path: root/common/hush.c
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/* non-cmd*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04common/ non-cmd: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2005-09-28Fix uninitialized variable problem in hush shellWolfgang Denk
Patch by Lars Rostock, 26 Sep 2005
2005-08-12Make bootretry feature work with hush shell.Wolfgang Denk
Caveat: this currently *requires* CONFIG_RESET_TO_RETRY to be set, too. Patch by Andreas Engel, 19 Jul 2005
2004-04-18Patches by Pantelis Antoniou, 16 Apr 2004:wdenk
- add support for a new version of an Intracom board and fix various other things on others. - add verify support to the crc32 command (define CONFIG_CRC32_VERIFY to enable it) - fix FEC driver for MPC8xx systems: 1. fix compilation problems for boards that use dynamic allocation of DPRAM 2. shut down FEC after network transfers - HUSH parser fixes: 1. A new test command was added. This is a simplified version of the one in the bourne shell. 2. A new exit command was added which terminates the current executing script. 3. Fixed handing of $? (exit code of last executed command)
2004-04-12Fix if / elif handling bug in HUSH shellwdenk
2004-02-23* Patch by Thomas Elste, 10 Feb 2004:wdenk
Add support for NET+50 CPU and ModNET50 board * Patch by Sam Song, 10 Feb 2004: Fix typos in cfi_flash.c * Patch by Leon Kukovec, 10 Feb 2004 Fixed long dir entry slot id calculation in get_vfatname * Patch by Robin Gilks, 10 Feb 2004: add "itest" command (operators: -eq, -ne, -lt, -gt, -le, -ge, ==, !=, <>, <, >, <=, >=)
2003-10-14* Make sure HUSH is initialized for running auto-update scriptsLABEL_2003_10_14_2140wdenk
* Make 5200 reset command _really_ reset the board, without running any other code after it * Fix flash mapping and display on P3G4 board * Patch by Kyle Harris, 15 Jul 2003: - add support for Intel IXP425 CPU - add support for IXDP425 eval board
2003-04-05* Patch by Arun Dharankar, 4 Apr 2003:LABEL_2003_04_05_0300wdenk
Add IDMA example code (tested on 8260 only) * Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs * Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS * Patch by Denis Peter, 04 Apr 2003: - update MIP405-4 board * Patches by Denis Peter, 03 April 2003: - fix PCI IRQs on MPL boards - fix two more un-relocated pointer problems * Fix behaviour of "run" command: - print error message iv variable does not exist - terminate processing of arguments in case of error * Patches by Peter Figuli, 10 Mar 2003 - Add support for BTUART on PXA platform - Add support for WEP EP250 (PXA) board * Fix flash problems on INCA-IP; add tool to allow bruning images to flash using a BDI2000 * Implement fix for I2C Edge Conditions problem for all boards that use the bit-banging driver (common/soft_i2c.c) * Add patches by Robert Schwebel, 31 Mar 2003: - csb226 board: bring in sync with innokom/memsetup.S - csb226 board: fix MDREFR handling - misc doc fixes / extensions - innokom board: cleanup, MDREFR fix in memsetup.S, config update - add BOOT_PROGRESS to armlinux.c
2003-01-11* Restrict baudrate settings on LWMON to higher speedsLABEL_2003_01_11_1050wdenk
when watchdog is on * Update baudrate in bd_info when it gets changed * Add watchdog trigger points while waiting for serial port (so far only 8xx -- needed on LWMON with 100ms watchdog) * Improve command line tool to access the U-Boot's environment (figuration of the utility, using a config file)
