path: root/common/hush.c
2014-03-07hush: fix some quoted variable expansion issuesStephen Warren
The following shell command fails: if test -z "$x"; then echo "zero"; else echo "non-zero"; fi (assuming $x does not exist, it prints "non-zero" rather than "zero"). ... since "$x" expands to nothing, and the argument is completely dropped, causing too few to be passed to -z, causing cmd_test() to error out early. This is because when variable expansions are processed by make_string(), the expanded results are concatenated back into a new string. However, no quoting is applied when doing so, so any empty variables simply don't generate any parameter when the combined string is parsed again. Fix this by explicitly replacing quoting any argument that was originally quoted when re-generating a string from the already-parsed argument list. This also fixes loss of whitespace in commands such as: setenv space " " setenv var " 1${space}${space} 2 " echo ">>${var}<<" Reported-by: Russell King <linux@arm.linux.org.uk> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2013-02-04cmd_time: merge run_command_and_time_it with cmd_processRichard Genoud
As far as every arch has a get_timer function, run_command_and_time_it code can now disappear. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Acked-By: Che-Liang Chiou <clchiou@chromium.org> [trini: s/ulong/unsigned long/ in command.h portion] Signed-off-by: Tom Rini <trini@ti.com>
2012-11-04common/misc: sparse fixesKim Phillips
command.c:44:38: error: bad constant expression dlmalloc.c:1468:2: warning: Using plain integer as NULL pointer dlmalloc.c:1468:5: warning: Using plain integer as NULL pointer dlmalloc.c:2176:12: warning: Using plain integer as NULL pointer dlmalloc.c:2179:31: warning: Using plain integer as NULL pointer dlmalloc.c:2382:14: warning: Using plain integer as NULL pointer dlmalloc.c:2436:14: warning: Using plain integer as NULL pointer dlmalloc.c:2582:31: warning: Using plain integer as NULL pointer dlmalloc.c:2585:17: warning: Using plain integer as NULL pointer dlmalloc.c:2646:14: warning: Using plain integer as NULL pointer dlmalloc.c:2659:19: warning: Using plain integer as NULL pointer dlmalloc.c:2692:19: warning: Using plain integer as NULL pointer dlmalloc.c:2707:19: warning: Using plain integer as NULL pointer dlmalloc.c:2708:14: warning: Using plain integer as NULL pointer dlmalloc.c:2786:31: warning: Using plain integer as NULL pointer dlmalloc.c:2801:12: warning: Using plain integer as NULL pointer dlmalloc.c:2801:22: warning: Using plain integer as NULL pointer dlmalloc.c:2926:27: warning: Using plain integer as NULL pointer dlmalloc.c:2928:14: warning: Using plain integer as NULL pointer dlmalloc.c:2929:12: warning: Using plain integer as NULL pointer dlmalloc.c:3075:14: warning: Using plain integer as NULL pointer hush.c:292:14: warning: symbol 'last_return_code' was not declared. Should it be static? hush.c:293:5: warning: symbol 'nesting_level' was not declared. Should it be static? hush.c:2175:20: warning: Using plain integer as NULL pointer hush.c:2175:34: warning: Using plain integer as NULL pointer hush.c:2210:41: warning: Using plain integer as NULL pointer hush.c:2216:45: warning: Using plain integer as NULL pointer hush.c:2249:25: warning: Using plain integer as NULL pointer hush.c:2332:13: warning: symbol 'new_pipe' was not declared. Should it be static? hush.c:2390:5: warning: symbol 'reserved_word' was not declared. Should it be static? hush.c:2927:5: warning: symbol 'parse_stream' was not declared. Should it be static? hush.c:3127:6: warning: symbol 'mapset' was not declared. Should it be static? hush.c:3133:6: warning: symbol 'update_ifs_map' was not declared. Should it be static? hush.c:3161:5: warning: symbol 'parse_stream_outer' was not declared. Should it be static? hush.c:3295:34: warning: Using plain integer as NULL pointer hush.c:3631:5: warning: symbol 'do_showvar' was not declared. Should it be static image.c:1282:29: warning: Using plain integer as NULL pointer image.c:1315:41: warning: Using plain integer as NULL pointer image.c:1330:25: warning: Using plain integer as NULL pointer image.c:1706:25: warning: Using plain integer as NULL pointer main.c:510:10: warning: symbol 'hist_num' was not declared. Should it be static? main.c:512:5: warning: symbol 'hist_list' was not declared. Should it be static? main.c:513:6: warning: symbol 'hist_lines' was not declared. Should it be static? usb_storage.c:195:6: warning: symbol 'usb_show_progress' was not declared. Should it be static? usb_storage.c:440:48: warning: Using plain integer as NULL pointer usb_storage.c:503:5: warning: symbol 'usb_stor_BBB_comdat' was not declared. Should it be static? usb_storage.c:551:5: warning: symbol 'usb_stor_CB_comdat' was not declared. Should it be static? usb_storage.c:629:55: