
by changing the code into "char * const argv[]".
This modification is the result of debugging a strange crash caused
after adding a new command, which used the following argument
processing code which has been working perfectly fine in all Unix
systems since version 6 - but not so in U-Boot:
int main (int argc, char **argv)
while (--argc > 0 && **++argv == '-') {
/* ====> */ while (*++*argv) {
switch (**argv) {
case 'd':
debug++;
break;
default:
usage ();
The line marked "====>" will corrupt the malloc data structures and
usually cause U-Boot to crash when the next command gets executed by
the shell. With the modification, the compiler will prevent this with
an
error: increment of read-only location '*argv'
N.B.: The code above can be trivially rewritten like this:
char *arg = *argv;
while (*++arg) {
switch (*arg) {
The console_buffer size is declared in common/main.c as
-- char console_buffer[CONFIG_SYS_CBSIZE + 1];
so this extern definition is wrong.
Signed-off-by: Remy Bohmer <linux@bohmer.net>
Add #ifdefs where necessary to not perform relocation fixups. This
allows boards/architectures which support relocation to trim a decent
chunk of code.
Note that this patch doesn't add #ifdefs to architecture-specific code
which does not support relocation.
An off-by-one error in hush.c resulted in an unintentional free() call
every time a command was executed
Many of the help messages were not really helpful; for example, many
commands that take no arguments would not print a correct synopsis
line, but "No additional help available." which is not exactly wrong,
but not helpful either.
Commit ``Make "usage" messages more helpful.'' changed this
partially. But it also became clear that lots of "Usage" and "Help"
messages (fields "usage" and "help" in struct cmd_tbl_s respective)
were actually redundant.
This patch cleans this up - for example:
Before:
=> help dtt
dtt - Digital Thermometer and Thermostat
Usage:
dtt - Read temperature from digital thermometer and thermostat.
After:
=> help dtt
dtt - Read temperature from Digital Thermometer and Thermostat
Usage:
dtt
Move global '#ifdef CONFIG_xxx .... #endif' out of the .c files and into
the COBJS-$(CONFIG_xxx) in the Makefile. Also delete unused var in kgdb
code in the process.
Remove command name from all command "usage" fields and update
common/command.c to display "name - usage" instead of
just "usage". Also remove newlines from command usage fields.
This new command shows the local variables defined in
the hush shell:
=> help showvar
showvar
- print values of all hushshell variables
showvar name ...
- print value of hushshell variable 'name'
Also make the set_local_var() and unset_local_var ()
no longer static, so it is possible to define local
hush shell variables at boot time. If CONFIG_HUSH_INIT_VAR
is defined, u-boot calls hush_init_var (), where
boardspecific code can define local hush shell
variables at boottime.
This patch changes the debug_printf() marco for U-Boot in hush.c and
moves the definition of DEBUG_SHELL to a place that is actually compiled
under U-Boot.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Fixed some broken instances of "#ifdef CMD_CFG_IDE" too.
Those always evaluated TRUE, and thus were always compiled
even when IDE really wasn't defined/wanted.
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
Patch by Lars Rostock, 26 Sep 2005
Caveat: this currently *requires* CONFIG_RESET_TO_RETRY to be set, too.
Patch by Andreas Engel, 19 Jul 2005
- add support for a new version of an Intracom board and fix
various other things on others.
- add verify support to the crc32 command (define
CONFIG_CRC32_VERIFY to enable it)
- fix FEC driver for MPC8xx systems:
1. fix compilation problems for boards that use dynamic
allocation of DPRAM
2. shut down FEC after network transfers
- HUSH parser fixes:
1. A new test command was added. This is a simplified version of
the one in the bourne shell.
2. A new exit command was added which terminates the current
executing script.
3. Fixed handing of $? (exit code of last executed command)
Add support for NET+50 CPU and ModNET50 board
* Patch by Sam Song, 10 Feb 2004:
Fix typos in cfi_flash.c
* Patch by Leon Kukovec, 10 Feb 2004
Fixed long dir entry slot id calculation in get_vfatname
* Patch by Robin Gilks, 10 Feb 2004:
add "itest" command (operators: -eq, -ne, -lt, -gt, -le, -ge, ==,
* Make 5200 reset command _really_ reset the board, without running
any other code after it
* Fix flash mapping and display on P3G4 board
* Patch by Kyle Harris, 15 Jul 2003:
- add support for Intel IXP425 CPU
- add support for IXDP425 eval board
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
Add IDMA example code (tested on 8260 only)
* Add support for Purple Board (MIPS64 5Kc)
* Add support for MIPS64 5Kc CPUs
* Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS
* Patch by Denis Peter, 04 Apr 2003:
- update MIP405-4 board
* Patches by Denis Peter, 03 April 2003:
- fix PCI IRQs on MPL boards
- fix two more un-relocated pointer problems
* Fix behaviour of "run" command:
- print error message iv variable does not exist
- terminate processing of arguments in case of error
* Patches by Peter Figuli, 10 Mar 2003
- Add support for BTUART on PXA platform
- Add support for WEP EP250 (PXA) board
* Fix flash problems on INCA-IP; add tool to allow bruning images to
flash using a BDI2000
* Implement fix for I2C Edge Conditions problem for all boards that
use the bit-banging driver (common/soft_i2c.c)
* Add patches by Robert Schwebel, 31 Mar 2003:
- csb226 board: bring in sync with innokom/memsetup.S
- csb226 board: fix MDREFR handling
- misc doc fixes / extensions
- innokom board: cleanup, MDREFR fix in memsetup.S, config update
- add BOOT_PROGRESS to armlinux.c
when watchdog is on
* Update baudrate in bd_info when it gets changed
* Add watchdog trigger points while waiting for serial port
(so far only 8xx -- needed on LWMON with 100ms watchdog)
* Improve command line tool to access the U-Boot's environment
(figuration of the utility, using a config file)
Add code for AmigaOne board
(preliminary merge to U-Boot, still WIP)
* Patch by Jon Diekema, 12 Nov 2002:
- Adding URL for IEEE OUI lookup
- Making the autoboot #defines dependent on CONFIG_AUTOBOOT_KEYED
being defined.
- In the CONFIG_EXTRA_ENV_SETTINGS #define, the root-on-initrd and
root-on-nfs macros are designed to switch how the default boot
method gets defined.
