path: root/common/flash.c
2018-01-29flash: Fix spelling of "ERR_TIMOUT"Mario Six
checkpatch.pl complains about the spelling of ERR_TIMOUT. Since the error is only used in a handful of files, we rename the error to ERR_TIMEOUT. Signed-off-by: Mario Six <mario.six@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2017-02-12flash: compile common/flash.c iif CONFIG_MTD_NO_FLASH is enabledMasahiro Yamada
The whole of common/flash.c is guarded by #if defined() ... #endif. Move the conditional to common/Makefile. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-01-05mpc8xx: remove SPD823TS board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de>
2013-04-22flash: Add optional verify-after-write featureStefan Roese
Sometimes it might make sense to verify the written data to NOR flash. This patch adds this feature. To enable this verify-after-write, you need to define CONFIG_FLASH_VERIFY in your board config header. Please note that this option is useless in nearly all cases, since such flash programming errors usually are detected earlier while unprotecting/erasing/programming. Please only enable this option if you really know what you are doing. Signed-off-by: Stefan Roese <sr@denx.de>
2012-09-03cfi: Make the flash erase and write operations abortableJoe Hershberger
Check for ctrlc() in operations that take time and loop over the flash addresses. In netconsole, tstc() is expensive. Only check once in a while to not slow down the operation significantly. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-20cfi_flash: Simplify dynamic flash bank number detectionStefan Roese
This patch simplifies the use of CONFIG_SYS_MAX_FLASH_BANKS_DETECT. By moving these optional variables and defines into the common code, board specific code is minimized. Currently only the following board use this feature: APC405, IDS8247, TQM834x And IDS8247 doesn't seem to really need this feature, since its not updating the bank number variable at all. So this patch removes the definition of CONFIG_SYS_MAX_FLASH_BANKS_DETECT from this board port. This new framework will be used by the upcoming lwmon5 update as well. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Heiko Schocher <hs@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
2010-08-09flash_protect: check for NULL flash infoMike Frysinger
If a flash is unable to be detected, and then someone calls flash_protect on it (like the common code does in flash_init), the flash_protect logic will dereference a NULL pointer. Since flash_protect already does sanity checking on the info structs, add a NULL pointer check in there. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-07-14Code cleanup: fix old style assignment ambiguities like "=-" etc.Wolfgang Denk
2007-07-31ppc4xx: Update AMCC Bamboo 440EP supportEugene OBrien
Changed storage type of cfg_simulate_spd_eeprom to const Changed storage type of gpio_tab to stack storage (Cannot access global data declarations in .bss until afer code relocation) Improved SDRAM tests to catch problems where data is not uniquely addressable (e.g. incorrectly programmed SDRAM row or columns) Added CONFIG_PROG_SDRAM_TLB to support Bamboo SIMM/DIMM modules Fixed AM29LV320DT (OpCode Flash) sector map Signed-off-by: Eugene OBrien <eugene.obrien@advantechamt.com> Signed-off-by: Stefan Roese <sr@denx.de>
2005-10-15Merge with /home/m8/git/u-bootWolfgang Denk
2005-10-11Added support for TQM834x boards.Marian Balakowicz
2004-04-08* Patch by Mark Jonas: Remove config.tmp files only whenwdenk
unconfiguring the board * Adapt RMU board for bigger flash memory * Test fix for ethernet problems on MPC5200