warning: Using plain integer as NULL pointer usb_storage.c:620:5: warning: symbol 'usb_stor_CBI_get_status' was not declared. Should it be static? usb_storage.c:675:43: warning: Using plain integer as NULL pointer usb_storage.c:668:5: warning: symbol 'usb_stor_BBB_clear_endpt_stall' was not declared. Should it be static? usb_storage.c:679:5: warning: symbol 'usb_stor_BBB_transport' was not declared. Should it be static? usb_storage.c:801:5: warning: symbol 'usb_stor_CB_transport' was not declared. Sh xyzModem.c:104:1: warning: symbol 'CYGACC_COMM_IF_GETC_TIMEOUT' was not declared. Should it be static? xyzModem.c:122:1: warning: symbol 'CYGACC_COMM_IF_PUTC' was not declared. Should it be static? xyzModem.c:169:1: warning: symbol 'parse_num' was not declared. Should it be stat note: hush.c's nesting_level deleted because not used. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-09-02hush: Don't parse the contents of a dereferenced varJoe Hershberger
When a variable which contains a user-supplied value is dereferenced (e.g. to be echo'ed), make sure that the value is not further parsed by hush. Set the hush local variable "HUSH_NO_EVAL=1" to enable this behavior. Without this patch, a sequence like this occurs: Panda # env set my_user_string Bob\'s favorite device Panda # print my_user_string my_user_string=Bob's favorite device Panda # echo $my_user_string syntax error hush.c:3007 With this patch, it looks like this: Panda # HUSH_NO_EVAL=1 Panda # env set my_user_string Bob\'s favorite device Panda # print my_user_string my_user_string=Bob's favorite device Panda # echo $my_user_string Bob's favorite device Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-09-02hush: Add default value substitution supportJoe Hershberger
Use standard sh syntax: ${VAR:-default} Use default value: if VAR is set and non-null, expands to $VAR. Otherwise, expands to default. ${VAR:=default} Set default value: if VAR is set and non-null, expands to $VAR. Otherwise, sets hush VAR to default and expands to default. ${VAR:+default} If VAR is set and non-null, expands to the empty string. Otherwise, expands to default. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-03-06Add cmd_process() to process commands in one placeSimon Glass
We currently have the same code in hush.c and main.c. This brings the code into one place. As an added feature, if the command function returns CMD_RET_USAGE then cmd_process() will print a usage message for the command before returning the standard failure code of 1. ARM code size increases about 32 bytes with this clean-up. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-06Remove interleave of non-U-Boot code in hushSimon Glass
There is a nasty interleave of #ifdefs in hush.c where the two code paths have different indents. Remove this ickiness. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-06Create a single cmd_call() function to handle command executionSimon Glass
We should aim for a single point of entry to the commands, whichever parser is used. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-11-22common: move extern char console_buffer[] to common.hIgor Grinberg
Extract all extern declarations for console_buffer[] out of c files into the common.h header. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Frank Gottschling <fgottschling@eltec.de> Cc: Murray Jensen <Murray.Jensen@csiro.au>
2011-10-26Move simple_itoa to vsprintfSimon Glass
This function is generally useful and shouldn't hide away in hush. It has been moved as is. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-17common: add run_command2 for running simple or hush commandsJason Hobbs
Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-05-10common/hush: make get_local_var visible for other usersHolger Brunck
Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2010-11-28do_reset: unify duplicate prototypesMike Frysinger
The duplication of the do_reset prototype has gotten out of hand, and they're not all in sync. Unify them all in command.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-28do_bootd: unify duplicate prototypesMike Frysinger
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-06-29Fix console_buffer size conflict error.Remy Bohmer
The console_buffer size is declared in common/main.c as -- char console_buffer[CONFIG_SYS_CBSIZE + 1]; so this extern definition is wrong. Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-10-03Conditionally perform common relocation fixupsPeter Tyser
Add #ifdefs where necessary to not perform relocation fixups. This allows boards/architectures which support relocation to trim a decent chunk of code. Note that this patch doesn't add #ifdefs to architecture-specific code which does not support relocation. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-08-09hush: Fix bogus free() callPeter Tyser
An off-by-one error in hush.c resulted in an unintentional free() call every time a command was executed Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-11common/{hush, kgdb, serial}.c: build by COBJS-$(...) in MakefileMike Frysinger
Move global '#ifdef CONFIG_xxx .... #endif' out of the .c files and into the COBJS-$(CONFIG_xxx) in the Makefile. Also delete unused var in kgdb code in the process. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-10-18hush: add showvar command for hush shell.Heiko Schocher
This new command shows the local variables defined in the hush shell: => help showvar showvar - print values of all hushshell variables showvar name ... - print value of hushshell variable 'name' Also make the set_local_var() and unset_local_var () no longer static, so it is possible to define local hush shell variables at boot time. If CONFIG_HUSH_INIT_VAR is defined, u-boot calls hush_init_var (), where boardspecific code can define local hush shell variables at boottime. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-08-21hush: Fix printf debug macro in hush.c so that it usable in U-BootStefan Roese
This patch changes the debug_printf() marco for U-Boot in hush.c and moves the definition of DEBUG_SHELL to a place that is actually compiled under U-Boot. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-14Code cleanup: fix old style assignment ambiguities like "=-" etc.Wolfgang Denk
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/* non-cmd*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04common/ non-cmd: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2005-09-28Fix uninitialized variable problem in hush shellWolfgang Denk
Patch by Lars Rostock, 26 Sep 2005
2005-08-12Make bootretry feature work with hush shell.Wolfgang Denk
Caveat: this currently *requires* CONFIG_RESET_TO_RETRY to be set, too. Patch by Andreas Engel, 19 Jul 2005
2004-04-18Patches by Pantelis Antoniou, 16 Apr 2004:wdenk
- add support for a new version of an Intracom board and fix various other things on others. - add verify support to the crc32 command (define CONFIG_CRC32_VERIFY to enable it) - fix FEC driver for MPC8xx systems: 1. fix compilation problems for boards that use dynamic allocation of DPRAM 2. shut down FEC after network transfers - HUSH parser fixes: 1. A new test command was added. This is a simplified version of the one in the bourne shell. 2. A new exit command was added which terminates the current executing script. 3. Fixed handing of $? (exit code of last executed command)
2004-04-12Fix if / elif handling bug in HUSH shellwdenk
2004-02-23* Patch by Thomas Elste, 10 Feb 2004:wdenk
Add support for NET+50 CPU and ModNET50 board * Patch by Sam Song, 10 Feb 2004: Fix typos in cfi_flash.c * Patch by Leon Kukovec, 10 Feb 2004 Fixed long dir entry slot id calculation in get_vfatname * Patch by Robin Gilks, 10 Feb 2004: add "itest" command (operators: -eq, -ne, -lt, -gt, -le, -ge, ==, !=, <>, <, >, <=, >=)
2003-10-14* Make sure HUSH is initialized for running auto-update scriptsLABEL_2003_10_14_2140wdenk
* Make 5200 reset command _really_ reset the board, without running any other code after it * Fix flash mapping and display on P3G4 board * Patch by Kyle Harris, 15 Jul 2003: - add support for Intel IXP425 CPU - add support for IXDP425 eval board
2003-04-05* Patch by Arun Dharankar, 4 Apr 2003:LABEL_2003_04_05_0300wdenk
Add IDMA example code (tested on 8260 only) * Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs * Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS * Patch by Denis Peter, 04 Apr 2003: - update MIP405-4 board * Patches by Denis Peter, 03 April 2003: - fix PCI IRQs on MPL boards - fix two more un-relocated pointer problems * Fix behaviour of "run" command: - print error message iv variable does not exist - terminate processing of arguments in case of error * Patches by Peter Figuli, 10 Mar 2003 - Add support for BTUART on PXA platform - Add support for WEP EP250 (PXA) board * Fix flash problems on INCA-IP; add tool to allow bruning images to flash using a BDI2000 * Implement fix for I2C Edge Conditions problem for all boards that use the bit-banging driver (common/soft_i2c.c) * Add patches by Robert Schwebel, 31 Mar 2003: - csb226 board: bring in sync with innokom/memsetup.S - csb226 board: fix MDREFR handling - misc doc fixes / extensions - innokom board: cleanup, MDREFR fix in memsetup.S, config update - add BOOT_PROGRESS to armlinux.c
2003-01-11* Restrict baudrate settings on LWMON to higher speedsLABEL_2003_01_11_1050wdenk
when watchdog is on * Update baudrate in bd_info when it gets changed * Add watchdog trigger points while waiting for serial port (so far only 8xx -- needed on LWMON with 100ms watchdog) * Improve command line tool to access the U-Boot's environment (figuration of the utility, using a config file)
